root/radiance/ray/src/rt/rtrace.c
Revision: 2.45
Committed: Fri Jun 10 16:49:42 2005 UTC (19 years, 10 months ago) by greg
Changes since 2.44: +7 -6 lines
Fixed bug where rtrace would quit after 2^31 primary rays
2 static const char RCSid[] = "$Id: rtrace.c,v 2.44 2005/06/05 19:52:01 greg Exp $";
5 * rtrace.c - program and variables for individual ray tracing.
6 */
7
8 #include "copyright.h"
9
10 /*
11 * Input is in the form:
12 *
13 * xorg yorg zorg xdir ydir zdir
14 *
15 * The direction need not be normalized. Output is flexible.
16 * If the direction vector is (0,0,0), then the output is flushed.
17 * All values default to ascii representation of real
18 * numbers. Binary representations can be selected
19 * with '-ff' for float or '-fd' for double. By default,
20 * radiance is computed. The '-i' or '-I' options indicate that
21 * irradiance values are desired.
22 */
23
24 #include <time.h>
25
26 #include "platform.h"
27 #include "ray.h"
28 #include "ambient.h"
29 #include "source.h"
30 #include "otypes.h"
31 #include "resolu.h"
32
33 CUBE thescene; /* our scene */
34 OBJECT nsceneobjs; /* number of objects in our scene */
35
36 int dimlist[MAXDIM]; /* sampling dimensions */
37 int ndims = 0; /* number of sampling dimensions */
38 int samplendx = 0; /* index for this sample */
39
40 int imm_irrad = 0; /* compute immediate irradiance? */
41 int lim_dist = 0; /* limit distance? */
42
43 int inform = 'a'; /* input format */
44 int outform = 'a'; /* output format */
45 char *outvals = "v"; /* output specification */
46
47 int do_irrad = 0; /* compute irradiance? */
48
49 void (*trace)() = NULL; /* trace call */
50
51 char *tralist[128]; /* list of modifers to trace (or no) */
52 int traincl = -1; /* include == 1, exclude == 0 */
53 #define MAXTSET 511 /* maximum number in trace set */
54 OBJECT traset[MAXTSET+1]={0}; /* trace include/exclude set */
55
56 int hresolu = 0; /* horizontal (scan) size */
57 int vresolu = 0; /* vertical resolution */
58
59 double dstrsrc = 0.0; /* square source distribution */
60 double shadthresh = .03; /* shadow threshold */
61 double shadcert = .75; /* shadow certainty */
62 int directrelay = 2; /* number of source relays */
63 int vspretest = 512; /* virtual source pretest density */
64 int directvis = 1; /* sources visible? */
65 double srcsizerat = .2; /* maximum ratio source size/dist. */
66
67 COLOR cextinction = BLKCOLOR; /* global extinction coefficient */
68 COLOR salbedo = BLKCOLOR; /* global scattering albedo */
69 double seccg = 0.; /* global scattering eccentricity */
70 double ssampdist = 0.; /* scatter sampling distance */
71
72 double specthresh = .15; /* specular sampling threshold */
73 double specjitter = 1.; /* specular sampling jitter */
74
75 int backvis = 1; /* back face visibility */
76
77 int maxdepth = -10; /* maximum recursion depth */
78 double minweight = 2e-3; /* minimum ray weight */
79
80 char *ambfile = NULL; /* ambient file name */
81 COLOR ambval = BLKCOLOR; /* ambient value */
82 int ambvwt = 0; /* initial weight for ambient value */
83 double ambacc = 0.15; /* ambient accuracy */
84 int ambres = 256; /* ambient resolution */
