root/radiance/ray/src/rt/rtrace.c
Revision: 2.6
Committed: Fri Jul 10 14:56:24 1992 UTC (32 years, 10 months ago) by greg
Changes since 2.5: +38 -1 lines
added ability to print COLRFMT output of values
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * rtrace.c - program and variables for individual ray tracing.
9 *
10 * 6/11/86
11 */
12
13 /*
14 * Input is in the form:
15 *
16 * xorg yorg zorg xdir ydir zdir
17 *
18 * The direction need not be normalized. Output is flexible.
19 * If the direction vector is (0,0,0), then the output is flushed.
20 * All values default to ascii representation of real
21 * numbers. Binary representations can be selected
22 * with '-ff' for float or '-fd' for double. By default,
23 * radiance is computed. The '-i' or '-I' options indicate that
24 * irradiance values are desired.
25 */
26
27 #include "ray.h"
28
29 #include "octree.h"
30
31 #include "otypes.h"
32
33 #include "resolu.h"
34
35 int dimlist[MAXDIM]; /* sampling dimensions */
36 int ndims = 0; /* number of sampling dimensions */
37 int samplendx = 0; /* index for this sample */
38
39 int imm_irrad = 0; /* compute immediate irradiance? */
40
41 int inform = 'a'; /* input format */
42 int outform = 'a'; /* output format */
43 char *outvals = "v"; /* output specification */
44
45 int hresolu = 0; /* horizontal (scan) size */
46 int vresolu = 0; /* vertical resolution */
47
48 double dstrsrc = 0.0; /* square source distribution */
49 double shadthresh = .05; /* shadow threshold */
50 double shadcert = .5; /* shadow certainty */
51 int directrelay = 1; /* number of source relays */
52 int vspretest = 512; /* virtual source pretest density */
53 int directinvis = 0; /* sources invisible? */
54 double srcsizerat = .25; /* maximum ratio source size/dist. */
55
56 double specthresh = .15; /* specular sampling threshold */
57 double specjitter = 1.; /* specular sampling jitter */
58
59 int maxdepth = 6; /* maximum recursion depth */
60 double minweight = 4e-3; /* minimum ray weight */
61
62 COLOR ambval = BLKCOLOR; /* ambient value */
63 double ambacc = 0.2; /* ambient accuracy */
64 int ambres = 32; /* ambient resolution */
65 int ambdiv = 128; /* ambient divisions */
66 int ambssamp = 0; /* ambient super-samples */
67 int ambounce = 0; /* ambient bounces */
68 char *amblist[128]; /* ambient include/exclude list */
69 int ambincl = -1; /* include == 1, exclude == 0 */
70
71 extern OBJREC Lamb; /* a Lambertian surface */
72
73 static RAY thisray; /* for our convenience */
74
75 static int oputo(), oputd(), oputv(), oputl(), oputL(),
76 oputp(), oputn(), oputs(), oputw(), oputm();
77
78 static int (*ray_out[10])(), (*every_out[10])();
79 static int castonly;
80
81 static int puta(), putf(), putd();
82
83 static int (*putreal)();
84
85
86 quit(code) /* quit program */
87 int code;
88 {
89 exit(code);
90 }
91
92
93 char *
94 formstr(f) /* return format identifier */
95 int f;
96 {
97 switch (f) {
98 case 'a': return("ascii");
99 case 'f': return("float");
100 case 'd': return("double");
101 case 'c': return(COLRFMT);
102 }
103 return("unknown");
104 }
105
106
107 rtrace(fname) /* trace rays from file */
108 char *fname;
109 {
110 long vcount = hresolu>1 ? hresolu*vresolu : vresolu;
111 long nextflush = hresolu;
112 FILE *fp;
113 FVECT orig, direc;
114 /* set up input */
115 if (fname == NULL)
116 fp = stdin;
117 else if ((fp = fopen(fname, "r")) == NULL) {
118 sprintf(errmsg, "cannot open input file \"%s\"", fname);
119 error(SYSTEM, errmsg);
