| 1 |
/* Copyright (c) 1994 Regents of the University of California */
| 2 |
| 3 |
#ifndef lint
| 4 |
static char SCCSid[] = "$SunId$ LBL";
| 5 |
#endif
| 6 |
| 7 |
| 8 |
* rtrace.c - program and variables for individual ray tracing.
| 9 |
| 10 |
* 6/11/86
| 11 |
| 12 |
| 13 |
| 14 |
* Input is in the form:
| 15 |
| 16 |
* xorg yorg zorg xdir ydir zdir
| 17 |
| 18 |
* The direction need not be normalized. Output is flexible.
| 19 |
* If the direction vector is (0,0,0), then the output is flushed.
| 20 |
* All values default to ascii representation of real
| 21 |
* numbers. Binary representations can be selected
| 22 |
* with '-ff' for float or '-fd' for double. By default,
| 23 |
* radiance is computed. The '-i' or '-I' options indicate that
| 24 |
* irradiance values are desired.
| 25 |
| 26 |
| 27 |
#include "ray.h"
| 28 |
| 29 |
#include "octree.h"
| 30 |
| 31 |
#include "otypes.h"
| 32 |
| 33 |
#include "resolu.h"
| 34 |
| 35 |
int dimlist[MAXDIM]; /* sampling dimensions */
| 36 |
int ndims = 0; /* number of sampling dimensions */
| 37 |
int samplendx = 0; /* index for this sample */
| 38 |
| 39 |
int imm_irrad = 0; /* compute immediate irradiance? */
| 40 |
| 41 |
int inform = 'a'; /* input format */
| 42 |
int outform = 'a'; /* output format */
| 43 |
char *outvals = "v"; /* output specification */
| 44 |
| 45 |
char *tralist[128]; /* list of modifers to trace (or no) */
| 46 |
int traincl = -1; /* include == 1, exclude == 0 */
| 47 |
#define MAXTSET 511 /* maximum number in trace set */
| 48 |
OBJECT traset[MAXTSET+1]={0}; /* trace include/exclude set */
| 49 |
| 50 |
int hresolu = 0; /* horizontal (scan) size */
| 51 |
int vresolu = 0; /* vertical resolution */
| 52 |
| 53 |
double dstrsrc = 0.0; /* square source distribution */
| 54 |
double shadthresh = .05; /* shadow threshold */
| 55 |
double shadcert = .5; /* shadow certainty */
| 56 |
int directrelay = 1; /* number of source relays */
| 57 |
int vspretest = 512; /* virtual source pretest density */
| 58 |
int directvis = 1; /* sources visible? */
| 59 |
double srcsizerat = .25; /* maximum ratio source size/dist. */
| 60 |
| 61 |
double specthresh = .15; /* specular sampling threshold */
| 62 |
double specjitter = 1.; /* specular sampling jitter */
| 63 |
| 64 |
int maxdepth = 6; /* maximum recursion depth */
| 65 |
double minweight = 4e-3; /* minimum ray weight */
| 66 |
| 67 |
COLOR ambval = BLKCOLOR; /* ambient value */
| 68 |
double ambacc = 0.2; /* ambient accuracy */
| 69 |
int ambres = 32; /* ambient resolution */
| 70 |
int ambdiv = 128; /* ambient divisions */
| 71 |
int ambssamp = 0; /* ambient super-samples */
| 72 |
int ambounce = 0; /* ambient bounces */
| 73 |
char *amblist[128]; /* ambient include/exclude list */
| 74 |
