--- ray/src/rt/rtrace.c 2005/04/19 01:15:06 2.40 +++ ray/src/rt/rtrace.c 2005/06/05 19:52:01 2.44 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rtrace.c,v 2.40 2005/04/19 01:15:06 greg Exp $"; +static const char RCSid[] = "$Id: rtrace.c,v 2.44 2005/06/05 19:52:01 greg Exp $"; #endif /* * rtrace.c - program and variables for individual ray tracing. @@ -74,7 +74,7 @@ double specjitter = 1.; /* specular sampling jitter int backvis = 1; /* back face visibility */ -int maxdepth = 8; /* maximum recursion depth */ +int maxdepth = -10; /* maximum recursion depth */ double minweight = 2e-3; /* minimum ray weight */ char *ambfile = NULL; /* ambient file name */ @@ -97,7 +97,7 @@ static putf_t puta, putd, putf; typedef void oputf_t(RAY *r); static oputf_t oputo, oputd, oputv, oputl, oputL, oputc, oputp, - oputn, oputN, oputs, oputw, oputW, oputm, oputM; + oputn, oputN, oputs, oputw, oputW, oputm, oputM, oputtilde; static void setoutput(char *vs); static void tranotify(OBJECT obj); @@ -160,10 +160,8 @@ rtrace( /* trace rays from file */ sprintf(errmsg, "cannot open input file \"%s\"", fname); error(SYSTEM, errmsg); } -#ifdef _WIN32 if (inform != 'a') SET_FILE_BINARY(fp); -#endif /* set up output */ setoutput(outvals); switch (outform) { @@ -213,7 +211,7 @@ rtrace( /* trace rays from file */ } fflush(stdout); if (vcount > 0) - error(USER, "read error"); + error(USER, "unexpected EOF on input"); if (fname != NULL) fclose(fp); } @@ -240,9 +238,11 @@ setoutput( /* set up output tables */ while (*vs) switch (*vs++) { case 'T': /* trace sources */ + if (!*vs) break; trace_sources(); /* fall through */ case 't': /* trace */ + if (!*vs) break; *table = NULL; table = every_out; trace = ourtrace; @@ -288,7 +288,7 @@ setoutput( /* set up output tables */ *table++ = oputW; if (ambounce > 0 && (ambacc > FTINY || ambssamp > 0)) error(WARNING, - "-otW accuracy requires -aa 0 -as 0"); + "-otW accuracy depends on -aa 0 -as 0"); break; case 'm': /* modifier */ *table++ = oputm; @@ -296,6 +296,9 @@ setoutput( /* set up output tables */ case 'M': /* material */ *table++ = oputM; break; + case '~': /* tilde */ + *table++ = oputtilde; + break; } *table = NULL; } @@ -463,7 +466,8 @@ ourtrace( /* print ray values */ tabin(r); for (tp = every_out; *tp != NULL; tp++) (**tp)(r); - putchar('\n'); + if (outform == 'a') + putchar('\n'); } @@ -506,9 +510,8 @@ oputv( /* print value */ RAY *r ) { - COLR cout; - if (outform == 'c') { + COLR cout; setcolr(cout, colval(r->rcol,RED), colval(r->rcol,GRN), colval(r->rcol,BLU)); @@ -631,16 +634,8 @@ oputW( /* print contribution */ ) { COLOR contr; - COLR cout; raycontrib(contr, r, PRIMARY); - if (outform == 'c') { - setcolr(cout, colval(contr,RED), - colval(contr,GRN), - colval(contr,BLU)); - fwrite((char *)cout, sizeof(cout), 1, stdout); - return; - } (*putreal)(colval(contr,RED)); (*putreal)(colval(contr,GRN)); (*putreal)(colval(contr,BLU)); @@ -678,6 +673,15 @@ oputM( /* print material */ } else putchar('*'); putchar('\t'); +} + + +static void +oputtilde( /* output tilde (spacer) */ + RAY *r +) +{ + fputs("~\t", stdout); }
