root/radiance/ray/src/rt/rtrace.c
Revision: 2.113
Committed: Thu Jan 2 01:54:49 2025 UTC (5 months ago) by greg
Changes since 2.112: +11 -11 lines
fix(rtrace,rxtrace): Made it so -oW doesn't include luminous efficacy multiplier
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.113 static const char RCSid[] = "$Id: rtrace.c,v 2.112 2024/01/06 01:21:34 greg Exp $";
3 greg 1.1 #endif
4     /*
5     * rtrace.c - program and variables for individual ray tracing.
6 greg 2.27 */
7
8 greg 2.28 #include "copyright.h"
9 greg 1.1
10     /*
11     * Input is in the form:
12     *
13     * xorg yorg zorg xdir ydir zdir
14     *
15     * The direction need not be normalized. Output is flexible.
16 greg 1.7 * If the direction vector is (0,0,0), then the output is flushed.
17 greg 1.1 * All values default to ascii representation of real
18     * numbers. Binary representations can be selected
19     * with '-ff' for float or '-fd' for double. By default,
20 greg 1.13 * radiance is computed. The '-i' or '-I' options indicate that
21 greg 1.1 * irradiance values are desired.
22     */
23 greg 2.32
24     #include <time.h>
25 greg 1.1
26 schorsch 2.30 #include "platform.h"
27 greg 1.1 #include "ray.h"
28 schorsch 2.37 #include "ambient.h"
29     #include "source.h"
30 greg 1.1 #include "otypes.h"
31 greg 2.72 #include "otspecial.h"
32 greg 2.6 #include "resolu.h"
33 schorsch 2.49 #include "random.h"
34 greg 2.6
35 greg 2.57 extern int inform; /* input format */
36     extern int outform; /* output format */
37     extern char *outvals; /* output values */
38 greg 2.27
39 greg 2.57 extern int imm_irrad; /* compute immediate irradiance? */
40     extern int lim_dist; /* limit distance? */
41 greg 1.14
42 greg 2.57 extern char *tralist[]; /* list of modifers to trace (or no) */
43     extern int traincl; /* include == 1, exclude == 0 */
44 greg 1.13
45 greg 2.57 extern int hresolu; /* horizontal resolution */
46     extern int vresolu; /* vertical resolution */
47 greg 1.1
48 greg 2.105 extern int castonly; /* only doing ray-casting? */
49 greg 2.55
50 greg 2.107 extern double (*sens_curve)(SCOLOR scol); /* spectral conversion for 1-channel */
51     extern double out_scalefactor; /* output calibration scale factor */
52     extern RGBPRIMP out_prims; /* output color primitives (NULL if spectral) */
53
54 greg 2.46 #ifndef MAXTSET
55 greg 2.55 #define MAXTSET 8191 /* maximum number in trace set */
56 greg 2.46 #endif
57 greg 2.15 OBJECT traset[MAXTSET+1]={0}; /* trace include/exclude set */
58
59 greg 2.102 static int Tflag = 0; /* source tracing enabled? */
60
61 greg 1.1 static RAY thisray; /* for our convenience */
62
63 greg 2.89 static FILE *inpfp = NULL; /* input stream pointer */
64
65     static FVECT *inp_queue = NULL; /* ray input queue if flushing */
66     static int inp_qpos = 0; /* next ray to return */
67     static int inp_qend = 0; /* number of rays in this work group */
68
69 greg 2.65 typedef void putf_t(RREAL *v, int n);
70 greg 2.107 static putf_t puta, putd, putf;
71 greg 1.1
72 schorsch 2.37 typedef void oputf_t(RAY *r);
73 greg 2.51 static oputf_t oputo, oputd, oputv, oputV, oputl, oputL, oputc, oputp,
74 greg 2.73 oputr, oputR, oputx, oputX, oputn, oputN, oputs,
75     oputw, oputW, oputm, oputM, oputtilde;
76 schorsch 2.37
77 greg 2.92 extern void tranotify(OBJECT obj);
78     static int is_fifo(FILE *fp);
79 schorsch 2.37 static void bogusray(void);
80 greg 2.59 static void raycast(RAY *r);
81     static void rayirrad(RAY *r);
82     static void rtcompute(FVECT org, FVECT dir, double dmax);
83 greg 2.57 static int printvals(RAY *r);
84     static int getvec(FVECT vec, int fmt, FILE *fp);
