| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: rtrace.c,v 2.40 2005/04/19 01:15:06 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* rtrace.c - program and variables for individual ray tracing.
| 6 |
| 7 |
| 8 |
#include "copyright.h"
| 9 |
| 10 |
| 11 |
* Input is in the form:
| 12 |
| 13 |
* xorg yorg zorg xdir ydir zdir
| 14 |
| 15 |
* The direction need not be normalized. Output is flexible.
| 16 |
* If the direction vector is (0,0,0), then the output is flushed.
| 17 |
* All values default to ascii representation of real
| 18 |
* numbers. Binary representations can be selected
| 19 |
* with '-ff' for float or '-fd' for double. By default,
| 20 |
* radiance is computed. The '-i' or '-I' options indicate that
| 21 |
* irradiance values are desired.
| 22 |
| 23 |
| 24 |
#include <time.h>
| 25 |
| 26 |
#include "platform.h"
| 27 |
#include "ray.h"
| 28 |
#include "ambient.h"
| 29 |
#include "source.h"
| 30 |
#include "otypes.h"
| 31 |
#include "resolu.h"
| 32 |
| 33 |
CUBE thescene; /* our scene */
| 34 |
OBJECT nsceneobjs; /* number of objects in our scene */
| 35 |
| 36 |
int dimlist[MAXDIM]; /* sampling dimensions */
| 37 |
int ndims = 0; /* number of sampling dimensions */
| 38 |
int samplendx = 0; /* index for this sample */
| 39 |
| 40 |
int imm_irrad = 0; /* compute immediate irradiance? */
| 41 |
int lim_dist = 0; /* limit distance? */
| 42 |
| 43 |
int inform = 'a'; /* input format */
| 44 |
int outform = 'a'; /* output format */
| 45 |
char *outvals = "v"; /* output specification */
| 46 |
| 47 |
int do_irrad = 0; /* compute irradiance? */
| 48 |
| 49 |
void (*trace)() = NULL; /* trace call */
| 50 |
| 51 |
char *tralist[128]; /* list of modifers to trace (or no) */
| 52 |
int traincl = -1; /* include == 1, exclude == 0 */
| 53 |
#define MAXTSET 511 /* maximum number in trace set */
| 54 |
OBJECT traset[MAXTSET+1]={0}; /* trace include/exclude set */
| 55 |
| 56 |
int hresolu = 0; /* horizontal (scan) size */
| 57 |
int vresolu = 0; /* vertical resolution */
| 58 |
| 59 |
double dstrsrc = 0.0; /* square source distribution */
| 60 |
double shadthresh = .03; /* shadow threshold */
| 61 |
double shadcert = .75; /* shadow certainty */
| 62 |
int directrelay = 2; /* number of source relays */
| 63 |
int vspretest = 512; /* virtual source pretest density */
| 64 |
int directvis = 1; /* sources visible? */
| 65 |
double srcsizerat = .2; /* maximum ratio source size/dist. */
| 66 |
| 67 |
COLOR cextinction = BLKCOLOR; /* global extinction coefficient */
| 68 |
COLOR salbedo = BLKCOLOR; /* global scattering albedo */
| 69 |
double seccg = 0.; /* global scattering eccentricity */
| 70 |
double ssampdist = 0.; /* scatter sampling distance */
| 71 |
| 72 |
double specthresh = .15; /* specular sampling threshold */
| 73 |
double specjitter = 1.; /* specular sampling jitter */
| 74 |
| 75 |
int backvis = 1; /* back face visibility */
| 76 |
| 77 |
int maxdepth = 8; /* maximum recursion depth */
| 78 |
