--- ray/src/rt/rtrace.c 1994/12/20 20:18:34 2.17 +++ ray/src/rt/rtrace.c 2003/02/25 02:47:23 2.28 @@ -1,15 +1,12 @@ -/* Copyright (c) 1994 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: rtrace.c,v 2.28 2003/02/25 02:47:23 greg Exp $"; #endif - /* * rtrace.c - program and variables for individual ray tracing. - * - * 6/11/86 */ +#include "copyright.h" + /* * Input is in the form: * @@ -26,22 +23,30 @@ static char SCCSid[] = "$SunId$ LBL"; #include "ray.h" -#include "octree.h" - #include "otypes.h" #include "resolu.h" +CUBE thescene; /* our scene */ +OBJECT nsceneobjs; /* number of objects in our scene */ + int dimlist[MAXDIM]; /* sampling dimensions */ int ndims = 0; /* number of sampling dimensions */ int samplendx = 0; /* index for this sample */ int imm_irrad = 0; /* compute immediate irradiance? */ +int lim_dist = 0; /* limit distance? */ int inform = 'a'; /* input format */ int outform = 'a'; /* output format */ char *outvals = "v"; /* output specification */ +int do_irrad = 0; /* compute irradiance? */ + +void (*trace)() = NULL; /* trace call */ + +extern void ambnotify(), tranotify(); +void (*addobjnotify[])() = {ambnotify, tranotify, NULL}; char *tralist[128]; /* list of modifers to trace (or no) */ int traincl = -1; /* include == 1, exclude == 0 */ #define MAXTSET 511 /* maximum number in trace set */ @@ -53,42 +58,53 @@ int vresolu = 0; /* vertical resolution */ double dstrsrc = 0.0; /* square source distribution */ double shadthresh = .05; /* shadow threshold */ double shadcert = .5; /* shadow certainty */ -int directrelay = 1; /* number of source relays */ +int directrelay = 2; /* number of source relays */ int vspretest = 512; /* virtual source pretest density */ int directvis = 1; /* sources visible? */ -double srcsizerat = .25; /* maximum ratio source size/dist. */ +double srcsizerat = .2; /* maximum ratio source size/dist. */ +COLOR cextinction = BLKCOLOR; /* global extinction coefficient */ +COLOR salbedo = BLKCOLOR; /* global scattering albedo */ +double seccg = 0.; /* global scattering eccentricity */ +double ssampdist = 0.; /* scatter sampling distance */ + double specthresh = .15; /* specular sampling threshold */ double specjitter = 1.; /* specular sampling jitter */ +int backvis = 1; /* back face visibility */ + int maxdepth = 6; /* maximum recursion depth */ double minweight = 4e-3; /* minimum ray weight */ +char *ambfile = NULL; /* ambient file name */ COLOR ambval = BLKCOLOR; /* ambient value */ +int ambvwt = 0; /* initial weight for ambient value */ double ambacc = 0.2; /* ambient accuracy */ -int ambres = 32; /* ambient resolution */ -int ambdiv = 128; /* ambient divisions */ +int ambres = 128; /* ambient resolution */ +int ambdiv = 512; /* ambient divisions */ int ambssamp = 0; /* ambient super-samples */ int ambounce = 0; /* ambient bounces */ char *amblist[128]; /* ambient include/exclude list */ int ambincl = -1; /* include == 1, exclude == 0 */ -extern OBJREC Lamb; /* a Lambertian surface */ static RAY thisray; /* for our convenience */ -static int oputo(), oputd(), oputv(), oputl(), oputL(), +static void oputo(), oputd(), oputv(), oputl(), oputL(), oputp(), oputn(), oputN(), oputs(), oputw(), oputm(); -static int ourtrace(), tabin(); -static int (*ray_out[16])(), (*every_out[16])(); +static void ourtrace(), tabin(); +static void (*ray_out[16])(), (*every_out[16])(); static int castonly = 0; -static int puta(), putf(), putd(); +static void puta(), putf(), putd(); -static int (*putreal)(); +static void (*putreal)(); +void bogusray(), rad(), irrad(), printvals(); + +void quit(code) /* quit program */ int code; { @@ -114,12 +130,14 @@ int f; } +void rtrace(fname) /* trace rays from file */ char *fname; { long vcount = hresolu>1 ? hresolu*vresolu : vresolu; long nextflush = hresolu; FILE *fp; + double d; FVECT orig, direc; /* set up input */ if (fname == NULL) @@ -154,20 +172,25 @@ char *fname; while (getvec(orig, inform, fp) == 0 && getvec(direc, inform, fp) == 0) { - if (normalize(direc) == 0.0) { /* zero ==> flush */ - fflush(stdout); - continue; - } - samplendx++; + d = normalize(direc); + if (d == 0.0) { /* zero ==> flush */ + bogusray(); + if (--nextflush <= 0 || vcount <= 0) { + fflush(stdout); + nextflush = hresolu; + } + } else { + samplendx++; /* compute and print */ - if (imm_irrad) - irrad(orig, direc); - else - rad(orig, direc); + if (imm_irrad) + irrad(orig, direc); + else + rad(orig, direc, lim_dist ? d : 0.0); /* flush if time */ - if (--nextflush == 0) { - fflush(stdout); - nextflush = hresolu; + if (--nextflush == 0) { + fflush(stdout); + nextflush = hresolu; + } } if (ferror(stdout)) error(SYSTEM, "write error"); @@ -185,8 +208,8 @@ char *fname; setoutput(vs) /* set up output tables */ register char *vs; { - extern int (*trace)(); - register int (**table)() = ray_out; + extern void (*trace)(); + register void (**table)() = ray_out; castonly = 1; while (*vs) @@ -238,21 +261,39 @@ register char *vs; } -rad(org, dir) /* compute and print ray value(s) */ +void +bogusray() /* print out empty record */ +{ + thisray.rorg[0] = thisray.rorg[1] = thisray.rorg[2] = + thisray.rdir[0] = thisray.rdir[1] = thisray.rdir[2] = 0.0; + rayorigin(&thisray, NULL, PRIMARY, 1.0); + printvals(&thisray); +} + + +void +rad(org, dir, dmax) /* compute and print ray value(s) */ FVECT org, dir; +double dmax; { VCOPY(thisray.rorg, org); VCOPY(thisray.rdir, dir); - thisray.rmax = 0.0; + thisray.rmax = dmax; rayorigin(&thisray, NULL, PRIMARY, 1.0); - if (castonly) - localhit(&thisray, &thescene) || sourcehit(&thisray); - else + if (castonly) { + if (!localhit(&thisray, &thescene)) + if (thisray.ro == &Aftplane) { /* clipped */ + thisray.ro = NULL; + thisray.rot = FHUGE; + } else + sourcehit(&thisray); + } else rayvalue(&thisray); printvals(&thisray); } +void irrad(org, dir) /* compute immediate irradiance value */ FVECT org, dir; { @@ -275,10 +316,11 @@ FVECT org, dir; } +void printvals(r) /* print requested ray values */ RAY *r; { - register int (**tp)(); + register void (**tp)(); if (ray_out[0] == NULL) return; @@ -289,12 +331,12 @@ RAY *r; } +int getvec(vec, fmt, fp) /* get a vector from fp */ register FVECT vec; int fmt; FILE *fp; { - extern char *fgetword(); static float vf[3]; static double vd[3]; char buf[32]; @@ -326,6 +368,7 @@ FILE *fp; } +void tranotify(obj) /* record new modifier */ OBJECT obj; { @@ -333,6 +376,11 @@ OBJECT obj; register OBJREC *o = objptr(obj); register char **tralp; + if (obj == OVOID) { /* starting over */ + traset[0] = 0; + hitlimit = 0; + return; + } if (hitlimit || !ismodifier(o->otype)) return; for (tralp = tralist; *tralp != NULL; tralp++) @@ -348,11 +396,11 @@ OBJECT obj; } -static +static void ourtrace(r) /* print ray values */ RAY *r; { - register int (**tp)(); + register void (**tp)(); if (every_out[0] == NULL) return; @@ -368,7 +416,7 @@ RAY *r; } -static +static void tabin(r) /* tab in appropriate amount */ RAY *r; { @@ -379,7 +427,7 @@ RAY *r; } -static +static void oputo(r) /* print origin */ register RAY *r; { @@ -389,7 +437,7 @@ register RAY *r; } -static +static void oputd(r) /* print direction */ register RAY *r; { @@ -399,7 +447,7 @@ register RAY *r; } -static +static void oputv(r) /* print value */ register RAY *r; { @@ -418,7 +466,7 @@ register RAY *r; } -static +static void oputl(r) /* print effective distance */ register RAY *r; { @@ -426,7 +474,7 @@ register RAY *r; } -static +static void oputL(r) /* print single ray length */ register RAY *r; { @@ -434,7 +482,7 @@ register RAY *r; } -static +static void oputp(r) /* print point */ register RAY *r; { @@ -450,7 +498,7 @@ register RAY *r; } -static +static void oputN(r) /* print unperturbed normal */ register RAY *r; { @@ -466,7 +514,7 @@ register RAY *r; } -static +static void oputn(r) /* print perturbed normal */ RAY *r; { @@ -485,7 +533,7 @@ RAY *r; } -static +static void oputs(r) /* print name */ register RAY *r; { @@ -497,7 +545,7 @@ register RAY *r; } -static +static void oputw(r) /* print weight */ register RAY *r; { @@ -505,19 +553,22 @@ register RAY *r; } -static +static void oputm(r) /* print modifier */ register RAY *r; { if (r->ro != NULL) - fputs(objptr(r->ro->omod)->oname, stdout); + if (r->ro->omod != OVOID) + fputs(objptr(r->ro->omod)->oname, stdout); + else + fputs(VOIDID, stdout); else putchar('*'); putchar('\t'); } -static +static void puta(v) /* print ascii value */ double v; { @@ -525,7 +576,7 @@ double v; } -static +static void putd(v) /* print binary double */ double v; { @@ -533,7 +584,7 @@ double v; } -static +static void putf(v) /* print binary float */ double v; {