85 int ambdiv = 1024; /* ambient divisions */
86 int ambssamp = 512; /* ambient super-samples */
87 int ambounce = 0; /* ambient bounces */
88 char *amblist[AMBLLEN]; /* ambient include/exclude list */
89 int ambincl = -1; /* include == 1, exclude == 0 */
90
91 static int castonly = 0;
92
93 static RAY thisray; /* for our convenience */
94
95 typedef void putf_t(double v);
96 static putf_t puta, putd, putf;
97
98 typedef void oputf_t(RAY *r);
99 static oputf_t oputo, oputd, oputv, oputl, oputL, oputc, oputp,
100 oputn, oputN, oputs, oputw, oputW, oputm, oputM, oputtilde;
101
102 static void setoutput(char *vs);
103 static void tranotify(OBJECT obj);
104 static void bogusray(void);
105 static void rad(FVECT org, FVECT dir, double dmax);
106 static void irrad(FVECT org, FVECT dir);
107 static void printvals(RAY *r);
108 static int getvec(FVECT vec, int fmt, FILE *fp);
109 static void tabin(RAY *r);
110 static void ourtrace(RAY *r);
111
112 static oputf_t *ray_out[16], *every_out[16];
113 static putf_t *putreal;
114
115 void (*addobjnotify[])() = {ambnotify, tranotify, NULL};
116
117
118 void
119 quit( /* quit program */
120 int code
121 )
122 {
123 #ifndef NON_POSIX /* XXX we don't clean up elsewhere? */
124 headclean(); /* delete header file */
125 pfclean(); /* clean up persist files */
126 #endif
127 exit(code);
128 }
129
130
131 extern char *
132 formstr( /* return format identifier */
133 int f
134 )
135 {
136 switch (f) {
137 case 'a': return("ascii");
138 case 'f': return("float");
139 case 'd': return("double");
140 case 'c': return(COLRFMT);
141 }
142 return("unknown");
143 }
144
145
146 extern void
147 rtrace( /* trace rays from file */
148 char *fname
149 )
150 {
151 unsigned long vcount = (hresolu > 1) ? (unsigned long)hresolu*vresolu
152 : vresolu;
153 long nextflush = hresolu;
154 FILE *fp;
155 double d;
156 FVECT orig, direc;
157 /* set up input */
158 if (fname == NULL)
159 fp = stdin;
160 else if ((fp = fopen(fname, "r")) == NULL) {
161 sprintf(errmsg, "cannot open input file \"%s\"", fname);
162 error(SYSTEM, errmsg);
163 }
164 if (inform != 'a')
165 SET_FILE_BINARY(fp);
166 /* set up output */
167 setoutput(outvals);
168 switch (outform) {
169 case 'a': putreal = puta; break;
170 case 'f': putreal = putf; break;
171 case 'd': putreal = putd; break;
172 case 'c':
173 if (strcmp(outvals, "v"))
174 error(USER, "color format with value output only");
175 break;
176 default:
177 error(CONSISTENCY, "botched output format");
178 }
179 if (hresolu > 0) {
180 if (vresolu > 0)
181 fprtresolu(hresolu, vresolu, stdout);
182 fflush(stdout);
183 }
184 /* process file */
185 while (getvec(orig, inform, fp) == 0 &&
186 getvec(direc, inform, fp) == 0) {
187
188 d = normalize(direc);
189 if (d == 0.0) { /* zero ==> flush */
190 bogusray();
191 if (--nextflush <= 0 || !vcount) {
192 fflush(stdout);
193 nextflush = hresolu;
194 }
195 } else {
196 samplendx++;
197 /* compute and print */
198 if (imm_irrad)
199 irrad(orig, direc);
200 else
201 rad(orig, direc, lim_dist ? d : 0.0);
202 /* flush if time */
203 if (!--nextflush) {
204 fflush(stdout);
205 nextflush = hresolu;
206 }
207 }
208 if (ferror(stdout))
