root/Development/ray/src/rt/rtrace.c
Fri Apr 11 20:27:23 2014 UTC (11 years, 8 months ago) by greg
Changes since 2.67: +15 -2 lines
Diff to previous 2.67
Made reading of vectors more consistent with FVFORMAT macro
Wed Jun 27 15:32:58 2012 UTC (13 years, 6 months ago) by greg
Changes since 2.66: +6 -2 lines
Diff to previous 2.66
Added check for blocked shadow rays
Sat Jun 9 07:16:47 2012 UTC (13 years, 6 months ago) by greg
Changes since 2.65: +2 -2 lines
Diff to previous 2.65
Wed Apr 6 00:14:26 2011 UTC (14 years, 9 months ago) by greg
Changes since 2.64: +54 -59 lines
Diff to previous 2.64
Improved output efficiency by reducing number of calls to fwrite()
Sun Sep 26 15:49:39 2010 UTC (15 years, 3 months ago) by greg
Changes since 2.63: +4 -3 lines
Diff to previous 2.63
Eliminated flushing with -x >1 if -y also set to improve -n performance
Wed Dec 16 03:30:50 2009 UTC (16 years ago) by greg
Changes since 2.62: +6 -5 lines
Diff to previous 2.62
Bug fix for zero-direction rays with multiprocessing
Mon Dec 14 07:31:37 2009 UTC (16 years ago) by greg
Changes since 2.61: +5 -2 lines
Diff to previous 2.61
Precautionary change to rayirrad()
Mon Dec 14 04:49:16 2009 UTC (16 years ago) by greg
Changes since 2.60: +2 -1 lines
Diff to previous 2.60
Important bug fix in -I calculation
Mon Dec 14 03:15:45 2009 UTC (16 years ago) by greg
Changes since 2.59: +7 -9 lines
Diff to previous 2.59
Minor cosmetic change
Sun Dec 13 19:13:04 2009 UTC (16 years ago) by greg
Changes since 2.58: +72 -50 lines
Diff to previous 2.58
Sat Dec 12 23:08:13 2009 UTC (16 years ago) by greg
Changes since 2.57: +10 -7 lines
Diff to previous 2.57
Bug fixes and performance improvements to rtrace -n option
Sat Dec 12 19:01:00 2009 UTC (16 years ago) by greg
Changes since 2.56: +40 -77 lines
Diff to previous 2.56
Fri Jul 17 06:21:29 2009 UTC (16 years, 5 months ago) by greg
Changes since 2.55: +15 -18 lines
Diff to previous 2.55
Fixed -oo output of rtrace -I
Sat Nov 17 06:21:58 2007 UTC (18 years, 1 month ago) by greg
Changes since 2.54: +7 -3 lines
Diff to previous 2.54
Increased limits to number of modifiers for trace and ambient include/exclude
Wed Apr 5 14:30:38 2006 UTC (19 years, 9 months ago) by greg
Diff to previous 2.53
Changed default in rtrace to -u+ (random sampling)
Wed Apr 5 06:22:57 2006 UTC (19 years, 9 months ago) by greg
Changes since 2.52: +2 -2 lines
Diff to previous 2.52
Made -u+ option truly random
Wed Feb 22 17:05:36 2006 UTC (19 years, 10 months ago) by greg
Diff to previous 2.51
Increased trace modifier limit to 8192 in rtrace
Sun Feb 5 22:22:20 2006 UTC (19 years, 11 months ago) by greg
Changes since 2.50: +24 -3 lines
Diff to previous 2.50
Added -V option to rtcontrib and -oV option to rtrace to report contributions
Fri Oct 7 03:45:14 2005 UTC (20 years, 3 months ago) by greg
Changes since 2.49: +3 -2 lines
Diff to previous 2.49
Added final write error check
Mon Sep 19 11:30:10 2005 UTC (20 years, 3 months ago) by schorsch
Diff to previous 2.48