120 }
121 /* set up output */
122 setoutput(outvals);
123 switch (outform) {
124 case 'a': putreal = puta; break;
125 case 'f': putreal = putf; break;
126 case 'd': putreal = putd; break;
127 case 'c':
128 if (strcmp(outvals, "v"))
129 error(USER, "color format with value output only");
130 break;
131 default:
132 error(CONSISTENCY, "botched output format");
133 }
134 fputformat(formstr(outform), stdout);
135 putchar('\n');
136 if (hresolu > 0 && vresolu > 0)
137 fprtresolu(hresolu, vresolu, stdout);
138 /* process file */
139 while (getvec(orig, inform, fp) == 0 &&
140 getvec(direc, inform, fp) == 0) {
141
142 if (normalize(direc) == 0.0) { /* zero ==> flush */
143 fflush(stdout);
144 continue;
145 }
146 samplendx++;
147 /* compute and print */
148 if (imm_irrad)
149 irrad(orig, direc);
150 else
151 traceray(orig, direc);
152 /* flush if time */
153 if (--nextflush == 0) {
154 fflush(stdout);
155 nextflush = hresolu;
156 }
157 if (ferror(stdout))
158 error(SYSTEM, "write error");
159 if (--vcount == 0) /* check for end */
160 break;
161 }
162 if (vcount > 0)
163 error(USER, "read error");
164 fclose(fp);
165 }
166
167
168 setoutput(vs) /* set up output tables */
169 register char *vs;
170 {
171 extern int ourtrace(), (*trace)();
172 register int (**table)() = ray_out;
173
174 castonly = 1;
175 while (*vs)
176 switch (*vs++) {
177 case 't': /* trace */
178 *table = NULL;
179 table = every_out;
180 trace = ourtrace;
181 castonly = 0;
182 break;
183 case 'o': /* origin */
184 *table++ = oputo;
185 break;
186 case 'd': /* direction */
187 *table++ = oputd;
188 break;
189 case 'v': /* value */
190 *table++ = oputv;
191 castonly = 0;
192 break;
193 case 'l': /* effective distance */
194 *table++ = oputl;
195 castonly = 0;
196 break;
197 case 'L': /* single ray length */
198 *table++ = oputL;
199 break;
200 case 'p': /* point */
201 *table++ = oputp;
202 break;
203 case 'n': /* normal */
204 *table++ = oputn;
205 break;
206 case 's': /* surface */
207 *table++ = oputs;
208 break;
209 case 'w': /* weight */
210 *table++ = oputw;
211 break;
212 case 'm': /* modifier */
213 *table++ = oputm;
214 break;
215 }
216 *table = NULL;
217 }
218
219
220 traceray(org, dir) /* compute and print ray value(s) */
221 FVECT org, dir;
222 {
223 register int (**tp)();
224
225 VCOPY(thisray.rorg, org);
226 VCOPY(thisray.rdir, dir);
227 rayorigin(&thisray, NULL, PRIMARY, 1.0);
228 if (castonly)
229 localhit(&thisray, &thescene) || sourcehit(&thisray);
230 else
231 rayvalue(&thisray);
232
233 if (ray_out[0] == NULL)
234 return;
235 for (tp = ray_out; *tp != NULL; tp++)
236 (**tp)(&thisray);
237 if (outform == 'a')
238 putchar('\n');
239 }
240
241
242 irrad(org, dir) /* compute immediate irradiance value */
243 FVECT org, dir;
244 {
245 register int i;
246
247 for (i = 0; i < 3; i++) {
248 thisray.rorg[i] = org[i] + dir[i];
249 thisray.rdir[i] = -dir[i];
250 }
251 rayorigin(&thisray, NULL, PRIMARY, 1.0);
252 /* pretend we hit surface */
253 thisray.rot = 1.0;
254 thisray.rod = 1.0;
255 VCOPY(thisray.ron, dir);
256 for (i = 0; i < 3; i++) /* fudge factor */
257 thisray.rop[i] = org[i] + 1e-4*dir[i];
258 /* compute and print */
259 (*ofun[Lamb.otype].funp)(&Lamb, &thisray);
260 oputv(&thisray);
261 if (outform == 'a')
262 putchar('\n');
263 }
264
265
266 getvec(vec, fmt, fp) /* get a vector from fp */
267 register FVECT vec;
268 int fmt;
269 FILE *fp;
270 {
271 extern char *fgetword();
272 static float vf[3];
273 static double vd[3];
274 char buf[32];