double minweight = 2e-3; /* minimum ray weight */
| 79 |
| 80 |
char *ambfile = NULL; /* ambient file name */
| 81 |
COLOR ambval = BLKCOLOR; /* ambient value */
| 82 |
int ambvwt = 0; /* initial weight for ambient value */
| 83 |
double ambacc = 0.15; /* ambient accuracy */
| 84 |
int ambres = 256; /* ambient resolution */
| 85 |
int ambdiv = 1024; /* ambient divisions */
| 86 |
int ambssamp = 512; /* ambient super-samples */
| 87 |
int ambounce = 0; /* ambient bounces */
| 88 |
char *amblist[AMBLLEN]; /* ambient include/exclude list */
| 89 |
int ambincl = -1; /* include == 1, exclude == 0 */
| 90 |
| 91 |
static int castonly = 0;
| 92 |
| 93 |
static RAY thisray; /* for our convenience */
| 94 |
| 95 |
typedef void putf_t(double v);
| 96 |
static putf_t puta, putd, putf;
| 97 |
| 98 |
typedef void oputf_t(RAY *r);
| 99 |
static oputf_t oputo, oputd, oputv, oputl, oputL, oputc, oputp,
| 100 |
oputn, oputN, oputs, oputw, oputW, oputm, oputM, oputdash;
| 101 |
| 102 |
static void setoutput(char *vs);
| 103 |
static void tranotify(OBJECT obj);
| 104 |
static void bogusray(void);
| 105 |
static void rad(FVECT org, FVECT dir, double dmax);
| 106 |
static void irrad(FVECT org, FVECT dir);
| 107 |
static void printvals(RAY *r);
| 108 |
static int getvec(FVECT vec, int fmt, FILE *fp);
| 109 |
static void tabin(RAY *r);
| 110 |
static void ourtrace(RAY *r);
| 111 |
| 112 |
static oputf_t *ray_out[16], *every_out[16];
| 113 |
static putf_t *putreal;
| 114 |
| 115 |
void (*addobjnotify[])() = {ambnotify, tranotify, NULL};
| 116 |
| 117 |
| 118 |
void
| 119 |
quit( /* quit program */
| 120 |
int code
| 121 |
| 122 |
| 123 |
#ifndef NON_POSIX /* XXX we don't clean up elsewhere? */
| 124 |
headclean(); /* delete header file */
| 125 |
pfclean(); /* clean up persist files */
| 126 |
#endif
| 127 |
exit(code);
| 128 |
| 129 |
| 130 |
| 131 |
extern char *
| 132 |
formstr( /* return format identifier */
| 133 |
int f
| 134 |
| 135 |
| 136 |
switch (f) {
| 137 |
case 'a': return("ascii");
| 138 |
case 'f': return("float");
| 139 |
case 'd': return("double");
| 140 |
case 'c': return(COLRFMT);
| 141 |
| 142 |
return("unknown");
| 143 |
| 144 |
| 145 |
| 146 |
extern void
| 147 |
rtrace( /* trace rays from file */
| 148 |
char *fname
| 149 |
| 150 |
| 151 |
long vcount = hresolu>1 ? hresolu*vresolu : vresolu;
| 152 |
long nextflush = hresolu;
| 153 |
FILE *fp;
| 154 |
double d;
| 155 |
FVECT orig, direc;
| 156 |
/* set up input */
| 157 |
if (fname == NULL)
| 158 |
fp = stdin;
| 159 |
else if ((fp = fopen(fname, "r")) == NULL) {
| 160 |
sprintf(errmsg, "cannot open input file \"%s\"", fname);
| 161 |
error(SYSTEM, errmsg);
| 162 |
| 163 |
#ifdef _WIN32
| 164 |
if (inform != 'a')
| 165 |
SET_FILE_BINARY(fp);
| 166 |
#endif
| 167 |
/* set up output */
| 168 |
setoutput(outvals);
| 169 |
switch (outform) {
| 170 |
case 'a': putreal = puta; break;
| 171 |
case 'f': putreal = putf; break;
| 172 |
case 'd': putreal = putd; break;
| 173 |
case 'c':
| 174 |
