root/radiance/ray/src/rt/rtrace.c
Revision: 1.19
Committed: Mon Jul 22 13:09:58 1991 UTC (33 years, 10 months ago) by greg
Changes since 1.18: +10 -2 lines
got rid of scanf() call
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * rtrace.c - program and variables for individual ray tracing.
9 *
10 * 6/11/86
11 */
12
13 /*
14 * Input is in the form:
15 *
16 * xorg yorg zorg xdir ydir zdir
17 *
18 * The direction need not be normalized. Output is flexible.
19 * If the direction vector is (0,0,0), then the output is flushed.
20 * All values default to ascii representation of real
21 * numbers. Binary representations can be selected
22 * with '-ff' for float or '-fd' for double. By default,
23 * radiance is computed. The '-i' or '-I' options indicate that
24 * irradiance values are desired.
25 */
26
27 #include "ray.h"
28
29 #include "octree.h"
30
31 #include "otypes.h"
32
33 int dimlist[MAXDIM]; /* sampling dimensions */
34 int ndims = 0; /* number of sampling dimensions */
35 int samplendx = 0; /* index for this sample */
36
37 int imm_irrad = 0; /* compute immediate irradiance? */
38
39 int inform = 'a'; /* input format */
40 int outform = 'a'; /* output format */
41 char *outvals = "v"; /* output specification */
42
43 int hresolu = 0; /* horizontal (scan) size */
44 int vresolu = 0; /* vertical resolution */
45
46 double dstrsrc = 0.0; /* square source distribution */
47 double shadthresh = .05; /* shadow threshold */
48 double shadcert = .5; /* shadow certainty */
49 int directrelay = 0; /* number of source relays */
50 int vspretest = 512; /* virtual source pretest density */
51 int directinvis = 0; /* sources invisible? */
52
53 int maxdepth = 6; /* maximum recursion depth */
54 double minweight = 4e-3; /* minimum ray weight */
55
56 COLOR ambval = BLKCOLOR; /* ambient value */
57 double ambacc = 0.2; /* ambient accuracy */
58 int ambres = 32; /* ambient resolution */
59 int ambdiv = 128; /* ambient divisions */
60 int ambssamp = 0; /* ambient super-samples */
61 int ambounce = 0; /* ambient bounces */
62 char *amblist[128]; /* ambient include/exclude list */
63 int ambincl = -1; /* include == 1, exclude == 0 */
64
65 extern OBJREC Lamb; /* a Lambertian surface */
66
67 static RAY thisray; /* for our convenience */
68
69 static int oputo(), oputd(), oputv(), oputl(),
70 oputp(), oputn(), oputs(), oputw(), oputm();
71
72 static int (*ray_out[10])(), (*every_out[10])();
73 static int castonly;
74
75 static int puta(), putf(), putd();
76
77 static int (*putreal)();
78
79
80 quit(code) /* quit program */
81 int code;
82 {
83 exit(code);
84 }
85
86
87 rtrace(fname) /* trace rays from file */
88 char *fname;
89 {
90 long vcount = hresolu>1 ? hresolu*vresolu : vresolu;
91 long nextflush = hresolu;
92 FILE *fp;
93 FVECT orig, direc;
94 /* set up input */
95 if (fname == NULL)
96 fp = stdin;
97 else if ((fp = fopen(fname, "r")) == NULL) {
98 sprintf(errmsg, "cannot open input file \"%s\"", fname);
99 error(SYSTEM, errmsg);
100 }
101 /* set up output */
102 setoutput(outvals);
