root/Development/ray/src/rt/rtrace.c
Revision: 2.54
Committed: Wed Apr 5 14:30:38 2006 UTC (19 years, 9 months ago) by greg
Changed default in rtrace to -u+ (random sampling)
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.54 static const char RCSid[] = "$Id: rtrace.c,v 2.53 2006/04/05 06:22:57 greg Exp $";
3 greg 1.1 #endif
4     /*
5     * rtrace.c - program and variables for individual ray tracing.
6 greg 2.27 */
7
8 greg 2.28 #include "copyright.h"
9 greg 1.1
10     /*
11     * Input is in the form:
12     *
13     * xorg yorg zorg xdir ydir zdir
14     *
15     * The direction need not be normalized. Output is flexible.
16 greg 1.7 * If the direction vector is (0,0,0), then the output is flushed.
17 greg 1.1 * All values default to ascii representation of real
18     * numbers. Binary representations can be selected
19     * with '-ff' for float or '-fd' for double. By default,
20 greg 1.13 * radiance is computed. The '-i' or '-I' options indicate that
21 greg 1.1 * irradiance values are desired.
22     */
23 greg 2.32
24     #include <time.h>
25 greg 1.1
26 schorsch 2.30 #include "platform.h"
27 greg 1.1 #include "ray.h"
28 schorsch 2.37 #include "ambient.h"
29     #include "source.h"
30 greg 1.1 #include "otypes.h"
31 greg 2.6 #include "resolu.h"
32 schorsch 2.49 #include "random.h"
33 greg 2.6
34 greg 2.27 CUBE thescene; /* our scene */
35     OBJECT nsceneobjs; /* number of objects in our scene */
36
37 greg 1.14 int dimlist[MAXDIM]; /* sampling dimensions */
38     int ndims = 0; /* number of sampling dimensions */
39     int samplendx = 0; /* index for this sample */
40
41 greg 1.13 int imm_irrad = 0; /* compute immediate irradiance? */
42 gregl 2.25 int lim_dist = 0; /* limit distance? */
43 greg 1.13
44 greg 1.1 int inform = 'a'; /* input format */
45     int outform = 'a'; /* output format */
46     char *outvals = "v"; /* output specification */
47
48 greg 2.27 int do_irrad = 0; /* compute irradiance? */
49
50 greg 2.54 int rand_samp = 1; /* pure Monte Carlo sampling? */
51 greg 2.47
52 greg 2.27 void (*trace)() = NULL; /* trace call */
53
54 greg 2.15 char *tralist[128]; /* list of modifers to trace (or no) */
55     int traincl = -1; /* include == 1, exclude == 0 */
56 greg 2.46 #ifndef MAXTSET
57 greg 2.52 #define MAXTSET 8192 /* maximum number in trace set */
58 greg 2.46 #endif
59 greg 2.15 OBJECT traset[MAXTSET+1]={0}; /* trace include/exclude set */
60
61 greg 1.1 int hresolu = 0; /* horizontal (scan) size */
62     int vresolu = 0; /* vertical resolution */
63
64     double dstrsrc = 0.0; /* square source distribution */
65 greg 2.35 double shadthresh = .03; /* shadow threshold */
66     double shadcert = .75; /* shadow certainty */
67 greg 2.19 int directrelay = 2; /* number of source relays */
68 greg 1.17 int vspretest = 512; /* virtual source pretest density */
69 greg 2.10 int directvis = 1; /* sources visible? */
70 greg 2.19 double srcsizerat = .2; /* maximum ratio source size/dist. */
71 greg 2.20
72     COLOR cextinction = BLKCOLOR; /* global extinction coefficient */
73 greg 2.22 COLOR salbedo = BLKCOLOR; /* global scattering albedo */
74 greg 2.20 double seccg = 0.; /* global scattering eccentricity */
75     double ssampdist = 0.; /* scatter sampling distance */
76 greg 1.1
77 greg 2.4 double specthresh = .15; /* specular sampling threshold */
78 greg 2.3 double specjitter = 1.; /* specular sampling jitter */
79
80 greg 2.18 int backvis = 1; /* back face visibility */
