root/Development/ray/src/rt/rtrace.c
Revision: 2.23
Committed: Tue Jan 14 19:54:27 1997 UTC (28 years, 10 months ago) by greg
Changes since 2.22: +4 -1 lines
fixed bug in printing void materials.
1 /* Copyright (c) 1995 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * rtrace.c - program and variables for individual ray tracing.
9 *
10 * 6/11/86
11 */
12
13 /*
14 * Input is in the form:
15 *
16 * xorg yorg zorg xdir ydir zdir
17 *
18 * The direction need not be normalized. Output is flexible.
19 * If the direction vector is (0,0,0), then the output is flushed.
20 * All values default to ascii representation of real
21 * numbers. Binary representations can be selected
22 * with '-ff' for float or '-fd' for double. By default,
23 * radiance is computed. The '-i' or '-I' options indicate that
24 * irradiance values are desired.
25 */
26
27 #include "ray.h"
28
29 #include "octree.h"
30
31 #include "otypes.h"
32
33 #include "resolu.h"
34
35 int dimlist[MAXDIM]; /* sampling dimensions */
36 int ndims = 0; /* number of sampling dimensions */
37 int samplendx = 0; /* index for this sample */
38
39 int imm_irrad = 0; /* compute immediate irradiance? */
40
41 int inform = 'a'; /* input format */
42 int outform = 'a'; /* output format */
43 char *outvals = "v"; /* output specification */
44
45 char *tralist[128]; /* list of modifers to trace (or no) */
46 int traincl = -1; /* include == 1, exclude == 0 */
47 #define MAXTSET 511 /* maximum number in trace set */
48 OBJECT traset[MAXTSET+1]={0}; /* trace include/exclude set */
49
50 int hresolu = 0; /* horizontal (scan) size */
51 int vresolu = 0; /* vertical resolution */
52
53 double dstrsrc = 0.0; /* square source distribution */
54 double shadthresh = .05; /* shadow threshold */
55 double shadcert = .5; /* shadow certainty */
56 int directrelay = 2; /* number of source relays */
57 int vspretest = 512; /* virtual source pretest density */
58 int directvis = 1; /* sources visible? */
59 double srcsizerat = .2; /* maximum ratio source size/dist. */
60
61 COLOR cextinction = BLKCOLOR; /* global extinction coefficient */
62 COLOR salbedo = BLKCOLOR; /* global scattering albedo */
63 double seccg = 0.; /* global scattering eccentricity */
64 double ssampdist = 0.; /* scatter sampling distance */
65
66 double specthresh = .15; /* specular sampling threshold */
67 double specjitter = 1.; /* specular sampling jitter */
68
69 int backvis = 1; /* back face visibility */
70
71 int maxdepth = 6; /* maximum recursion depth */
72 double minweight = 4e-3; /* minimum ray weight */
73
74 COLOR ambval = BLKCOLOR; /* ambient value */
75 int ambvwt = 0; /* initial weight for ambient value */
76 double ambacc = 0.2; /* ambient accuracy */
77 int ambres = 128; /* ambient resolution */
78 int ambdiv = 512; /* ambient divisions */
79 int ambssamp = 0; /* ambient super-samples */
80 int ambounce = 0; /* ambient bounces */
81 char *amblist[128]; /* ambient include/exclude list */
82 int ambincl = -1; /* include == 1, exclude == 0 */
83
84 extern OBJREC Lamb; /* a Lambertian surface */
85
86 static RAY thisray; /* for our convenience */
87