if (strcmp(outvals, "v"))
| 175 |
error(USER, "color format with value output only");
| 176 |
break;
| 177 |
default:
| 178 |
error(CONSISTENCY, "botched output format");
| 179 |
| 180 |
if (hresolu > 0) {
| 181 |
if (vresolu > 0)
| 182 |
fprtresolu(hresolu, vresolu, stdout);
| 183 |
fflush(stdout);
| 184 |
| 185 |
/* process file */
| 186 |
while (getvec(orig, inform, fp) == 0 &&
| 187 |
getvec(direc, inform, fp) == 0) {
| 188 |
| 189 |
d = normalize(direc);
| 190 |
if (d == 0.0) { /* zero ==> flush */
| 191 |
bogusray();
| 192 |
if (--nextflush <= 0 || vcount <= 0) {
| 193 |
fflush(stdout);
| 194 |
| 195 |
| 196 |
} else {
| 197 |
samplendx++;
| 198 |
/* compute and print */
| 199 |
if (imm_irrad)
| 200 |
irrad(orig, direc);
| 201 |
else
| 202 |
rad(orig, direc, lim_dist ? d : 0.0);
| 203 |
/* flush if time */
| 204 |
if (--nextflush == 0) {
| 205 |
fflush(stdout);
| 206 |
| 207 |
| 208 |
| 209 |
if (ferror(stdout))
| 210 |
error(SYSTEM, "write error");
| 211 |
if (--vcount == 0) /* check for end */
| 212 |
break;
| 213 |
| 214 |
fflush(stdout);
| 215 |
if (vcount > 0)
| 216 |
error(USER, "read error");
| 217 |
if (fname != NULL)
| 218 |
fclose(fp);
| 219 |
| 220 |
| 221 |
| 222 |
static void
| 223 |
trace_sources(void) /* trace rays to light sources, also */
| 224 |
| 225 |
int sn;
| 226 |
| 227 |
for (sn = 0; sn < nsources; sn++)
| 228 |
source[sn].sflags |= SFOLLOW;
| 229 |
| 230 |
| 231 |
| 232 |
static void
| 233 |
setoutput( /* set up output tables */
| 234 |
register char *vs
| 235 |
| 236 |
| 237 |
register oputf_t **table = ray_out;
| 238 |
| 239 |
castonly = 1;
| 240 |
while (*vs)
| 241 |
switch (*vs++) {
| 242 |
case 'T': /* trace sources */
| 243 |
trace_sources();
| 244 |
/* fall through */
| 245 |
case 't': /* trace */
| 246 |
*table = NULL;
| 247 |
table = every_out;
| 248 |
trace = ourtrace;
| 249 |
castonly = 0;
| 250 |
break;
| 251 |
case 'o': /* origin */
| 252 |
*table++ = oputo;
| 253 |
break;
| 254 |
case 'd': /* direction */
| 255 |
*table++ = oputd;
| 256 |
break;
| 257 |
case 'v': /* value */
| 258 |
*table++ = oputv;
| 259 |
castonly = 0;
| 260 |
break;
| 261 |
case 'l': /* effective distance */
| 262 |
*table++ = oputl;
| 263 |
castonly = 0;
| 264 |
break;
| 265 |
case 'c': /* local coordinates */
| 266 |
*table++ = oputc;
| 267 |
break;
| 268 |
case 'L': /* single ray length */
| 269 |
*table++ = oputL;
| 270 |
break;
| 271 |
case 'p': /* point */
| 272 |
*table++ = oputp;
| 273 |
break;
| 274 |
case 'n': /* perturbed normal */
| 275 |
*table++ = oputn;
| 276 |
castonly = 0;
| 277 |
break;
| 278 |
case 'N': /* unperturbed normal */
| 279 |
*table++ = oputN;
| 280 |
break;
| 281 |
case 's': /* surface */
| 282 |
*table++ = oputs;
| 283 |
break;
| 284 |
case 'w': /* weight */
| 285 |
*table++ = oputw;
| 286 |
break;
| 287 |
case 'W': /* coefficient */
| 288 |
*table++ = oputW;
| 289 |
if (ambounce > 0 && (ambacc > FTINY || ambssamp > 0))
| 290 |
error(WARNING,
| 291 |
"-otW accuracy depends on -aa 0 -as 0");