81
82 greg 2.44 int maxdepth = -10; /* maximum recursion depth */
83 greg 2.34 double minweight = 2e-3; /* minimum ray weight */
84 greg 1.1
85 greg 2.27 char *ambfile = NULL; /* ambient file name */
86 greg 1.1 COLOR ambval = BLKCOLOR; /* ambient value */
87 greg 2.21 int ambvwt = 0; /* initial weight for ambient value */
88 greg 2.36 double ambacc = 0.15; /* ambient accuracy */
89 greg 2.34 int ambres = 256; /* ambient resolution */
90     int ambdiv = 1024; /* ambient divisions */
91     int ambssamp = 512; /* ambient super-samples */
92 greg 1.1 int ambounce = 0; /* ambient bounces */
93 greg 2.38 char *amblist[AMBLLEN]; /* ambient include/exclude list */
94 greg 1.1 int ambincl = -1; /* include == 1, exclude == 0 */
95
96 schorsch 2.37 static int castonly = 0;
97 gregl 2.25
98 greg 1.1 static RAY thisray; /* for our convenience */
99
100 schorsch 2.37 typedef void putf_t(double v);
101     static putf_t puta, putd, putf;
102 greg 1.1
103 schorsch 2.37 typedef void oputf_t(RAY *r);
104 greg 2.51 static oputf_t oputo, oputd, oputv, oputV, oputl, oputL, oputc, oputp,
105 greg 2.42 oputn, oputN, oputs, oputw, oputW, oputm, oputM, oputtilde;
106 schorsch 2.37
107     static void setoutput(char *vs);
108     static void tranotify(OBJECT obj);
109     static void bogusray(void);
110     static void rad(FVECT org, FVECT dir, double dmax);
111     static void irrad(FVECT org, FVECT dir);
112     static void printvals(RAY *r);
113     static int getvec(FVECT vec, int fmt, FILE *fp);
114     static void tabin(RAY *r);
115     static void ourtrace(RAY *r);
116 greg 1.1
117 schorsch 2.37 static oputf_t *ray_out[16], *every_out[16];
118     static putf_t *putreal;
119 greg 2.27
120 schorsch 2.37 void (*addobjnotify[])() = {ambnotify, tranotify, NULL};
121 greg 1.1
122
123 greg 2.27 void
124 schorsch 2.37 quit( /* quit program */
125     int code
126     )
127 greg 1.1 {
128 schorsch 2.31 #ifndef NON_POSIX /* XXX we don't clean up elsewhere? */
129 greg 2.11 headclean(); /* delete header file */
130     pfclean(); /* clean up persist files */
131     #endif
132 greg 1.1 exit(code);
133     }
134
135
136 schorsch 2.37 extern char *
137     formstr( /* return format identifier */
138     int f
139     )
140 greg 2.6 {
141     switch (f) {
142     case 'a': return("ascii");
143     case 'f': return("float");
144     case 'd': return("double");
145     case 'c': return(COLRFMT);
146     }
147     return("unknown");
148     }
149
150
151 schorsch 2.37 extern void
152     rtrace( /* trace rays from file */
153     char *fname
154     )
155 greg 1.1 {
156 greg 2.45 unsigned long vcount = (hresolu > 1) ? (unsigned long)hresolu*vresolu
157     : vresolu;
158 greg 1.1 long nextflush = hresolu;
159     FILE *fp;
160 gregl 2.25 double d;
161 greg 1.2 FVECT orig, direc;
162 greg 1.1 /* set up input */
163     if (fname == NULL)
164     fp = stdin;
165     else if ((fp = fopen(fname, "r")) == NULL) {
166     sprintf(errmsg, "cannot open input file \"%s\"", fname);
167     error(SYSTEM, errmsg);
168     }
169 greg 2.8 if (inform != 'a')
170 schorsch 2.30 SET_FILE_BINARY(fp);
171 greg 1.1 /* set up output */
172 greg 2.16 setoutput(outvals);
173 greg 1.1 switch (outform) {
174     case 'a': putreal = puta; break;
175     case 'f': putreal = putf; break;
176     case 'd': putreal = putd; break;
177 greg 2.6 case 'c':
178     if (strcmp(outvals, "v"))
179     error(USER, "color format with value output only");
180     break;
