| 1 |
greg |
1.1 |
#ifndef lint
| 2 |
greg |
2.113 |
static const char RCSid[] = "$Id: rtrace.c,v 2.112 2024/01/06 01:21:34 greg Exp $";
| 3 |
greg |
1.1 |
#endif
| 4 |
| 5 |
* rtrace.c - program and variables for individual ray tracing.
| 6 |
greg |
2.27 |
| 7 |
| 8 |
greg |
2.28 |
#include "copyright.h"
| 9 |
greg |
1.1 |
| 10 |
| 11 |
* Input is in the form:
| 12 |
| 13 |
* xorg yorg zorg xdir ydir zdir
| 14 |
| 15 |
* The direction need not be normalized. Output is flexible.
| 16 |
greg |
1.7 |
* If the direction vector is (0,0,0), then the output is flushed.
| 17 |
greg |
1.1 |
* All values default to ascii representation of real
| 18 |
* numbers. Binary representations can be selected
| 19 |
* with '-ff' for float or '-fd' for double. By default,
| 20 |
greg |
1.13 |
* radiance is computed. The '-i' or '-I' options indicate that
| 21 |
greg |
1.1 |
* irradiance values are desired.
| 22 |
| 23 |
greg |
2.32 |
| 24 |
#include <time.h>
| 25 |
greg |
1.1 |
| 26 |
schorsch |
2.30 |
#include "platform.h"
| 27 |
greg |
1.1 |
#include "ray.h"
| 28 |
schorsch |
2.37 |
#include "ambient.h"
| 29 |
#include "source.h"
| 30 |
greg |
1.1 |
#include "otypes.h"
| 31 |
greg |
2.72 |
#include "otspecial.h"
| 32 |
greg |
2.6 |
#include "resolu.h"
| 33 |
schorsch |
2.49 |
#include "random.h"
| 34 |
greg |
2.6 |
| 35 |
greg |
2.57 |
extern int inform; /* input format */
| 36 |
extern int outform; /* output format */
| 37 |
extern char *outvals; /* output values */
| 38 |
greg |
2.27 |
| 39 |
greg |
2.57 |
extern int imm_irrad; /* compute immediate irradiance? */
| 40 |
extern int lim_dist; /* limit distance? */
| 41 |
greg |
1.14 |
| 42 |
greg |
2.57 |
extern char *tralist[]; /* list of modifers to trace (or no) */
| 43 |
extern int traincl; /* include == 1, exclude == 0 */
| 44 |
greg |
1.13 |
| 45 |
greg |
2.57 |
extern int hresolu; /* horizontal resolution */
| 46 |
extern int vresolu; /* vertical resolution */
| 47 |
greg |
1.1 |
| 48 |
greg |
2.105 |
extern int castonly; /* only doing ray-casting? */
| 49 |
greg |
2.55 |
| 50 |
greg |
2.107 |
extern double (*sens_curve)(SCOLOR scol); /* spectral conversion for 1-channel */
| 51 |
extern double out_scalefactor; /* output calibration scale factor */
| 52 |
extern RGBPRIMP out_prims; /* output color primitives (NULL if spectral) */
| 53 |
| 54 |
greg |
2.46 |
#ifndef MAXTSET
| 55 |
greg |
2.55 |
#define MAXTSET 8191 /* maximum number in trace set */
| 56 |
greg |
2.46 |
#endif
| 57 |
greg |
2.15 |
OBJECT traset[MAXTSET+1]={0}; /* trace include/exclude set */
| 58 |
| 59 |
greg |
2.102 |
static int Tflag = 0; /* source tracing enabled? */
| 60 |
| 61 |
greg |
1.1 |
static RAY thisray; /* for our convenience */
| 62 |
| 63 |
greg |
2.89 |
static FILE *inpfp = NULL; /* input stream pointer */
| 64 |
| 65 |
static FVECT *inp_queue = NULL; /* ray input queue if flushing */
| 66 |
static int inp_qpos = 0; /* next ray to return */
| 67 |
static int inp_qend = 0; /* number of rays in this work group */
| 68 |
| 69 |
greg |
2.65 |
typedef void putf_t(RREAL *v, int n);
| 70 |
greg |
2.107 |
static putf_t puta, putd, putf;
| 71 |
greg |
1.1 |
| 72 |
schorsch |
2.37 |
typedef void oputf_t(RAY *r);
| 73 |
greg |
2.51 |
static oputf_t oputo, oputd, oputv, oputV, oputl, oputL, oputc, oputp,
| 74 |
greg |
2.73 |
oputr, oputR, oputx, oputX, oputn, oputN, oputs,
| 75 |
oputw, oputW, oputm, oputM, oputtilde;
| 76 |
schorsch |
2.37 |
| 77 |
greg |
2.92 |
extern void tranotify(OBJECT obj);
| 78 |
static int is_fifo(FILE *fp);
| 79 |
schorsch |
2.37 |
static void bogusray(void);
| 80 |
greg |
2.59 |
static void raycast(RAY *r);
| 81 |
static void rayirrad(RAY *r);
| 82 |
static void rtcompute(FVECT org, FVECT dir, double dmax);
| 83 |
greg |
2.57 |
static int printvals(RAY *r);
| 84 |
static int getvec(FVECT vec, int fmt, FILE *fp);
| 85 |
greg |
2.89 |
static int iszerovec(const FVECT vec);
| 86 |
static double nextray(FVECT org, FVECT dir);
| 87 |
greg |
2.57 |
static void tabin(RAY *r);
| 88 |
static void ourtrace(RAY *r);
| 89 |
greg |
