root/radiance/ray/src/rt/rtrace.c
Changes since 2.36: +112 -76 lines
Diff to previous 2.36 , to selected 2.22
Sun Mar 28 16:31:14 2004 UTC (20 years, 1 month ago) by greg
Diff to previous 2.35 , to selected 2.22
Sat Oct 4 14:39:53 2003 UTC (20 years, 6 months ago) by greg
Diff to previous 2.34 , to selected 2.22
More adjustments and corrections to default parameters
Changes since 2.33: +7 -7 lines
Diff to previous 2.33 , to selected 2.22
Changes since 2.32: +3 -2 lines
Diff to previous 2.32 , to selected 2.22
Wed Jul 16 01:32:53 2003 UTC (20 years, 9 months ago) by greg
Changes since 2.31: +3 -1 lines
Diff to previous 2.31 , to selected 2.22
Minor compile fixes
Diff to previous 2.30 , to selected 2.22
Thu Jun 5 19:29:34 2003 UTC (20 years, 10 months ago) by schorsch
Changes since 2.29: +4 -5 lines
Diff to previous 2.29 , to selected 2.22
Fri Apr 18 17:29:22 2003 UTC (21 years ago) by greg
Changes since 2.28: +23 -11 lines
Diff to previous 2.28 , to selected 2.22
Added rtrace -oc option to output local (u,v) coordinates
Changes since 2.27: +1 -56 lines
Diff to previous 2.27 , to selected 2.22
Changes since 2.26: +107 -36 lines
Diff to previous 2.26 , to selected 2.22
Thu Oct 30 11:01:16 1997 UTC (26 years, 6 months ago) by gregl
Diff to previous 2.25 , to selected 2.22
modified code so zero record flushing happens unless -x > 0 && -y > 0
Fri Oct 17 10:14:37 1997 UTC (26 years, 6 months ago) by gregl
Changes since 2.24: +18 -7 lines
Diff to previous 2.24 , to selected 2.22
added -ld boolean option to rtrace for limiting ray distance
Wed Jul 9 11:25:49 1997 UTC (26 years, 9 months ago) by gregl
Changes since 2.23: +26 -13 lines
Diff to previous 2.23 , to selected 2.22
Tue Jan 14 19:54:27 1997 UTC (27 years, 3 months ago) by greg
Changes since 2.22: +4 -1 lines
Diff to previous 2.22
fixed bug in printing void materials.
Revision 2.22 - (view) (download) (annotate) - [selected]
Wed Apr 17 14:02:09 1996 UTC (28 years ago) by greg
Changes since 2.21: +1 -1 lines
Diff to previous 2.21
Wed Feb 14 15:18:12 1996 UTC (28 years, 2 months ago) by greg
Changes since 2.20: +1 -0 lines
Diff to previous 2.20 , to selected 2.22
Fri Dec 8 18:49:12 1995 UTC (28 years, 4 months ago) by greg
Changes since 2.19: +6 -1 lines
Diff to previous 2.19 , to selected 2.22
Mon Aug 21 10:29:20 1995 UTC (28 years, 8 months ago) by greg
Changes since 2.18: +4 -4 lines
Diff to previous 2.18 , to selected 2.22
increase default parameters for more accurate calculations
Wed Dec 21 09:52:00 1994 UTC (29 years, 4 months ago) by greg
Changes since 2.17: +2 -0 lines
Diff to previous 2.17 , to selected 2.22
added -bv option for back face visibility (normally on)
Tue Dec 20 20:18:34 1994 UTC (29 years, 4 months ago) by greg
Changes since 2.16: +2 -1 lines
Diff to previous 2.16 , to selected 2.22
Wed Jul 14 10:38:49 1993 UTC (30 years, 9 months ago) by greg
Changes since 2.15: +22 -20 lines
Diff to previous 2.15 , to selected 2.22
consistency improvements related to -I option
Fri Jun 18 10:14:42 1993 UTC (30 years, 10 months ago) by greg
Changes since 2.14: +31 -0 lines
Diff to previous 2.14 , to selected 2.22
added -ti, -te, -tI and -tE options to rtrace for exclude/include traces
Tue May 4 13:26:52 1993 UTC (31 years ago) by greg
Changes since 2.13: +6 -3 lines
Diff to previous 2.13 , to selected 2.22
made sure that -I option completely overrides -o option
Mon Mar 8 12:37:33 1993 UTC (31 years, 1 month ago) by greg
Diff to previous 2.12 , to selected 2.22
Fri Jan 22 09:51:20 1993 UTC (31 years, 3 months ago) by greg
Changes since 2.11: +8 -3 lines
Diff to previous 2.11 , to selected 2.22
bug fixes and improvements on stdio flushing
Wed Jan 20 15:19:51 1993 UTC (31 years, 3 months ago) by greg
Changes since 2.10: +4 -0 lines
Diff to previous 2.10 , to selected 2.22
Thu Nov 19 20:26:10 1992 UTC (31 years, 5 months ago) by greg
Diff to previous 2.9 , to selected 2.22
changed -di to ! -dv
Fri Nov 6 16:48:32 1992 UTC (31 years, 5 months ago) by greg
Changes since 2.8: +26 -3 lines
Diff to previous 2.8 , to selected 2.22