181     default:
182     error(CONSISTENCY, "botched output format");
183 greg 1.1 }
184 greg 2.12 if (hresolu > 0) {
185     if (vresolu > 0)
186     fprtresolu(hresolu, vresolu, stdout);
187     fflush(stdout);
188     }
189 greg 1.1 /* process file */
190     while (getvec(orig, inform, fp) == 0 &&
191     getvec(direc, inform, fp) == 0) {
192
193 gregl 2.25 d = normalize(direc);
194     if (d == 0.0) { /* zero ==> flush */
195 gregl 2.24 bogusray();
196 greg 2.45 if (--nextflush <= 0 || !vcount) {
197 gregl 2.24 fflush(stdout);
198     nextflush = hresolu;
199     }
200     } else {
201 greg 2.53 samplendx++;
202 greg 1.1 /* compute and print */
203 gregl 2.24 if (imm_irrad)
204     irrad(orig, direc);
205     else
206 gregl 2.25 rad(orig, direc, lim_dist ? d : 0.0);
207 greg 1.7 /* flush if time */
208 greg 2.45 if (!--nextflush) {
209 gregl 2.24 fflush(stdout);
210     nextflush = hresolu;
211     }
212 greg 1.1 }
213     if (ferror(stdout))
214     error(SYSTEM, "write error");
215 greg 2.45 if (vcount && !--vcount) /* check for end */
216 greg 1.1 break;
217     }
218 greg 2.50 if (fflush(stdout) < 0)
219     error(SYSTEM, "write error");
220 greg 2.45 if (vcount)
221 greg 2.42 error(USER, "unexpected EOF on input");
222 greg 2.12 if (fname != NULL)
223     fclose(fp);
224 greg 1.1 }
225
226
227 schorsch 2.37 static void
228 greg 2.40 trace_sources(void) /* trace rays to light sources, also */
229     {
230     int sn;
231
232     for (sn = 0; sn < nsources; sn++)
233     source[sn].sflags |= SFOLLOW;
234     }
235
236
237     static void
238 schorsch 2.37 setoutput( /* set up output tables */
239     register char *vs
240     )
241 greg 1.1 {
242 schorsch 2.37 register oputf_t **table = ray_out;
243 greg 1.1
244 greg 1.11 castonly = 1;
245 greg 1.1 while (*vs)
246     switch (*vs++) {
247 greg 2.40 case 'T': /* trace sources */
248 greg 2.42 if (!*vs) break;
249 greg 2.40 trace_sources();
250     /* fall through */
251 greg 1.1 case 't': /* trace */
252 greg 2.42 if (!*vs) break;
253 greg 1.1 *table = NULL;
254     table = every_out;
255     trace = ourtrace;
256 greg 1.11 castonly = 0;
257 greg 1.1 break;
258     case 'o': /* origin */
259     *table++ = oputo;
260     break;
261     case 'd': /* direction */
262     *table++ = oputd;
263     break;
264     case 'v': /* value */
265     *table++ = oputv;
266 greg 1.11 castonly = 0;
267 greg 1.1 break;
268 greg 2.51 case 'V': /* contribution */
269     *table++ = oputV;
270     if (ambounce > 0 && (ambacc > FTINY || ambssamp > 0))
271     error(WARNING,
272     "-otV accuracy depends on -aa 0 -as 0");
273     break;
274 greg 2.5 case 'l': /* effective distance */
275 greg 1.1 *table++ = oputl;
276 greg 1.11 castonly = 0;
277 greg 1.1 break;
278 greg 2.29 case 'c': /* local coordinates */
279     *table++ = oputc;
280     break;
281 greg 2.5 case 'L': /* single ray length */
282     *table++ = oputL;
283     break;
284 greg 1.1 case 'p': /* point */
285     *table++ = oputp;
286     break;
287 greg 2.9 case 'n': /* perturbed normal */
288 greg 1.1 *table++ = oputn;
289 greg 2.9 castonly = 0;
290 greg 1.1 break;
291 greg 2.9 case 'N': /* unperturbed normal */
292     *table++ = oputN;
293     break;
294 greg 1.1 case 's': /* surface */
295     *table++ = oputs;
296     break;
297     case 'w': /* weight */
298     *table++ = oputw;
299     break;
300 greg 2.40 case 'W': /* coefficient */
301     *table++ = oputW;
302     if (ambounce > 0 && (ambacc > FTINY || ambssamp > 0))
