--- ray/src/rt/rtrace.c 2012/06/09 07:16:47 2.66 +++ ray/src/rt/rtrace.c 2020/03/04 01:23:31 2.87 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rtrace.c,v 2.66 2012/06/09 07:16:47 greg Exp $"; +static const char RCSid[] = "$Id: rtrace.c,v 2.87 2020/03/04 01:23:31 greg Exp $"; #endif /* * rtrace.c - program and variables for individual ray tracing. @@ -28,6 +28,7 @@ static const char RCSid[] = "$Id: rtrace.c,v 2.66 2012 #include "ambient.h" #include "source.h" #include "otypes.h" +#include "otspecial.h" #include "resolu.h" #include "random.h" @@ -54,11 +55,12 @@ OBJECT traset[MAXTSET+1]={0}; /* trace include/exclud static RAY thisray; /* for our convenience */ typedef void putf_t(RREAL *v, int n); -static putf_t puta, putd, putf; +static putf_t puta, putd, putf, putrgbe; typedef void oputf_t(RAY *r); static oputf_t oputo, oputd, oputv, oputV, oputl, oputL, oputc, oputp, - oputn, oputN, oputs, oputw, oputW, oputm, oputM, oputtilde; + oputr, oputR, oputx, oputX, oputn, oputN, oputs, + oputw, oputW, oputm, oputM, oputtilde; static void setoutput(char *vs); extern void tranotify(OBJECT obj); @@ -71,7 +73,7 @@ static int getvec(FVECT vec, int fmt, FILE *fp); static void tabin(RAY *r); static void ourtrace(RAY *r); -static oputf_t *ray_out[16], *every_out[16]; +static oputf_t *ray_out[32], *every_out[32]; static putf_t *putreal; @@ -115,7 +117,8 @@ rtrace( /* trace rays from file */ { unsigned long vcount = (hresolu > 1) ? (unsigned long)hresolu*vresolu : (unsigned long)vresolu; - long nextflush = (vresolu > 0) & (hresolu > 1) ? 0 : hresolu; + long nextflush = (!vresolu | (hresolu <= 1)) * hresolu; + int something2flush = 0; FILE *fp; double d; FVECT orig, direc; @@ -134,14 +137,18 @@ rtrace( /* trace rays from file */ castonly = 0; else if (castonly) nproc = 1; /* don't bother multiprocessing */ + if ((nextflush > 0) & (nproc > nextflush)) { + error(WARNING, "reducing number of processes to match flush interval"); + nproc = nextflush; + } switch (outform) { case 'a': putreal = puta; break; case 'f': putreal = putf; break; case 'd': putreal = putd; break; case 'c': - if (strcmp(outvals, "v")) - error(USER, "color format with value output only"); - break; + if (outvals[0] && (outvals[1] || !strchr("vrx", outvals[0]))) + error(USER, "color format only with -ov, -or, -ox"); + putreal = putrgbe; break; default: error(CONSISTENCY, "botched output format"); } @@ -152,39 +159,41 @@ rtrace( /* trace rays from file */ if (hresolu > 0) { if (vresolu > 0) fprtresolu(hresolu, vresolu, stdout); - fflush(stdout); + else + fflush(stdout); } /* process file */ while (getvec(orig, inform, fp) == 0 && getvec(direc, inform, fp) == 0) { d = normalize(direc); - if (d == 0.0) { /* zero ==> flush */ - if (--nextflush <= 0 || !vcount) { - if (nproc > 1 && ray_fifo_flush() < 0) - error(USER, "lost children"); + if (d == 0.0) { /* flush request? */ + if (something2flush) { + if (ray_pnprocs > 1 && ray_fifo_flush() < 0) + error(USER, "child(ren) died"); bogusray(); fflush(stdout); - nextflush = (vresolu > 0) & (hresolu > 1) ? 