Bug fix for zero-direction rays with multiprocessing
Precautionary change to rayirrad()
Important bug fix in -I calculation
Minor cosmetic change
Bug fixes and performance improvements to rtrace -n option
Fixed -oo output of rtrace -I
Increased limits to number of modifiers for trace and ambient include/exclude
Changed default in rtrace to -u+ (random sampling)
Made -u+ option truly random
Increased trace modifier limit to 8192 in rtrace
Added -V option to rtcontrib and -oV option to rtrace to report contributions
Added final write error check
Fixed bugs in black glass transmission and source weight computation
Fixe in rtcontrib -M option
Fixed bug where rtrace would quit after 2^31 primary rays
More adjustments and corrections to default parameters
Eliminated copystruct() macro, which is unnecessary in ANSI. Reduced ambiguity warnings for nested if/if/else clauses.
Minor compile fixes
Added rtrace -oc option to output local (u,v) coordinates
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
modified code so zero record flushing happens unless -x > 0 && -y > 0
added -ld boolean option to rtrace for limiting ray distance
fixed bug in printing void materials.
increase default parameters for more accurate calculations
added -bv option for back face visibility (normally on)
consistency improvements related to -I option
added -ti, -te, -tI and -tE options to rtrace for exclude/include traces
made sure that -I option completely overrides -o option
bug fixes and improvements on stdio flushing
changed -di to ! -dv
added -oN for unperturbed surface normal and made -on perturbed
added setmode(fd,O_BINARY) where needed for MSDOS
fixed bug introduced in last change with -h- option of rtrace
added ability to print COLRFMT output of values
added -oL output option for single-ray length
changed default values and handling of specthresh
added -sj and -st options and changed old -s options to -p
removed atof() declarations for NeXT
got rid of scanf() call
increased defaults for -dp parameter
added virtual sources
added -oI option for irradiance after intersection
added conditional ray casting to rtrace for efficiency
added flushing for zero input direction vector
Reduced default ambient resolution
Efficient approximation to direct component with many sources Glow type changed Spot type eliminated
eliminated unused variable