int ambincl = -1; /* include == 1, exclude == 0 */
| 75 |
| 76 |
extern OBJREC Lamb; /* a Lambertian surface */
| 77 |
| 78 |
static RAY thisray; /* for our convenience */
| 79 |
| 80 |
static int oputo(), oputd(), oputv(), oputl(), oputL(),
| 81 |
oputp(), oputn(), oputN(), oputs(), oputw(), oputm();
| 82 |
| 83 |
static int ourtrace(), tabin();
| 84 |
static int (*ray_out[16])(), (*every_out[16])();
| 85 |
static int castonly = 0;
| 86 |
| 87 |
static int puta(), putf(), putd();
| 88 |
| 89 |
static int (*putreal)();
| 90 |
| 91 |
| 92 |
quit(code) /* quit program */
| 93 |
int code;
| 94 |
| 95 |
#ifndef NIX
| 96 |
headclean(); /* delete header file */
| 97 |
pfclean(); /* clean up persist files */
| 98 |
#endif
| 99 |
exit(code);
| 100 |
| 101 |
| 102 |
| 103 |
char *
| 104 |
formstr(f) /* return format identifier */
| 105 |
int f;
| 106 |
| 107 |
switch (f) {
| 108 |
case 'a': return("ascii");
| 109 |
case 'f': return("float");
| 110 |
case 'd': return("double");
| 111 |
case 'c': return(COLRFMT);
| 112 |
| 113 |
return("unknown");
| 114 |
| 115 |
| 116 |
| 117 |
rtrace(fname) /* trace rays from file */
| 118 |
char *fname;
| 119 |
| 120 |
long vcount = hresolu>1 ? hresolu*vresolu : vresolu;
| 121 |
long nextflush = hresolu;
| 122 |
FILE *fp;
| 123 |
FVECT orig, direc;
| 124 |
/* set up input */
| 125 |
if (fname == NULL)
| 126 |
fp = stdin;
| 127 |
else if ((fp = fopen(fname, "r")) == NULL) {
| 128 |
sprintf(errmsg, "cannot open input file \"%s\"", fname);
| 129 |
error(SYSTEM, errmsg);
| 130 |
| 131 |
#ifdef MSDOS
| 132 |
if (inform != 'a')
| 133 |
setmode(fileno(fp), O_BINARY);
| 134 |
#endif
| 135 |
/* set up output */
| 136 |
setoutput(outvals);
| 137 |
switch (outform) {
| 138 |
case 'a': putreal = puta; break;
| 139 |
case 'f': putreal = putf; break;
| 140 |
case 'd': putreal = putd; break;
| 141 |
case 'c':
| 142 |
if (strcmp(outvals, "v"))
| 143 |
error(USER, "color format with value output only");
| 144 |
break;
| 145 |
default:
| 146 |
error(CONSISTENCY, "botched output format");
| 147 |
| 148 |
if (hresolu > 0) {
| 149 |
if (vresolu > 0)
| 150 |
fprtresolu(hresolu, vresolu, stdout);
| 151 |
fflush(stdout);
| 152 |
| 153 |
/* process file */
| 154 |
while (getvec(orig, inform, fp) == 0 &&
| 155 |
getvec(direc, inform, fp) == 0) {
| 156 |
| 157 |
if (normalize(direc) == 0.0) { /* zero ==> flush */
| 158 |
fflush(stdout);
| 159 |
continue;
| 160 |
| 161 |
samplendx++;
| 162 |
/* compute and print */
| 163 |
if (imm_irrad)
| 164 |
irrad(orig, direc);
| 165 |
else
| 166 |
rad(orig, direc);
| 167 |
/* flush if time */
| 168 |
if (--nextflush == 0) {
| 169 |
fflush(stdout);
| 170 |
| 171 |
| 172 |
if (ferror(stdout))
| 173 |
error(SYSTEM, "write error");
| 174 |
if (--vcount == 0) /* check for end */
| 175 |
break;
| 176 |
| 177 |