85 greg 2.89 static int iszerovec(const FVECT vec);
86     static double nextray(FVECT org, FVECT dir);
87 greg 2.57 static void tabin(RAY *r);
88     static void ourtrace(RAY *r);
89 greg 1.1
90 greg 2.113 static void putscolor(COLORV *scol, double sf);
91 greg 2.107
92 greg 2.73 static oputf_t *ray_out[32], *every_out[32];
93 schorsch 2.37 static putf_t *putreal;
94 greg 2.27
95 greg 1.1
96 greg 2.27 void
97 schorsch 2.37 quit( /* quit program */
98     int code
99     )
100 greg 1.1 {
101 greg 2.57 if (ray_pnprocs > 0) /* close children if any */
102     ray_pclose(0);
103 greg 2.99 else if (ray_pnprocs < 0)
104     _exit(code); /* avoid flush() in child */
105 greg 2.57 #ifndef NON_POSIX
106 greg 2.99 else {
107 greg 2.58 headclean(); /* delete header file */
108     pfclean(); /* clean up persist files */
109     }
110 greg 2.11 #endif
111 greg 1.1 exit(code);
112     }
113
114
115 greg 2.106 const char *
116 schorsch 2.37 formstr( /* return format identifier */
117     int f
118     )
119 greg 2.6 {
120     switch (f) {
121     case 'a': return("ascii");
122     case 'f': return("float");
123     case 'd': return("double");
124 greg 2.107 case 'c':
125     if (out_prims == NULL)
126     return(SPECFMT);
127     if (out_prims == xyzprims)
128     return(CIEFMT);
129     return(COLRFMT);
130 greg 2.6 }
131     return("unknown");
132     }
133
134
135 greg 2.102 static void
136     trace_sources(void) /* trace rays to light sources, also */
137     {
138     int sn;
139
140     for (sn = 0; sn < nsources; sn++)
141     source[sn].sflags |= SFOLLOW;
142     }
143
144
145 greg 2.92 void
146 schorsch 2.37 rtrace( /* trace rays from file */
147 greg 2.59 char *fname,
148     int nproc
149 schorsch 2.37 )
150 greg 1.1 {
151 greg 2.45 unsigned long vcount = (hresolu > 1) ? (unsigned long)hresolu*vresolu
152 greg 2.66 : (unsigned long)vresolu;
153 greg 2.85 long nextflush = (!vresolu | (hresolu <= 1)) * hresolu;
154 greg 2.79 int something2flush = 0;
155 greg 1.1 FILE *fp;
156 gregl 2.25 double d;
157 greg 1.2 FVECT orig, direc;
158 greg 1.1 /* set up input */
159     if (fname == NULL)
160 greg 2.89 inpfp = stdin;
161     else if ((inpfp = fopen(fname, "r")) == NULL) {
162 greg 1.1 sprintf(errmsg, "cannot open input file \"%s\"", fname);
163     error(SYSTEM, errmsg);
164     }
165 greg 2.89 #ifdef getc_unlocked
166     flockfile(inpfp); /* avoid lock/unlock overhead */
167     flockfile(stdout);
168     #endif
169 greg 2.8 if (inform != 'a')
170 greg 2.89 SET_FILE_BINARY(inpfp);
171 greg 1.1 /* set up output */
172 greg 2.94 if (castonly || every_out[0] != NULL)
173 greg 2.59 nproc = 1; /* don't bother multiprocessing */
174 greg 2.104 if (every_out[0] != NULL) {
175     trace = ourtrace; /* enable full tree tracing */
176     if (Tflag) /* light sources, too? */
177     trace_sources();
178     }
179 greg 2.79 if ((nextflush > 0) & (nproc > nextflush)) {
180     error(WARNING, "reducing number of processes to match flush interval");
181     nproc = nextflush;
182     }
183 greg 2.59 if (nproc > 1) { /* start multiprocessing */
184     ray_popen(nproc);
185 greg 2.58 ray_fifo_out = printvals;
186 greg 2.59 }
187 greg 2.12 if (hresolu > 0) {
188     if (vresolu > 0)
189     fprtresolu(hresolu, vresolu, stdout);
190 greg 2.78 else
191     fflush(stdout);
192 greg 2.12 }
193 greg 2.89 /* process input rays */
194     while ((d = nextray(orig, direc)) >= 0.0) {
195 greg 2.87 if (d == 0.0) { /* flush request? */
196 greg 2.85 if (something2flush) {
197 greg 2.74 if (ray_pnprocs > 1 && ray_fifo_flush() < 0)
198 greg 2.71 error(USER, "child(ren) died");
199 greg 2.87 bogusray();
200 gregl 2.24 fflush(stdout);
