root/Development/ray/src/rt/rtrace.c
Revision: 1.11
Committed: Sat Aug 18 10:34:47 1990 UTC (35 years, 3 months ago) by greg
Changes since 1.10: +11 -1 lines
added conditional ray casting to rtrace for efficiency
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * rtrace.c - program and variables for individual ray tracing.
9 *
10 * 6/11/86
11 */
12
13 /*
14 * Input is in the form:
15 *
16 * xorg yorg zorg xdir ydir zdir
17 *
18 * The direction need not be normalized. Output is flexible.
19 * If the direction vector is (0,0,0), then the output is flushed.
20 * All values default to ascii representation of real
21 * numbers. Binary representations can be selected
22 * with '-ff' for float or '-fd' for double. By default,
23 * radiance is computed. The '-i' option indicates that
24 * irradiance values are desired.
25 */
26
27 #include "ray.h"
28
29 #include "octree.h"
30
31 #include "otypes.h"
32
33 int inform = 'a'; /* input format */
34 int outform = 'a'; /* output format */
35 char *outvals = "v"; /* output specification */
36
37 int hresolu = 0; /* horizontal (scan) size */
38 int vresolu = 0; /* vertical resolution */
39
40 double dstrsrc = 0.0; /* square source distribution */
41 double shadthresh = .05; /* shadow threshold */
42 double shadcert = .5; /* shadow certainty */
43
44 int maxdepth = 6; /* maximum recursion depth */
45 double minweight = 4e-3; /* minimum ray weight */
46
47 COLOR ambval = BLKCOLOR; /* ambient value */
48 double ambacc = 0.2; /* ambient accuracy */
49 int ambres = 32; /* ambient resolution */
50 int ambdiv = 128; /* ambient divisions */
51 int ambssamp = 0; /* ambient super-samples */
52 int ambounce = 0; /* ambient bounces */
53 char *amblist[128]; /* ambient include/exclude list */
54 int ambincl = -1; /* include == 1, exclude == 0 */
55
56 static RAY thisray; /* for our convenience */
57
58 static int oputo(), oputd(), oputv(), oputl(),
59 oputp(), oputn(), oputs(), oputw(), oputm();
60
61 static int (*ray_out[10])(), (*every_out[10])();
62 static int castonly;
63
64 static int puta(), putf(), putd();
65
66 static int (*putreal)();
67
68
69 quit(code) /* quit program */
70 int code;
71 {
72 exit(code);
73 }
74
75
76 rtrace(fname) /* trace rays from file */
77 char *fname;
78 {
79 long vcount = hresolu>1 ? hresolu*vresolu : vresolu;
80 long nextflush = hresolu;
81 FILE *fp;
82 FVECT orig, direc;
83 /* set up input */
84 if (fname == NULL)
85 fp = stdin;
86 else if ((fp = fopen(fname, "r")) == NULL) {
87 sprintf(errmsg, "cannot open input file \"%s\"", fname);
88 error(SYSTEM, errmsg);
89 }
90 /* set up output */
91 setoutput(outvals);
92 switch (outform) {
93 case 'a': putreal = puta; break;
94 case 'f': putreal = putf; break;
95 case 'd': putreal = putd; break;
96 }
97 /* process file */
98 while (getvec(orig, inform, fp) == 0 &&
99 getvec(direc, inform, fp) == 0) {
100
101 if (normalize(direc) == 0.0) { /* zero ==> flush */
102 fflush(stdout);
103 continue;
104 }
105 /* compute and print */
106 if (outvals[0] == 'i')
107 irrad(orig, direc);
108 else
109 radiance(orig, direc);
110 /* flush if time */
111 if (--nextflush == 0) {
112 fflush(stdout);
113 nextflush = hresolu;
114 }
115 if (ferror(stdout))
116 error(SYSTEM, "write error");
117 if (--vcount == 0) /* check for end */
118 break;
119 }
120 if (vcount > 0)
121 error(USER, "read error");
122 fclose(fp);
123 }
124
125
126 setoutput(vs) /* set up output tables */
127 register char *vs;
128 {
129 extern int ourtrace(), (*trace)();
130 register int (**table)() = ray_out;
131
132 castonly = 1;
133 while (*vs)
134 switch (*vs++) {
135 case 't': /* trace */
136 *table = NULL;
137 table = every_out;
138 trace = ourtrace;
139 castonly = 0;
140 break;
141 case 'o': /* origin */
142 *table++ = oputo;
143 break;
144 case 'd': /* direction */
145 *table++ = oputd;
146 break;
147 case 'v': /* value */
148 *table++ = oputv;
149 castonly = 0;
150 break;
151 case 'l': /* length */
152 *table++ = oputl;
153 castonly = 0;
154 break;
155 case 'p': /* point */
156 *table++ = oputp;
157 break;
158 case 'n': /* normal */
159 *table++ = oputn;
160 break;
161 case 's': /* surface */
162 *table++ = oputs;
163 break;
164 case 'w': /* weight */
165 *table++ = oputw;
166 break;
167 case 'm': /* modifier */
168 *table++ = oputm;
169 break;
170 }
171 *table = NULL;
172 }
173
174
