--- ray/src/rt/rtrace.c 1992/07/21 10:36:37 2.7 +++ ray/src/rt/rtrace.c 2003/07/21 22:30:19 2.33 @@ -1,15 +1,12 @@ -/* Copyright (c) 1992 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: rtrace.c,v 2.33 2003/07/21 22:30:19 schorsch Exp $"; #endif - /* * rtrace.c - program and variables for individual ray tracing. - * - * 6/11/86 */ +#include "copyright.h" + /* * Input is in the form: * @@ -24,68 +21,98 @@ static char SCCSid[] = "$SunId$ LBL"; * irradiance values are desired. */ -#include "ray.h" +#include -#include "octree.h" - +#include "platform.h" +#include "ray.h" #include "otypes.h" - #include "resolu.h" +CUBE thescene; /* our scene */ +OBJECT nsceneobjs; /* number of objects in our scene */ + int dimlist[MAXDIM]; /* sampling dimensions */ int ndims = 0; /* number of sampling dimensions */ int samplendx = 0; /* index for this sample */ int imm_irrad = 0; /* compute immediate irradiance? */ +int lim_dist = 0; /* limit distance? */ int inform = 'a'; /* input format */ int outform = 'a'; /* output format */ char *outvals = "v"; /* output specification */ +int do_irrad = 0; /* compute irradiance? */ + +void (*trace)() = NULL; /* trace call */ + +extern void ambnotify(), tranotify(); +void (*addobjnotify[])() = {ambnotify, tranotify, NULL}; +char *tralist[128]; /* list of modifers to trace (or no) */ +int traincl = -1; /* include == 1, exclude == 0 */ +#define MAXTSET 511 /* maximum number in trace set */ +OBJECT traset[MAXTSET+1]={0}; /* trace include/exclude set */ + int hresolu = 0; /* horizontal (scan) size */ int vresolu = 0; /* vertical resolution */ double dstrsrc = 0.0; /* square source distribution */ double shadthresh = .05; /* shadow threshold */ double shadcert = .5; /* shadow certainty */ -int directrelay = 1; /* number of source relays */ +int directrelay = 2; /* number of source relays */ int vspretest = 512; /* virtual source pretest density */ -int directinvis = 0; /* sources invisible? */ -double srcsizerat = .25; /* maximum ratio source size/dist. */ +int directvis = 1; /* sources visible? */ +double srcsizerat = .2; /* maximum ratio source size/dist. */ +COLOR cextinction = BLKCOLOR; /* global extinction coefficient */ +COLOR salbedo = BLKCOLOR; /* global scattering albedo */ +double seccg = 0.; /* global scattering eccentricity */ +double ssampdist = 0.; /* scatter sampling distance */ + double specthresh = .15; /* specular sampling threshold */ double specjitter = 1.; /* specular sampling jitter */ +int backvis = 1; /* back face visibility */ + int maxdepth = 6; /* maximum recursion depth */ double minweight = 4e-3; /* minimum ray weight */ +char *ambfile = NULL; /* ambient file name */ COLOR ambval = BLKCOLOR; /* ambient value */ +int ambvwt = 0; /* initial weight for ambient value */ double ambacc = 0.2; /* ambient accuracy */ -int ambres = 32; /* ambient resolution */ -int ambdiv = 128; /* ambient divisions */ +int ambres = 128; /* ambient resolution */ +int ambdiv = 512; /* ambient divisions */ int ambssamp = 0; /* ambient super-samples */ int ambounce = 0; /* ambient bounces */ char *amblist[128]; /* ambient include/exclude list */ int ambincl = -1; /* include == 1, exclude == 0 */ -extern OBJREC Lamb; /* a Lambertian surface */ static RAY thisray; /* for our convenience */ -static int oputo(), oputd(), oputv(), oputl(), oputL(), - oputp(), oputn(), oputs(), oputw(), oputm(); +static void oputo(), oputd(), oputv(), oputl(), oputL(), oputc(), + oputp(), oputn(), oputN(), oputs(), oputw(), oputm(); -static int (*ray_out[10])(), (*every_out[10])(); -static int castonly; +static void ourtrace(), tabin(); +static void (*ray_out[16])(), (*every_out[16])(); +static int castonly = 0; -static int puta(), putf(), putd(); +static void puta(), putf(), putd(); -static int (*putreal)(); +static void (*putreal)(); +void bogusray(), rad(), irrad(), printvals(); + +void quit(code) /* quit program */ int code; { +#ifndef