201 greg 2.86 nextflush = (!vresolu | (hresolu <= 1)) * hresolu;
202 greg 2.79 something2flush = 0;
203 greg 2.87 } else
204     bogusray();
205 greg 2.57 } else { /* compute and print */
206 greg 2.59 rtcompute(orig, direc, lim_dist ? d : 0.0);
207 greg 2.89 if (!--nextflush) { /* flush if time */
208 greg 2.74 if (ray_pnprocs > 1 && ray_fifo_flush() < 0)
209 greg 2.71 error(USER, "child(ren) died");
210 gregl 2.24 fflush(stdout);
211     nextflush = hresolu;
212 greg 2.78 } else
213 greg 2.79 something2flush = 1;
214 greg 1.1 }
215     if (ferror(stdout))
216     error(SYSTEM, "write error");
217 greg 2.45 if (vcount && !--vcount) /* check for end */
218 greg 1.1 break;
219     }
220 greg 2.74 if (ray_pnprocs > 1) { /* clean up children */
221 greg 2.59 if (ray_fifo_flush() < 0)
222     error(USER, "unable to complete processing");
223     ray_pclose(0);
224     }
225 greg 2.89 if (vcount)
226     error(WARNING, "unexpected EOF on input");
227 greg 2.50 if (fflush(stdout) < 0)
228     error(SYSTEM, "write error");
229 greg 2.89 if (fname != NULL) {
230     fclose(inpfp);
231     inpfp = NULL;
232     }
233     nextray(NULL, NULL);
234 greg 1.1 }
235
236
237 greg 2.91 int
238     setrtoutput(void) /* set up output tables, return #comp */
239 greg 1.1 {
240 greg 2.91 char *vs = outvals;
241 greg 2.56 oputf_t **table = ray_out;
242 greg 2.107 const int nco = (sens_curve != NULL) ? 1 :
243     (out_prims != NULL) ? 3 : NCSAMP;
244 greg 2.91 int ncomp = 0;
245
246     if (!*vs)
247     error(USER, "empty output specification");
248 greg 1.1
249 greg 2.103 switch (outform) { /* make sure (*putreal)() calls someone! */
250     case 'a': putreal = puta; break;
251     case 'f': putreal = putf; break;
252     case 'd': putreal = putd; break;
253     case 'c':
254     if (outvals[1] || !strchr("vrx", outvals[0]))
255     error(USER, "color format only with -ov, -or, -ox");
256 greg 2.108 if (nco < 3)
257     error(USER, "color format incompatible with -pY, -pS, -pM");
258 greg 2.107 break;
259 greg 2.103 default:
260     error(CONSISTENCY, "botched output format");
261     }
262 greg 2.94 castonly = 1; /* sets castonly as side-effect */
263 greg 2.91 do
264     switch (*vs) {
265 greg 2.40 case 'T': /* trace sources */
266 greg 2.102 Tflag++;
267 greg 2.40 /* fall through */
268 greg 1.1 case 't': /* trace */
269 greg 2.91 if (!vs[1]) break;
270 greg 1.1 *table = NULL;
271     table = every_out;
272 greg 1.11 castonly = 0;
273 greg 1.1 break;
274     case 'o': /* origin */
275     *table++ = oputo;
276 greg 2.91 ncomp += 3;
277 greg 1.1 break;
278     case 'd': /* direction */
279     *table++ = oputd;
280 greg 2.91 ncomp += 3;
281 greg 1.1 break;
282 greg 2.73 case 'r': /* reflected contrib. */
283     *table++ = oputr;
284 greg 2.107 ncomp += nco;
285 greg 2.73 castonly = 0;
286     break;
287     case 'R': /* reflected distance */
288     *table++ = oputR;
289 greg 2.91 ncomp++;
290 greg 2.73 castonly = 0;
291     break;
292     case 'x': /* xmit contrib. */
293     *table++ = oputx;
294 greg 2.107 ncomp += nco;
295 greg 2.73 castonly = 0;
296     break;
297     case 'X': /* xmit distance */
298     *table++ = oputX;
299 greg 2.91 ncomp++;
300 greg 2.73 castonly = 0;
301     break;
302 greg 1.1 case 'v': /* value */
303     *table++ = oputv;
304 greg 2.107 ncomp += nco;
305 greg 1.11 castonly = 0;
306 greg 1.1 break;
307 greg 2.51 case 'V': /* contribution */
308     *table++ = oputV;
309 greg 2.107 ncomp += nco;
310 greg 2.94 castonly = 0;
311 greg 2.51 if (ambounce > 0 && (ambacc > FTINY || ambssamp > 0))
312     error(WARNING,
313     "-otV accuracy depends on -aa 0 -as 0");
314     break;