175 radiance(org, dir) /* compute radiance value */
176 FVECT org, dir;
177 {
178 register int (**tp)();
179
180 VCOPY(thisray.rorg, org);
181 VCOPY(thisray.rdir, dir);
182 rayorigin(&thisray, NULL, PRIMARY, 1.0);
183 if (castonly)
184 localhit(&thisray, &thescene) || sourcehit(&thisray);
185 else
186 rayvalue(&thisray);
187
188 if (ray_out[0] == NULL)
189 return;
190 for (tp = ray_out; *tp != NULL; tp++)
191 (**tp)(&thisray);
192 if (outform == 'a')
193 putchar('\n');
194 }
195
196
197 irrad(org, dir) /* compute irradiance value */
198 FVECT org, dir;
199 {
200 static double Lambfa[5] = {PI, PI, PI, 0.0, 0.0};
201 static OBJREC Lamb = {
202 OVOID, MAT_PLASTIC, "Lambertian",
203 {0, 5, NULL, Lambfa}, NULL, -1,
204 };
205 register int i;
206
207 for (i = 0; i < 3; i++) {
208 thisray.rorg[i] = org[i] + dir[i];
209 thisray.rdir[i] = -dir[i];
210 }
211 rayorigin(&thisray, NULL, PRIMARY, 1.0);
212 /* pretend we hit surface */
213 thisray.rot = 1.0;
214 thisray.rod = 1.0;
215 VCOPY(thisray.ron, dir);
216 for (i = 0; i < 3; i++) /* fudge factor */
217 thisray.rop[i] = org[i] + 1e-4*dir[i];
218 /* compute and print */
219 (*ofun[Lamb.otype].funp)(&Lamb, &thisray);
220 oputv(&thisray);
221 if (outform == 'a')
222 putchar('\n');
223 }
224
225
226 getvec(vec, fmt, fp) /* get a vector from fp */
227 register FVECT vec;
228 int fmt;
229 FILE *fp;
230 {
231 static float vf[3];
232
233 switch (fmt) {
234 case 'a': /* ascii */
235 if (fscanf(fp, "%lf %lf %lf", vec, vec+1, vec+2) != 3)
236 return(-1);
237 break;
238 case 'f': /* binary float */
239 if (fread((char *)vf, sizeof(float), 3, fp) != 3)
240 return(-1);
241 vec[0] = vf[0]; vec[1] = vf[1]; vec[2] = vf[2];
242 break;
243 case 'd': /* binary double */
244 if (fread((char *)vec, sizeof(double), 3, fp) != 3)
245 return(-1);
246 break;
247 }
248 return(0);
249 }
250
251
252 static
253 ourtrace(r) /* print ray values */
254 RAY *r;
255 {
256 register int (**tp)();
257
258 if (every_out[0] == NULL)
259 return;
260 tabin(r);
261 for (tp = every_out; *tp != NULL; tp++)
262 (**tp)(r);
263 putchar('\n');
264 }
265
266
267 static
268 tabin(r) /* tab in appropriate amount */
269 RAY *r;
270 {
271 register RAY *rp;
272
273 for (rp = r->parent; rp != NULL; rp = rp->parent)
274 putchar('\t');
275 }
276
277
278 static
279 oputo(r) /* print origin */
280 register RAY *r;
281 {
282 (*putreal)(r->rorg[0]);
283 (*putreal)(r->rorg[1]);
284 (*putreal)(r->rorg[2]);
285 }
286
287
288 static
289 oputd(r) /* print direction */
290 register RAY *r;
291 {
292 (*putreal)(r->rdir[0]);
293 (*putreal)(r->rdir[1]);
294 (*putreal)(r->rdir[2]);
295 }
296
297
298 static
299 oputv(r) /* print value */
300 register RAY *r;
301 {
302 (*putreal)(colval(r->rcol,RED));
303 (*putreal)(colval(r->rcol,GRN));
304 (*putreal)(colval(r->rcol,BLU));
305 }
306
307
308 static
309 oputl(r) /* print length */
310 register RAY *r;
311 {
312 (*putreal)(r->rt);
313 }
314
315
316 static
317 oputp(r) /* print point */
318 register RAY *r;
319 {
320 if (r->rot < FHUGE) {
321 (*putreal)(r->rop[0]);
322 (*putreal)(r->rop[1]);
323 (*putreal)(r->rop[2]);
324 } else {
325 (*putreal)(0.0);
326 (*putreal)(0.0);
327 (*putreal)(0.0);
328 }
329 }
330
331
332 static
333 oputn(r) /* print normal */
334 register RAY *r;
335 {
336 if (r->rot < FHUGE) {
337 (*putreal)(r->ron[0]);
338 (*putreal)(r->ron[1]);
339 (*putreal)(r->ron[2]);
340 } else {
341 (*putreal)(0.0);
342 (*putreal)(0.0);
343 (*putreal)(0.0);
344 }
345 }
346
347
348 static
349 oputs(r) /* print name */
350 register RAY *r;
351 {
352 if (r->ro != NULL)
353 fputs(r->ro->oname, stdout);
354 else
355 putchar('*');
356 putchar('\t');
357 }
358
359
360 static
361 oputw(r) /* print weight */
362 register RAY *r;
363 {
364 (*putreal)(r->rweight);
365 }
366
367
368 static
369 oputm(r) /* print modifier */
370 register RAY *r;
371 {
372 if (r->ro != NULL)
373 fputs(objptr(r->ro->omod)->oname, stdout);
374 else
375 putchar('*');
376 putchar('\t');
377 }
378
379
380 static
381 puta(v) /* print ascii value */
382 double v;
383 {
384 printf("%e\t", v);
385 }
386
387
388 static
389 putd(v) /* print binary double */
390 double v;
391 {
392 fwrite((char *)&v, sizeof(v), 1, stdout);
393 }
394
395
396 static
397 putf(v) /* print binary float */
398 double v;
399 {
400 float f = v;
401
402 fwrite((char *)&f, sizeof(f), 1, stdout);
403 }