303     error(WARNING,
304 greg 2.41 "-otW accuracy depends on -aa 0 -as 0");
305 greg 2.40 break;
306 greg 1.1 case 'm': /* modifier */
307     *table++ = oputm;
308     break;
309 greg 2.39 case 'M': /* material */
310     *table++ = oputM;
311     break;
312 greg 2.42 case '~': /* tilde */
313     *table++ = oputtilde;
314 greg 2.41 break;
315 greg 1.1 }
316     *table = NULL;
317 gregl 2.24 }
318
319
320 schorsch 2.37 static void
321     bogusray(void) /* print out empty record */
322 gregl 2.24 {
323     thisray.rorg[0] = thisray.rorg[1] = thisray.rorg[2] =
324     thisray.rdir[0] = thisray.rdir[1] = thisray.rdir[2] = 0.0;
325 greg 2.40 thisray.rmax = 0.0;
326     rayorigin(&thisray, PRIMARY, NULL, NULL);
327 gregl 2.24 printvals(&thisray);
328 greg 1.1 }
329
330
331 schorsch 2.37 static void
332     rad( /* compute and print ray value(s) */
333     FVECT org,
334     FVECT dir,
335     double dmax
336     )
337 greg 1.1 {
338     VCOPY(thisray.rorg, org);
339     VCOPY(thisray.rdir, dir);
340 gregl 2.25 thisray.rmax = dmax;
341 greg 2.40 rayorigin(&thisray, PRIMARY, NULL, NULL);
342 gregl 2.25 if (castonly) {
343 schorsch 2.33 if (!localhit(&thisray, &thescene)) {
344 gregl 2.25 if (thisray.ro == &Aftplane) { /* clipped */
345     thisray.ro = NULL;
346     thisray.rot = FHUGE;
347     } else
348     sourcehit(&thisray);
349 schorsch 2.33 }
350 gregl 2.25 } else
351 greg 1.11 rayvalue(&thisray);
352 greg 2.16 printvals(&thisray);
353 greg 1.1 }
354
355
356 schorsch 2.37 static void
357     irrad( /* compute immediate irradiance value */
358     FVECT org,
359     FVECT dir
360     )
361 greg 1.1 {
362     register int i;
363
364     for (i = 0; i < 3; i++) {
365     thisray.rorg[i] = org[i] + dir[i];
366     thisray.rdir[i] = -dir[i];
367     }
368 greg 2.40 thisray.rmax = 0.0;
369     rayorigin(&thisray, PRIMARY, NULL, NULL);
370 greg 1.1 /* pretend we hit surface */
371 greg 2.16 thisray.rot = 1.0-1e-4;
372 greg 1.1 thisray.rod = 1.0;
373     VCOPY(thisray.ron, dir);
374     for (i = 0; i < 3; i++) /* fudge factor */
375     thisray.rop[i] = org[i] + 1e-4*dir[i];
376     /* compute and print */
377     (*ofun[Lamb.otype].funp)(&Lamb, &thisray);
378 greg 2.16 printvals(&thisray);
379     }
380
381
382 schorsch 2.37 static void
383     printvals( /* print requested ray values */
384     RAY *r
385     )
386 greg 2.16 {
387 schorsch 2.37 register oputf_t **tp;
388 greg 2.16
389     if (ray_out[0] == NULL)
390     return;
391     for (tp = ray_out; *tp != NULL; tp++)
392     (**tp)(r);
393 greg 1.1 if (outform == 'a')
394     putchar('\n');
395     }
396
397
398 schorsch 2.37 static int
399     getvec( /* get a vector from fp */
400     register FVECT vec,
401     int fmt,
402     FILE *fp
403     )
404 greg 1.1 {
405     static float vf[3];
406 greg 2.5 static double vd[3];
407 greg 1.19 char buf[32];
408     register int i;
409 greg 1.1
410     switch (fmt) {
411     case 'a': /* ascii */
412 greg 1.19 for (i = 0; i < 3; i++) {
413     if (fgetword(buf, sizeof(buf), fp) == NULL ||
414     !isflt(buf))
415     return(-1);
416     vec[i] = atof(buf);
417     }
418 greg 1.1 break;
419     case 'f': /* binary float */
420 greg 1.8 if (fread((char *)vf, sizeof(float), 3, fp) != 3)
421 greg 1.1 return(-1);
422     vec[0] = vf[0]; vec[1] = vf[1]; vec[2] = vf[2];
423     break;
424     case 'd': /* binary double */
425 greg 2.5 if (fread((char *)vd, sizeof(double), 3, fp) != 3)
