--- ray/src/rt/rtrace.c 1996/04/17 14:02:09 2.22 +++ ray/src/rt/rtrace.c 2003/09/24 14:55:54 2.34 @@ -1,15 +1,12 @@ -/* Copyright (c) 1995 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: rtrace.c,v 2.34 2003/09/24 14:55:54 greg Exp $"; #endif - /* * rtrace.c - program and variables for individual ray tracing. - * - * 6/11/86 */ +#include "copyright.h" + /* * Input is in the form: * @@ -24,24 +21,33 @@ static char SCCSid[] = "$SunId$ LBL"; * irradiance values are desired. */ -#include "ray.h" +#include -#include "octree.h" - +#include "platform.h" +#include "ray.h" #include "otypes.h" - #include "resolu.h" +CUBE thescene; /* our scene */ +OBJECT nsceneobjs; /* number of objects in our scene */ + int dimlist[MAXDIM]; /* sampling dimensions */ int ndims = 0; /* number of sampling dimensions */ int samplendx = 0; /* index for this sample */ int imm_irrad = 0; /* compute immediate irradiance? */ +int lim_dist = 0; /* limit distance? */ int inform = 'a'; /* input format */ int outform = 'a'; /* output format */ char *outvals = "v"; /* output specification */ +int do_irrad = 0; /* compute irradiance? */ + +void (*trace)() = NULL; /* trace call */ + +extern void ambnotify(), tranotify(); +void (*addobjnotify[])() = {ambnotify, tranotify, NULL}; char *tralist[128]; /* list of modifers to trace (or no) */ int traincl = -1; /* include == 1, exclude == 0 */ #define MAXTSET 511 /* maximum number in trace set */ @@ -68,39 +74,42 @@ double specjitter = 1.; /* specular sampling jitter int backvis = 1; /* back face visibility */ -int maxdepth = 6; /* maximum recursion depth */ -double minweight = 4e-3; /* minimum ray weight */ +int maxdepth = 8; /* maximum recursion depth */ +double minweight = 2e-3; /* minimum ray weight */ +char *ambfile = NULL; /* ambient file name */ COLOR ambval = BLKCOLOR; /* ambient value */ int ambvwt = 0; /* initial weight for ambient value */ -double ambacc = 0.2; /* ambient accuracy */ -int ambres = 128; /* ambient resolution */ -int ambdiv = 512; /* ambient divisions */ -int ambssamp = 0; /* ambient super-samples */ +double ambacc = 0.1; /* ambient accuracy */ +int ambres = 256; /* ambient resolution */ +int ambdiv = 1024; /* ambient divisions */ +int ambssamp = 512; /* ambient super-samples */ int ambounce = 0; /* ambient bounces */ char *amblist[128]; /* ambient include/exclude list */ int ambincl = -1; /* include == 1, exclude == 0 */ -extern OBJREC Lamb; /* a Lambertian surface */ static RAY thisray; /* for our convenience */ -static int oputo(), oputd(), oputv(), oputl(), oputL(), +static void oputo(), oputd(), oputv(), oputl(), oputL(), oputc(), oputp(), oputn(), oputN(), oputs(), oputw(), oputm(); -static int ourtrace(), tabin(); -static int (*ray_out[16])(), (*every_out[16])(); +static void ourtrace(), tabin(); +static void (*ray_out[16])(), (*every_out[16])(); static int castonly = 0; -static int puta(), putf(), putd(); +static void puta(), putf(), putd(); -static int (*putreal)(); +static void (*putreal)(); +void bogusray(), rad(), irrad(), printvals(); + +void quit(code) /* quit program */ int code; { -#ifndef NIX +#ifndef NON_POSIX /* XXX we don't clean up elsewhere? */ headclean(); /* delete header file */ pfclean(); /* clean up persist files */ #endif @@ -122,12 +131,14 @@ int f; } +void rtrace(fname) /* trace rays from file */ char *fname; { long vcount = hresolu>1 ? hresolu*vresolu : vresolu; long nextflush = hresolu; FILE *fp; + double d; FVECT orig, direc; /* set up input */ if (fname == NULL) @@ -136,9 +147,9 @@ char *fname; sprintf(errmsg, "cannot open input file \"%s\"", fname); error(SYSTEM, errmsg); } -#ifdef MSDOS +#ifdef _WIN32 if (inform != 'a') - setmode(fileno(fp), O_BINARY); + SET_FILE_BINARY(fp); #endif /* set up output */ setoutput(outvals); @@ -162,20 +173,25 @@ char *fname; while (getvec(orig, inform, fp) == 0 && getvec(direc, inform, fp) == 0) { - if (normalize(direc) == 0.0) { /* zero ==> flush */ - fflush(stdout); - continue; - } - samplendx++; + d = normalize(direc); + if (d == 0.0) { /* zero ==> flush */ + bogusray(); + if (--nextflush <= 0 || vcount <= 0) { + fflush(stdout); + nextflush = hresolu; + } + } else { + samplendx++; /* compute and print */ - if (imm_irrad) - irrad(orig, direc); - else - rad(orig, direc); + if (imm_irrad) + irrad(orig, direc); + else + rad(orig, direc, lim_dist ? d : 0.0); /* flush if time */ - if (--nextflush == 0) { - fflush(stdout); - nextflush = hresolu; + if (--nextflush == 0) { + fflush(stdout); + nextflush = hresolu; + } } if (ferror(stdout)) error(SYSTEM, "write error"); @@ -193,8 +209,8 @@ char *fname; setoutput(vs) /* set up output tables */ register char *vs; { - extern int (*trace)(); - register int (**table)() = ray_out; + extern void (*trace)(); + register void (**table)() = ray_out; castonly = 1; while (*vs) @@ -219,6 +235,9 @@ register char *vs; *table++ = oputl; castonly = 0; break; + case 'c': /* local coordinates */ + *table++ = oputc; + break; case 'L': /* single ray length */ *table++ = oputL; break; @@ -246,21 +265,40 @@ register char *vs; } -rad(org, dir) /* compute and print ray value(s) */ +void +bogusray() /* print out empty record */ +{ + thisray.rorg[0] = thisray.rorg[1] = thisray.rorg[2] = + thisray.rdir[0] = thisray.rdir[1] = thisray.rdir[2] = 0.0; + rayorigin(&thisray, NULL, PRIMARY, 1.0); + printvals(&thisray); +} + + +void +rad(org, dir, dmax) /* compute and print ray value(s) */ FVECT org, dir; +double dmax; { VCOPY(thisray.rorg, org); VCOPY(thisray.rdir, dir); - thisray.rmax = 0.0; + thisray.rmax = dmax; rayorigin(&thisray, NULL, PRIMARY, 1.0); - if (castonly) - localhit(&thisray, &thescene) || sourcehit(&thisray); - else + if (castonly) { + if (!localhit(&thisray, &thescene)) { + if (thisray.ro == &Aftplane) { /* clipped */ + thisray.ro = NULL; + thisray.rot = FHUGE; + } else + sourcehit(&thisray); + } + } else rayvalue(&thisray); printvals(&thisray); } +void irrad(org, dir) /* compute immediate irradiance value */ FVECT org, dir; { @@ -283,10 +321,11 @@ FVECT org, dir; } +void printvals(r) /* print requested ray values */ RAY *r; { - register int (**tp)(); + register void (**tp)(); if (ray_out[0] == NULL) return; @@ -297,12 +336,12 @@ RAY *r; } +int getvec(vec, fmt, fp) /* get a vector from fp */ register FVECT vec; int fmt; FILE *fp; { - extern char *fgetword(); static float vf[3]; static double vd[3]; char buf[32]; @@ -334,6 +373,7 @@ FILE *fp; } +void tranotify(obj) /* record new modifier */ OBJECT obj; { @@ -341,6 +381,11 @@ OBJECT obj; register OBJREC *o = objptr(obj); register char **tralp; + if (obj == OVOID) { /* starting over */ + traset[0] = 0; + hitlimit = 0; + return; + } if (hitlimit || !ismodifier(o->otype)) return; for (tralp = tralist; *tralp != NULL; tralp++) @@ -356,11 +401,11 @@ OBJECT obj; } -static +static void ourtrace(r) /* print ray values */ RAY *r; { - register int (**tp)(); + register void (**tp)(); if (every_out[0] == NULL) return; @@ -376,7 +421,7 @@ RAY *r; } -static +static void tabin(r) /* tab in appropriate amount */ RAY *r; { @@ -387,9 +432,9 @@ RAY *r; } -static +static void oputo(r) /* print origin */ -register RAY *r; +RAY *r; { (*putreal)(r->rorg[0]); (*putreal)(r->rorg[1]); @@ -397,9 +442,9 @@ register RAY *r; } -static +static void oputd(r) /* print direction */ -register RAY *r; +RAY *r; { (*putreal)(r->rdir[0]); (*putreal)(r->rdir[1]); @@ -407,9 +452,9 @@ register RAY *r; } -static +static void oputv(r) /* print value */ -register RAY *r; +RAY *r; { COLR cout; @@ -426,25 +471,34 @@ register RAY *r; } -static +static void oputl(r) /* print effective distance */ -register RAY *r; +RAY *r; { (*putreal)(r->rt); } -static +static void oputL(r) /* print single ray length */ -register RAY *r; +RAY *r; { (*putreal)(r->rot); } -static +static void +oputc(r) /* print local coordinates */ +RAY *r; +{ + (*putreal)(r->uv[0]); + (*putreal)(r->uv[1]); +} + + +static void oputp(r) /* print point */ -register RAY *r; +RAY *r; { if (r->rot < FHUGE) { (*putreal)(r->rop[0]); @@ -458,9 +512,9 @@ register RAY *r; } -static +static void oputN(r) /* print unperturbed normal */ -register RAY *r; +RAY *r; { if (r->rot < FHUGE) { (*putreal)(r->ron[0]); @@ -474,7 +528,7 @@ register RAY *r; } -static +static void oputn(r) /* print perturbed normal */ RAY *r; { @@ -493,9 +547,9 @@ RAY *r; } -static +static void oputs(r) /* print name */ -register RAY *r; +RAY *r; { if (r->ro != NULL) fputs(r->ro->oname, stdout); @@ -505,27 +559,30 @@ register RAY *r; } -static +static void oputw(r) /* print weight */ -register RAY *r; +RAY *r; { (*putreal)(r->rweight); } -static +static void oputm(r) /* print modifier */ -register RAY *r; +RAY *r; { if (r->ro != NULL) - fputs(objptr(r->ro->omod)->oname, stdout); + if (r->ro->omod != OVOID) + fputs(objptr(r->ro->omod)->oname, stdout); + else + fputs(VOIDID, stdout); else putchar('*'); putchar('\t'); } -static +static void puta(v) /* print ascii value */ double v; { @@ -533,7 +590,7 @@ double v; } -static +static void putd(v) /* print binary double */ double v; { @@ -541,7 +598,7 @@ double v; } -static +static void putf(v) /* print binary float */ double v; {