0 : - hresolu; + nextflush = (!vresolu | (hresolu <= 1)) * hresolu; + something2flush = 0; } else bogusray(); } else { /* compute and print */ rtcompute(orig, direc, lim_dist ? d : 0.0); /* flush if time */ if (!--nextflush) { - if (nproc > 1 && ray_fifo_flush() < 0) - error(USER, "lost children"); + if (ray_pnprocs > 1 && ray_fifo_flush() < 0) + error(USER, "child(ren) died"); fflush(stdout); nextflush = hresolu; - } + } else + something2flush = 1; } if (ferror(stdout)) error(SYSTEM, "write error"); if (vcount && !--vcount) /* check for end */ break; } - if (nproc > 1) { /* clean up children */ + if (ray_pnprocs > 1) { /* clean up children */ if (ray_fifo_flush() < 0) error(USER, "unable to complete processing"); ray_pclose(0); @@ -235,6 +244,22 @@ setoutput( /* set up output tables */ case 'd': /* direction */ *table++ = oputd; break; + case 'r': /* reflected contrib. */ + *table++ = oputr; + castonly = 0; + break; + case 'R': /* reflected distance */ + *table++ = oputR; + castonly = 0; + break; + case 'x': /* xmit contrib. */ + *table++ = oputx; + castonly = 0; + break; + case 'X': /* xmit distance */ + *table++ = oputX; + castonly = 0; + break; case 'v': /* value */ *table++ = oputv; castonly = 0; @@ -273,7 +298,8 @@ setoutput( /* set up output tables */ break; case 'W': /* coefficient */ *table++ = oputW; - if (ambounce > 0 && (ambacc > FTINY || ambssamp > 0)) + castonly = 0; + if (ambounce > 0 && (ambacc > FTINY) | (ambssamp > 0)) error(WARNING, "-otW accuracy depends on -aa 0 -as 0"); break; @@ -288,15 +314,21 @@ setoutput( /* set up output tables */ break; } *table = NULL; + /* compatibility */ + for (table = ray_out; *table != NULL; table++) { + if ((*table == oputV) | (*table == oputW)) + error(WARNING, "-oVW options require trace mode"); + if ((do_irrad | imm_irrad) && + (*table == oputr) | (*table == oputR) | + (*table == oputx) | (*table == oputX)) + error(WARNING, "-orRxX options incompatible with -I+ and -i+"); + } } static void bogusray(void) /* print out empty record */ { - thisray.rorg[0] = thisray.rorg[1] = thisray.rorg[2] = - thisray.rdir[0] = thisray.rdir[1] = thisray.rdir[2] = 0.0; - thisray.rmax = 0.0; rayorigin(&thisray, PRIMARY, NULL, NULL); printvals(&thisray); } @@ -323,8 +355,8 @@ rayirrad( /* compute irradiance rather than radiance ) { void (*old_revf)(RAY *) = r->revf; - - r->rot = 1e-5; /* pretend we hit surface */ + /* pretend we hit surface */ + r->rxt = r->rot = 1e-5; VSUM(r->rop, r->rorg, r->rdir, r->rot); r->ron[0] = -r->rdir[0]; r->ron[1] = -r->rdir[1]; @@ -410,12 +442,12 @@ getvec( /* get a vector from fp */ } break; case 'f': /* binary float */ - if (fread((char *)vf, sizeof(float), 3, fp) != 3) + if (getbinary(vf, sizeof(float), 3, fp) != 3) return(-1); VCOPY(vec, vf); break; case 'd': /* binary double */ - if (fread((char *)vd, sizeof(double), 3, fp) != 3) + if (getbinary(vd, sizeof(double), 3, fp) != 3) return(-1); VCOPY(vec, vd); break; @@ -508,20 +540,59 @@ oputd( /* print direction */ static void +oputr( /* print mirrored contribution */ + RAY *r +) +{ + RREAL cval[3]; + + cval[0] = colval(r->mcol,RED); + cval[1] = colval(r->mcol,GRN); + cval[2] = colval(r->mcol,BLU); + (*putreal)(cval, 3); +} + + + +static void +oputR( /* print mirrored distance */ + RAY *r +) +{ + (*putreal)(&r->rmt, 1); +} + + +static void +oputx( /* print unmirrored contribution */ + RAY *r +) +{ + RREAL cval[3]; + + cval[0] = colval(r->rcol,RED) - colval(r->mcol,RED); + cval[1] = colval(r->rcol,GRN) - colval(r->mcol,GRN); + cval[2] = colval(r->rcol,BLU) - colval(r->mcol,BLU); + (*putreal)(cval, 3); +} + + +static void +oputX( /* print unmirrored distance */ + RAY *r +) +{ + (*putreal)(&r->rxt, 1); +} + + +static void oputv( /* print value */ RAY *r ) { RREAL cval[3]; - if (outform == 'c') { - COLR cout; - setcolr(cout, colval(r->rcol,RED), - colval(r->rcol,GRN), - colval(r->rcol,BLU)); - fwrite(cout, sizeof(cout), 1, stdout); - return; - } cval[0] = colval(r->rcol,RED); cval[1] = colval(r->rcol,GRN); cval[2] = colval(r->rcol,BLU); @@ -547,7 +618,9 @@ oputl( /* print effective distance */ RAY *r ) { - (*putreal)(&r->rt, 1); + RREAL d = raydistance(r); + + (*putreal)(&d, 1); } @@ -589,9 +662,16 @@ oputN( /* print unperturbed normal */ RAY *r ) { - if (r->rot < FHUGE) - (*putreal)(r->ron, 3); - else + if (r->rot < FHUGE) { + if (r->rflips & 1) { /* undo any flippin' flips */ + FVECT unrm; + unrm[0] = -r->ron[0]; + unrm[1] = -r->ron[1]; + unrm[2] = -r->ron[2]; + (*putreal)(unrm, 3); + } else + (*putreal)(r->ron, 3); + } else (*putreal)(vdummy, 3); } @@ -642,8 +722,12 @@ oputW( /* print coefficient */ ) { RREAL contr[3]; + /* shadow ray not on source? */ + if (r->rsrc >= 0 && source[r->rsrc].so != r->ro) + setcolor(contr, 0.0, 0.0, 0.0); + else + raycontrib(contr, r, PRIMARY); - raycontrib(contr, r, PRIMARY); (*putreal)(contr, 3); } @@ -706,17 +790,27 @@ puta( /* print ascii value(s) */ static void -putd(RREAL *v, int n) /* print binary double(s) */ +putd(RREAL *v, int n) /* output binary double(s) */ { - if (sizeof(RREAL) != sizeof(double)) +#ifdef SMLFLT + double da[3]; + int i; + + if (n > 3) error(INTERNAL, "code error in putd()"); - fwrite(v, sizeof(RREAL), n, stdout); + for (i = n; i--; ) + da[i] = v[i]; + putbinary(da, sizeof(double), n, stdout); +#else + putbinary(v, sizeof(RREAL), n, stdout); +#endif } static void -putf(RREAL *v, int n) /* print binary float(s) */ +putf(RREAL *v, int n) /* output binary float(s) */ { +#ifndef SMLFLT float fa[3]; int i; @@ -724,5 +818,20 @@ putf(RREAL *v, int n) /* print binary float(s) */ error(INTERNAL, "code error in putf()"); for (i = n; i--; ) fa[i] = v[i]; - fwrite(fa, sizeof(float), n, stdout); + putbinary(fa, sizeof(float), n, stdout); +#else + putbinary(v, sizeof(RREAL), n, stdout); +#endif +} + + +static void +putrgbe(RREAL *v, int n) /* output RGBE color */ +{ + COLR cout; + + if (n != 3) + error(INTERNAL, "putrgbe() not called with 3 components"); + setcolr(cout, v[0], v[1], v[2]); + putbinary(cout, sizeof(cout), 1, stdout); }