1.1 |
| 90 |
greg |
2.113 |
static void putscolor(COLORV *scol, double sf);
| 91 |
greg |
2.107 |
| 92 |
greg |
2.73 |
static oputf_t *ray_out[32], *every_out[32];
| 93 |
schorsch |
2.37 |
static putf_t *putreal;
| 94 |
greg |
2.27 |
| 95 |
greg |
1.1 |
| 96 |
greg |
2.27 |
void
| 97 |
schorsch |
2.37 |
quit( /* quit program */
| 98 |
int code
| 99 |
| 100 |
greg |
1.1 |
| 101 |
greg |
2.57 |
if (ray_pnprocs > 0) /* close children if any */
| 102 |
ray_pclose(0);
| 103 |
greg |
2.99 |
else if (ray_pnprocs < 0)
| 104 |
_exit(code); /* avoid flush() in child */
| 105 |
greg |
2.57 |
#ifndef NON_POSIX
| 106 |
greg |
2.99 |
else {
| 107 |
greg |
2.58 |
headclean(); /* delete header file */
| 108 |
pfclean(); /* clean up persist files */
| 109 |
| 110 |
greg |
2.11 |
#endif
| 111 |
greg |
1.1 |
exit(code);
| 112 |
| 113 |
| 114 |
| 115 |
greg |
2.106 |
const char *
| 116 |
schorsch |
2.37 |
formstr( /* return format identifier */
| 117 |
int f
| 118 |
| 119 |
greg |
2.6 |
| 120 |
switch (f) {
| 121 |
case 'a': return("ascii");
| 122 |
case 'f': return("float");
| 123 |
case 'd': return("double");
| 124 |
greg |
2.107 |
case 'c':
| 125 |
if (out_prims == NULL)
| 126 |
return(SPECFMT);
| 127 |
if (out_prims == xyzprims)
| 128 |
return(CIEFMT);
| 129 |
return(COLRFMT);
| 130 |
greg |
2.6 |
| 131 |
return("unknown");
| 132 |
| 133 |
| 134 |
| 135 |
greg |
2.102 |
static void
| 136 |
trace_sources(void) /* trace rays to light sources, also */
| 137 |
| 138 |
int sn;
| 139 |
| 140 |
for (sn = 0; sn < nsources; sn++)
| 141 |
source[sn].sflags |= SFOLLOW;
| 142 |
| 143 |
| 144 |
| 145 |
greg |
2.92 |
void
| 146 |
schorsch |
2.37 |
rtrace( /* trace rays from file */
| 147 |
greg |
2.59 |
char *fname,
| 148 |
int nproc
| 149 |
schorsch |
2.37 |
| 150 |
greg |
1.1 |
| 151 |
greg |
2.45 |
unsigned long vcount = (hresolu > 1) ? (unsigned long)hresolu*vresolu
| 152 |
greg |
2.66 |
: (unsigned long)vresolu;
| 153 |
greg |
2.85 |
long nextflush = (!vresolu | (hresolu <= 1)) * hresolu;
| 154 |
greg |
2.79 |
int something2flush = 0;
| 155 |
greg |
1.1 |
FILE *fp;
| 156 |
gregl |
2.25 |
double d;
| 157 |
greg |
1.2 |
FVECT orig, direc;
| 158 |
greg |
1.1 |
/* set up input */
| 159 |
if (fname == NULL)
| 160 |
greg |
2.89 |
inpfp = stdin;
| 161 |
else if ((inpfp = fopen(fname, "r")) == NULL) {
| 162 |
greg |
1.1 |
sprintf(errmsg, "cannot open input file \"%s\"", fname);
| 163 |
error(SYSTEM, errmsg);
| 164 |
| 165 |
greg |
2.89 |
#ifdef getc_unlocked
| 166 |
flockfile(inpfp); /* avoid lock/unlock overhead */
| 167 |
flockfile(stdout);
| 168 |
#endif
| 169 |
greg |
2.8 |
if (inform != 'a')
| 170 |
greg |
2.89 |
SET_FILE_BINARY(inpfp);
| 171 |
greg |
1.1 |
/* set up output */
| 172 |
greg |
2.94 |
if (castonly || every_out[0] != NULL)
| 173 |
greg |
2.59 |
nproc = 1; /* don't bother multiprocessing */
| 174 |
greg |
2.104 |
if (every_out[0] != NULL) {
| 175 |
trace = ourtrace; /* enable full tree tracing */
| 176 |
if (Tflag) /* light sources, too? */
| 177 |
trace_sources();
| 178 |
| 179 |
greg |
2.79 |
if ((nextflush > 0) & (nproc > nextflush)) {
| 180 |
error(WARNING, "reducing number of processes to match flush interval");
| 181 |
nproc = nextflush;
| 182 |
| 183 |
greg |
2.59 |
if (nproc > 1) { /* start multiprocessing */
| 184 |
ray_popen(nproc);
| 185 |
greg |
2.58 |
ray_fifo_out = printvals;
| 186 |
greg |
2.59 |
| 187 |
greg |
2.12 |
if (hresolu > 0) {
| 188 |
if (vresolu > 0)
| 189 |
fprtresolu(hresolu, vresolu, stdout);
| 190 |
greg |
2.78 |
else
| 191 |
fflush(stdout);
| 192 |
greg |
2.12 |
| 193 |
greg |
2.89 |
/* process input rays */
| 194 |
while ((d = nextray(orig, direc)) >= 0.0) {
| 195 |
greg |
2.87 |
if (d == 0.0) { /* flush request? */
| 196 |
greg |
2.85 |
if (something2flush) {
| 197 |
greg |
2.74 |
if (ray_pnprocs > 1 && ray_fifo_flush() < 0)
| 198 |
greg |
2.71 |
error(USER, "child(ren) died");
| 199 |
greg |
2.87 |
bogusray();
| 200 |
gregl |
2.24 |
fflush(stdout);
| 201 |
greg |
2.86 |
| 202 |
greg |
2.79 |
| 203 |
greg |
2.87 |
} else
| 204 |