fflush(stdout);
| 178 |
if (vcount > 0)
| 179 |
error(USER, "read error");
| 180 |
if (fname != NULL)
| 181 |
fclose(fp);
| 182 |
| 183 |
| 184 |
| 185 |
setoutput(vs) /* set up output tables */
| 186 |
register char *vs;
| 187 |
| 188 |
extern int (*trace)();
| 189 |
register int (**table)() = ray_out;
| 190 |
| 191 |
castonly = 1;
| 192 |
while (*vs)
| 193 |
switch (*vs++) {
| 194 |
case 't': /* trace */
| 195 |
*table = NULL;
| 196 |
table = every_out;
| 197 |
trace = ourtrace;
| 198 |
castonly = 0;
| 199 |
break;
| 200 |
case 'o': /* origin */
| 201 |
*table++ = oputo;
| 202 |
break;
| 203 |
case 'd': /* direction */
| 204 |
*table++ = oputd;
| 205 |
break;
| 206 |
case 'v': /* value */
| 207 |
*table++ = oputv;
| 208 |
castonly = 0;
| 209 |
break;
| 210 |
case 'l': /* effective distance */
| 211 |
*table++ = oputl;
| 212 |
castonly = 0;
| 213 |
break;
| 214 |
case 'L': /* single ray length */
| 215 |
*table++ = oputL;
| 216 |
break;
| 217 |
case 'p': /* point */
| 218 |
*table++ = oputp;
| 219 |
break;
| 220 |
case 'n': /* perturbed normal */
| 221 |
*table++ = oputn;
| 222 |
castonly = 0;
| 223 |
break;
| 224 |
case 'N': /* unperturbed normal */
| 225 |
*table++ = oputN;
| 226 |
break;
| 227 |
case 's': /* surface */
| 228 |
*table++ = oputs;
| 229 |
break;
| 230 |
case 'w': /* weight */
| 231 |
*table++ = oputw;
| 232 |
break;
| 233 |
case 'm': /* modifier */
| 234 |
*table++ = oputm;
| 235 |
break;
| 236 |
| 237 |
*table = NULL;
| 238 |
| 239 |
| 240 |
| 241 |
rad(org, dir) /* compute and print ray value(s) */
| 242 |
FVECT org, dir;
| 243 |
| 244 |
VCOPY(thisray.rorg, org);
| 245 |
VCOPY(thisray.rdir, dir);
| 246 |
thisray.rmax = 0.0;
| 247 |
rayorigin(&thisray, NULL, PRIMARY, 1.0);
| 248 |
if (castonly)
| 249 |
localhit(&thisray, &thescene) || sourcehit(&thisray);
| 250 |
else
| 251 |
rayvalue(&thisray);
| 252 |
printvals(&thisray);
| 253 |
| 254 |
| 255 |
| 256 |
irrad(org, dir) /* compute immediate irradiance value */
| 257 |
FVECT org, dir;
| 258 |
| 259 |
register int i;
| 260 |
| 261 |
for (i = 0; i < 3; i++) {
| 262 |
thisray.rorg[i] = org[i] + dir[i];
| 263 |
thisray.rdir[i] = -dir[i];
| 264 |
| 265 |
| 266 |
/* pretend we hit surface */
| 267 |
thisray.rot = 1.0-1e-4;
| 268 |
thisray.rod = 1.0;
| 269 |
VCOPY(thisray.ron, dir);
| 270 |
for (i = 0; i < 3; i++) /* fudge factor */
| 271 |
thisray.rop[i] = org[i] + 1e-4*dir[i];
| 272 |
| 273 |
(*ofun[Lamb.otype].funp)(&Lamb, &thisray);
| 274 |
| 275 |
| 276 |
| 277 |
| 278 |
printvals(r) /* print requested ray values */
| 279 |
RAY *r;
| 280 |
| 281 |
register int (**tp)();
| 282 |
| 283 |
if (ray_out[0] == NULL)
| 284 |
return;
| 285 |
for (tp = ray_out; *tp != NULL; tp++)
| 286 |
(**tp)(r);
| 287 |
if (outform == 'a')
| 288 |
putchar('\n');
| 289 |
