root/radiance/ray/src/rt/rtrace.c
Revision: 2.10
Committed: Thu Nov 19 20:26:10 1992 UTC (32 years, 5 months ago) by greg
changed -di to ! -dv
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * rtrace.c - program and variables for individual ray tracing.
9 *
10 * 6/11/86
11 */
12
13 /*
14 * Input is in the form:
15 *
16 * xorg yorg zorg xdir ydir zdir
17 *
18 * The direction need not be normalized. Output is flexible.
19 * If the direction vector is (0,0,0), then the output is flushed.
20 * All values default to ascii representation of real
21 * numbers. Binary representations can be selected
22 * with '-ff' for float or '-fd' for double. By default,
23 * radiance is computed. The '-i' or '-I' options indicate that
24 * irradiance values are desired.
25 */
26
27 #include "ray.h"
28
29 #include "octree.h"
30
31 #include "otypes.h"
32
33 #include "resolu.h"
34
35 int dimlist[MAXDIM]; /* sampling dimensions */
36 int ndims = 0; /* number of sampling dimensions */
37 int samplendx = 0; /* index for this sample */
38
39 int imm_irrad = 0; /* compute immediate irradiance? */
40
41 int inform = 'a'; /* input format */
42 int outform = 'a'; /* output format */
43 char *outvals = "v"; /* output specification */
44
45 int hresolu = 0; /* horizontal (scan) size */
46 int vresolu = 0; /* vertical resolution */
47
48 double dstrsrc = 0.0; /* square source distribution */
49 double shadthresh = .05; /* shadow threshold */
50 double shadcert = .5; /* shadow certainty */
51 int directrelay = 1; /* number of source relays */
52 int vspretest = 512; /* virtual source pretest density */
53 int directvis = 1; /* sources visible? */
54 double srcsizerat = .25; /* maximum ratio source size/dist. */
55
56 double specthresh = .15; /* specular sampling threshold */
57 double specjitter = 1.; /* specular sampling jitter */
58
59 int maxdepth = 6; /* maximum recursion depth */
60 double minweight = 4e-3; /* minimum ray weight */
61
62 COLOR ambval = BLKCOLOR; /* ambient value */
63 double ambacc = 0.2; /* ambient accuracy */
64 int ambres = 32; /* ambient resolution */
65 int ambdiv = 128; /* ambient divisions */
66 int ambssamp = 0; /* ambient super-samples */
67 int ambounce = 0; /* ambient bounces */
68 char *amblist[128]; /* ambient include/exclude list */
69 int ambincl = -1; /* include == 1, exclude == 0 */
70
71 extern OBJREC Lamb; /* a Lambertian surface */
72
73 static RAY thisray; /* for our convenience */
74
75 static int oputo(), oputd(), oputv(), oputl(), oputL(),
76 oputp(), oputn(), oputN(), oputs(), oputw(), oputm();
77
78 static int (*ray_out[10])(), (*every_out[10])();
79 static int castonly;
80
81 static int puta(), putf(), putd();
82
83 static int (*putreal)();
84
85
86 quit(code) /* quit program */
87 int code;
88 {
89 exit(code);
90 }
91
92
93 char *
94 formstr(f) /* return format identifier */
95 int f;
96 {
97 switch (f) {
98 case 'a': return("ascii");
99 case 'f': return("float");
100 case 'd': return("double");
101 case 'c': return(COLRFMT);
102 }
103 return("unknown");
104 }
105
106
107 rtrace(fname) /* trace rays from file */
108 char *fname;
109 {
110 long vcount = hresolu>1 ? hresolu*vresolu : vresolu;
111 long nextflush = hresolu;
112 FILE *fp;
113 FVECT orig, direc;
114 /* set up input */
115 if (fname == NULL)
116 fp = stdin;
117 else if ((fp = fopen(fname, "r")) == NULL) {
118 sprintf(errmsg, "cannot open input file \"%s\"", fname);
119 error(SYSTEM, errmsg);
120 }
121 #ifdef MSDOS
122 if (inform != 'a')
123 setmode(fileno(fp), O_BINARY);
124 #endif
125 /* set up output */
126 setoutput(outvals);
127 switch (outform) {
128 case 'a': putreal = puta; break;