88 static int oputo(), oputd(), oputv(), oputl(), oputL(),
89 oputp(), oputn(), oputN(), oputs(), oputw(), oputm();
90
91 static int ourtrace(), tabin();
92 static int (*ray_out[16])(), (*every_out[16])();
93 static int castonly = 0;
94
95 static int puta(), putf(), putd();
96
97 static int (*putreal)();
98
99
100 quit(code) /* quit program */
101 int code;
102 {
103 #ifndef NIX
104 headclean(); /* delete header file */
105 pfclean(); /* clean up persist files */
106 #endif
107 exit(code);
108 }
109
110
111 char *
112 formstr(f) /* return format identifier */
113 int f;
114 {
115 switch (f) {
116 case 'a': return("ascii");
117 case 'f': return("float");
118 case 'd': return("double");
119 case 'c': return(COLRFMT);
120 }
121 return("unknown");
122 }
123
124
125 rtrace(fname) /* trace rays from file */
126 char *fname;
127 {
128 long vcount = hresolu>1 ? hresolu*vresolu : vresolu;
129 long nextflush = hresolu;
130 FILE *fp;
131 FVECT orig, direc;
132 /* set up input */
133 if (fname == NULL)
134 fp = stdin;
135 else if ((fp = fopen(fname, "r")) == NULL) {
136 sprintf(errmsg, "cannot open input file \"%s\"", fname);
137 error(SYSTEM, errmsg);
138 }
139 #ifdef MSDOS
140 if (inform != 'a')
141 setmode(fileno(fp), O_BINARY);
142 #endif
143 /* set up output */
144 setoutput(outvals);
145 switch (outform) {
146 case 'a': putreal = puta; break;
147 case 'f': putreal = putf; break;
148 case 'd': putreal = putd; break;
149 case 'c':
150 if (strcmp(outvals, "v"))
151 error(USER, "color format with value output only");
152 break;
153 default:
154 error(CONSISTENCY, "botched output format");
155 }
156 if (hresolu > 0) {
157 if (vresolu > 0)
158 fprtresolu(hresolu, vresolu, stdout);
159 fflush(stdout);
160 }
161 /* process file */
162 while (getvec(orig, inform, fp) == 0 &&
163 getvec(direc, inform, fp) == 0) {
164
165 if (normalize(direc) == 0.0) { /* zero ==> flush */
166 fflush(stdout);
167 continue;
168 }
169 samplendx++;
170 /* compute and print */
171 if (imm_irrad)
172 irrad(orig, direc);
173 else
174 rad(orig, direc);
175 /* flush if time */
176 if (--nextflush == 0) {
177 fflush(stdout);
178 nextflush = hresolu;
179 }
180 if (ferror(stdout))
181 error(SYSTEM, "write error");
182 if (--vcount == 0) /* check for end */
183 break;
184 }
185 fflush(stdout);
186 if (vcount > 0)
187 error(USER, "read error");
188 if (fname != NULL)
189 fclose(fp);
190 }
191
192
193 setoutput(vs) /* set up output tables */
194 register char *vs;
195 {
196 extern int (*trace)();
197 register int (**table)() = ray_out;
198
199 castonly = 1;
200 while (*vs)
201 switch (*vs++) {
202 case 't': /* trace */
203 *table = NULL;
204 table = every_out;
205 trace = ourtrace;
206 castonly = 0;
207 break;
208 case 'o': /* origin */
209 *table++ = oputo;
210 break;
211 case 'd': /* direction */
212 *table++ = oputd;
213 break;
214 case 'v': /* value */
215 *table++ = oputv;
216 castonly = 0;
217 break;
218 case 'l': /* effective distance */
219 *table++ = oputl;
220 castonly = 0;
221 break;
222 case 'L': /* single ray length */
223 *table++ = oputL;
224 break;
225 case 'p': /* point */
226 *table++ = oputp;
227 break;
228 case 'n': /* perturbed normal */