| 292 |
break;
| 293 |
case 'm': /* modifier */
| 294 |
*table++ = oputm;
| 295 |
break;
| 296 |
case 'M': /* material */
| 297 |
*table++ = oputM;
| 298 |
break;
| 299 |
case '-': /* dash */
| 300 |
*table++ = oputdash;
| 301 |
break;
| 302 |
| 303 |
*table = NULL;
| 304 |
| 305 |
| 306 |
| 307 |
static void
| 308 |
bogusray(void) /* print out empty record */
| 309 |
| 310 |
thisray.rorg[0] = thisray.rorg[1] = thisray.rorg[2] =
| 311 |
thisray.rdir[0] = thisray.rdir[1] = thisray.rdir[2] = 0.0;
| 312 |
thisray.rmax = 0.0;
| 313 |
rayorigin(&thisray, PRIMARY, NULL, NULL);
| 314 |
printvals(&thisray);
| 315 |
| 316 |
| 317 |
| 318 |
static void
| 319 |
rad( /* compute and print ray value(s) */
| 320 |
FVECT org,
| 321 |
FVECT dir,
| 322 |
double dmax
| 323 |
| 324 |
| 325 |
VCOPY(thisray.rorg, org);
| 326 |
VCOPY(thisray.rdir, dir);
| 327 |
thisray.rmax = dmax;
| 328 |
| 329 |
if (castonly) {
| 330 |
if (!localhit(&thisray, &thescene)) {
| 331 |
if (thisray.ro == &Aftplane) { /* clipped */
| 332 |
thisray.ro = NULL;
| 333 |
thisray.rot = FHUGE;
| 334 |
} else
| 335 |
sourcehit(&thisray);
| 336 |
| 337 |
} else
| 338 |
rayvalue(&thisray);
| 339 |
| 340 |
| 341 |
| 342 |
| 343 |
static void
| 344 |
irrad( /* compute immediate irradiance value */
| 345 |
FVECT org,
| 346 |
FVECT dir
| 347 |
| 348 |
| 349 |
register int i;
| 350 |
| 351 |
for (i = 0; i < 3; i++) {
| 352 |
thisray.rorg[i] = org[i] + dir[i];
| 353 |
thisray.rdir[i] = -dir[i];
| 354 |
| 355 |
thisray.rmax = 0.0;
| 356 |
| 357 |
/* pretend we hit surface */
| 358 |
thisray.rot = 1.0-1e-4;
| 359 |
thisray.rod = 1.0;
| 360 |
VCOPY(thisray.ron, dir);
| 361 |
for (i = 0; i < 3; i++) /* fudge factor */
| 362 |
thisray.rop[i] = org[i] + 1e-4*dir[i];
| 363 |
| 364 |
(*ofun[Lamb.otype].funp)(&Lamb, &thisray);
| 365 |
| 366 |
| 367 |
| 368 |
| 369 |
static void
| 370 |
printvals( /* print requested ray values */
| 371 |
RAY *r
| 372 |
| 373 |
| 374 |
register oputf_t **tp;
| 375 |
| 376 |
if (ray_out[0] == NULL)
| 377 |
return;
| 378 |
for (tp = ray_out; *tp != NULL; tp++)
| 379 |
(**tp)(r);
| 380 |
if (outform == 'a')
| 381 |
putchar('\n');
| 382 |
| 383 |
| 384 |
| 385 |
static int
| 386 |
getvec( /* get a vector from fp */
| 387 |
register FVECT vec,
| 388 |
int fmt,
| 389 |
FILE *fp
| 390 |
| 391 |
| 392 |
static float vf[3];
| 393 |
static double vd[3];
| 394 |
char buf[32];
| 395 |
register int i;
| 396 |
| 397 |
switch (fmt) {
| 398 |
case 'a': /* ascii */
| 399 |
| 400 |
if (fgetword(buf, sizeof(buf), fp) == NULL ||
| 401 |
!isflt(buf))
| 402 |
return(-1);
| 403 |
vec[i] = atof(buf);
| 404 |
| 405 |
break;
| 406 |
case 'f': /* binary float */
| 407 |
if (fread((char *)vf, sizeof(float), 3, fp) != 3)
| 408 |
return(-1);
| 409 |
vec[0] = vf[0]; vec[1] = vf[1]; vec[2] = vf[2];
| 410 |
break;
| 411 |
case 'd': /* binary double */
| 412 |
if (fread((char *)vd, sizeof(double), 3, fp) != 3)
| 413 |
return(-1);
| 414 |
vec[0] = vd[0]; vec[1] = vd[1]; vec[2] = vd[2];