bogusray();
| 205 |
greg |
2.57 |
} else { /* compute and print */
| 206 |
greg |
2.59 |
rtcompute(orig, direc, lim_dist ? d : 0.0);
| 207 |
greg |
2.89 |
if (!--nextflush) { /* flush if time */
| 208 |
greg |
2.74 |
| 209 |
greg |
2.71 |
| 210 |
gregl |
2.24 |
fflush(stdout);
| 211 |
nextflush = hresolu;
| 212 |
greg |
2.78 |
} else
| 213 |
greg |
2.79 |
something2flush = 1;
| 214 |
greg |
1.1 |
| 215 |
if (ferror(stdout))
| 216 |
error(SYSTEM, "write error");
| 217 |
greg |
2.45 |
if (vcount && !--vcount) /* check for end */
| 218 |
greg |
1.1 |
break;
| 219 |
| 220 |
greg |
2.74 |
if (ray_pnprocs > 1) { /* clean up children */
| 221 |
greg |
2.59 |
if (ray_fifo_flush() < 0)
| 222 |
error(USER, "unable to complete processing");
| 223 |
ray_pclose(0);
| 224 |
| 225 |
greg |
2.89 |
if (vcount)
| 226 |
error(WARNING, "unexpected EOF on input");
| 227 |
greg |
2.50 |
if (fflush(stdout) < 0)
| 228 |
| 229 |
greg |
2.89 |
if (fname != NULL) {
| 230 |
fclose(inpfp);
| 231 |
inpfp = NULL;
| 232 |
| 233 |
nextray(NULL, NULL);
| 234 |
greg |
1.1 |
| 235 |
| 236 |
| 237 |
greg |
2.91 |
int
| 238 |
setrtoutput(void) /* set up output tables, return #comp */
| 239 |
greg |
1.1 |
| 240 |
greg |
2.91 |
char *vs = outvals;
| 241 |
greg |
2.56 |
oputf_t **table = ray_out;
| 242 |
greg |
2.107 |
const int nco = (sens_curve != NULL) ? 1 :
| 243 |
(out_prims != NULL) ? 3 : NCSAMP;
| 244 |
greg |
2.91 |
int ncomp = 0;
| 245 |
| 246 |
if (!*vs)
| 247 |
error(USER, "empty output specification");
| 248 |
greg |
1.1 |
| 249 |
greg |
2.103 |
switch (outform) { /* make sure (*putreal)() calls someone! */
| 250 |
case 'a': putreal = puta; break;
| 251 |
case 'f': putreal = putf; break;
| 252 |
case 'd': putreal = putd; break;
| 253 |
case 'c':
| 254 |
if (outvals[1] || !strchr("vrx", outvals[0]))
| 255 |
error(USER, "color format only with -ov, -or, -ox");
| 256 |
greg |
2.108 |
if (nco < 3)
| 257 |
error(USER, "color format incompatible with -pY, -pS, -pM");
| 258 |
greg |
2.107 |
break;
| 259 |
greg |
2.103 |
default:
| 260 |
error(CONSISTENCY, "botched output format");
| 261 |
| 262 |
greg |
2.94 |
castonly = 1; /* sets castonly as side-effect */
| 263 |
greg |
2.91 |
do
| 264 |
switch (*vs) {
| 265 |
greg |
2.40 |
case 'T': /* trace sources */
| 266 |
greg |
2.102 |
Tflag++;
| 267 |
greg |
2.40 |
/* fall through */
| 268 |
greg |
1.1 |
case 't': /* trace */
| 269 |
greg |
2.91 |
if (!vs[1]) break;
| 270 |
greg |
1.1 |
*table = NULL;
| 271 |
table = every_out;
| 272 |
greg |
1.11 |
castonly = 0;
| 273 |
greg |
1.1 |
break;
| 274 |
case 'o': /* origin */
| 275 |
*table++ = oputo;
| 276 |
greg |
2.91 |
ncomp += 3;
| 277 |
greg |
1.1 |
break;
| 278 |
case 'd': /* direction */
| 279 |
*table++ = oputd;
| 280 |
greg |
2.91 |
ncomp += 3;
| 281 |
greg |
1.1 |
break;
| 282 |
greg |
2.73 |
case 'r': /* reflected contrib. */
| 283 |
*table++ = oputr;
| 284 |
greg |
2.107 |
ncomp += nco;
| 285 |
greg |
2.73 |
castonly = 0;
| 286 |
break;
| 287 |
case 'R': /* reflected distance */
| 288 |
*table++ = oputR;
| 289 |
greg |
2.91 |
ncomp++;
| 290 |
greg |
2.73 |
castonly = 0;
| 291 |
break;
| 292 |
case 'x': /* xmit contrib. */
| 293 |
*table++ = oputx;
| 294 |
greg |
2.107 |
ncomp += nco;
| 295 |
greg |
2.73 |
castonly = 0;
| 296 |
break;
| 297 |
case 'X': /* xmit distance */
| 298 |
*table++ = oputX;
| 299 |
greg |
2.91 |
ncomp++;
| 300 |
greg |
2.73 |
castonly = 0;
| 301 |
break;
| 302 |
greg |
1.1 |
case 'v': /* value */
| 303 |
*table++ = oputv;
| 304 |
greg |
2.107 |
ncomp += nco;
| 305 |
greg |
1.11 |
castonly = 0;
| 306 |
greg |
1.1 |
break;
| 307 |
greg |
2.51 |
case 'V': /* contribution */
| 308 |
*table++ = oputV;
| 309 |
greg |
2.107 |
ncomp += nco;
| 310 |
greg |
2.94 |
castonly = 0;
| 311 |
greg |
2.51 |
if (ambounce > 0 && (ambacc > FTINY || ambssamp > 0))
| 312 |
error(WARNING,
| 313 |
"-otV accuracy depends on -aa 0 -as 0");
| 314 |
break;
| 315 |
greg |
2.5 |
case 'l': /* effective distance */
| 316 |
greg |
1.1 |
*table++ = oputl;
| 317 |
greg |
2.91 |
ncomp++;
| 318 |
greg |
