root/radiance/ray/src/rt/rtrace.c
Revision: 1.5
Committed: Tue Jun 13 10:57:43 1989 UTC (36 years, 1 month ago) by greg
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * rtrace.c - program and variables for individual ray tracing.
9 *
10 * 6/11/86
11 */
12
13 /*
14 * Input is in the form:
15 *
16 * xorg yorg zorg xdir ydir zdir
17 *
18 * The direction need not be normalized. Output is flexible.
19 * All values default to ascii representation of real
20 * numbers. Binary representations can be selected
21 * with '-ff' for float or '-fd' for double. By default,
22 * radiance is computed. The '-i' option indicates that
23 * irradiance values are desired.
24 */
25
26 #include "ray.h"
27
28 #include "otypes.h"
29
30 int inform = 'a'; /* input format */
31 int outform = 'a'; /* output format */
32 char *outvals = "v"; /* output specification */
33
34 int hresolu = 0; /* horizontal (scan) size */
35 int vresolu = 0; /* vertical resolution */
36
37 double dstrsrc = 0.0; /* square source distribution */
38 double shadthresh = .05; /* shadow threshold */
39 double shadcert = .5; /* shadow certainty */
40
41 int maxdepth = 6; /* maximum recursion depth */
42 double minweight = 4e-3; /* minimum ray weight */
43
44 COLOR ambval = BLKCOLOR; /* ambient value */
45 double ambacc = 0.2; /* ambient accuracy */
46 int ambres = 128; /* ambient resolution */
47 int ambdiv = 128; /* ambient divisions */
48 int ambssamp = 0; /* ambient super-samples */
49 int ambounce = 0; /* ambient bounces */
50 char *amblist[128]; /* ambient include/exclude list */
51 int ambincl = -1; /* include == 1, exclude == 0 */
52
53 static RAY thisray; /* for our convenience */
54
55 extern int oputo(), oputd(), oputv(), oputl(),
56 oputp(), oputn(), oputs(), oputw(), oputm();
57
58 static int (*ray_out[10])(), (*every_out[10])();
59
60 extern int puta(), putf(), putd();
61
62 static int (*putreal)();
63
64
65 quit(code) /* quit program */
66 int code;
67 {
68 exit(code);
69 }
70
71
72 rtrace(fname) /* trace rays from file */
73 char *fname;
74 {
75 long vcount = hresolu>1 ? hresolu*vresolu : vresolu;
76 long nextflush = hresolu;
77 FILE *fp;
78 FVECT orig, direc;
79 /* set up input */
80 if (fname == NULL)
81 fp = stdin;
82 else if ((fp = fopen(fname, "r")) == NULL) {
83 sprintf(errmsg, "cannot open input file \"%s\"", fname);
84 error(SYSTEM, errmsg);
85 }
86 /* set up output */
87 setoutput(outvals);
88 switch (outform) {
89 case 'a': putreal = puta; break;
90 case 'f': putreal = putf; break;
91 case 'd': putreal = putd; break;
92 }
93 /* process file */
94 while (getvec(orig, inform, fp) == 0 &&
95 getvec(direc, inform, fp) == 0) {
96
97 if (normalize(direc) == 0.0)
98 error(USER, "zero direction vector");
99 /* compute and print */
100 if (outvals[0] == 'i')
101 irrad(orig, direc);
102 else
103 radiance(orig, direc);
104 /* flush if requested */
105 if (--nextflush == 0) {
106 fflush(stdout);
107 nextflush = hresolu;
108 }
109 if (ferror(stdout))
110 error(SYSTEM, "write error");
111 if (--vcount == 0) /* check for end */
112 break;
113 }
114 if (vcount > 0)
115 error(USER, "read error");
116 fclose(fp);
117 }
118
119
120 setoutput(vs) /* set up output tables */
121 register char *vs;
122 {
123 extern int ourtrace(), (*trace)();
124 register int (**table)() = ray_out;
125
126 while (*vs)
127 switch (*vs++) {
128 case 't': /* trace */
129 *table = NULL;
130 table = every_out;
131 trace = ourtrace;
132 break;
133 case 'o': /* origin */
134 *table++ = oputo;
135 break;
136 case 'd': /* direction */
137 *table++ = oputd;
138 break;
139 case 'v': /* value */
140 *table++ = oputv;
141 break;
142 case 'l': /* length */
143 *table++ = oputl;
144 break;
145 case 'p': /* point */
146 *table++ = oputp;
147 break;
148 case 'n': /* normal */
149 *table++ = oputn;
150 break;
151 case 's': /* surface */
152 *table++ = oputs;
153 break;
154 case 'w': /* weight */
155 *table++ = oputw;
156 break;
157 case 'm': /* modifier */
158 *table++ = oputm;
159 break;
160 }
161 *table = NULL;
162 }
163
164
165 radiance(org, dir) /* compute radiance value */
166 FVECT org, dir;
167 {
168 register int (**tp)();
169
170 VCOPY(thisray.rorg, org);