added -oN for unperturbed surface normal and made -on perturbed
Thu Oct 15 21:13:21 1992 UTC (31 years, 6 months ago) by greg
Changes since 2.7: +4 -0 lines
Diff to previous 2.7 , to selected 2.22
added setmode(fd,O_BINARY) where needed for MSDOS
Tue Jul 21 10:36:37 1992 UTC (31 years, 9 months ago) by greg
Changes since 2.6: +0 -2 lines
Diff to previous 2.6 , to selected 2.22
fixed bug introduced in last change with -h- option of rtrace
Fri Jul 10 14:56:24 1992 UTC (31 years, 9 months ago) by greg
Changes since 2.5: +38 -1 lines
Diff to previous 2.5 , to selected 2.22
added ability to print COLRFMT output of values
Thu Mar 12 09:46:19 1992 UTC (32 years, 1 month ago) by greg
Changes since 2.4: +17 -4 lines
Diff to previous 2.4 , to selected 2.22
added -oL output option for single-ray length
Thu Jan 16 12:05:20 1992 UTC (32 years, 3 months ago) by greg
Diff to previous 2.3 , to selected 2.22
changed default values and handling of specthresh
Tue Jan 14 16:16:07 1992 UTC (32 years, 3 months ago) by greg
Changes since 2.2: +3 -0 lines
Diff to previous 2.2 , to selected 2.22
added -sj and -st options and changed old -s options to -p
Thu Dec 19 14:54:53 1991 UTC (32 years, 4 months ago) by greg
Diff to previous 2.1 , to selected 2.22
removed atof() declarations for NeXT
Tue Nov 12 17:09:39 1991 UTC (32 years, 5 months ago) by greg
Diff to previous 1.20 , to selected 2.22
Mon Oct 21 12:58:10 1991 UTC (32 years, 6 months ago) by greg
Changes since 1.19: +2 -1 lines
Diff to previous 1.19 , to selected 2.22
Mon Jul 22 13:09:58 1991 UTC (32 years, 9 months ago) by greg
Changes since 1.18: +10 -2 lines
Diff to previous 1.18 , to selected 2.22
got rid of scanf() call
Thu Jul 18 14:43:03 1991 UTC (32 years, 9 months ago) by greg
Changes since 1.17: +1 -0 lines
Diff to previous 1.17 , to selected 2.22
Tue Jun 25 14:06:18 1991 UTC (32 years, 10 months ago) by greg
Diff to previous 1.16 , to selected 2.22
increased defaults for -dp parameter
Mon Jun 24 16:16:54 1991 UTC (32 years, 10 months ago) by greg
Changes since 1.15: +1 -0 lines
Diff to previous 1.15 , to selected 2.22
Wed Jun 19 16:36:48 1991 UTC (32 years, 10 months ago) by greg
Changes since 1.14: +1 -0 lines
Diff to previous 1.14 , to selected 2.22
added virtual sources
Tue May 21 17:41:23 1991 UTC (32 years, 11 months ago) by greg
Changes since 1.13: +5 -0 lines
Diff to previous 1.13 , to selected 2.22
Wed May 1 11:16:58 1991 UTC (33 years ago) by greg
Changes since 1.12: +9 -29 lines
Diff to previous 1.12 , to selected 2.22
Thu Mar 28 10:16:35 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.11: +25 -6 lines
Diff to previous 1.11 , to selected 2.22
added -oI option for irradiance after intersection
Sat Aug 18 10:34:47 1990 UTC (33 years, 8 months ago) by greg
Changes since 1.10: +11 -1 lines
Diff to previous 1.10 , to selected 2.22
added conditional ray casting to rtrace for efficiency
Tue Jun 26 09:00:15 1990 UTC (33 years, 10 months ago) by greg
Diff to previous 1.9 , to selected 2.22
Tue Mar 27 11:40:10 1990 UTC (34 years, 1 month ago) by greg
Changes since 1.8: +1 -4 lines
Diff to previous 1.8 , to selected 2.22
Fri Jan 19 00:00:26 1990 UTC (34 years, 3 months ago) by greg
Diff to previous 1.7 , to selected 2.22
Thu Jan 4 11:16:05 1990 UTC (34 years, 4 months ago) by greg
Changes since 1.6: +6 -3 lines
Diff to previous 1.6 , to selected 2.22
added flushing for zero input direction vector
Mon Jul 10 15:21:28 1989 UTC (34 years, 9 months ago) by greg
Diff to previous 1.5 , to selected 2.22
Reduced default ambient resolution
Tue Jun 13 10:57:43 1989 UTC (34 years, 10 months ago) by greg
Diff to previous 1.4 , to selected 2.22
Wed Jun 7 21:00:59 1989 UTC (34 years, 10 months ago) by greg
Diff to previous 1.3 , to selected 2.22
Wed Jun 7 08:35:23 1989 UTC (34 years, 10 months ago) by greg
Diff to previous 1.2 , to selected 2.22
Glow type changed
Spot type eliminated
Wed Mar 15 13:47:57 1989 UTC (35 years, 1 month ago) by greg
Diff to previous 1.1 , to selected 2.22
eliminated unused variable
Thu Feb 2 10:41:37 1989 UTC (35 years, 3 months ago) by greg
Diff to selected 2.22