229 *table++ = oputn;
230 castonly = 0;
231 break;
232 case 'N': /* unperturbed normal */
233 *table++ = oputN;
234 break;
235 case 's': /* surface */
236 *table++ = oputs;
237 break;
238 case 'w': /* weight */
239 *table++ = oputw;
240 break;
241 case 'm': /* modifier */
242 *table++ = oputm;
243 break;
244 }
245 *table = NULL;
246 }
247
248
249 rad(org, dir) /* compute and print ray value(s) */
250 FVECT org, dir;
251 {
252 VCOPY(thisray.rorg, org);
253 VCOPY(thisray.rdir, dir);
254 thisray.rmax = 0.0;
255 rayorigin(&thisray, NULL, PRIMARY, 1.0);
256 if (castonly)
257 localhit(&thisray, &thescene) || sourcehit(&thisray);
258 else
259 rayvalue(&thisray);
260 printvals(&thisray);
261 }
262
263
264 irrad(org, dir) /* compute immediate irradiance value */
265 FVECT org, dir;
266 {
267 register int i;
268
269 for (i = 0; i < 3; i++) {
270 thisray.rorg[i] = org[i] + dir[i];
271 thisray.rdir[i] = -dir[i];
272 }
273 rayorigin(&thisray, NULL, PRIMARY, 1.0);
274 /* pretend we hit surface */
275 thisray.rot = 1.0-1e-4;
276 thisray.rod = 1.0;
277 VCOPY(thisray.ron, dir);
278 for (i = 0; i < 3; i++) /* fudge factor */
279 thisray.rop[i] = org[i] + 1e-4*dir[i];
280 /* compute and print */
281 (*ofun[Lamb.otype].funp)(&Lamb, &thisray);
282 printvals(&thisray);
283 }
284
285
286 printvals(r) /* print requested ray values */
287 RAY *r;
288 {
289 register int (**tp)();
290
291 if (ray_out[0] == NULL)
292 return;
293 for (tp = ray_out; *tp != NULL; tp++)
294 (**tp)(r);
295 if (outform == 'a')
296 putchar('\n');
297 }
298
299
300 getvec(vec, fmt, fp) /* get a vector from fp */
301 register FVECT vec;
302 int fmt;
303 FILE *fp;
304 {
305 extern char *fgetword();
306 static float vf[3];
307 static double vd[3];
308 char buf[32];
309 register int i;
310
311 switch (fmt) {
312 case 'a': /* ascii */
313 for (i = 0; i < 3; i++) {
314 if (fgetword(buf, sizeof(buf), fp) == NULL ||
315 !isflt(buf))
316 return(-1);
317 vec[i] = atof(buf);
318 }
319 break;
320 case 'f': /* binary float */
321 if (fread((char *)vf, sizeof(float), 3, fp) != 3)
322 return(-1);
323 vec[0] = vf[0]; vec[1] = vf[1]; vec[2] = vf[2];
324 break;
325 case 'd': /* binary double */
326 if (fread((char *)vd, sizeof(double), 3, fp) != 3)
327 return(-1);
328 vec[0] = vd[0]; vec[1] = vd[1]; vec[2] = vd[2];
329 break;
330 default:
331 error(CONSISTENCY, "botched input format");
332 }
333 return(0);
334 }
335
336
337 tranotify(obj) /* record new modifier */
338 OBJECT obj;
339 {
340 static int hitlimit = 0;
341 register OBJREC *o = objptr(obj);
342 register char **tralp;
343
344 if (hitlimit || !ismodifier(o->otype))
345 return;
346 for (tralp = tralist; *tralp != NULL; tralp++)
347 if (!strcmp(o->oname, *tralp)) {
348 if (traset[0] >= MAXTSET) {
349 error(WARNING, "too many modifiers in trace list");
350 hitlimit++;
351 return; /* should this be fatal? */
352 }
353 insertelem(traset, obj);
354 return;
355 }
356 }
357
358
359 static
360 ourtrace(r) /* print ray values */
361 RAY *r;
362 {
363 register int (**tp)();
364
365 if (every_out[0] == NULL)
366 return;
367 if (r->ro == NULL) {
368 if (traincl == 1)
369 return;