426 greg 1.1 return(-1);
427 greg 2.5 vec[0] = vd[0]; vec[1] = vd[1]; vec[2] = vd[2];
428 greg 1.1 break;
429 greg 2.6 default:
430     error(CONSISTENCY, "botched input format");
431 greg 1.1 }
432     return(0);
433     }
434
435
436 schorsch 2.37 static void
437     tranotify( /* record new modifier */
438     OBJECT obj
439     )
440 greg 2.15 {
441     static int hitlimit = 0;
442     register OBJREC *o = objptr(obj);
443     register char **tralp;
444
445 greg 2.27 if (obj == OVOID) { /* starting over */
446     traset[0] = 0;
447     hitlimit = 0;
448     return;
449     }
450 greg 2.15 if (hitlimit || !ismodifier(o->otype))
451     return;
452     for (tralp = tralist; *tralp != NULL; tralp++)
453     if (!strcmp(o->oname, *tralp)) {
454     if (traset[0] >= MAXTSET) {
455     error(WARNING, "too many modifiers in trace list");
456     hitlimit++;
457     return; /* should this be fatal? */
458     }
459     insertelem(traset, obj);
460     return;
461     }
462     }
463
464
465 greg 2.27 static void
466 schorsch 2.37 ourtrace( /* print ray values */
467     RAY *r
468     )
469 greg 1.1 {
470 schorsch 2.37 register oputf_t **tp;
471 greg 1.1
472     if (every_out[0] == NULL)
473 greg 2.15 return;
474 greg 2.16 if (r->ro == NULL) {
475     if (traincl == 1)
476     return;
477     } else if (traincl != -1 && traincl != inset(traset, r->ro->omod))
478 greg 1.1 return;
479     tabin(r);
480     for (tp = every_out; *tp != NULL; tp++)
481     (**tp)(r);
482 greg 2.41 if (outform == 'a')
483     putchar('\n');
484 greg 1.1 }
485
486
487 greg 2.27 static void
488 schorsch 2.37 tabin( /* tab in appropriate amount */
489     RAY *r
490     )
491 greg 1.1 {
492 greg 2.40 const RAY *rp;
493 greg 1.1
494     for (rp = r->parent; rp != NULL; rp = rp->parent)
495     putchar('\t');
496     }
497
498
499 greg 2.27 static void
500 schorsch 2.37 oputo( /* print origin */
501     RAY *r
502     )
503 greg 1.1 {
504     (*putreal)(r->rorg[0]);
505     (*putreal)(r->rorg[1]);
506     (*putreal)(r->rorg[2]);
507     }
508
509
510 greg 2.27 static void
511 schorsch 2.37 oputd( /* print direction */
512     RAY *r
513     )
514 greg 1.1 {
515     (*putreal)(r->rdir[0]);
516     (*putreal)(r->rdir[1]);
517     (*putreal)(r->rdir[2]);
518     }
519
520
521 greg 2.27 static void
522 schorsch 2.37 oputv( /* print value */
523     RAY *r
524     )
525 greg 1.1 {
526 greg 2.6 if (outform == 'c') {
527 greg 2.41 COLR cout;
528 greg 2.6 setcolr(cout, colval(r->rcol,RED),
529     colval(r->rcol,GRN),
530     colval(r->rcol,BLU));
531     fwrite((char *)cout, sizeof(cout), 1, stdout);
532     return;
533     }
534 greg 1.1 (*putreal)(colval(r->rcol,RED));
535     (*putreal)(colval(r->rcol,GRN));
536     (*putreal)(colval(r->rcol,BLU));
537     }
538
539
540 greg 2.27 static void
541 greg 2.51 oputV( /* print value contribution */
542     RAY *r
543     )
544     {
545     double contr[3];
546
547     raycontrib(contr, r, PRIMARY);
548     multcolor(contr, r->rcol);
549     (*putreal)(contr[RED]);
550     (*putreal)(contr[GRN]);
551     (*putreal)(contr[BLU]);
552     }
553
554
555     static void
556 schorsch 2.37 oputl( /* print effective distance */
557     RAY *r
558     )
559 greg 1.1 {
560 greg 1.9 (*putreal)(r->rt);
561 greg 2.5 }
562
563
564 greg 2.27 static void
565 schorsch 2.37 oputL( /* print single ray length */
566     RAY *r
567     )
568 greg 2.5 {
569     (*putreal)(r->rot);
570 greg 1.1 }
571
572