209 error(SYSTEM, "write error");
210 if (vcount && !--vcount) /* check for end */
211 break;
212 }
213 fflush(stdout);
214 if (vcount)
215 error(USER, "unexpected EOF on input");
216 if (fname != NULL)
217 fclose(fp);
218 }
219
220
221 static void
222 trace_sources(void) /* trace rays to light sources, also */
223 {
224 int sn;
225
226 for (sn = 0; sn < nsources; sn++)
227 source[sn].sflags |= SFOLLOW;
228 }
229
230
231 static void
232 setoutput( /* set up output tables */
233 register char *vs
234 )
235 {
236 register oputf_t **table = ray_out;
237
238 castonly = 1;
239 while (*vs)
240 switch (*vs++) {
241 case 'T': /* trace sources */
242 if (!*vs) break;
243 trace_sources();
244 /* fall through */
245 case 't': /* trace */
246 if (!*vs) break;
247 *table = NULL;
248 table = every_out;
249 trace = ourtrace;
250 castonly = 0;
251 break;
252 case 'o': /* origin */
253 *table++ = oputo;
254 break;
255 case 'd': /* direction */
256 *table++ = oputd;
257 break;
258 case 'v': /* value */
259 *table++ = oputv;
260 castonly = 0;
261 break;
262 case 'l': /* effective distance */
263 *table++ = oputl;
264 castonly = 0;
265 break;
266 case 'c': /* local coordinates */
267 *table++ = oputc;
268 break;
269 case 'L': /* single ray length */
270 *table++ = oputL;
271 break;
272 case 'p': /* point */
273 *table++ = oputp;
274 break;
275 case 'n': /* perturbed normal */
276 *table++ = oputn;
277 castonly = 0;
278 break;
279 case 'N': /* unperturbed normal */
280 *table++ = oputN;
281 break;
282 case 's': /* surface */
283 *table++ = oputs;
284 break;
285 case 'w': /* weight */
286 *table++ = oputw;
287 break;
288 case 'W': /* coefficient */
289 *table++ = oputW;
290 if (ambounce > 0 && (ambacc > FTINY || ambssamp > 0))
291 error(WARNING,
292 "-otW accuracy depends on -aa 0 -as 0");
293 break;
294 case 'm': /* modifier */
295 *table++ = oputm;
296 break;
297 case 'M': /* material */
298 *table++ = oputM;
299 break;
300 case '~': /* tilde */
301 *table++ = oputtilde;
302 break;
303 }
304 *table = NULL;
305 }
306
307
308 static void
309 bogusray(void) /* print out empty record */
310 {
311 thisray.rorg[0] = thisray.rorg[1] = thisray.rorg[2] =
312 thisray.rdir[0] = thisray.rdir[1] = thisray.rdir[2] = 0.0;
313 thisray.rmax = 0.0;
314 rayorigin(&thisray, PRIMARY, NULL, NULL);
315 printvals(&thisray);
316 }
317
318
319 static void
320 rad( /* compute and print ray value(s) */
321 FVECT org,
322 FVECT dir,
323 double dmax
324 )
325 {
326 VCOPY(thisray.rorg, org);
327 VCOPY(thisray.rdir, dir);
328 thisray.rmax = dmax;
329 rayorigin(&thisray, PRIMARY, NULL, NULL);
330 if (castonly) {
331 if (!localhit(&thisray, &thescene)) {
332 if (thisray.ro == &Aftplane) { /* clipped */
333 thisray.ro = NULL;
334 thisray.rot = FHUGE;
335 } else
336 sourcehit(&thisray);
337 }
338 } else
339 rayvalue(&thisray);
340 printvals(&thisray);
341 }
342
343
344 static void
345 irrad( /* compute immediate irradiance value */
346 FVECT org,
347 FVECT dir
348 )
349 {
350 register int i;
351
352 for (i = 0; i < 3; i++) {
353 thisray.rorg[i] = org[i] + dir[i];
354 thisray.rdir[i] = -dir[i];
355 }
356 thisray.rmax = 0.0;
357 rayorigin(&thisray, PRIMARY, NULL, NULL);