| 415 |
break;
| 416 |
default:
| 417 |
error(CONSISTENCY, "botched input format");
| 418 |
| 419 |
return(0);
| 420 |
| 421 |
| 422 |
| 423 |
static void
| 424 |
tranotify( /* record new modifier */
| 425 |
OBJECT obj
| 426 |
| 427 |
| 428 |
static int hitlimit = 0;
| 429 |
register OBJREC *o = objptr(obj);
| 430 |
register char **tralp;
| 431 |
| 432 |
if (obj == OVOID) { /* starting over */
| 433 |
traset[0] = 0;
| 434 |
hitlimit = 0;
| 435 |
return;
| 436 |
| 437 |
if (hitlimit || !ismodifier(o->otype))
| 438 |
return;
| 439 |
for (tralp = tralist; *tralp != NULL; tralp++)
| 440 |
if (!strcmp(o->oname, *tralp)) {
| 441 |
if (traset[0] >= MAXTSET) {
| 442 |
error(WARNING, "too many modifiers in trace list");
| 443 |
hitlimit++;
| 444 |
return; /* should this be fatal? */
| 445 |
| 446 |
insertelem(traset, obj);
| 447 |
return;
| 448 |
| 449 |
| 450 |
| 451 |
| 452 |
static void
| 453 |
ourtrace( /* print ray values */
| 454 |
RAY *r
| 455 |
| 456 |
| 457 |
| 458 |
| 459 |
if (every_out[0] == NULL)
| 460 |
return;
| 461 |
if (r->ro == NULL) {
| 462 |
if (traincl == 1)
| 463 |
return;
| 464 |
} else if (traincl != -1 && traincl != inset(traset, r->ro->omod))
| 465 |
return;
| 466 |
tabin(r);
| 467 |
for (tp = every_out; *tp != NULL; tp++)
| 468 |
(**tp)(r);
| 469 |
if (outform == 'a')
| 470 |
putchar('\n');
| 471 |
| 472 |
| 473 |
| 474 |
static void
| 475 |
tabin( /* tab in appropriate amount */
| 476 |
RAY *r
| 477 |
| 478 |
| 479 |
const RAY *rp;
| 480 |
| 481 |
for (rp = r->parent; rp != NULL; rp = rp->parent)
| 482 |
putchar('\t');
| 483 |
| 484 |
| 485 |
| 486 |
static void
| 487 |
oputo( /* print origin */
| 488 |
RAY *r
| 489 |
| 490 |
| 491 |
(*putreal)(r->rorg[0]);
| 492 |
(*putreal)(r->rorg[1]);
| 493 |
(*putreal)(r->rorg[2]);
| 494 |
| 495 |
| 496 |
| 497 |
static void
| 498 |
oputd( /* print direction */
| 499 |
RAY *r
| 500 |
| 501 |
| 502 |
(*putreal)(r->rdir[0]);
| 503 |
(*putreal)(r->rdir[1]);
| 504 |
(*putreal)(r->rdir[2]);
| 505 |
| 506 |
| 507 |
| 508 |
static void
| 509 |
oputv( /* print value */
| 510 |
RAY *r
| 511 |
| 512 |
| 513 |
if (outform == 'c') {
| 514 |
COLR cout;
| 515 |
setcolr(cout, colval(r->rcol,RED),
| 516 |
colval(r->rcol,GRN),
| 517 |
colval(r->rcol,BLU));
| 518 |
fwrite((char *)cout, sizeof(cout), 1, stdout);
| 519 |
return;
| 520 |
| 521 |
(*putreal)(colval(r->rcol,RED));
| 522 |
(*putreal)(colval(r->rcol,GRN));
| 523 |
(*putreal)(colval(r->rcol,BLU));
| 524 |
| 525 |
| 526 |
| 527 |
static void
| 528 |
oputl( /* print effective distance */
| 529 |
RAY *r
| 530 |
| 531 |
| 532 |
(*putreal)(r->rt);
| 533 |
| 534 |
| 535 |
| 536 |
static void
| 537 |
oputL( /* print single ray length */
| 538 |
RAY *r
| 539 |
| 540 |
| 541 |
(*putreal)(r->rot);
| 542 |
| 543 |
| 544 |
| 545 |
static void
| 546 |
oputc( /* print local coordinates */
| 547 |
RAY *r
| 548 |
| 549 |
| 550 |
(*putreal)(r->uv[0]);
| 551 |
(*putreal)(r->uv[1]);
| 552 |
| 553 |
| 554 |
| 555 |
static void
| 556 |
oputp( /* print point */