1.11 |
castonly = 0;
| 319 |
greg |
1.1 |
break;
| 320 |
greg |
2.29 |
case 'c': /* local coordinates */
| 321 |
*table++ = oputc;
| 322 |
greg |
2.91 |
ncomp += 2;
| 323 |
greg |
2.29 |
break;
| 324 |
greg |
2.5 |
case 'L': /* single ray length */
| 325 |
*table++ = oputL;
| 326 |
greg |
2.91 |
ncomp++;
| 327 |
greg |
2.5 |
break;
| 328 |
greg |
1.1 |
case 'p': /* point */
| 329 |
*table++ = oputp;
| 330 |
greg |
2.91 |
ncomp += 3;
| 331 |
greg |
1.1 |
break;
| 332 |
greg |
2.9 |
case 'n': /* perturbed normal */
| 333 |
greg |
1.1 |
*table++ = oputn;
| 334 |
greg |
2.91 |
ncomp += 3;
| 335 |
greg |
2.9 |
castonly = 0;
| 336 |
greg |
1.1 |
break;
| 337 |
greg |
2.9 |
case 'N': /* unperturbed normal */
| 338 |
*table++ = oputN;
| 339 |
greg |
2.91 |
ncomp += 3;
| 340 |
greg |
2.9 |
break;
| 341 |
greg |
1.1 |
case 's': /* surface */
| 342 |
*table++ = oputs;
| 343 |
greg |
2.91 |
ncomp++;
| 344 |
greg |
1.1 |
break;
| 345 |
case 'w': /* weight */
| 346 |
*table++ = oputw;
| 347 |
greg |
2.91 |
ncomp++;
| 348 |
greg |
1.1 |
break;
| 349 |
greg |
2.40 |
case 'W': /* coefficient */
| 350 |
*table++ = oputW;
| 351 |
greg |
2.107 |
ncomp += nco;
| 352 |
greg |
2.73 |
castonly = 0;
| 353 |
greg |
2.80 |
if (ambounce > 0 && (ambacc > FTINY) | (ambssamp > 0))
| 354 |
greg |
2.40 |
error(WARNING,
| 355 |
greg |
2.41 |
"-otW accuracy depends on -aa 0 -as 0");
| 356 |
greg |
2.40 |
break;
| 357 |
greg |
1.1 |
case 'm': /* modifier */
| 358 |
*table++ = oputm;
| 359 |
greg |
2.91 |
ncomp++;
| 360 |
greg |
1.1 |
break;
| 361 |
greg |
2.39 |
case 'M': /* material */
| 362 |
*table++ = oputM;
| 363 |
greg |
2.91 |
ncomp++;
| 364 |
greg |
2.39 |
break;
| 365 |
greg |
2.42 |
case '~': /* tilde */
| 366 |
*table++ = oputtilde;
| 367 |
greg |
2.41 |
break;
| 368 |
greg |
2.91 |
default:
| 369 |
sprintf(errmsg, "unrecognized output option '%c'", *vs);
| 370 |
error(USER, errmsg);
| 371 |
greg |
1.1 |
| 372 |
greg |
2.91 |
while (*++vs);
| 373 |
| 374 |
greg |
1.1 |
*table = NULL;
| 375 |
greg |
2.91 |
if (*every_out != NULL)
| 376 |
ncomp = 0;
| 377 |
greg |
2.81 |
/* compatibility */
| 378 |
greg |
2.94 |
if ((do_irrad | imm_irrad) && castonly)
| 379 |
error(USER, "-I+ and -i+ options require some value output");
| 380 |
greg |
2.81 |
for (table = ray_out; *table != NULL; table++) {
| 381 |
if ((*table == oputV) | (*table == oputW))
| 382 |
error(WARNING, "-oVW options require trace mode");
| 383 |
| 384 |
(*table == oputr) | (*table == oputR) |
| 385 |
(*table == oputx) | (*table == oputX))
| 386 |
error(WARNING, "-orRxX options incompatible with -I+ and -i+");
| 387 |
| 388 |
greg |
2.91 |
return(ncomp);
| 389 |
gregl |
2.24 |
| 390 |
| 391 |
| 392 |
schorsch |
2.37 |
static void
| 393 |
bogusray(void) /* print out empty record */
| 394 |
gregl |
2.24 |
| 395 |
greg |
2.40 |
rayorigin(&thisray, PRIMARY, NULL, NULL);
| 396 |
gregl |
2.24 |
printvals(&thisray);
| 397 |
greg |
1.1 |
| 398 |
| 399 |
| 400 |
schorsch |
2.37 |
static void
| 401 |
greg |
2.59 |
raycast( /* compute first ray intersection only */
| 402 |
RAY *r
| 403 |
schorsch |
2.37 |
| 404 |
greg |
1.1 |
| 405 |
greg |
2.59 |
if (!localhit(r, &thescene)) {
| 406 |
if (r->ro == &Aftplane) { /* clipped */
| 407 |
r->ro = NULL;
| 408 |
r->rot = FHUGE;
| 409 |
} else
| 410 |
sourcehit(r);
| 411 |
greg |
2.57 |
| 412 |
greg |
1.1 |
| 413 |
| 414 |
| 415 |
schorsch |
2.37 |
static void
| 416 |
greg |
2.59 |
rayirrad( /* compute irradiance rather than radiance */
| 417 |
RAY *r
| 418 |
| 419 |
| 420 |
greg |
2.62 |
void (*old_revf)(RAY *) = r->revf;
| 421 |
greg |
2.75 |
/* pretend we hit surface */
| 422 |
greg |
2.76 |
r->rxt = r->rot = 1e-5;
| 423 |
greg |
2.59 |
VSUM(r->rop, r->rorg, r->rdir, r->rot);
| 424 |
r->ron[0] = -r->rdir[0];
| 425 |
r->ron[1] = -r->rdir[1];
| 426 |
r->ron[2] = -r->rdir[2];
| 427 |
r->rod = 1.0;
| 428 |
greg |
2.62 |
/* compute result */
| 429 |
greg |
2.61 |
r->revf = raytrace;
| 430 |
greg |
2.59 |
(*ofun[Lamb.otype].funp)(&Lamb, r);
| 431 |
greg |
2.62 |
r->revf = old_revf;
| 432 |
greg |