103 switch (outform) {
104 case 'a': putreal = puta; break;
105 case 'f': putreal = putf; break;
106 case 'd': putreal = putd; break;
107 }
108 /* process file */
109 while (getvec(orig, inform, fp) == 0 &&
110 getvec(direc, inform, fp) == 0) {
111
112 if (normalize(direc) == 0.0) { /* zero ==> flush */
113 fflush(stdout);
114 continue;
115 }
116 samplendx++;
117 /* compute and print */
118 if (imm_irrad)
119 irrad(orig, direc);
120 else
121 traceray(orig, direc);
122 /* flush if time */
123 if (--nextflush == 0) {
124 fflush(stdout);
125 nextflush = hresolu;
126 }
127 if (ferror(stdout))
128 error(SYSTEM, "write error");
129 if (--vcount == 0) /* check for end */
130 break;
131 }
132 if (vcount > 0)
133 error(USER, "read error");
134 fclose(fp);
135 }
136
137
138 setoutput(vs) /* set up output tables */
139 register char *vs;
140 {
141 extern int ourtrace(), (*trace)();
142 register int (**table)() = ray_out;
143
144 castonly = 1;
145 while (*vs)
146 switch (*vs++) {
147 case 't': /* trace */
148 *table = NULL;
149 table = every_out;
150 trace = ourtrace;
151 castonly = 0;
152 break;
153 case 'o': /* origin */
154 *table++ = oputo;
155 break;
156 case 'd': /* direction */
157 *table++ = oputd;
158 break;
159 case 'v': /* value */
160 *table++ = oputv;
161 castonly = 0;
162 break;
163 case 'l': /* length */
164 *table++ = oputl;
165 castonly = 0;
166 break;
167 case 'p': /* point */
168 *table++ = oputp;
169 break;
170 case 'n': /* normal */
171 *table++ = oputn;
172 break;
173 case 's': /* surface */
174 *table++ = oputs;
175 break;
176 case 'w': /* weight */
177 *table++ = oputw;
178 break;
179 case 'm': /* modifier */
180 *table++ = oputm;
181 break;
182 }
183 *table = NULL;
184 }
185
186
187 traceray(org, dir) /* compute and print ray value(s) */
188 FVECT org, dir;
189 {
190 register int (**tp)();
191
192 VCOPY(thisray.rorg, org);
193 VCOPY(thisray.rdir, dir);
194 rayorigin(&thisray, NULL, PRIMARY, 1.0);
195 if (castonly)
196 localhit(&thisray, &thescene) || sourcehit(&thisray);
197 else
198 rayvalue(&thisray);
199
200 if (ray_out[0] == NULL)
201 return;
202 for (tp = ray_out; *tp != NULL; tp++)
203 (**tp)(&thisray);
204 if (outform == 'a')
205 putchar('\n');
206 }
207
208
209 irrad(org, dir) /* compute immediate irradiance value */
210 FVECT org, dir;
211 {
212 register int i;
213
214 for (i = 0; i < 3; i++) {
215 thisray.rorg[i] = org[i] + dir[i];
216 thisray.rdir[i] = -dir[i];
217 }
218 rayorigin(&thisray, NULL, PRIMARY, 1.0);
219 /* pretend we hit surface */
220 thisray.rot = 1.0;
221 thisray.rod = 1.0;
222 VCOPY(thisray.ron, dir);
223 for (i = 0; i < 3; i++) /* fudge factor */
224 thisray.rop[i] = org[i] + 1e-4*dir[i];
225 /* compute and print */
226 (*ofun[Lamb.otype].funp)(&Lamb, &thisray);
227 oputv(&thisray);
228 if (outform == 'a')
229 putchar('\n');
230 }
231
232
233 getvec(vec, fmt, fp) /* get a vector from fp */
234 register FVECT vec;
235 int fmt;
236 FILE *fp;
237 {
238 extern char *fgetword();
239 extern double atof();
240 static float vf[3];
241 char buf[32];