315 greg 2.5 case 'l': /* effective distance */
316 greg 1.1 *table++ = oputl;
317 greg 2.91 ncomp++;
318 greg 1.11 castonly = 0;
319 greg 1.1 break;
320 greg 2.29 case 'c': /* local coordinates */
321     *table++ = oputc;
322 greg 2.91 ncomp += 2;
323 greg 2.29 break;
324 greg 2.5 case 'L': /* single ray length */
325     *table++ = oputL;
326 greg 2.91 ncomp++;
327 greg 2.5 break;
328 greg 1.1 case 'p': /* point */
329     *table++ = oputp;
330 greg 2.91 ncomp += 3;
331 greg 1.1 break;
332 greg 2.9 case 'n': /* perturbed normal */
333 greg 1.1 *table++ = oputn;
334 greg 2.91 ncomp += 3;
335 greg 2.9 castonly = 0;
336 greg 1.1 break;
337 greg 2.9 case 'N': /* unperturbed normal */
338     *table++ = oputN;
339 greg 2.91 ncomp += 3;
340 greg 2.9 break;
341 greg 1.1 case 's': /* surface */
342     *table++ = oputs;
343 greg 2.91 ncomp++;
344 greg 1.1 break;
345     case 'w': /* weight */
346     *table++ = oputw;
347 greg 2.91 ncomp++;
348 greg 1.1 break;
349 greg 2.40 case 'W': /* coefficient */
350     *table++ = oputW;
351 greg 2.107 ncomp += nco;
352 greg 2.73 castonly = 0;
353 greg 2.80 if (ambounce > 0 && (ambacc > FTINY) | (ambssamp > 0))
354 greg 2.40 error(WARNING,
355 greg 2.41 "-otW accuracy depends on -aa 0 -as 0");
356 greg 2.40 break;
357 greg 1.1 case 'm': /* modifier */
358     *table++ = oputm;
359 greg 2.91 ncomp++;
360 greg 1.1 break;
361 greg 2.39 case 'M': /* material */
362     *table++ = oputM;
363 greg 2.91 ncomp++;
364 greg 2.39 break;
365 greg 2.42 case '~': /* tilde */
366     *table++ = oputtilde;
367 greg 2.41 break;
368 greg 2.91 default:
369     sprintf(errmsg, "unrecognized output option '%c'", *vs);
370     error(USER, errmsg);
371 greg 1.1 }
372 greg 2.91 while (*++vs);
373
374 greg 1.1 *table = NULL;
375 greg 2.91 if (*every_out != NULL)
376     ncomp = 0;
377 greg 2.81 /* compatibility */
378 greg 2.94 if ((do_irrad | imm_irrad) && castonly)
379     error(USER, "-I+ and -i+ options require some value output");
380 greg 2.81 for (table = ray_out; *table != NULL; table++) {
381     if ((*table == oputV) | (*table == oputW))
382     error(WARNING, "-oVW options require trace mode");
383     if ((do_irrad | imm_irrad) &&
384     (*table == oputr) | (*table == oputR) |
385     (*table == oputx) | (*table == oputX))
386     error(WARNING, "-orRxX options incompatible with -I+ and -i+");
387     }
388 greg 2.91 return(ncomp);
389 gregl 2.24 }
390
391
392 schorsch 2.37 static void
393     bogusray(void) /* print out empty record */
394 gregl 2.24 {
395 greg 2.40 rayorigin(&thisray, PRIMARY, NULL, NULL);
396 gregl 2.24 printvals(&thisray);
397 greg 1.1 }
398
399
400 schorsch 2.37 static void
401 greg 2.59 raycast( /* compute first ray intersection only */
402     RAY *r
403 schorsch 2.37 )
404 greg 1.1 {
405 greg 2.59 if (!localhit(r, &thescene)) {
406     if (r->ro == &Aftplane) { /* clipped */
407     r->ro = NULL;
408     r->rot = FHUGE;
409     } else
410     sourcehit(r);
411 greg 2.57 }
412 greg 1.1 }
413
414
415 schorsch 2.37 static void
416 greg 2.59 rayirrad( /* compute irradiance rather than radiance */
417     RAY *r
418     )
419     {
420 greg 2.62 void (*old_revf)(RAY *) = r->revf;
421 greg 2.75 /* pretend we hit surface */
422 greg 2.76 r->rxt = r->rot = 1e-5;
423 greg 2.59 VSUM(r->rop, r->rorg, r->rdir, r->rot);
424     r->ron[0] = -r->rdir[0];
425     r->ron[1] = -r->rdir[1];
426     r->ron[2] = -r->rdir[2];
427     r->rod = 1.0;
428 greg 2.62 /* compute result */
429 greg 2.61 r->revf = raytrace;
430 greg 2.59 (*ofun[Lamb.otype].funp)(&Lamb, r);
431 greg 2.62 r->revf = old_revf;
432 greg 2.59 }
433
434
435     static void
