root/radiance/ray/src/rt/rtrace.c
Revision: 2.26
Committed: Thu Oct 30 11:01:16 1997 UTC (26 years, 7 months ago) by gregl
modified code so zero record flushing happens unless -x > 0 && -y > 0
1 /* Copyright (c) 1997 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * rtrace.c - program and variables for individual ray tracing.
9 *
10 * 6/11/86
11 */
12
13 /*
14 * Input is in the form:
15 *
16 * xorg yorg zorg xdir ydir zdir
17 *
18 * The direction need not be normalized. Output is flexible.
19 * If the direction vector is (0,0,0), then the output is flushed.
20 * All values default to ascii representation of real
21 * numbers. Binary representations can be selected
22 * with '-ff' for float or '-fd' for double. By default,
23 * radiance is computed. The '-i' or '-I' options indicate that
24 * irradiance values are desired.
25 */
26
27 #include "ray.h"
28
29 #include "octree.h"
30
31 #include "otypes.h"
32
33 #include "resolu.h"
34
35 int dimlist[MAXDIM]; /* sampling dimensions */
36 int ndims = 0; /* number of sampling dimensions */
37 int samplendx = 0; /* index for this sample */
38
39 int imm_irrad = 0; /* compute immediate irradiance? */
40 int lim_dist = 0; /* limit distance? */
41
42 int inform = 'a'; /* input format */
43 int outform = 'a'; /* output format */
44 char *outvals = "v"; /* output specification */
45
46 char *tralist[128]; /* list of modifers to trace (or no) */
47 int traincl = -1; /* include == 1, exclude == 0 */
48 #define MAXTSET 511 /* maximum number in trace set */
49 OBJECT traset[MAXTSET+1]={0}; /* trace include/exclude set */
50
51 int hresolu = 0; /* horizontal (scan) size */
52 int vresolu = 0; /* vertical resolution */
53
54 double dstrsrc = 0.0; /* square source distribution */
55 double shadthresh = .05; /* shadow threshold */
56 double shadcert = .5; /* shadow certainty */
57 int directrelay = 2; /* number of source relays */
58 int vspretest = 512; /* virtual source pretest density */
59 int directvis = 1; /* sources visible? */
60 double srcsizerat = .2; /* maximum ratio source size/dist. */
61
62 COLOR cextinction = BLKCOLOR; /* global extinction coefficient */
63 COLOR salbedo = BLKCOLOR; /* global scattering albedo */
64 double seccg = 0.; /* global scattering eccentricity */
65 double ssampdist = 0.; /* scatter sampling distance */
66
67 double specthresh = .15; /* specular sampling threshold */
68 double specjitter = 1.; /* specular sampling jitter */
69
70 int backvis = 1; /* back face visibility */
71
72 int maxdepth = 6; /* maximum recursion depth */
73 double minweight = 4e-3; /* minimum ray weight */
74
75 COLOR ambval = BLKCOLOR; /* ambient value */
76 int ambvwt = 0; /* initial weight for ambient value */
77 double ambacc = 0.2; /* ambient accuracy */
78 int ambres = 128; /* ambient resolution */
79 int ambdiv = 512; /* ambient divisions */
80 int ambssamp = 0; /* ambient super-samples */
81 int ambounce = 0; /* ambient bounces */
82 char *amblist[128]; /* ambient include/exclude list */
83 int ambincl = -1; /* include == 1, exclude == 0 */
84
85 extern OBJREC Lamb; /* a Lambertian surface */
86 extern OBJREC Aftplane; /* aft clipping object */
87
88
89 static RAY thisray; /* for our convenience */
90
91 static int oputo(), oputd(), oputv(), oputl(), oputL(),