171 VCOPY(thisray.rdir, dir);
172 rayorigin(&thisray, NULL, PRIMARY, 1.0);
173 rayvalue(&thisray);
174
175 if (ray_out[0] == NULL)
176 return;
177 for (tp = ray_out; *tp != NULL; tp++)
178 (**tp)(&thisray);
179 if (outform == 'a')
180 putchar('\n');
181 }
182
183
184 irrad(org, dir) /* compute irradiance value */
185 FVECT org, dir;
186 {
187 static double Lambfa[5] = {PI, PI, PI, 0.0, 0.0};
188 static OBJREC Lamb = {
189 OVOID, MAT_PLASTIC, "Lambertian",
190 {0, 5, NULL, Lambfa}, NULL, -1,
191 };
192 register int i;
193
194 for (i = 0; i < 3; i++) {
195 thisray.rorg[i] = org[i] + dir[i];
196 thisray.rdir[i] = -dir[i];
197 }
198 rayorigin(&thisray, NULL, PRIMARY, 1.0);
199 /* pretend we hit surface */
200 thisray.rot = 1.0;
201 thisray.rod = 1.0;
202 VCOPY(thisray.ron, dir);
203 for (i = 0; i < 3; i++) /* fudge factor */
204 thisray.rop[i] = org[i] + 1e-4*dir[i];
205 /* compute and print */
206 (*ofun[Lamb.otype].funp)(&Lamb, &thisray);
207 oputv(&thisray);
208 if (outform == 'a')
209 putchar('\n');
210 }
211
212
213 getvec(vec, fmt, fp) /* get a vector from fp */
214 register FVECT vec;
215 int fmt;
216 FILE *fp;
217 {
218 static float vf[3];
219
220 switch (fmt) {
221 case 'a': /* ascii */
222 if (fscanf(fp, "%lf %lf %lf", vec, vec+1, vec+2) != 3)
223 return(-1);
224 break;
225 case 'f': /* binary float */
226 if (fread(vf, sizeof(float), 3, fp) != 3)
227 return(-1);
228 vec[0] = vf[0]; vec[1] = vf[1]; vec[2] = vf[2];
229 break;
230 case 'd': /* binary double */
231 if (fread(vec, sizeof(double), 3, fp) != 3)
232 return(-1);
233 break;
234 }
235 return(0);
236 }
237
238
239 static
240 ourtrace(r) /* print ray values */
241 RAY *r;
242 {
243 register int (**tp)();
244
245 if (every_out[0] == NULL)
246 return;
247 tabin(r);
248 for (tp = every_out; *tp != NULL; tp++)
249 (**tp)(r);
250 putchar('\n');
251 }
252
253
254 static
255 tabin(r) /* tab in appropriate amount */
256 RAY *r;
257 {
258 register RAY *rp;
259
260 for (rp = r->parent; rp != NULL; rp = rp->parent)
261 putchar('\t');
262 }
263
264
265 static
266 oputo(r) /* print origin */
267 register RAY *r;
268 {
269 (*putreal)(r->rorg[0]);
270 (*putreal)(r->rorg[1]);
271 (*putreal)(r->rorg[2]);
272 }
273
274
275 static
276 oputd(r) /* print direction */
277 register RAY *r;
278 {
279 (*putreal)(r->rdir[0]);
280 (*putreal)(r->rdir[1]);
281 (*putreal)(r->rdir[2]);
282 }
283
284
285 static
286 oputv(r) /* print value */
287 register RAY *r;
288 {
289 (*putreal)(colval(r->rcol,RED));
290 (*putreal)(colval(r->rcol,GRN));
291 (*putreal)(colval(r->rcol,BLU));
292 }
293
294
295 static
296 oputl(r) /* print length */
297 register RAY *r;
298 {
299 if (r->rot < FHUGE)
300 (*putreal)(r->rot);
301 else
302 (*putreal)(0.0);
303 }
304
305
306 static
307 oputp(r) /* print point */
308 register RAY *r;
309 {
310 if (r->rot < FHUGE) {
311 (*putreal)(r->rop[0]);
312 (*putreal)(r->rop[1]);
313 (*putreal)(r->rop[2]);
314 } else {
315 (*putreal)(0.0);
316 (*putreal)(0.0);
317 (*putreal)(0.0);
318 }
319 }
320
321
322 static
323 oputn(r) /* print normal */
324 register RAY *r;
325 {
326 if (r->rot < FHUGE) {
327 (*putreal)(r->ron[0]);
328 (*putreal)(r->ron[1]);
329 (*putreal)(r->ron[2]);
330 } else {
331 (*putreal)(0.0);
332 (*putreal)(0.0);
333 (*putreal)(0.0);
334 }
335 }
336
337
338 static
339 oputs(r) /* print name */
340 register RAY *r;
341 {
342 if (r->ro != NULL)
343 fputs(r->ro->oname, stdout);
344 else
345 putchar('*');
346 putchar('\t');
347 }
348
349
350 static
351 oputw(r) /* print weight */
352 register RAY *r;
353 {
354 (*putreal)(r->rweight);
355 }
356
357
358 static
359 oputm(r) /* print modifier */
360 register RAY *r;
361 {
362 if (r->ro != NULL)
363 fputs(objptr(r->ro->omod)->oname, stdout);
364 else
365 putchar('*');
366 putchar('\t');
367 }
368
369
370 static
371 puta(v) /* print ascii value */
372 double v;
373 {
374 printf("%e\t", v);
375 }
376
377
378 static
379 putd(v) /* print binary double */
380 double v;
381 {
382 fwrite(&v, sizeof(v), 1, stdout);
383 }
384
385
386 static
387 putf(v) /* print binary float */
388 double v;
389 {
390 float f = v;
391
392 fwrite(&f, sizeof(f), 1, stdout);
393 }