358 /* pretend we hit surface */
359 thisray.rot = 1.0-1e-4;
360 thisray.rod = 1.0;
361 VCOPY(thisray.ron, dir);
362 for (i = 0; i < 3; i++) /* fudge factor */
363 thisray.rop[i] = org[i] + 1e-4*dir[i];
364 /* compute and print */
365 (*ofun[Lamb.otype].funp)(&Lamb, &thisray);
366 printvals(&thisray);
367 }
368
369
370 static void
371 printvals( /* print requested ray values */
372 RAY *r
373 )
374 {
375 register oputf_t **tp;
376
377 if (ray_out[0] == NULL)
378 return;
379 for (tp = ray_out; *tp != NULL; tp++)
380 (**tp)(r);
381 if (outform == 'a')
382 putchar('\n');
383 }
384
385
386 static int
387 getvec( /* get a vector from fp */
388 register FVECT vec,
389 int fmt,
390 FILE *fp
391 )
392 {
393 static float vf[3];
394 static double vd[3];
395 char buf[32];
396 register int i;
397
398 switch (fmt) {
399 case 'a': /* ascii */
400 for (i = 0; i < 3; i++) {
401 if (fgetword(buf, sizeof(buf), fp) == NULL ||
402 !isflt(buf))
403 return(-1);
404 vec[i] = atof(buf);
405 }
406 break;
407 case 'f': /* binary float */
408 if (fread((char *)vf, sizeof(float), 3, fp) != 3)
409 return(-1);
410 vec[0] = vf[0]; vec[1] = vf[1]; vec[2] = vf[2];
411 break;
412 case 'd': /* binary double */
413 if (fread((char *)vd, sizeof(double), 3, fp) != 3)
414 return(-1);
415 vec[0] = vd[0]; vec[1] = vd[1]; vec[2] = vd[2];
416 break;
417 default:
418 error(CONSISTENCY, "botched input format");
419 }
420 return(0);
421 }
422
423
424 static void
425 tranotify( /* record new modifier */
426 OBJECT obj
427 )
428 {
429 static int hitlimit = 0;
430 register OBJREC *o = objptr(obj);
431 register char **tralp;
432
433 if (obj == OVOID) { /* starting over */
434 traset[0] = 0;
435 hitlimit = 0;
436 return;
437 }
438 if (hitlimit || !ismodifier(o->otype))
439 return;
440 for (tralp = tralist; *tralp != NULL; tralp++)
441 if (!strcmp(o->oname, *tralp)) {
442 if (traset[0] >= MAXTSET) {
443 error(WARNING, "too many modifiers in trace list");
444 hitlimit++;
445 return; /* should this be fatal? */
446 }
447 insertelem(traset, obj);
448 return;
449 }
450 }
451
452
453 static void
454 ourtrace( /* print ray values */
455 RAY *r
456 )
457 {
458 register oputf_t **tp;
459
460 if (every_out[0] == NULL)
461 return;
462 if (r->ro == NULL) {
463 if (traincl == 1)
464 return;
465 } else if (traincl != -1 && traincl != inset(traset, r->ro->omod))
466 return;
467 tabin(r);
468 for (tp = every_out; *tp != NULL; tp++)
469 (**tp)(r);
470 if (outform == 'a')
471 putchar('\n');
472 }
473
474
475 static void
476 tabin( /* tab in appropriate amount */
477 RAY *r
478 )
479 {
480 const RAY *rp;
481
482 for (rp = r->parent; rp != NULL; rp = rp->parent)
483 putchar('\t');
484 }
485
486
487 static void
488 oputo( /* print origin */
489 RAY *r
490 )
491 {
492 (*putreal)(r->rorg[0]);
493 (*putreal)(r->rorg[1]);
494 (*putreal)(r->rorg[2]);
495 }
496
497
498 static void
499 oputd( /* print direction */
500 RAY *r
501 )
502 {
503 (*putreal)(r->rdir[0]);
504 (*putreal)(r->rdir[1]);
505 (*putreal)(r->rdir[2]);
506 }
507
508
509 static void
510 oputv( /* print value */
511 RAY *r
512 )
513 {
514 if (outform == 'c') {
515 COLR cout;