92 oputp(), oputn(), oputN(), oputs(), oputw(), oputm();
93
94 static int ourtrace(), tabin();
95 static int (*ray_out[16])(), (*every_out[16])();
96 static int castonly = 0;
97
98 static int puta(), putf(), putd();
99
100 static int (*putreal)();
101
102
103 quit(code) /* quit program */
104 int code;
105 {
106 #ifndef NIX
107 headclean(); /* delete header file */
108 pfclean(); /* clean up persist files */
109 #endif
110 exit(code);
111 }
112
113
114 char *
115 formstr(f) /* return format identifier */
116 int f;
117 {
118 switch (f) {
119 case 'a': return("ascii");
120 case 'f': return("float");
121 case 'd': return("double");
122 case 'c': return(COLRFMT);
123 }
124 return("unknown");
125 }
126
127
128 rtrace(fname) /* trace rays from file */
129 char *fname;
130 {
131 long vcount = hresolu>1 ? hresolu*vresolu : vresolu;
132 long nextflush = hresolu;
133 FILE *fp;
134 double d;
135 FVECT orig, direc;
136 /* set up input */
137 if (fname == NULL)
138 fp = stdin;
139 else if ((fp = fopen(fname, "r")) == NULL) {
140 sprintf(errmsg, "cannot open input file \"%s\"", fname);
141 error(SYSTEM, errmsg);
142 }
143 #ifdef MSDOS
144 if (inform != 'a')
145 setmode(fileno(fp), O_BINARY);
146 #endif
147 /* set up output */
148 setoutput(outvals);
149 switch (outform) {
150 case 'a': putreal = puta; break;
151 case 'f': putreal = putf; break;
152 case 'd': putreal = putd; break;
153 case 'c':
154 if (strcmp(outvals, "v"))
155 error(USER, "color format with value output only");
156 break;
157 default:
158 error(CONSISTENCY, "botched output format");
159 }
160 if (hresolu > 0) {
161 if (vresolu > 0)
162 fprtresolu(hresolu, vresolu, stdout);
163 fflush(stdout);
164 }
165 /* process file */
166 while (getvec(orig, inform, fp) == 0 &&
167 getvec(direc, inform, fp) == 0) {
168
169 d = normalize(direc);
170 if (d == 0.0) { /* zero ==> flush */
171 bogusray();
172 if (--nextflush <= 0 || vcount <= 0) {
173 fflush(stdout);
174 nextflush = hresolu;
175 }
176 } else {
177 samplendx++;
178 /* compute and print */
179 if (imm_irrad)
180 irrad(orig, direc);
181 else
182 rad(orig, direc, lim_dist ? d : 0.0);
183 /* flush if time */
184 if (--nextflush == 0) {
185 fflush(stdout);
186 nextflush = hresolu;
187 }
188 }
189 if (ferror(stdout))
190 error(SYSTEM, "write error");
191 if (--vcount == 0) /* check for end */
192 break;
193 }
194 fflush(stdout);
195 if (vcount > 0)
196 error(USER, "read error");
197 if (fname != NULL)
198 fclose(fp);
199 }
200
201
202 setoutput(vs) /* set up output tables */
203 register char *vs;
204 {
205 extern int (*trace)();
206 register int (**table)() = ray_out;
207
208 castonly = 1;
209 while (*vs)
210 switch (*vs++) {
211 case 't': /* trace */
212 *table = NULL;
213 table = every_out;
214 trace = ourtrace;
215 castonly = 0;
216 break;
217 case 'o': /* origin */
218 *table++ = oputo;
219 break;
220 case 'd': /* direction */
221 *table++ = oputd;
222 break;
223 case 'v': /* value */
224 *table++ = oputv;
225 castonly = 0;
226 break;
227 case 'l': /* effective distance */
228 *table++ = oputl;
229 castonly = 0;
230 break;
231 case 'L': /* single ray length */
232 *table++ = oputL;
233 break;
234 case 'p': /* point */
235 *table++ = oputp;
236 break;
237 case 'n': /* perturbed normal */
238 *table++ = oputn;
239 castonly = 0;
240 break;
241 case 'N': /* unperturbed normal */