436     rtcompute( /* compute and print ray value(s) */
437 schorsch 2.37 FVECT org,
438 greg 2.59 FVECT dir,
439     double dmax
440 schorsch 2.37 )
441 greg 1.1 {
442 greg 2.60 /* set up ray */
443     if (imm_irrad) {
444 greg 2.59 VSUM(thisray.rorg, org, dir, 1.1e-4);
445     thisray.rdir[0] = -dir[0];
446     thisray.rdir[1] = -dir[1];
447     thisray.rdir[2] = -dir[2];
448     thisray.rmax = 0.0;
449     } else {
450     VCOPY(thisray.rorg, org);
451     VCOPY(thisray.rdir, dir);
452     thisray.rmax = dmax;
453     }
454 greg 2.101 rayorigin(&thisray, PRIMARY, NULL, NULL);
455     if (imm_irrad)
456     thisray.revf = rayirrad;
457     else if (castonly)
458     thisray.revf = raycast;
459 greg 2.59 if (ray_pnprocs > 1) { /* multiprocessing FIFO? */
460     if (ray_fifo_in(&thisray) < 0)
461     error(USER, "lost children");
462     return;
463     }
464     samplendx++; /* else do it ourselves */
465     rayvalue(&thisray);
466 greg 2.16 printvals(&thisray);
467     }
468
469
470 greg 2.57 static int
471 schorsch 2.37 printvals( /* print requested ray values */
472     RAY *r
473     )
474 greg 2.16 {
475 greg 2.56 oputf_t **tp;
476 greg 2.16
477     if (ray_out[0] == NULL)
478 greg 2.57 return(0);
479 greg 2.16 for (tp = ray_out; *tp != NULL; tp++)
480     (**tp)(r);
481 greg 1.1 if (outform == 'a')
482     putchar('\n');
483 greg 2.57 return(1);
484 greg 1.1 }
485
486
487 schorsch 2.37 static int
488 greg 2.92 is_fifo( /* check if file pointer connected to pipe */
489     FILE *fp
490     )
491     {
492     #ifdef S_ISFIFO
493     struct stat sbuf;
494
495     if (fstat(fileno(fp), &sbuf) < 0)
496     error(SYSTEM, "fstat() failed on input stream");
497     return(S_ISFIFO(sbuf.st_mode));
498     #else
499     return (fp == stdin); /* just a guess, really */
500     #endif
501     }
502
503
504     static int
505 greg 2.89 getvec( /* get a vector from fp */
506 greg 2.56 FVECT vec,
507 schorsch 2.37 int fmt,
508     FILE *fp
509     )
510 greg 1.1 {
511     static float vf[3];
512 greg 2.5 static double vd[3];
513 greg 1.19 char buf[32];
514 greg 2.56 int i;
515 greg 1.1
516     switch (fmt) {
517     case 'a': /* ascii */
518 greg 1.19 for (i = 0; i < 3; i++) {
519     if (fgetword(buf, sizeof(buf), fp) == NULL ||
520     !isflt(buf))
521     return(-1);
522     vec[i] = atof(buf);
523     }
524 greg 1.1 break;
525     case 'f': /* binary float */
526 greg 2.70 if (getbinary(vf, sizeof(float), 3, fp) != 3)
527 greg 1.1 return(-1);
528 greg 2.58 VCOPY(vec, vf);
529 greg 1.1 break;
530     case 'd': /* binary double */
531 greg 2.70 if (getbinary(vd, sizeof(double), 3, fp) != 3)
532 greg 1.1 return(-1);
533 greg 2.58 VCOPY(vec, vd);
534 greg 1.1 break;
535 greg 2.6 default:
536     error(CONSISTENCY, "botched input format");
537 greg 1.1 }
538     return(0);
539     }
540
541
542 greg 2.89 static int
543     iszerovec(const FVECT vec)
544     {
545     return (vec[0] == 0.0) & (vec[1] == 0.0) & (vec[2] == 0.0);
546     }
547
548
549     static double
550     nextray( /* return next ray in work group (-1.0 if EOF) */
551     FVECT org,
552     FVECT dir
553     )
554     {
555     const size_t qlength = !vresolu * hresolu;
556
557     if ((org == NULL) | (dir == NULL)) {
558     if (inp_queue != NULL) /* asking to free queue */
559     free(inp_queue);
560     inp_queue = NULL;
561     inp_qpos = inp_qend = 0;
562     return(-1.);
563     }
564     if (!inp_qend) { /* initialize FIFO queue */
565     int rsiz = 6*20; /* conservative ascii ray size */
566     if (inform == 'f') rsiz = 6*sizeof(float);
567     else if (inform == 'd') rsiz = 6*sizeof(double);
568 greg 2.92 /* check against pipe limit */