2.59 |
| 433 |
| 434 |
| 435 |
static void
| 436 |
rtcompute( /* compute and print ray value(s) */
| 437 |
schorsch |
2.37 |
FVECT org,
| 438 |
greg |
2.59 |
FVECT dir,
| 439 |
double dmax
| 440 |
schorsch |
2.37 |
| 441 |
greg |
1.1 |
| 442 |
greg |
2.60 |
/* set up ray */
| 443 |
if (imm_irrad) {
| 444 |
greg |
2.59 |
VSUM(thisray.rorg, org, dir, 1.1e-4);
| 445 |
thisray.rdir[0] = -dir[0];
| 446 |
thisray.rdir[1] = -dir[1];
| 447 |
thisray.rdir[2] = -dir[2];
| 448 |
thisray.rmax = 0.0;
| 449 |
} else {
| 450 |
VCOPY(thisray.rorg, org);
| 451 |
VCOPY(thisray.rdir, dir);
| 452 |
thisray.rmax = dmax;
| 453 |
| 454 |
greg |
2.101 |
| 455 |
if (imm_irrad)
| 456 |
thisray.revf = rayirrad;
| 457 |
else if (castonly)
| 458 |
thisray.revf = raycast;
| 459 |
greg |
2.59 |
if (ray_pnprocs > 1) { /* multiprocessing FIFO? */
| 460 |
if (ray_fifo_in(&thisray) < 0)
| 461 |
error(USER, "lost children");
| 462 |
return;
| 463 |
| 464 |
samplendx++; /* else do it ourselves */
| 465 |
rayvalue(&thisray);
| 466 |
greg |
2.16 |
| 467 |
| 468 |
| 469 |
| 470 |
greg |
2.57 |
static int
| 471 |
schorsch |
2.37 |
printvals( /* print requested ray values */
| 472 |
RAY *r
| 473 |
| 474 |
greg |
2.16 |
| 475 |
greg |
2.56 |
oputf_t **tp;
| 476 |
greg |
2.16 |
| 477 |
if (ray_out[0] == NULL)
| 478 |
greg |
2.57 |
return(0);
| 479 |
greg |
2.16 |
for (tp = ray_out; *tp != NULL; tp++)
| 480 |
(**tp)(r);
| 481 |
greg |
1.1 |
if (outform == 'a')
| 482 |
putchar('\n');
| 483 |
greg |
2.57 |
return(1);
| 484 |
greg |
1.1 |
| 485 |
| 486 |
| 487 |
schorsch |
2.37 |
static int
| 488 |
greg |
2.92 |
is_fifo( /* check if file pointer connected to pipe */
| 489 |
FILE *fp
| 490 |
| 491 |
| 492 |
#ifdef S_ISFIFO
| 493 |
struct stat sbuf;
| 494 |
| 495 |
if (fstat(fileno(fp), &sbuf) < 0)
| 496 |
error(SYSTEM, "fstat() failed on input stream");
| 497 |
return(S_ISFIFO(sbuf.st_mode));
| 498 |
#else
| 499 |
return (fp == stdin); /* just a guess, really */
| 500 |
#endif
| 501 |
| 502 |
| 503 |
| 504 |
static int
| 505 |
greg |
2.89 |
getvec( /* get a vector from fp */
| 506 |
greg |
2.56 |
FVECT vec,
| 507 |
schorsch |
2.37 |
int fmt,
| 508 |
FILE *fp
| 509 |
| 510 |
greg |
1.1 |
| 511 |
static float vf[3];
| 512 |
greg |
2.5 |
static double vd[3];
| 513 |
greg |
1.19 |
char buf[32];
| 514 |
greg |
2.56 |
int i;
| 515 |
greg |
1.1 |
| 516 |
switch (fmt) {
| 517 |
case 'a': /* ascii */
| 518 |
greg |
1.19 |
for (i = 0; i < 3; i++) {
| 519 |
if (fgetword(buf, sizeof(buf), fp) == NULL ||
| 520 |
!isflt(buf))
| 521 |
return(-1);
| 522 |
vec[i] = atof(buf);
| 523 |
| 524 |
greg |
1.1 |
break;
| 525 |
case 'f': /* binary float */
| 526 |
greg |
2.70 |
if (getbinary(vf, sizeof(float), 3, fp) != 3)
| 527 |
greg |
1.1 |
return(-1);
| 528 |
greg |
2.58 |
VCOPY(vec, vf);
| 529 |
greg |
1.1 |
break;
| 530 |
case 'd': /* binary double */
| 531 |
greg |
2.70 |
if (getbinary(vd, sizeof(double), 3, fp) != 3)
| 532 |
greg |
1.1 |
return(-1);
| 533 |
greg |
2.58 |
VCOPY(vec, vd);
| 534 |
greg |
1.1 |
break;
| 535 |
greg |
2.6 |
default:
| 536 |
error(CONSISTENCY, "botched input format");
| 537 |
greg |
1.1 |
| 538 |
return(0);
| 539 |
| 540 |
| 541 |
| 542 |
greg |
2.89 |
static int
| 543 |
| 544 |
| 545 |
return (vec[0] == 0.0) & (vec[1] == 0.0) & (vec[2] == 0.0);
| 546 |
| 547 |
| 548 |
| 549 |
static double
| 550 |
nextray( /* return next ray in work group (-1.0 if EOF) */
| 551 |
FVECT org,
| 552 |
FVECT dir
| 553 |
| 554 |
| 555 |
const size_t qlength = !vresolu * hresolu;
| 556 |
| 557 |
if ((org == NULL) | (dir == NULL)) {
| 558 |
if (inp_queue != NULL) /* asking to free queue */
| 559 |
free(inp_queue);
| 560 |
inp_queue = NULL;
| 561 |
inp_qpos = inp_qend = 0;
| 562 |
return(-1.);
| 563 |
| 564 |
if (!inp_qend) { /* initialize FIFO queue */
| 565 |
int rsiz = 6*20; /* conservative ascii ray size */
| 566 |
if (inform == 'f') rsiz = 6*sizeof(float);
| 567 |
else if (inform == 'd') rsiz = 6*sizeof(double);
| 568 |
greg |
2.92 |
/* check against pipe limit */
| 569 |
if (qlength*rsiz > 512 && is_fifo(inpfp))