516 setcolr(cout, colval(r->rcol,RED),
517 colval(r->rcol,GRN),
518 colval(r->rcol,BLU));
519 fwrite((char *)cout, sizeof(cout), 1, stdout);
520 return;
521 }
522 (*putreal)(colval(r->rcol,RED));
523 (*putreal)(colval(r->rcol,GRN));
524 (*putreal)(colval(r->rcol,BLU));
525 }
526
527
528 static void
529 oputl( /* print effective distance */
530 RAY *r
531 )
532 {
533 (*putreal)(r->rt);
534 }
535
536
537 static void
538 oputL( /* print single ray length */
539 RAY *r
540 )
541 {
542 (*putreal)(r->rot);
543 }
544
545
546 static void
547 oputc( /* print local coordinates */
548 RAY *r
549 )
550 {
551 (*putreal)(r->uv[0]);
552 (*putreal)(r->uv[1]);
553 }
554
555
556 static void
557 oputp( /* print point */
558 RAY *r
559 )
560 {
561 if (r->rot < FHUGE) {
562 (*putreal)(r->rop[0]);
563 (*putreal)(r->rop[1]);
564 (*putreal)(r->rop[2]);
565 } else {
566 (*putreal)(0.0);
567 (*putreal)(0.0);
568 (*putreal)(0.0);
569 }
570 }
571
572
573 static void
574 oputN( /* print unperturbed normal */
575 RAY *r
576 )
577 {
578 if (r->rot < FHUGE) {
579 (*putreal)(r->ron[0]);
580 (*putreal)(r->ron[1]);
581 (*putreal)(r->ron[2]);
582 } else {
583 (*putreal)(0.0);
584 (*putreal)(0.0);
585 (*putreal)(0.0);
586 }
587 }
588
589
590 static void
591 oputn( /* print perturbed normal */
592 RAY *r
593 )
594 {
595 FVECT pnorm;
596
597 if (r->rot >= FHUGE) {
598 (*putreal)(0.0);
599 (*putreal)(0.0);
600 (*putreal)(0.0);
601 return;
602 }
603 raynormal(pnorm, r);
604 (*putreal)(pnorm[0]);
605 (*putreal)(pnorm[1]);
606 (*putreal)(pnorm[2]);
607 }
608
609
610 static void
611 oputs( /* print name */
612 RAY *r
613 )
614 {
615 if (r->ro != NULL)
616 fputs(r->ro->oname, stdout);
617 else
618 putchar('*');
619 putchar('\t');
620 }
621
622
623 static void
624 oputw( /* print weight */
625 RAY *r
626 )
627 {
628 (*putreal)(r->rweight);
629 }
630
631
632 static void
633 oputW( /* print contribution */
634 RAY *r
635 )
636 {
637 COLOR contr;
638
639 raycontrib(contr, r, PRIMARY);
640 (*putreal)(colval(contr,RED));
641 (*putreal)(colval(contr,GRN));
642 (*putreal)(colval(contr,BLU));
643 }
644
645
646 static void
647 oputm( /* print modifier */
648 RAY *r
649 )
650 {
651 if (r->ro != NULL)
652 if (r->ro->omod != OVOID)
653 fputs(objptr(r->ro->omod)->oname, stdout);
654 else
655 fputs(VOIDID, stdout);
656 else
657 putchar('*');
658 putchar('\t');
659 }
660
661
662 static void
663 oputM( /* print material */
664 RAY *r
665 )
666 {
667 OBJREC *mat;
668
669 if (r->ro != NULL) {
670 if ((mat = findmaterial(r->ro)) != NULL)
671 fputs(mat->oname, stdout);
672 else
673 fputs(VOIDID, stdout);
674 } else
675 putchar('*');
676 putchar('\t');
677 }
678
679
680 static void
681 oputtilde( /* output tilde (spacer) */
682 RAY *r
683 )
684 {
685 fputs("~\t", stdout);
686 }
687
688
689 static void
690 puta( /* print ascii value */
691 double v
692 )
693 {
694 printf("%e\t", v);
695 }
696
697
698 static void
699 putd(v) /* print binary double */
700 double v;
701 {
702 fwrite((char *)&v, sizeof(v), 1, stdout);
703 }
704
705
706 static void
707 putf(v) /* print binary float */
708 double v;
709 {
710 float f = v;
711
712 fwrite((char *)&f, sizeof(f), 1, stdout);
713 }