569     if (qlength*rsiz > 512 && is_fifo(inpfp))
570 greg 2.89 inp_queue = (FVECT *)malloc(sizeof(FVECT)*2*qlength);
571     inp_qend = -(inp_queue == NULL); /* flag for no queue */
572     }
573     if (inp_qend < 0) { /* not queuing? */
574     if (getvec(org, inform, inpfp) < 0 ||
575     getvec(dir, inform, inpfp) < 0)
576     return(-1.);
577     return normalize(dir);
578     }
579     if (inp_qpos >= inp_qend) { /* need to refill input queue? */
580     for (inp_qend = 0; inp_qend < qlength; inp_qend++) {
581     if (getvec(inp_queue[2*inp_qend], inform, inpfp) < 0
582     || getvec(inp_queue[2*inp_qend+1],
583     inform, inpfp) < 0)
584     break; /* hit EOF */
585     if (iszerovec(inp_queue[2*inp_qend+1])) {
586     ++inp_qend; /* flush request */
587     break;
588     }
589     }
590     inp_qpos = 0;
591     }
592     if (inp_qpos >= inp_qend) /* unexpected EOF? */
593     return(-1.);
594     VCOPY(org, inp_queue[2*inp_qpos]);
595     VCOPY(dir, inp_queue[2*inp_qpos+1]);
596     ++inp_qpos;
597     return normalize(dir);
598     }
599
600
601 greg 2.57 void
602 schorsch 2.37 tranotify( /* record new modifier */
603     OBJECT obj
604     )
605 greg 2.15 {
606     static int hitlimit = 0;
607 greg 2.56 OBJREC *o = objptr(obj);
608     char **tralp;
609 greg 2.15
610 greg 2.27 if (obj == OVOID) { /* starting over */
611     traset[0] = 0;
612     hitlimit = 0;
613     return;
614     }
615 greg 2.15 if (hitlimit || !ismodifier(o->otype))
616     return;
617     for (tralp = tralist; *tralp != NULL; tralp++)
618     if (!strcmp(o->oname, *tralp)) {
619     if (traset[0] >= MAXTSET) {
620     error(WARNING, "too many modifiers in trace list");
621     hitlimit++;
622     return; /* should this be fatal? */
623     }
624     insertelem(traset, obj);
625     return;
626     }
627     }
628
629
630 greg 2.27 static void
631 schorsch 2.37 ourtrace( /* print ray values */
632     RAY *r
633     )
634 greg 1.1 {
635 greg 2.56 oputf_t **tp;
636 greg 1.1
637     if (every_out[0] == NULL)
638 greg 2.15 return;
639 greg 2.16 if (r->ro == NULL) {
640     if (traincl == 1)
641     return;
642     } else if (traincl != -1 && traincl != inset(traset, r->ro->omod))
643 greg 1.1 return;
644     tabin(r);
645     for (tp = every_out; *tp != NULL; tp++)
646     (**tp)(r);
647 greg 2.41 if (outform == 'a')
648     putchar('\n');
649 greg 1.1 }
650
651
652 greg 2.27 static void
653 schorsch 2.37 tabin( /* tab in appropriate amount */
654     RAY *r
655     )
656 greg 1.1 {
657 greg 2.40 const RAY *rp;
658 greg 1.1
659     for (rp = r->parent; rp != NULL; rp = rp->parent)
660     putchar('\t');
661     }
662
663
664 greg 2.27 static void
665 schorsch 2.37 oputo( /* print origin */
666     RAY *r
667     )
668 greg 1.1 {
669 greg 2.65 (*putreal)(r->rorg, 3);
670 greg 1.1 }
671
672
673 greg 2.27 static void
674 schorsch 2.37 oputd( /* print direction */
675     RAY *r
676     )
677 greg 1.1 {
678 greg 2.65 (*putreal)(r->rdir, 3);
679 greg 1.1 }
680
681
682 greg 2.27 static void
683 greg 2.73 oputr( /* print mirrored contribution */
684     RAY *r
685     )
686     {
687 greg 2.113 putscolor(r->mcol, out_scalefactor);
688 greg 2.73 }
689
690
691
692     static void
693     oputR( /* print mirrored distance */
694     RAY *r
695     )
696     {
697     (*putreal)(&r->rmt, 1);
698     }
699
700
701     static void
702     oputx( /* print unmirrored contribution */
703     RAY *r
704     )
705     {
706 greg 2.107 SCOLOR cdiff;
707
708     copyscolor(cdiff, r->rcol);
709     sopscolor(cdiff, -=, r->mcol);
710 greg 2.73
711 greg 2.113 putscolor(cdiff, out_scalefactor);
712 greg 2.73 }
713
714
715     static void