| 570 |
greg |
2.89 |
inp_queue = (FVECT *)malloc(sizeof(FVECT)*2*qlength);
| 571 |
inp_qend = -(inp_queue == NULL); /* flag for no queue */
| 572 |
| 573 |
if (inp_qend < 0) { /* not queuing? */
| 574 |
if (getvec(org, inform, inpfp) < 0 ||
| 575 |
getvec(dir, inform, inpfp) < 0)
| 576 |
return(-1.);
| 577 |
return normalize(dir);
| 578 |
| 579 |
if (inp_qpos >= inp_qend) { /* need to refill input queue? */
| 580 |
for (inp_qend = 0; inp_qend < qlength; inp_qend++) {
| 581 |
if (getvec(inp_queue[2*inp_qend], inform, inpfp) < 0
| 582 |
|| getvec(inp_queue[2*inp_qend+1],
| 583 |
inform, inpfp) < 0)
| 584 |
break; /* hit EOF */
| 585 |
if (iszerovec(inp_queue[2*inp_qend+1])) {
| 586 |
++inp_qend; /* flush request */
| 587 |
break;
| 588 |
| 589 |
| 590 |
inp_qpos = 0;
| 591 |
| 592 |
if (inp_qpos >= inp_qend) /* unexpected EOF? */
| 593 |
return(-1.);
| 594 |
VCOPY(org, inp_queue[2*inp_qpos]);
| 595 |
VCOPY(dir, inp_queue[2*inp_qpos+1]);
| 596 |
++inp_qpos;
| 597 |
| 598 |
| 599 |
| 600 |
| 601 |
greg |
2.57 |
void
| 602 |
schorsch |
2.37 |
tranotify( /* record new modifier */
| 603 |
OBJECT obj
| 604 |
| 605 |
greg |
2.15 |
| 606 |
static int hitlimit = 0;
| 607 |
greg |
2.56 |
OBJREC *o = objptr(obj);
| 608 |
char **tralp;
| 609 |
greg |
2.15 |
| 610 |
greg |
2.27 |
if (obj == OVOID) { /* starting over */
| 611 |
traset[0] = 0;
| 612 |
hitlimit = 0;
| 613 |
return;
| 614 |
| 615 |
greg |
2.15 |
if (hitlimit || !ismodifier(o->otype))
| 616 |
return;
| 617 |
for (tralp = tralist; *tralp != NULL; tralp++)
| 618 |
if (!strcmp(o->oname, *tralp)) {
| 619 |
if (traset[0] >= MAXTSET) {
| 620 |
error(WARNING, "too many modifiers in trace list");
| 621 |
hitlimit++;
| 622 |
return; /* should this be fatal? */
| 623 |
| 624 |
insertelem(traset, obj);
| 625 |
return;
| 626 |
| 627 |
| 628 |
| 629 |
| 630 |
greg |
2.27 |
static void
| 631 |
schorsch |
2.37 |
ourtrace( /* print ray values */
| 632 |
RAY *r
| 633 |
| 634 |
greg |
1.1 |
| 635 |
greg |
2.56 |
oputf_t **tp;
| 636 |
greg |
1.1 |
| 637 |
if (every_out[0] == NULL)
| 638 |
greg |
2.15 |
return;
| 639 |
greg |
2.16 |
if (r->ro == NULL) {
| 640 |
if (traincl == 1)
| 641 |
return;
| 642 |
} else if (traincl != -1 && traincl != inset(traset, r->ro->omod))
| 643 |
greg |
1.1 |
return;
| 644 |
tabin(r);
| 645 |
for (tp = every_out; *tp != NULL; tp++)
| 646 |
(**tp)(r);
| 647 |
greg |
2.41 |
if (outform == 'a')
| 648 |
putchar('\n');
| 649 |
greg |
1.1 |
| 650 |
| 651 |
| 652 |
greg |
2.27 |
static void
| 653 |
schorsch |
2.37 |
tabin( /* tab in appropriate amount */
| 654 |
RAY *r
| 655 |
| 656 |
greg |
1.1 |
| 657 |
greg |
2.40 |
const RAY *rp;
| 658 |
greg |
1.1 |
| 659 |
for (rp = r->parent; rp != NULL; rp = rp->parent)
| 660 |
putchar('\t');
| 661 |
| 662 |
| 663 |
| 664 |
greg |
2.27 |
static void
| 665 |
schorsch |
2.37 |
oputo( /* print origin */
| 666 |
RAY *r
| 667 |
| 668 |
greg |
1.1 |
| 669 |
greg |
2.65 |
(*putreal)(r->rorg, 3);
| 670 |
greg |
1.1 |
| 671 |
| 672 |
| 673 |
greg |
2.27 |
static void
| 674 |
schorsch |
2.37 |
oputd( /* print direction */
| 675 |
RAY *r
| 676 |
| 677 |
greg |
1.1 |
| 678 |
greg |
2.65 |
(*putreal)(r->rdir, 3);
| 679 |
greg |
1.1 |
| 680 |
| 681 |
| 682 |
greg |
2.27 |
static void
| 683 |
greg |
2.73 |
oputr( /* print mirrored contribution */
| 684 |
RAY *r
| 685 |
| 686 |
| 687 |
greg |
2.113 |
putscolor(r->mcol, out_scalefactor);
| 688 |
greg |
2.73 |
| 689 |
| 690 |
| 691 |
| 692 |
static void
| 693 |
oputR( /* print mirrored distance */
| 694 |
RAY *r
| 695 |
| 696 |
| 697 |
(*putreal)(&r->rmt, 1);
| 698 |
| 699 |
| 700 |
| 701 |
static void
| 702 |
oputx( /* print unmirrored contribution */
| 703 |
RAY *r
| 704 |
| 705 |
| 706 |
greg |
2.107 |
SCOLOR cdiff;
| 707 |
| 708 |
copyscolor(cdiff, r->rcol);
| 709 |
sopscolor(cdiff, -=, r->mcol);
| 710 |
greg |
2.73 |
| 711 |
greg |
2.113 |
putscolor(cdiff, out_scalefactor);
| 712 |
greg |
2.73 |
| 713 |
| 714 |
| 715 |
static void
| 716 |
oputX( /* print unmirrored distance */
| 717 |
RAY *r
| 718 |
| 719 |
| 720 |