| 557 |
RAY *r
| 558 |
| 559 |
| 560 |
if (r->rot < FHUGE) {
| 561 |
(*putreal)(r->rop[0]);
| 562 |
(*putreal)(r->rop[1]);
| 563 |
(*putreal)(r->rop[2]);
| 564 |
} else {
| 565 |
(*putreal)(0.0);
| 566 |
(*putreal)(0.0);
| 567 |
(*putreal)(0.0);
| 568 |
| 569 |
| 570 |
| 571 |
| 572 |
static void
| 573 |
oputN( /* print unperturbed normal */
| 574 |
RAY *r
| 575 |
| 576 |
| 577 |
| 578 |
(*putreal)(r->ron[0]);
| 579 |
(*putreal)(r->ron[1]);
| 580 |
(*putreal)(r->ron[2]);
| 581 |
} else {
| 582 |
(*putreal)(0.0);
| 583 |
(*putreal)(0.0);
| 584 |
(*putreal)(0.0);
| 585 |
| 586 |
| 587 |
| 588 |
| 589 |
static void
| 590 |
oputn( /* print perturbed normal */
| 591 |
RAY *r
| 592 |
| 593 |
| 594 |
FVECT pnorm;
| 595 |
| 596 |
if (r->rot >= FHUGE) {
| 597 |
(*putreal)(0.0);
| 598 |
(*putreal)(0.0);
| 599 |
(*putreal)(0.0);
| 600 |
return;
| 601 |
| 602 |
raynormal(pnorm, r);
| 603 |
(*putreal)(pnorm[0]);
| 604 |
(*putreal)(pnorm[1]);
| 605 |
(*putreal)(pnorm[2]);
| 606 |
| 607 |
| 608 |
| 609 |
static void
| 610 |
oputs( /* print name */
| 611 |
RAY *r
| 612 |
| 613 |
| 614 |
if (r->ro != NULL)
| 615 |
fputs(r->ro->oname, stdout);
| 616 |
else
| 617 |
putchar('*');
| 618 |
putchar('\t');
| 619 |
| 620 |
| 621 |
| 622 |
static void
| 623 |
oputw( /* print weight */
| 624 |
RAY *r
| 625 |
| 626 |
| 627 |
(*putreal)(r->rweight);
| 628 |
| 629 |
| 630 |
| 631 |
static void
| 632 |
oputW( /* print contribution */
| 633 |
RAY *r
| 634 |
| 635 |
| 636 |
COLOR contr;
| 637 |
| 638 |
raycontrib(contr, r, PRIMARY);
| 639 |
(*putreal)(colval(contr,RED));
| 640 |
(*putreal)(colval(contr,GRN));
| 641 |
(*putreal)(colval(contr,BLU));
| 642 |
| 643 |
| 644 |
| 645 |
static void
| 646 |
oputm( /* print modifier */
| 647 |
RAY *r
| 648 |
| 649 |
| 650 |
if (r->ro != NULL)
| 651 |
if (r->ro->omod != OVOID)
| 652 |
fputs(objptr(r->ro->omod)->oname, stdout);
| 653 |
else
| 654 |
fputs(VOIDID, stdout);
| 655 |
else
| 656 |
putchar('*');
| 657 |
putchar('\t');
| 658 |
| 659 |
| 660 |
| 661 |
static void
| 662 |
oputM( /* print material */
| 663 |
RAY *r
| 664 |
| 665 |
| 666 |
OBJREC *mat;
| 667 |
| 668 |
if (r->ro != NULL) {
| 669 |
if ((mat = findmaterial(r->ro)) != NULL)
| 670 |
fputs(mat->oname, stdout);
| 671 |
else
| 672 |
| 673 |
} else
| 674 |
putchar('*');
| 675 |
putchar('\t');
| 676 |
| 677 |
| 678 |
| 679 |
static void
| 680 |
oputdash( /* output dash (spacer) */
| 681 |
RAY *r
| 682 |
| 683 |
| 684 |
putchar('-');
| 685 |
putchar('\t');
| 686 |
| 687 |
| 688 |
| 689 |
static void
| 690 |
puta( /* print ascii value */
| 691 |
double v
| 692 |
| 693 |
| 694 |
printf("%e\t", v);
| 695 |
| 696 |
| 697 |
| 698 |
static void
| 699 |
putd(v) /* print binary double */
| 700 |
double v;
| 701 |
| 702 |
fwrite((char *)&v, sizeof(v), 1, stdout);
| 703 |
| 704 |
| 705 |
| 706 |
static void
| 707 |
putf(v) /* print binary float */
| 708 |
double v;
| 709 |
| 710 |
float f = v;
| 711 |
| 712 |
fwrite((char *)&f, sizeof(f), 1, stdout);
| 713 |