NON_POSIX /* XXX we don't clean up elsewhere? */ + headclean(); /* delete header file */ + pfclean(); /* clean up persist files */ +#endif exit(code); } @@ -104,12 +131,14 @@ int f; } +void rtrace(fname) /* trace rays from file */ char *fname; { long vcount = hresolu>1 ? hresolu*vresolu : vresolu; long nextflush = hresolu; FILE *fp; + double d; FVECT orig, direc; /* set up input */ if (fname == NULL) @@ -118,6 +147,10 @@ char *fname; sprintf(errmsg, "cannot open input file \"%s\"", fname); error(SYSTEM, errmsg); } +#ifdef _WIN32 + if (inform != 'a') + SET_FILE_BINARY(fp); +#endif /* set up output */ setoutput(outvals); switch (outform) { @@ -131,43 +164,53 @@ char *fname; default: error(CONSISTENCY, "botched output format"); } - if (hresolu > 0 && vresolu > 0) - fprtresolu(hresolu, vresolu, stdout); + if (hresolu > 0) { + if (vresolu > 0) + fprtresolu(hresolu, vresolu, stdout); + fflush(stdout); + } /* process file */ while (getvec(orig, inform, fp) == 0 && getvec(direc, inform, fp) == 0) { - if (normalize(direc) == 0.0) { /* zero ==> flush */ - fflush(stdout); - continue; - } - samplendx++; + d = normalize(direc); + if (d == 0.0) { /* zero ==> flush */ + bogusray(); + if (--nextflush <= 0 || vcount <= 0) { + fflush(stdout); + nextflush = hresolu; + } + } else { + samplendx++; /* compute and print */ - if (imm_irrad) - irrad(orig, direc); - else - traceray(orig, direc); + if (imm_irrad) + irrad(orig, direc); + else + rad(orig, direc, lim_dist ? d : 0.0); /* flush if time */ - if (--nextflush == 0) { - fflush(stdout); - nextflush = hresolu; + if (--nextflush == 0) { + fflush(stdout); + nextflush = hresolu; + } } if (ferror(stdout)) error(SYSTEM, "write error"); if (--vcount == 0) /* check for end */ break; } + fflush(stdout); if (vcount > 0) error(USER, "read error"); - fclose(fp); + if (fname != NULL) + fclose(fp); } setoutput(vs) /* set up output tables */ register char *vs; { - extern int ourtrace(), (*trace)(); - register int (**table)() = ray_out; + extern void (*trace)(); + register void (**table)() = ray_out; castonly = 1; while (*vs) @@ -192,15 +235,22 @@ register char *vs; *table++ = oputl; castonly = 0; break; + case 'c': /* local coordinates */ + *table++ = oputc; + break; case 'L': /* single ray length */ *table++ = oputL; break; case 'p': /* point */ *table++ = oputp; break; - case 'n': /* normal */ + case 'n': /* perturbed normal */ *table++ = oputn; + castonly = 0; break; + case 'N': /* unperturbed normal */ + *table++ = oputN; + break; case 's': /* surface */ *table++ = oputs; break; @@ -215,28 +265,40 @@ register char *vs; } -traceray(org, dir) /* compute and print ray value(s) */ -FVECT org, dir; +void +bogusray() /* print out empty record */ { - register int (**tp)(); + thisray.rorg[0] = thisray.rorg[1] = thisray.rorg[2] = + thisray.rdir[0] = thisray.rdir[1] = thisray.rdir[2] = 0.0; + rayorigin(&thisray, NULL, PRIMARY, 1.0); + printvals(&thisray); +} + +void +rad(org, dir, dmax) /* compute and print ray value(s) */ +FVECT org, dir; +double dmax; +{ VCOPY(thisray.rorg, org); VCOPY(thisray.rdir, dir); + thisray.rmax = dmax; rayorigin(&thisray, NULL, PRIMARY, 1.0); - if (castonly) - localhit(&thisray, &thescene) || sourcehit(&thisray); - else + if (castonly) { + if (!localhit(&thisray, &thescene)) { + if (thisray.ro == &Aftplane) { /* clipped */ + thisray.ro = NULL; + thisray.rot = FHUGE; + } else + sourcehit(&thisray); + } + } else rayvalue(&thisray); - - if (ray_out[0] == NULL) - return; - for (tp = ray_out; *tp != NULL; tp++) - (**tp)(&thisray); - if (outform == 'a') - putchar('\n'); + printvals(&thisray); } +void irrad(org, dir) /* compute immediate irradiance value */ FVECT org, dir; { @@ -248,25 +310,38 @@ FVECT org, dir; } rayorigin(&thisray, NULL, PRIMARY, 1.0); /* pretend we hit surface */ - thisray.rot = 1.0; + thisray.rot = 1.0-1e-4; thisray.rod = 1.0; VCOPY(thisray.ron, dir); for (i = 0; i < 3; i++) /* fudge