275 register int i;
276
277 switch (fmt) {
278 case 'a': /* ascii */
279 for (i = 0; i < 3; i++) {
280 if (fgetword(buf, sizeof(buf), fp) == NULL ||
281 !isflt(buf))
282 return(-1);
283 vec[i] = atof(buf);
284 }
285 break;
286 case 'f': /* binary float */
287 if (fread((char *)vf, sizeof(float), 3, fp) != 3)
288 return(-1);
289 vec[0] = vf[0]; vec[1] = vf[1]; vec[2] = vf[2];
290 break;
291 case 'd': /* binary double */
292 if (fread((char *)vd, sizeof(double), 3, fp) != 3)
293 return(-1);
294 vec[0] = vd[0]; vec[1] = vd[1]; vec[2] = vd[2];
295 break;
296 default:
297 error(CONSISTENCY, "botched input format");
298 }
299 return(0);
300 }
301
302
303 static
304 ourtrace(r) /* print ray values */
305 RAY *r;
306 {
307 register int (**tp)();
308
309 if (every_out[0] == NULL)
310 return;
311 tabin(r);
312 for (tp = every_out; *tp != NULL; tp++)
313 (**tp)(r);
314 putchar('\n');
315 }
316
317
318 static
319 tabin(r) /* tab in appropriate amount */
320 RAY *r;
321 {
322 register RAY *rp;
323
324 for (rp = r->parent; rp != NULL; rp = rp->parent)
325 putchar('\t');
326 }
327
328
329 static
330 oputo(r) /* print origin */
331 register RAY *r;
332 {
333 (*putreal)(r->rorg[0]);
334 (*putreal)(r->rorg[1]);
335 (*putreal)(r->rorg[2]);
336 }
337
338
339 static
340 oputd(r) /* print direction */
341 register RAY *r;
342 {
343 (*putreal)(r->rdir[0]);
344 (*putreal)(r->rdir[1]);
345 (*putreal)(r->rdir[2]);
346 }
347
348
349 static
350 oputv(r) /* print value */
351 register RAY *r;
352 {
353 COLR cout;
354
355 if (outform == 'c') {
356 setcolr(cout, colval(r->rcol,RED),
357 colval(r->rcol,GRN),
358 colval(r->rcol,BLU));
359 fwrite((char *)cout, sizeof(cout), 1, stdout);
360 return;
361 }
362 (*putreal)(colval(r->rcol,RED));
363 (*putreal)(colval(r->rcol,GRN));
364 (*putreal)(colval(r->rcol,BLU));
365 }
366
367
368 static
369 oputl(r) /* print effective distance */
370 register RAY *r;
371 {
372 (*putreal)(r->rt);
373 }
374
375
376 static
377 oputL(r) /* print single ray length */
378 register RAY *r;
379 {
380 (*putreal)(r->rot);
381 }
382
383
384 static
385 oputp(r) /* print point */
386 register RAY *r;
387 {
388 if (r->rot < FHUGE) {
389 (*putreal)(r->rop[0]);
390 (*putreal)(r->rop[1]);
391 (*putreal)(r->rop[2]);
392 } else {
393 (*putreal)(0.0);
394 (*putreal)(0.0);
395 (*putreal)(0.0);
396 }
397 }
398
399
400 static
401 oputn(r) /* print normal */
402 register RAY *r;
403 {
404 if (r->rot < FHUGE) {
405 (*putreal)(r->ron[0]);
406 (*putreal)(r->ron[1]);
407 (*putreal)(r->ron[2]);
408 } else {
409 (*putreal)(0.0);
410 (*putreal)(0.0);
411 (*putreal)(0.0);
412 }
413 }
414
415
416 static
417 oputs(r) /* print name */
418 register RAY *r;
419 {
420 if (r->ro != NULL)
421 fputs(r->ro->oname, stdout);
422 else
423 putchar('*');
424 putchar('\t');
425 }
426
427
428 static
429 oputw(r) /* print weight */
430 register RAY *r;
431 {
432 (*putreal)(r->rweight);
433 }
434
435
436 static
437 oputm(r) /* print modifier */
438 register RAY *r;
439 {
440 if (r->ro != NULL)
441 fputs(objptr(r->ro->omod)->oname, stdout);
442 else
443 putchar('*');
444 putchar('\t');
445 }
446
447
448 static
449 puta(v) /* print ascii value */
450 double v;
451 {
452 printf("%e\t", v);
453 }
454
455
456 static
457 putd(v) /* print binary double */
458 double v;
459 {
460 fwrite((char *)&v, sizeof(v), 1, stdout);
461 }
462
463
464 static
465 putf(v) /* print binary float */
466 double v;
467 {
468 float f = v;
469
470 fwrite((char *)&f, sizeof(f), 1, stdout);
471 }