242 *table++ = oputN;
243 break;
244 case 's': /* surface */
245 *table++ = oputs;
246 break;
247 case 'w': /* weight */
248 *table++ = oputw;
249 break;
250 case 'm': /* modifier */
251 *table++ = oputm;
252 break;
253 }
254 *table = NULL;
255 }
256
257
258 bogusray() /* print out empty record */
259 {
260 thisray.rorg[0] = thisray.rorg[1] = thisray.rorg[2] =
261 thisray.rdir[0] = thisray.rdir[1] = thisray.rdir[2] = 0.0;
262 rayorigin(&thisray, NULL, PRIMARY, 1.0);
263 printvals(&thisray);
264 }
265
266
267 rad(org, dir, dmax) /* compute and print ray value(s) */
268 FVECT org, dir;
269 double dmax;
270 {
271 VCOPY(thisray.rorg, org);
272 VCOPY(thisray.rdir, dir);
273 thisray.rmax = dmax;
274 rayorigin(&thisray, NULL, PRIMARY, 1.0);
275 if (castonly) {
276 if (!localhit(&thisray, &thescene))
277 if (thisray.ro == &Aftplane) { /* clipped */
278 thisray.ro = NULL;
279 thisray.rot = FHUGE;
280 } else
281 sourcehit(&thisray);
282 } else
283 rayvalue(&thisray);
284 printvals(&thisray);
285 }
286
287
288 irrad(org, dir) /* compute immediate irradiance value */
289 FVECT org, dir;
290 {
291 register int i;
292
293 for (i = 0; i < 3; i++) {
294 thisray.rorg[i] = org[i] + dir[i];
295 thisray.rdir[i] = -dir[i];
296 }
297 rayorigin(&thisray, NULL, PRIMARY, 1.0);
298 /* pretend we hit surface */
299 thisray.rot = 1.0-1e-4;
300 thisray.rod = 1.0;
301 VCOPY(thisray.ron, dir);
302 for (i = 0; i < 3; i++) /* fudge factor */
303 thisray.rop[i] = org[i] + 1e-4*dir[i];
304 /* compute and print */
305 (*ofun[Lamb.otype].funp)(&Lamb, &thisray);
306 printvals(&thisray);
307 }
308
309
310 printvals(r) /* print requested ray values */
311 RAY *r;
312 {
313 register int (**tp)();
314
315 if (ray_out[0] == NULL)
316 return;
317 for (tp = ray_out; *tp != NULL; tp++)
318 (**tp)(r);
319 if (outform == 'a')
320 putchar('\n');
321 }
322
323
324 getvec(vec, fmt, fp) /* get a vector from fp */
325 register FVECT vec;
326 int fmt;
327 FILE *fp;
328 {
329 extern char *fgetword();
330 static float vf[3];
331 static double vd[3];
332 char buf[32];
333 register int i;
334
335 switch (fmt) {
336 case 'a': /* ascii */
337 for (i = 0; i < 3; i++) {
338 if (fgetword(buf, sizeof(buf), fp) == NULL ||
339 !isflt(buf))
340 return(-1);
341 vec[i] = atof(buf);
342 }
343 break;
344 case 'f': /* binary float */
345 if (fread((char *)vf, sizeof(float), 3, fp) != 3)
346 return(-1);
347 vec[0] = vf[0]; vec[1] = vf[1]; vec[2] = vf[2];
348 break;
349 case 'd': /* binary double */
350 if (fread((char *)vd, sizeof(double), 3, fp) != 3)
351 return(-1);
352 vec[0] = vd[0]; vec[1] = vd[1]; vec[2] = vd[2];
353 break;
354 default:
355 error(CONSISTENCY, "botched input format");
356 }
357 return(0);
358 }
359
360
361 tranotify(obj) /* record new modifier */
362 OBJECT obj;
363 {
364 static int hitlimit = 0;
365 register OBJREC *o = objptr(obj);
366 register char **tralp;
367
368 if (hitlimit || !ismodifier(o->otype))
369 return;
370 for (tralp = tralist; *tralp != NULL; tralp++)
371 if (!strcmp(o->oname, *tralp)) {
372 if (traset[0] >= MAXTSET) {
373 error(WARNING, "too many modifiers in trace list");
374 hitlimit++;
375 return; /* should this be fatal? */
376 }
377 insertelem(traset, obj);
378 return;
379 }
380 }
381
382
383 static
384 ourtrace(r) /* print ray values */
385 RAY *r;
386 {