(*putreal)(&r->rxt, 1);
| 721 |
| 722 |
| 723 |
| 724 |
static void
| 725 |
schorsch |
2.37 |
oputv( /* print value */
| 726 |
RAY *r
| 727 |
| 728 |
greg |
1.1 |
| 729 |
greg |
2.113 |
putscolor(r->rcol, out_scalefactor);
| 730 |
greg |
1.1 |
| 731 |
| 732 |
| 733 |
greg |
2.27 |
static void
| 734 |
greg |
2.51 |
oputV( /* print value contribution */
| 735 |
RAY *r
| 736 |
| 737 |
| 738 |
greg |
2.107 |
SCOLOR contr;
| 739 |
greg |
2.51 |
| 740 |
raycontrib(contr, r, PRIMARY);
| 741 |
greg |
2.107 |
smultscolor(contr, r->rcol);
| 742 |
greg |
2.113 |
putscolor(contr, out_scalefactor);
| 743 |
greg |
2.51 |
| 744 |
| 745 |
| 746 |
static void
| 747 |
schorsch |
2.37 |
oputl( /* print effective distance */
| 748 |
RAY *r
| 749 |
| 750 |
greg |
1.1 |
| 751 |
greg |
2.73 |
RREAL d = raydistance(r);
| 752 |
| 753 |
(*putreal)(&d, 1);
| 754 |
greg |
2.5 |
| 755 |
| 756 |
| 757 |
greg |
2.27 |
static void
| 758 |
schorsch |
2.37 |
oputL( /* print single ray length */
| 759 |
RAY *r
| 760 |
| 761 |
greg |
2.5 |
| 762 |
greg |
2.65 |
(*putreal)(&r->rot, 1);
| 763 |
greg |
1.1 |
| 764 |
| 765 |
| 766 |
greg |
2.27 |
static void
| 767 |
schorsch |
2.37 |
oputc( /* print local coordinates */
| 768 |
RAY *r
| 769 |
| 770 |
greg |
2.29 |
| 771 |
greg |
2.65 |
(*putreal)(r->uv, 2);
| 772 |
greg |
2.29 |
| 773 |
| 774 |
| 775 |
greg |
2.65 |
static RREAL vdummy[3] = {0.0, 0.0, 0.0};
| 776 |
| 777 |
| 778 |
greg |
2.29 |
static void
| 779 |
greg |
2.100 |
oputp( /* print intersection point */
| 780 |
schorsch |
2.37 |
RAY *r
| 781 |
| 782 |
greg |
1.1 |
| 783 |
greg |
2.100 |
(*putreal)(r->rop, 3); /* set to ray origin if distant or no hit */
| 784 |
greg |
1.1 |
| 785 |
| 786 |
| 787 |
greg |
2.27 |
static void
| 788 |
schorsch |
2.37 |
oputN( /* print unperturbed normal */
| 789 |
RAY *r
| 790 |
| 791 |
greg |
1.1 |
| 792 |
greg |
2.100 |
if (r->ro == NULL) { /* zero vector if clipped or no hit */
| 793 |
(*putreal)(vdummy, 3);
| 794 |
return;
| 795 |
| 796 |
if (r->rflips & 1) { /* undo any flippin' flips */
| 797 |
FVECT unrm;
| 798 |
unrm[0] = -r->ron[0];
| 799 |
unrm[1] = -r->ron[1];
| 800 |
unrm[2] = -r->ron[2];
| 801 |
(*putreal)(unrm, 3);
| 802 |
greg |
2.82 |
} else
| 803 |
greg |
2.100 |
(*putreal)(r->ron, 3);
| 804 |
greg |
2.9 |
| 805 |
| 806 |
| 807 |
greg |
2.27 |
static void
| 808 |
schorsch |
2.37 |
oputn( /* print perturbed normal */
| 809 |
RAY *r
| 810 |
| 811 |
greg |
2.9 |
| 812 |
FVECT pnorm;
| 813 |
| 814 |
greg |
2.100 |
if (r->ro == NULL) { /* clipped or no hit */
| 815 |
greg |
2.65 |
| 816 |
greg |
2.9 |
return;
| 817 |
| 818 |
raynormal(pnorm, r);
| 819 |
greg |
2.65 |
(*putreal)(pnorm, 3);
| 820 |
greg |
1.1 |
| 821 |
| 822 |
| 823 |
greg |
2.27 |
static void
| 824 |
schorsch |
2.37 |
oputs( /* print name */
| 825 |
RAY *r
| 826 |
| 827 |
greg |
1.1 |
| 828 |
if (r->ro != NULL)
| 829 |
fputs(r->ro->oname, stdout);
| 830 |
else
| 831 |
putchar('*');
| 832 |
putchar('\t');
| 833 |
| 834 |
| 835 |
| 836 |
greg |
2.27 |
static void
| 837 |
schorsch |
2.37 |
oputw( /* print weight */
| 838 |
RAY *r
| 839 |
| 840 |
greg |
1.1 |
| 841 |
greg |
2.65 |
RREAL rwt = r->rweight;
| 842 |
| 843 |
(*putreal)(&rwt, 1);
| 844 |
greg |
1.1 |
| 845 |
| 846 |
| 847 |
greg |
2.27 |
static void
| 848 |
greg |
2.51 |
oputW( /* print coefficient */
| 849 |
greg |
2.40 |
RAY *r
| 850 |
| 851 |
| 852 |
greg |
2.107 |
SCOLOR contr;
| 853 |
greg |
2.67 |
/* shadow ray not on source? */
| 854 |
if (r->rsrc >= 0 && source[r->rsrc].so != r->ro)
| 855 |
greg |
2.107 |
scolorblack(contr);
| 856 |
greg |
2.67 |
else
| 857 |
| 858 |
greg |
2.40 |
| 859 |
greg |
2.113 |
putscolor(contr, 1.);
| 860 |
greg |
2.40 |
| 861 |
| 862 |
| 863 |
static void
| 864 |
schorsch |
2.37 |
oputm( /* print modifier */
| 865 |
RAY *r
| 866 |
| 867 |
greg |
1.1 |
| 868 |
if (r->ro != NULL)
| 869 |
greg |
2.23 |
if (r->ro->omod != OVOID)
| 870 |
fputs(objptr(r->ro->omod)->oname, stdout);
| 871 |
else
| 872 |
fputs(VOIDID, stdout);
| 873 |
greg |
1.1 |
else
| 874 |
putchar('*');
| 875 |
putchar('\t');