573 greg 2.27 static void
574 schorsch 2.37 oputc( /* print local coordinates */
575     RAY *r
576     )
577 greg 2.29 {
578     (*putreal)(r->uv[0]);
579     (*putreal)(r->uv[1]);
580     }
581
582
583     static void
584 schorsch 2.37 oputp( /* print point */
585     RAY *r
586     )
587 greg 1.1 {
588     if (r->rot < FHUGE) {
589     (*putreal)(r->rop[0]);
590     (*putreal)(r->rop[1]);
591     (*putreal)(r->rop[2]);
592     } else {
593     (*putreal)(0.0);
594     (*putreal)(0.0);
595     (*putreal)(0.0);
596     }
597     }
598
599
600 greg 2.27 static void
601 schorsch 2.37 oputN( /* print unperturbed normal */
602     RAY *r
603     )
604 greg 1.1 {
605     if (r->rot < FHUGE) {
606     (*putreal)(r->ron[0]);
607     (*putreal)(r->ron[1]);
608     (*putreal)(r->ron[2]);
609     } else {
610     (*putreal)(0.0);
611     (*putreal)(0.0);
612     (*putreal)(0.0);
613     }
614 greg 2.9 }
615
616
617 greg 2.27 static void
618 schorsch 2.37 oputn( /* print perturbed normal */
619     RAY *r
620     )
621 greg 2.9 {
622     FVECT pnorm;
623
624     if (r->rot >= FHUGE) {
625     (*putreal)(0.0);
626     (*putreal)(0.0);
627     (*putreal)(0.0);
628     return;
629     }
630     raynormal(pnorm, r);
631     (*putreal)(pnorm[0]);
632     (*putreal)(pnorm[1]);
633     (*putreal)(pnorm[2]);
634 greg 1.1 }
635
636
637 greg 2.27 static void
638 schorsch 2.37 oputs( /* print name */
639     RAY *r
640     )
641 greg 1.1 {
642     if (r->ro != NULL)
643     fputs(r->ro->oname, stdout);
644     else
645     putchar('*');
646     putchar('\t');
647     }
648
649
650 greg 2.27 static void
651 schorsch 2.37 oputw( /* print weight */
652     RAY *r
653     )
654 greg 1.1 {
655     (*putreal)(r->rweight);
656     }
657
658
659 greg 2.27 static void
660 greg 2.51 oputW( /* print coefficient */
661 greg 2.40 RAY *r
662     )
663     {
664 greg 2.48 double contr[3];
665 greg 2.40
666     raycontrib(contr, r, PRIMARY);
667 greg 2.48 (*putreal)(contr[RED]);
668     (*putreal)(contr[GRN]);
669     (*putreal)(contr[BLU]);
670 greg 2.40 }
671
672
673     static void
674 schorsch 2.37 oputm( /* print modifier */
675     RAY *r
676     )
677 greg 1.1 {
678     if (r->ro != NULL)
679 greg 2.23 if (r->ro->omod != OVOID)
680     fputs(objptr(r->ro->omod)->oname, stdout);
681     else
682     fputs(VOIDID, stdout);
683 greg 1.1 else
684     putchar('*');
685     putchar('\t');
686     }
687
688
689 greg 2.27 static void
690 greg 2.39 oputM( /* print material */
691     RAY *r
692     )
693     {
694     OBJREC *mat;
695
696     if (r->ro != NULL) {
697     if ((mat = findmaterial(r->ro)) != NULL)
698     fputs(mat->oname, stdout);
699     else
700     fputs(VOIDID, stdout);
701     } else
702     putchar('*');
703     putchar('\t');
704     }
705
706
707     static void
708 greg 2.42 oputtilde( /* output tilde (spacer) */
709 greg 2.41 RAY *r
710     )
711     {
712 greg 2.42 fputs("~\t", stdout);
713 greg 2.41 }
714
715
716     static void
717 schorsch 2.37 puta( /* print ascii value */
718     double v
719     )
720 greg 1.1 {
721     printf("%e\t", v);
722     }
723
724
725 greg 2.27 static void
726 greg 1.1 putd(v) /* print binary double */
727     double v;
728     {
729 greg 1.8 fwrite((char *)&v, sizeof(v), 1, stdout);
730 greg 1.1 }
731
732
733 greg 2.27 static void
734 greg 1.1 putf(v) /* print binary float */
735     double v;
736     {
737     float f = v;
738
739 greg 1.8 fwrite((char *)&f, sizeof(f), 1, stdout);
740 greg 1.1 }