716     oputX( /* print unmirrored distance */
717     RAY *r
718     )
719     {
720     (*putreal)(&r->rxt, 1);
721     }
722
723
724     static void
725 schorsch 2.37 oputv( /* print value */
726     RAY *r
727     )
728 greg 1.1 {
729 greg 2.113 putscolor(r->rcol, out_scalefactor);
730 greg 1.1 }
731
732
733 greg 2.27 static void
734 greg 2.51 oputV( /* print value contribution */
735     RAY *r
736     )
737     {
738 greg 2.107 SCOLOR contr;
739 greg 2.51
740     raycontrib(contr, r, PRIMARY);
741 greg 2.107 smultscolor(contr, r->rcol);
742 greg 2.113 putscolor(contr, out_scalefactor);
743 greg 2.51 }
744
745
746     static void
747 schorsch 2.37 oputl( /* print effective distance */
748     RAY *r
749     )
750 greg 1.1 {
751 greg 2.73 RREAL d = raydistance(r);
752
753     (*putreal)(&d, 1);
754 greg 2.5 }
755
756
757 greg 2.27 static void
758 schorsch 2.37 oputL( /* print single ray length */
759     RAY *r
760     )
761 greg 2.5 {
762 greg 2.65 (*putreal)(&r->rot, 1);
763 greg 1.1 }
764
765
766 greg 2.27 static void
767 schorsch 2.37 oputc( /* print local coordinates */
768     RAY *r
769     )
770 greg 2.29 {
771 greg 2.65 (*putreal)(r->uv, 2);
772 greg 2.29 }
773
774
775 greg 2.65 static RREAL vdummy[3] = {0.0, 0.0, 0.0};
776
777
778 greg 2.29 static void
779 greg 2.100 oputp( /* print intersection point */
780 schorsch 2.37 RAY *r
781     )
782 greg 1.1 {
783 greg 2.100 (*putreal)(r->rop, 3); /* set to ray origin if distant or no hit */
784 greg 1.1 }
785
786
787 greg 2.27 static void
788 schorsch 2.37 oputN( /* print unperturbed normal */
789     RAY *r
790     )
791 greg 1.1 {
792 greg 2.100 if (r->ro == NULL) { /* zero vector if clipped or no hit */
793     (*putreal)(vdummy, 3);
794     return;
795     }
796     if (r->rflips & 1) { /* undo any flippin' flips */
797     FVECT unrm;
798     unrm[0] = -r->ron[0];
799     unrm[1] = -r->ron[1];
800     unrm[2] = -r->ron[2];
801     (*putreal)(unrm, 3);
802 greg 2.82 } else
803 greg 2.100 (*putreal)(r->ron, 3);
804 greg 2.9 }
805
806
807 greg 2.27 static void
808 schorsch 2.37 oputn( /* print perturbed normal */
809     RAY *r
810     )
811 greg 2.9 {
812     FVECT pnorm;
813
814 greg 2.100 if (r->ro == NULL) { /* clipped or no hit */
815 greg 2.65 (*putreal)(vdummy, 3);
816 greg 2.9 return;
817     }
818     raynormal(pnorm, r);
819 greg 2.65 (*putreal)(pnorm, 3);
820 greg 1.1 }
821
822
823 greg 2.27 static void
824 schorsch 2.37 oputs( /* print name */
825     RAY *r
826     )
827 greg 1.1 {
828     if (r->ro != NULL)
829     fputs(r->ro->oname, stdout);
830     else
831     putchar('*');
832     putchar('\t');
833     }
834
835
836 greg 2.27 static void
837 schorsch 2.37 oputw( /* print weight */
838     RAY *r
839     )
840 greg 1.1 {
841 greg 2.65 RREAL rwt = r->rweight;
842
843     (*putreal)(&rwt, 1);
844 greg 1.1 }
845
846
847 greg 2.27 static void
848 greg 2.51 oputW( /* print coefficient */
849 greg 2.40 RAY *r
850     )
851     {
852 greg 2.107 SCOLOR contr;
853 greg 2.67 /* shadow ray not on source? */
854     if (r->rsrc >= 0 && source[r->rsrc].so != r->ro)
855 greg 2.107 scolorblack(contr);
856 greg 2.67 else
857     raycontrib(contr, r, PRIMARY);
858 greg 2.40
859 greg 2.113 putscolor(contr, 1.);
860 greg 2.40 }
861
862
863     static void
864 schorsch 2.37 oputm( /* print modifier */
865     RAY *r
866     )
867 greg 1.1 {
868     if (r->ro != NULL)
869 greg 2.23 if (r->ro->omod != OVOID)
870     fputs(objptr(r->ro->omod)->oname, stdout);
871     else
872     fputs(VOIDID, stdout);
873 greg 1.1 else
874     putchar('*');
875     putchar('\t');
876     }
877
878
879 greg 2.27 static void
880 greg 2.39 oputM( /* print material */