129 case 'f': putreal = putf; break;
130 case 'd': putreal = putd; break;
131 case 'c':
132 if (strcmp(outvals, "v"))
133 error(USER, "color format with value output only");
134 break;
135 default:
136 error(CONSISTENCY, "botched output format");
137 }
138 if (hresolu > 0 && vresolu > 0)
139 fprtresolu(hresolu, vresolu, stdout);
140 /* process file */
141 while (getvec(orig, inform, fp) == 0 &&
142 getvec(direc, inform, fp) == 0) {
143
144 if (normalize(direc) == 0.0) { /* zero ==> flush */
145 fflush(stdout);
146 continue;
147 }
148 samplendx++;
149 /* compute and print */
150 if (imm_irrad)
151 irrad(orig, direc);
152 else
153 traceray(orig, direc);
154 /* flush if time */
155 if (--nextflush == 0) {
156 fflush(stdout);
157 nextflush = hresolu;
158 }
159 if (ferror(stdout))
160 error(SYSTEM, "write error");
161 if (--vcount == 0) /* check for end */
162 break;
163 }
164 if (vcount > 0)
165 error(USER, "read error");
166 fclose(fp);
167 }
168
169
170 setoutput(vs) /* set up output tables */
171 register char *vs;
172 {
173 extern int ourtrace(), (*trace)();
174 register int (**table)() = ray_out;
175
176 castonly = 1;
177 while (*vs)
178 switch (*vs++) {
179 case 't': /* trace */
180 *table = NULL;
181 table = every_out;
182 trace = ourtrace;
183 castonly = 0;
184 break;
185 case 'o': /* origin */
186 *table++ = oputo;
187 break;
188 case 'd': /* direction */
189 *table++ = oputd;
190 break;
191 case 'v': /* value */
192 *table++ = oputv;
193 castonly = 0;
194 break;
195 case 'l': /* effective distance */
196 *table++ = oputl;
197 castonly = 0;
198 break;
199 case 'L': /* single ray length */
200 *table++ = oputL;
201 break;
202 case 'p': /* point */
203 *table++ = oputp;
204 break;
205 case 'n': /* perturbed normal */
206 *table++ = oputn;
207 castonly = 0;
208 break;
209 case 'N': /* unperturbed normal */
210 *table++ = oputN;
211 break;
212 case 's': /* surface */
213 *table++ = oputs;
214 break;
215 case 'w': /* weight */
216 *table++ = oputw;
217 break;
218 case 'm': /* modifier */
219 *table++ = oputm;
220 break;
221 }
222 *table = NULL;
223 }
224
225
226 traceray(org, dir) /* compute and print ray value(s) */
227 FVECT org, dir;
228 {
229 register int (**tp)();
230
231 VCOPY(thisray.rorg, org);
232 VCOPY(thisray.rdir, dir);
233 rayorigin(&thisray, NULL, PRIMARY, 1.0);
234 if (castonly)
235 localhit(&thisray, &thescene) || sourcehit(&thisray);
236 else
237 rayvalue(&thisray);
238
239 if (ray_out[0] == NULL)
240 return;
241 for (tp = ray_out; *tp != NULL; tp++)
242 (**tp)(&thisray);
243 if (outform == 'a')
244 putchar('\n');
245 }
246
247
248 irrad(org, dir) /* compute immediate irradiance value */
249 FVECT org, dir;
250 {
251 register int i;
252
253 for (i = 0; i < 3; i++) {
254 thisray.rorg[i] = org[i] + dir[i];
255 thisray.rdir[i] = -dir[i];
256 }
257 rayorigin(&thisray, NULL, PRIMARY, 1.0);
258 /* pretend we hit surface */
259 thisray.rot = 1.0;
260 thisray.rod = 1.0;
261 VCOPY(thisray.ron, dir);
262 for (i = 0; i < 3; i++) /* fudge factor */
263 thisray.rop[i] = org[i] + 1e-4*dir[i];
264 /* compute and print */
265 (*ofun[Lamb.otype].funp)(&Lamb, &thisray);
266 oputv(&thisray);
267 if (outform == 'a')
268 putchar('\n');
269 }
270
271
272 getvec(vec, fmt, fp) /* get a vector from fp */
273 register FVECT vec;
274 int fmt;
275 FILE *fp;
276 {
277 extern char *fgetword();
278 static float vf[3];
279 static double vd[3];
280 char buf[32];
281 register int i;
282
283 switch (fmt) {
284 case 'a': /* ascii */
285 for (i = 0; i < 3; i++) {
286 if (fgetword(buf, sizeof(buf), fp) == NULL ||
287 !isflt(buf))
288 return(-1);