387 register int (**tp)();
388
389 if (every_out[0] == NULL)
390 return;
391 if (r->ro == NULL) {
392 if (traincl == 1)
393 return;
394 } else if (traincl != -1 && traincl != inset(traset, r->ro->omod))
395 return;
396 tabin(r);
397 for (tp = every_out; *tp != NULL; tp++)
398 (**tp)(r);
399 putchar('\n');
400 }
401
402
403 static
404 tabin(r) /* tab in appropriate amount */
405 RAY *r;
406 {
407 register RAY *rp;
408
409 for (rp = r->parent; rp != NULL; rp = rp->parent)
410 putchar('\t');
411 }
412
413
414 static
415 oputo(r) /* print origin */
416 register RAY *r;
417 {
418 (*putreal)(r->rorg[0]);
419 (*putreal)(r->rorg[1]);
420 (*putreal)(r->rorg[2]);
421 }
422
423
424 static
425 oputd(r) /* print direction */
426 register RAY *r;
427 {
428 (*putreal)(r->rdir[0]);
429 (*putreal)(r->rdir[1]);
430 (*putreal)(r->rdir[2]);
431 }
432
433
434 static
435 oputv(r) /* print value */
436 register RAY *r;
437 {
438 COLR cout;
439
440 if (outform == 'c') {
441 setcolr(cout, colval(r->rcol,RED),
442 colval(r->rcol,GRN),
443 colval(r->rcol,BLU));
444 fwrite((char *)cout, sizeof(cout), 1, stdout);
445 return;
446 }
447 (*putreal)(colval(r->rcol,RED));
448 (*putreal)(colval(r->rcol,GRN));
449 (*putreal)(colval(r->rcol,BLU));
450 }
451
452
453 static
454 oputl(r) /* print effective distance */
455 register RAY *r;
456 {
457 (*putreal)(r->rt);
458 }
459
460
461 static
462 oputL(r) /* print single ray length */
463 register RAY *r;
464 {
465 (*putreal)(r->rot);
466 }
467
468
469 static
470 oputp(r) /* print point */
471 register RAY *r;
472 {
473 if (r->rot < FHUGE) {
474 (*putreal)(r->rop[0]);
475 (*putreal)(r->rop[1]);
476 (*putreal)(r->rop[2]);
477 } else {
478 (*putreal)(0.0);
479 (*putreal)(0.0);
480 (*putreal)(0.0);
481 }
482 }
483
484
485 static
486 oputN(r) /* print unperturbed normal */
487 register RAY *r;
488 {
489 if (r->rot < FHUGE) {
490 (*putreal)(r->ron[0]);
491 (*putreal)(r->ron[1]);
492 (*putreal)(r->ron[2]);
493 } else {
494 (*putreal)(0.0);
495 (*putreal)(0.0);
496 (*putreal)(0.0);
497 }
498 }
499
500
501 static
502 oputn(r) /* print perturbed normal */
503 RAY *r;
504 {
505 FVECT pnorm;
506
507 if (r->rot >= FHUGE) {
508 (*putreal)(0.0);
509 (*putreal)(0.0);
510 (*putreal)(0.0);
511 return;
512 }
513 raynormal(pnorm, r);
514 (*putreal)(pnorm[0]);
515 (*putreal)(pnorm[1]);
516 (*putreal)(pnorm[2]);
517 }
518
519
520 static
521 oputs(r) /* print name */
522 register RAY *r;
523 {
524 if (r->ro != NULL)
525 fputs(r->ro->oname, stdout);
526 else
527 putchar('*');
528 putchar('\t');
529 }
530
531
532 static
533 oputw(r) /* print weight */
534 register RAY *r;
535 {
536 (*putreal)(r->rweight);
537 }
538
539
540 static
541 oputm(r) /* print modifier */
542 register RAY *r;
543 {
544 if (r->ro != NULL)
545 if (r->ro->omod != OVOID)
546 fputs(objptr(r->ro->omod)->oname, stdout);
547 else
548 fputs(VOIDID, stdout);
549 else
550 putchar('*');
551 putchar('\t');
552 }
553
554
555 static
556 puta(v) /* print ascii value */
557 double v;
558 {
559 printf("%e\t", v);
560 }
561
562
563 static
564 putd(v) /* print binary double */
565 double v;
566 {
567 fwrite((char *)&v, sizeof(v), 1, stdout);
568 }
569
570
571 static
572 putf(v) /* print binary float */
573 double v;
574 {
575 float f = v;
576
577 fwrite((char *)&f, sizeof(f), 1, stdout);
578 }