| 290 |
| 291 |
| 292 |
getvec(vec, fmt, fp) /* get a vector from fp */
| 293 |
register FVECT vec;
| 294 |
int fmt;
| 295 |
FILE *fp;
| 296 |
| 297 |
extern char *fgetword();
| 298 |
static float vf[3];
| 299 |
static double vd[3];
| 300 |
char buf[32];
| 301 |
register int i;
| 302 |
| 303 |
switch (fmt) {
| 304 |
case 'a': /* ascii */
| 305 |
| 306 |
if (fgetword(buf, sizeof(buf), fp) == NULL ||
| 307 |
!isflt(buf))
| 308 |
return(-1);
| 309 |
vec[i] = atof(buf);
| 310 |
| 311 |
break;
| 312 |
case 'f': /* binary float */
| 313 |
if (fread((char *)vf, sizeof(float), 3, fp) != 3)
| 314 |
return(-1);
| 315 |
vec[0] = vf[0]; vec[1] = vf[1]; vec[2] = vf[2];
| 316 |
break;
| 317 |
case 'd': /* binary double */
| 318 |
if (fread((char *)vd, sizeof(double), 3, fp) != 3)
| 319 |
return(-1);
| 320 |
vec[0] = vd[0]; vec[1] = vd[1]; vec[2] = vd[2];
| 321 |
break;
| 322 |
default:
| 323 |
error(CONSISTENCY, "botched input format");
| 324 |
| 325 |
return(0);
| 326 |
| 327 |
| 328 |
| 329 |
tranotify(obj) /* record new modifier */
| 330 |
OBJECT obj;
| 331 |
| 332 |
static int hitlimit = 0;
| 333 |
register OBJREC *o = objptr(obj);
| 334 |
register char **tralp;
| 335 |
| 336 |
if (hitlimit || !ismodifier(o->otype))
| 337 |
return;
| 338 |
for (tralp = tralist; *tralp != NULL; tralp++)
| 339 |
if (!strcmp(o->oname, *tralp)) {
| 340 |
if (traset[0] >= MAXTSET) {
| 341 |
error(WARNING, "too many modifiers in trace list");
| 342 |
hitlimit++;
| 343 |
return; /* should this be fatal? */
| 344 |
| 345 |
insertelem(traset, obj);
| 346 |
return;
| 347 |
| 348 |
| 349 |
| 350 |
| 351 |
static
| 352 |
ourtrace(r) /* print ray values */
| 353 |
RAY *r;
| 354 |
| 355 |
| 356 |
| 357 |
if (every_out[0] == NULL)
| 358 |
return;
| 359 |
if (r->ro == NULL) {
| 360 |
if (traincl == 1)
| 361 |
return;
| 362 |
} else if (traincl != -1 && traincl != inset(traset, r->ro->omod))
| 363 |
return;
| 364 |
tabin(r);
| 365 |
for (tp = every_out; *tp != NULL; tp++)
| 366 |
(**tp)(r);
| 367 |
putchar('\n');
| 368 |
| 369 |
| 370 |
| 371 |
static
| 372 |
tabin(r) /* tab in appropriate amount */
| 373 |
RAY *r;
| 374 |
| 375 |
register RAY *rp;
| 376 |
| 377 |
for (rp = r->parent; rp != NULL; rp = rp->parent)
| 378 |
putchar('\t');
| 379 |
| 380 |
| 381 |
| 382 |
static
| 383 |
oputo(r) /* print origin */
| 384 |
register RAY *r;
| 385 |
| 386 |
(*putreal)(r->rorg[0]);
| 387 |
(*putreal)(r->rorg[1]);
| 388 |
(*putreal)(r->rorg[2]);
| 389 |
| 390 |
| 391 |
| 392 |
static
| 393 |
oputd(r) /* print direction */
| 394 |
register RAY *r;
| 395 |
| 396 |
(*putreal)(r->rdir[0]);
| 397 |
(*putreal)(r->rdir[1]);
| 398 |
(*putreal)(r->rdir[2]);
| 399 |
| 400 |
| 401 |
| 402 |
static
| 403 |
oputv(r) /* print value */
| 404 |
register RAY *r;
| 405 |
| 406 |
COLR cout;