| 876 |
| 877 |
| 878 |
| 879 |
greg |
2.27 |
static void
| 880 |
greg |
2.39 |
oputM( /* print material */
| 881 |
RAY *r
| 882 |
| 883 |
| 884 |
OBJREC *mat;
| 885 |
| 886 |
if (r->ro != NULL) {
| 887 |
if ((mat = findmaterial(r->ro)) != NULL)
| 888 |
fputs(mat->oname, stdout);
| 889 |
else
| 890 |
| 891 |
} else
| 892 |
putchar('*');
| 893 |
putchar('\t');
| 894 |
| 895 |
| 896 |
| 897 |
static void
| 898 |
greg |
2.42 |
oputtilde( /* output tilde (spacer) */
| 899 |
greg |
2.41 |
RAY *r
| 900 |
| 901 |
| 902 |
greg |
2.42 |
fputs("~\t", stdout);
| 903 |
greg |
2.41 |
| 904 |
| 905 |
| 906 |
static void
| 907 |
greg |
2.65 |
puta( /* print ascii value(s) */
| 908 |
RREAL *v, int n
| 909 |
schorsch |
2.37 |
| 910 |
greg |
1.1 |
| 911 |
greg |
2.65 |
if (n == 3) {
| 912 |
printf("%e\t%e\t%e\t", v[0], v[1], v[2]);
| 913 |
return;
| 914 |
| 915 |
while (n--)
| 916 |
printf("%e\t", *v++);
| 917 |
greg |
1.1 |
| 918 |
| 919 |
| 920 |
greg |
2.27 |
static void
| 921 |
greg |
2.80 |
putd(RREAL *v, int n) /* output binary double(s) */
| 922 |
greg |
1.1 |
| 923 |
greg |
2.68 |
#ifdef SMLFLT
| 924 |
greg |
2.110 |
double da[MAXCSAMP];
| 925 |
greg |
2.68 |
int i;
| 926 |
| 927 |
greg |
2.110 |
if (n > MAXCSAMP)
| 928 |
greg |
2.65 |
error(INTERNAL, "code error in putd()");
| 929 |
greg |
2.68 |
for (i = n; i--; )
| 930 |
da[i] = v[i];
| 931 |
greg |
2.69 |
putbinary(da, sizeof(double), n, stdout);
| 932 |
greg |
2.68 |
#else
| 933 |
greg |
2.69 |
putbinary(v, sizeof(RREAL), n, stdout);
| 934 |
greg |
2.68 |
#endif
| 935 |
greg |
1.1 |
| 936 |
| 937 |
| 938 |
greg |
2.27 |
static void
| 939 |
greg |
2.80 |
putf(RREAL *v, int n) /* output binary float(s) */
| 940 |
greg |
1.1 |
| 941 |
greg |
2.68 |
#ifndef SMLFLT
| 942 |
greg |
2.110 |
float fa[MAXCSAMP];
| 943 |
greg |
2.65 |
int i;
| 944 |
greg |
1.1 |
| 945 |
greg |
2.110 |
if (n > MAXCSAMP)
| 946 |
greg |
2.65 |
error(INTERNAL, "code error in putf()");
| 947 |
for (i = n; i--; )
| 948 |
fa[i] = v[i];
| 949 |
greg |
2.69 |
putbinary(fa, sizeof(float), n, stdout);
| 950 |
greg |
2.68 |
#else
| 951 |
greg |
2.69 |
| 952 |
greg |
2.68 |
#endif
| 953 |
greg |
1.1 |
| 954 |
greg |
2.80 |
| 955 |
| 956 |
static void
| 957 |
greg |
2.113 |
putscolor(COLORV *scol, double sf) /* output (spectral) color */
| 958 |
greg |
2.80 |
| 959 |
greg |
2.107 |
static COLORMAT xyz2myrgbmat;
| 960 |
SCOLOR my_scol;
| 961 |
COLOR col;
| 962 |
greg |
2.112 |
/* single channel output? */
| 963 |
if (sens_curve != NULL) {
| 964 |
greg |
2.113 |
RREAL v = (*sens_curve)(scol) * sf;
| 965 |
greg |
2.112 |
(*putreal)(&v, 1);
| 966 |
return;
| 967 |
| 968 |
greg |
2.113 |
if (sf != 1.) { /* apply scalefactor if any */
| 969 |
greg |
2.107 |
copyscolor(my_scol, scol);
| 970 |
greg |
2.113 |
scalescolor(my_scol, sf);
| 971 |
greg |
2.107 |
scol = my_scol;
| 972 |
| 973 |
if (out_prims == NULL) { /* full spectral reporting */
| 974 |
if (outform == 'c') {
| 975 |
SCOLR sclr;
| 976 |
scolor_scolr(sclr, scol);
| 977 |
putbinary(sclr, LSCOLR, 1, stdout);
| 978 |
} else if (sizeof(RREAL) != sizeof(COLORV)) {
| 979 |
RREAL sreal[MAXCSAMP];
| 980 |
int i = NCSAMP;
| 981 |
while (i--) sreal[i] = scol[i];
| 982 |
(*putreal)(sreal, NCSAMP);
| 983 |
} else
| 984 |
(*putreal)((RREAL *)scol, NCSAMP);
| 985 |
return;
| 986 |
| 987 |
if (out_prims == xyzprims) {
| 988 |
scolor_cie(col, scol);
| 989 |
} else if (out_prims == stdprims) {
| 990 |
scolor_rgb(col, scol);
| 991 |
} else {
| 992 |
COLOR xyz;
| 993 |
if (xyz2myrgbmat[0][0] == 0)
| 994 |
compxyz2rgbWBmat(xyz2myrgbmat, out_prims);
| 995 |
scolor_cie(xyz, scol);
| 996 |
colortrans(col, xyz2myrgbmat, xyz);
| 997 |
clipgamut(col, xyz[CIEY], CGAMUT_LOWER, cblack, cwhite);
| 998 |
| 999 |
| 1000 |
COLR clr;
| 1001 |
setcolr(clr, colval(col,RED), colval(col,GRN), colval(col,BLU));
| 1002 |
putbinary(clr, sizeof(COLR), 1, stdout);
| 1003 |
| 1004 |
RREAL creal[3];
| 1005 |
copycolor(creal, col);
| 1006 |
(*putreal)(creal, 3);
| 1007 |
} else
| 1008 |
(*putreal)((RREAL *)col, 3);
| 1009 |
greg |
2.80 |