370 } else if (traincl != -1 && traincl != inset(traset, r->ro->omod))
371 return;
372 tabin(r);
373 for (tp = every_out; *tp != NULL; tp++)
374 (**tp)(r);
375 putchar('\n');
376 }
377
378
379 static
380 tabin(r) /* tab in appropriate amount */
381 RAY *r;
382 {
383 register RAY *rp;
384
385 for (rp = r->parent; rp != NULL; rp = rp->parent)
386 putchar('\t');
387 }
388
389
390 static
391 oputo(r) /* print origin */
392 register RAY *r;
393 {
394 (*putreal)(r->rorg[0]);
395 (*putreal)(r->rorg[1]);
396 (*putreal)(r->rorg[2]);
397 }
398
399
400 static
401 oputd(r) /* print direction */
402 register RAY *r;
403 {
404 (*putreal)(r->rdir[0]);
405 (*putreal)(r->rdir[1]);
406 (*putreal)(r->rdir[2]);
407 }
408
409
410 static
411 oputv(r) /* print value */
412 register RAY *r;
413 {
414 COLR cout;
415
416 if (outform == 'c') {
417 setcolr(cout, colval(r->rcol,RED),
418 colval(r->rcol,GRN),
419 colval(r->rcol,BLU));
420 fwrite((char *)cout, sizeof(cout), 1, stdout);
421 return;
422 }
423 (*putreal)(colval(r->rcol,RED));
424 (*putreal)(colval(r->rcol,GRN));
425 (*putreal)(colval(r->rcol,BLU));
426 }
427
428
429 static
430 oputl(r) /* print effective distance */
431 register RAY *r;
432 {
433 (*putreal)(r->rt);
434 }
435
436
437 static
438 oputL(r) /* print single ray length */
439 register RAY *r;
440 {
441 (*putreal)(r->rot);
442 }
443
444
445 static
446 oputp(r) /* print point */
447 register RAY *r;
448 {
449 if (r->rot < FHUGE) {
450 (*putreal)(r->rop[0]);
451 (*putreal)(r->rop[1]);
452 (*putreal)(r->rop[2]);
453 } else {
454 (*putreal)(0.0);
455 (*putreal)(0.0);
456 (*putreal)(0.0);
457 }
458 }
459
460
461 static
462 oputN(r) /* print unperturbed normal */
463 register RAY *r;
464 {
465 if (r->rot < FHUGE) {
466 (*putreal)(r->ron[0]);
467 (*putreal)(r->ron[1]);
468 (*putreal)(r->ron[2]);
469 } else {
470 (*putreal)(0.0);
471 (*putreal)(0.0);
472 (*putreal)(0.0);
473 }
474 }
475
476
477 static
478 oputn(r) /* print perturbed normal */
479 RAY *r;
480 {
481 FVECT pnorm;
482
483 if (r->rot >= FHUGE) {
484 (*putreal)(0.0);
485 (*putreal)(0.0);
486 (*putreal)(0.0);
487 return;
488 }
489 raynormal(pnorm, r);
490 (*putreal)(pnorm[0]);
491 (*putreal)(pnorm[1]);
492 (*putreal)(pnorm[2]);
493 }
494
495
496 static
497 oputs(r) /* print name */
498 register RAY *r;
499 {
500 if (r->ro != NULL)
501 fputs(r->ro->oname, stdout);
502 else
503 putchar('*');
504 putchar('\t');
505 }
506
507
508 static
509 oputw(r) /* print weight */
510 register RAY *r;
511 {
512 (*putreal)(r->rweight);
513 }
514
515
516 static
517 oputm(r) /* print modifier */
518 register RAY *r;
519 {
520 if (r->ro != NULL)
521 if (r->ro->omod != OVOID)
522 fputs(objptr(r->ro->omod)->oname, stdout);
523 else
524 fputs(VOIDID, stdout);
525 else
526 putchar('*');
527 putchar('\t');
528 }
529
530
531 static
532 puta(v) /* print ascii value */
533 double v;
534 {
535 printf("%e\t", v);
536 }
537
538
539 static
540 putd(v) /* print binary double */
541 double v;
542 {
543 fwrite((char *)&v, sizeof(v), 1, stdout);
544 }
545
546
547 static
548 putf(v) /* print binary float */
549 double v;
550 {
551 float f = v;
552
553 fwrite((char *)&f, sizeof(f), 1, stdout);
554 }