factor */ thisray.rop[i] = org[i] + 1e-4*dir[i]; /* compute and print */ (*ofun[Lamb.otype].funp)(&Lamb, &thisray); - oputv(&thisray); + printvals(&thisray); +} + + +void +printvals(r) /* print requested ray values */ +RAY *r; +{ + register void (**tp)(); + + if (ray_out[0] == NULL) + return; + for (tp = ray_out; *tp != NULL; tp++) + (**tp)(r); if (outform == 'a') putchar('\n'); } +int getvec(vec, fmt, fp) /* get a vector from fp */ register FVECT vec; int fmt; FILE *fp; { - extern char *fgetword(); static float vf[3]; static double vd[3]; char buf[32]; @@ -298,14 +373,47 @@ FILE *fp; } -static +void +tranotify(obj) /* record new modifier */ +OBJECT obj; +{ + static int hitlimit = 0; + register OBJREC *o = objptr(obj); + register char **tralp; + + if (obj == OVOID) { /* starting over */ + traset[0] = 0; + hitlimit = 0; + return; + } + if (hitlimit || !ismodifier(o->otype)) + return; + for (tralp = tralist; *tralp != NULL; tralp++) + if (!strcmp(o->oname, *tralp)) { + if (traset[0] >= MAXTSET) { + error(WARNING, "too many modifiers in trace list"); + hitlimit++; + return; /* should this be fatal? */ + } + insertelem(traset, obj); + return; + } +} + + +static void ourtrace(r) /* print ray values */ RAY *r; { - register int (**tp)(); + register void (**tp)(); if (every_out[0] == NULL) return; + if (r->ro == NULL) { + if (traincl == 1) + return; + } else if (traincl != -1 && traincl != inset(traset, r->ro->omod)) + return; tabin(r); for (tp = every_out; *tp != NULL; tp++) (**tp)(r); @@ -313,7 +421,7 @@ RAY *r; } -static +static void tabin(r) /* tab in appropriate amount */ RAY *r; { @@ -324,9 +432,9 @@ RAY *r; } -static +static void oputo(r) /* print origin */ -register RAY *r; +RAY *r; { (*putreal)(r->rorg[0]); (*putreal)(r->rorg[1]); @@ -334,9 +442,9 @@ register RAY *r; } -static +static void oputd(r) /* print direction */ -register RAY *r; +RAY *r; { (*putreal)(r->rdir[0]); (*putreal)(r->rdir[1]); @@ -344,9 +452,9 @@ register RAY *r; } -static +static void oputv(r) /* print value */ -register RAY *r; +RAY *r; { COLR cout; @@ -363,25 +471,34 @@ register RAY *r; } -static +static void oputl(r) /* print effective distance */ -register RAY *r; +RAY *r; { (*putreal)(r->rt); } -static +static void oputL(r) /* print single ray length */ -register RAY *r; +RAY *r; { (*putreal)(r->rot); } -static +static void +oputc(r) /* print local coordinates */ +RAY *r; +{ + (*putreal)(r->uv[0]); + (*putreal)(r->uv[1]); +} + + +static void oputp(r) /* print point */ -register RAY *r; +RAY *r; { if (r->rot < FHUGE) { (*putreal)(r->rop[0]); @@ -395,9 +512,9 @@ register RAY *r; } -static -oputn(r) /* print normal */ -register RAY *r; +static void +oputN(r) /* print unperturbed normal */ +RAY *r; { if (r->rot < FHUGE) { (*putreal)(r->ron[0]); @@ -411,9 +528,28 @@ register RAY *r; } -static +static void +oputn(r) /* print perturbed normal */ +RAY *r; +{ + FVECT pnorm; + + if (r->rot >= FHUGE) { + (*putreal)(0.0); + (*putreal)(0.0); + (*putreal)(0.0); + return; + } + raynormal(pnorm, r); + (*putreal)(pnorm[0]); + (*putreal)(pnorm[1]); + (*putreal)(pnorm[2]); +} + + +static void oputs(r) /* print name */ -register RAY *r; +RAY *r; { if (r->ro != NULL) fputs(r->ro->oname, stdout); @@ -423,27 +559,30 @@ register RAY *r; } -static +static void oputw(r) /* print weight */ -register RAY *r; +RAY *r; { (*putreal)(r->rweight); } -static +static void oputm(r) /* print modifier */ -register RAY *r; +RAY *r; { if (r->ro != NULL) - fputs(objptr(r->ro->omod)->oname, stdout); + if (r->ro->omod != OVOID) + fputs(objptr(r->ro->omod)->oname, stdout); + else + fputs(VOIDID, stdout); else putchar('*'); putchar('\t'); } -static +static void puta(v) /* print ascii value */ double v; { @@ -451,7 +590,7 @@ double v; } -static +static void putd(v) /* print binary double */ double v; { @@ -459,7 +598,7 @@ double v; } -static +static void putf(v) /* print binary float */ double v; {