242 register int i;
243
244 switch (fmt) {
245 case 'a': /* ascii */
246 for (i = 0; i < 3; i++) {
247 if (fgetword(buf, sizeof(buf), fp) == NULL ||
248 !isflt(buf))
249 return(-1);
250 vec[i] = atof(buf);
251 }
252 break;
253 case 'f': /* binary float */
254 if (fread((char *)vf, sizeof(float), 3, fp) != 3)
255 return(-1);
256 vec[0] = vf[0]; vec[1] = vf[1]; vec[2] = vf[2];
257 break;
258 case 'd': /* binary double */
259 if (fread((char *)vec, sizeof(double), 3, fp) != 3)
260 return(-1);
261 break;
262 }
263 return(0);
264 }
265
266
267 static
268 ourtrace(r) /* print ray values */
269 RAY *r;
270 {
271 register int (**tp)();
272
273 if (every_out[0] == NULL)
274 return;
275 tabin(r);
276 for (tp = every_out; *tp != NULL; tp++)
277 (**tp)(r);
278 putchar('\n');
279 }
280
281
282 static
283 tabin(r) /* tab in appropriate amount */
284 RAY *r;
285 {
286 register RAY *rp;
287
288 for (rp = r->parent; rp != NULL; rp = rp->parent)
289 putchar('\t');
290 }
291
292
293 static
294 oputo(r) /* print origin */
295 register RAY *r;
296 {
297 (*putreal)(r->rorg[0]);
298 (*putreal)(r->rorg[1]);
299 (*putreal)(r->rorg[2]);
300 }
301
302
303 static
304 oputd(r) /* print direction */
305 register RAY *r;
306 {
307 (*putreal)(r->rdir[0]);
308 (*putreal)(r->rdir[1]);
309 (*putreal)(r->rdir[2]);
310 }
311
312
313 static
314 oputv(r) /* print value */
315 register RAY *r;
316 {
317 (*putreal)(colval(r->rcol,RED));
318 (*putreal)(colval(r->rcol,GRN));
319 (*putreal)(colval(r->rcol,BLU));
320 }
321
322
323 static
324 oputl(r) /* print length */
325 register RAY *r;
326 {
327 (*putreal)(r->rt);
328 }
329
330
331 static
332 oputp(r) /* print point */
333 register RAY *r;
334 {
335 if (r->rot < FHUGE) {
336 (*putreal)(r->rop[0]);
337 (*putreal)(r->rop[1]);
338 (*putreal)(r->rop[2]);
339 } else {
340 (*putreal)(0.0);
341 (*putreal)(0.0);
342 (*putreal)(0.0);
343 }
344 }
345
346
347 static
348 oputn(r) /* print normal */
349 register RAY *r;
350 {
351 if (r->rot < FHUGE) {
352 (*putreal)(r->ron[0]);
353 (*putreal)(r->ron[1]);
354 (*putreal)(r->ron[2]);
355 } else {
356 (*putreal)(0.0);
357 (*putreal)(0.0);
358 (*putreal)(0.0);
359 }
360 }
361
362
363 static
364 oputs(r) /* print name */
365 register RAY *r;
366 {
367 if (r->ro != NULL)
368 fputs(r->ro->oname, stdout);
369 else
370 putchar('*');
371 putchar('\t');
372 }
373
374
375 static
376 oputw(r) /* print weight */
377 register RAY *r;
378 {
379 (*putreal)(r->rweight);
380 }
381
382
383 static
384 oputm(r) /* print modifier */
385 register RAY *r;
386 {
387 if (r->ro != NULL)
388 fputs(objptr(r->ro->omod)->oname, stdout);
389 else
390 putchar('*');
391 putchar('\t');
392 }
393
394
395 static
396 puta(v) /* print ascii value */
397 double v;
398 {
399 printf("%e\t", v);
400 }
401
402
403 static
404 putd(v) /* print binary double */
405 double v;
406 {
407 fwrite((char *)&v, sizeof(v), 1, stdout);
408 }
409
410
411 static
412 putf(v) /* print binary float */
413 double v;
414 {
415 float f = v;
416
417 fwrite((char *)&f, sizeof(f), 1, stdout);
418 }