881     RAY *r
882     )
883     {
884     OBJREC *mat;
885
886     if (r->ro != NULL) {
887     if ((mat = findmaterial(r->ro)) != NULL)
888     fputs(mat->oname, stdout);
889     else
890     fputs(VOIDID, stdout);
891     } else
892     putchar('*');
893     putchar('\t');
894     }
895
896
897     static void
898 greg 2.42 oputtilde( /* output tilde (spacer) */
899 greg 2.41 RAY *r
900     )
901     {
902 greg 2.42 fputs("~\t", stdout);
903 greg 2.41 }
904
905
906     static void
907 greg 2.65 puta( /* print ascii value(s) */
908     RREAL *v, int n
909 schorsch 2.37 )
910 greg 1.1 {
911 greg 2.65 if (n == 3) {
912     printf("%e\t%e\t%e\t", v[0], v[1], v[2]);
913     return;
914     }
915     while (n--)
916     printf("%e\t", *v++);
917 greg 1.1 }
918
919
920 greg 2.27 static void
921 greg 2.80 putd(RREAL *v, int n) /* output binary double(s) */
922 greg 1.1 {
923 greg 2.68 #ifdef SMLFLT
924 greg 2.110 double da[MAXCSAMP];
925 greg 2.68 int i;
926
927 greg 2.110 if (n > MAXCSAMP)
928 greg 2.65 error(INTERNAL, "code error in putd()");
929 greg 2.68 for (i = n; i--; )
930     da[i] = v[i];
931 greg 2.69 putbinary(da, sizeof(double), n, stdout);
932 greg 2.68 #else
933 greg 2.69 putbinary(v, sizeof(RREAL), n, stdout);
934 greg 2.68 #endif
935 greg 1.1 }
936
937
938 greg 2.27 static void
939 greg 2.80 putf(RREAL *v, int n) /* output binary float(s) */
940 greg 1.1 {
941 greg 2.68 #ifndef SMLFLT
942 greg 2.110 float fa[MAXCSAMP];
943 greg 2.65 int i;
944 greg 1.1
945 greg 2.110 if (n > MAXCSAMP)
946 greg 2.65 error(INTERNAL, "code error in putf()");
947     for (i = n; i--; )
948     fa[i] = v[i];
949 greg 2.69 putbinary(fa, sizeof(float), n, stdout);
950 greg 2.68 #else
951 greg 2.69 putbinary(v, sizeof(RREAL), n, stdout);
952 greg 2.68 #endif
953 greg 1.1 }
954 greg 2.80
955
956     static void
957 greg 2.113 putscolor(COLORV *scol, double sf) /* output (spectral) color */
958 greg 2.80 {
959 greg 2.107 static COLORMAT xyz2myrgbmat;
960     SCOLOR my_scol;
961     COLOR col;
962 greg 2.112 /* single channel output? */
963     if (sens_curve != NULL) {
964 greg 2.113 RREAL v = (*sens_curve)(scol) * sf;
965 greg 2.112 (*putreal)(&v, 1);
966     return;
967     }
968 greg 2.113 if (sf != 1.) { /* apply scalefactor if any */
969 greg 2.107 copyscolor(my_scol, scol);
970 greg 2.113 scalescolor(my_scol, sf);
971 greg 2.107 scol = my_scol;
972     }
973     if (out_prims == NULL) { /* full spectral reporting */
974     if (outform == 'c') {
975     SCOLR sclr;
976     scolor_scolr(sclr, scol);
977     putbinary(sclr, LSCOLR, 1, stdout);
978     } else if (sizeof(RREAL) != sizeof(COLORV)) {
979     RREAL sreal[MAXCSAMP];
980     int i = NCSAMP;
981     while (i--) sreal[i] = scol[i];
982     (*putreal)(sreal, NCSAMP);
983     } else
984     (*putreal)((RREAL *)scol, NCSAMP);
985     return;
986     }
987     if (out_prims == xyzprims) {
988     scolor_cie(col, scol);
989     } else if (out_prims == stdprims) {
990     scolor_rgb(col, scol);
991     } else {
992     COLOR xyz;
993     if (xyz2myrgbmat[0][0] == 0)
994     compxyz2rgbWBmat(xyz2myrgbmat, out_prims);
995     scolor_cie(xyz, scol);
996     colortrans(col, xyz2myrgbmat, xyz);
997     clipgamut(col, xyz[CIEY], CGAMUT_LOWER, cblack, cwhite);
998     }
999     if (outform == 'c') {
1000     COLR clr;
1001     setcolr(clr, colval(col,RED), colval(col,GRN), colval(col,BLU));
1002     putbinary(clr, sizeof(COLR), 1, stdout);
1003     } else if (sizeof(RREAL) != sizeof(COLORV)) {
1004     RREAL creal[3];
1005     copycolor(creal, col);
1006     (*putreal)(creal, 3);
1007     } else
1008     (*putreal)((RREAL *)col, 3);
1009 greg 2.80 }