| 407 |
| 408 |
if (outform == 'c') {
| 409 |
setcolr(cout, colval(r->rcol,RED),
| 410 |
colval(r->rcol,GRN),
| 411 |
colval(r->rcol,BLU));
| 412 |
fwrite((char *)cout, sizeof(cout), 1, stdout);
| 413 |
return;
| 414 |
| 415 |
(*putreal)(colval(r->rcol,RED));
| 416 |
(*putreal)(colval(r->rcol,GRN));
| 417 |
(*putreal)(colval(r->rcol,BLU));
| 418 |
| 419 |
| 420 |
| 421 |
static
| 422 |
oputl(r) /* print effective distance */
| 423 |
register RAY *r;
| 424 |
| 425 |
(*putreal)(r->rt);
| 426 |
| 427 |
| 428 |
| 429 |
static
| 430 |
oputL(r) /* print single ray length */
| 431 |
register RAY *r;
| 432 |
| 433 |
(*putreal)(r->rot);
| 434 |
| 435 |
| 436 |
| 437 |
static
| 438 |
oputp(r) /* print point */
| 439 |
register RAY *r;
| 440 |
| 441 |
if (r->rot < FHUGE) {
| 442 |
(*putreal)(r->rop[0]);
| 443 |
(*putreal)(r->rop[1]);
| 444 |
(*putreal)(r->rop[2]);
| 445 |
} else {
| 446 |
(*putreal)(0.0);
| 447 |
(*putreal)(0.0);
| 448 |
(*putreal)(0.0);
| 449 |
| 450 |
| 451 |
| 452 |
| 453 |
static
| 454 |
oputN(r) /* print unperturbed normal */
| 455 |
register RAY *r;
| 456 |
| 457 |
| 458 |
(*putreal)(r->ron[0]);
| 459 |
(*putreal)(r->ron[1]);
| 460 |
(*putreal)(r->ron[2]);
| 461 |
} else {
| 462 |
(*putreal)(0.0);
| 463 |
(*putreal)(0.0);
| 464 |
(*putreal)(0.0);
| 465 |
| 466 |
| 467 |
| 468 |
| 469 |
static
| 470 |
oputn(r) /* print perturbed normal */
| 471 |
RAY *r;
| 472 |
| 473 |
FVECT pnorm;
| 474 |
| 475 |
if (r->rot >= FHUGE) {
| 476 |
(*putreal)(0.0);
| 477 |
(*putreal)(0.0);
| 478 |
(*putreal)(0.0);
| 479 |
return;
| 480 |
| 481 |
raynormal(pnorm, r);
| 482 |
(*putreal)(pnorm[0]);
| 483 |
(*putreal)(pnorm[1]);
| 484 |
(*putreal)(pnorm[2]);
| 485 |
| 486 |
| 487 |
| 488 |
static
| 489 |
oputs(r) /* print name */
| 490 |
register RAY *r;
| 491 |
| 492 |
if (r->ro != NULL)
| 493 |
fputs(r->ro->oname, stdout);
| 494 |
else
| 495 |
putchar('*');
| 496 |
putchar('\t');
| 497 |
| 498 |
| 499 |
| 500 |
static
| 501 |
oputw(r) /* print weight */
| 502 |
register RAY *r;
| 503 |
| 504 |
(*putreal)(r->rweight);
| 505 |
| 506 |
| 507 |
| 508 |
static
| 509 |
oputm(r) /* print modifier */
| 510 |
register RAY *r;
| 511 |
| 512 |
if (r->ro != NULL)
| 513 |
fputs(objptr(r->ro->omod)->oname, stdout);
| 514 |
else
| 515 |
putchar('*');
| 516 |
putchar('\t');
| 517 |
| 518 |
| 519 |
| 520 |
static
| 521 |
puta(v) /* print ascii value */
| 522 |
double v;
| 523 |
| 524 |
printf("%e\t", v);
| 525 |
| 526 |
| 527 |
| 528 |
static
| 529 |
putd(v) /* print binary double */
| 530 |
double v;
| 531 |
| 532 |
fwrite((char *)&v, sizeof(v), 1, stdout);
| 533 |
| 534 |
| 535 |
| 536 |
static
| 537 |
putf(v) /* print binary float */
| 538 |
double v;
| 539 |
| 540 |
float f = v;
| 541 |
| 542 |
fwrite((char *)&f, sizeof(f), 1, stdout);
| 543 |