289 vec[i] = atof(buf);
290 }
291 break;
292 case 'f': /* binary float */
293 if (fread((char *)vf, sizeof(float), 3, fp) != 3)
294 return(-1);
295 vec[0] = vf[0]; vec[1] = vf[1]; vec[2] = vf[2];
296 break;
297 case 'd': /* binary double */
298 if (fread((char *)vd, sizeof(double), 3, fp) != 3)
299 return(-1);
300 vec[0] = vd[0]; vec[1] = vd[1]; vec[2] = vd[2];
301 break;
302 default:
303 error(CONSISTENCY, "botched input format");
304 }
305 return(0);
306 }
307
308
309 static
310 ourtrace(r) /* print ray values */
311 RAY *r;
312 {
313 register int (**tp)();
314
315 if (every_out[0] == NULL)
316 return;
317 tabin(r);
318 for (tp = every_out; *tp != NULL; tp++)
319 (**tp)(r);
320 putchar('\n');
321 }
322
323
324 static
325 tabin(r) /* tab in appropriate amount */
326 RAY *r;
327 {
328 register RAY *rp;
329
330 for (rp = r->parent; rp != NULL; rp = rp->parent)
331 putchar('\t');
332 }
333
334
335 static
336 oputo(r) /* print origin */
337 register RAY *r;
338 {
339 (*putreal)(r->rorg[0]);
340 (*putreal)(r->rorg[1]);
341 (*putreal)(r->rorg[2]);
342 }
343
344
345 static
346 oputd(r) /* print direction */
347 register RAY *r;
348 {
349 (*putreal)(r->rdir[0]);
350 (*putreal)(r->rdir[1]);
351 (*putreal)(r->rdir[2]);
352 }
353
354
355 static
356 oputv(r) /* print value */
357 register RAY *r;
358 {
359 COLR cout;
360
361 if (outform == 'c') {
362 setcolr(cout, colval(r->rcol,RED),
363 colval(r->rcol,GRN),
364 colval(r->rcol,BLU));
365 fwrite((char *)cout, sizeof(cout), 1, stdout);
366 return;
367 }
368 (*putreal)(colval(r->rcol,RED));
369 (*putreal)(colval(r->rcol,GRN));
370 (*putreal)(colval(r->rcol,BLU));
371 }
372
373
374 static
375 oputl(r) /* print effective distance */
376 register RAY *r;
377 {
378 (*putreal)(r->rt);
379 }
380
381
382 static
383 oputL(r) /* print single ray length */
384 register RAY *r;
385 {
386 (*putreal)(r->rot);
387 }
388
389
390 static
391 oputp(r) /* print point */
392 register RAY *r;
393 {
394 if (r->rot < FHUGE) {
395 (*putreal)(r->rop[0]);
396 (*putreal)(r->rop[1]);
397 (*putreal)(r->rop[2]);
398 } else {
399 (*putreal)(0.0);
400 (*putreal)(0.0);
401 (*putreal)(0.0);
402 }
403 }
404
405
406 static
407 oputN(r) /* print unperturbed normal */
408 register RAY *r;
409 {
410 if (r->rot < FHUGE) {
411 (*putreal)(r->ron[0]);
412 (*putreal)(r->ron[1]);
413 (*putreal)(r->ron[2]);
414 } else {
415 (*putreal)(0.0);
416 (*putreal)(0.0);
417 (*putreal)(0.0);
418 }
419 }
420
421
422 static
423 oputn(r) /* print perturbed normal */
424 RAY *r;
425 {
426 FVECT pnorm;
427
428 if (r->rot >= FHUGE) {
429 (*putreal)(0.0);
430 (*putreal)(0.0);
431 (*putreal)(0.0);
432 return;
433 }
434 raynormal(pnorm, r);
435 (*putreal)(pnorm[0]);
436 (*putreal)(pnorm[1]);
437 (*putreal)(pnorm[2]);
438 }
439
440
441 static
442 oputs(r) /* print name */
443 register RAY *r;
444 {
445 if (r->ro != NULL)
446 fputs(r->ro->oname, stdout);
447 else
448 putchar('*');
449 putchar('\t');
450 }
451
452
453 static
454 oputw(r) /* print weight */
455 register RAY *r;
456 {
457 (*putreal)(r->rweight);
458 }
459
460
461 static
462 oputm(r) /* print modifier */
463 register RAY *r;
464 {
465 if (r->ro != NULL)
466 fputs(objptr(r->ro->omod)->oname, stdout);
467 else
468 putchar('*');
469 putchar('\t');
470 }
471
472
473 static
474 puta(v) /* print ascii value */
475 double v;
476 {
477 printf("%e\t", v);
478 }
479
480
481 static
482 putd(v) /* print binary double */
483 double v;
484 {
485 fwrite((char *)&v, sizeof(v), 1, stdout);
486 }
487
488
489 static
490 putf(v) /* print binary float */
491 double v;
492 {
493 float f = v;
494
495 fwrite((char *)&f, sizeof(f), 1, stdout);
496 }