Tue Jun 21 15:06:50 2005 UTC (20 years, 6 months ago) by greg
Changes since 2.47: +5 -5 lines
Diff to previous 2.47
Fixed bugs in black glass transmission and source weight computation
Mon Jun 13 20:07:56 2005 UTC (20 years, 6 months ago) by greg
Changes since 2.46: +4 -2 lines
Diff to previous 2.46
Fri Jun 10 20:44:00 2005 UTC (20 years, 7 months ago) by greg
Changes since 2.45: +4 -2 lines
Diff to previous 2.45
Fixe in rtcontrib -M option
Fri Jun 10 16:49:42 2005 UTC (20 years, 7 months ago) by greg
Changes since 2.44: +7 -6 lines
Diff to previous 2.44
Fixed bug where rtrace would quit after 2^31 primary rays
Sun Jun 5 19:52:01 2005 UTC (20 years, 7 months ago) by greg
Diff to previous 2.43
Thu Jun 2 04:47:27 2005 UTC (20 years, 7 months ago) by greg
Changes since 2.42: +1 -3 lines
Diff to previous 2.42
Thu May 26 06:55:22 2005 UTC (20 years, 7 months ago) by greg
Changes since 2.41: +9 -8 lines
Diff to previous 2.41
Wed May 25 04:44:26 2005 UTC (20 years, 7 months ago) by greg
Changes since 2.40: +19 -14 lines
Diff to previous 2.40
Tue Apr 19 01:15:06 2005 UTC (20 years, 8 months ago) by greg
Changes since 2.39: +50 -7 lines
Diff to previous 2.39
Thu Apr 14 18:04:12 2005 UTC (20 years, 8 months ago) by greg
Changes since 2.38: +23 -2 lines
Diff to previous 2.38
Fri Nov 5 17:36:56 2004 UTC (21 years, 2 months ago) by greg
Diff to previous 2.37
Tue Mar 30 16:13:01 2004 UTC (21 years, 9 months ago) by schorsch
Changes since 2.36: +112 -76 lines
Diff to previous 2.36
Sun Mar 28 16:31:14 2004 UTC (21 years, 9 months ago) by greg
Diff to previous 2.35
Sat Oct 4 14:39:53 2003 UTC (22 years, 3 months ago) by greg
Diff to previous 2.34
More adjustments and corrections to default parameters
Wed Sep 24 14:55:54 2003 UTC (22 years, 3 months ago) by greg
Changes since 2.33: +7 -7 lines
Diff to previous 2.33
Mon Jul 21 22:30:19 2003 UTC (22 years, 5 months ago) by schorsch
Changes since 2.32: +3 -2 lines
Diff to previous 2.32
Wed Jul 16 01:32:53 2003 UTC (22 years, 5 months ago) by greg
Changes since 2.31: +3 -1 lines
Diff to previous 2.31
Minor compile fixes
Mon Jun 30 14:59:12 2003 UTC (22 years, 6 months ago) by schorsch
Diff to previous 2.30
Thu Jun 5 19:29:34 2003 UTC (22 years, 7 months ago) by schorsch
Changes since 2.29: +4 -5 lines
Diff to previous 2.29
Fri Apr 18 17:29:22 2003 UTC (22 years, 8 months ago) by greg
Changes since 2.28: +23 -11 lines
Diff to previous 2.28
Added rtrace -oc option to output local (u,v) coordinates
Tue Feb 25 02:47:23 2003 UTC (22 years, 10 months ago) by greg
Changes since 2.27: +1 -56 lines
Diff to previous 2.27
Sat Feb 22 02:07:29 2003 UTC (22 years, 10 months ago) by greg
Changes since 2.26: +107 -36 lines
Diff to previous 2.26
Thu Oct 30 11:01:16 1997 UTC (28 years, 2 months ago) by gregl
Diff to previous 2.25
modified code so zero record flushing happens unless -x > 0 && -y > 0
Fri Oct 17 10:14:37 1997 UTC (28 years, 2 months ago) by gregl
Changes since 2.24: +18 -7 lines
Diff to previous 2.24
added -ld boolean option to rtrace for limiting ray distance
Wed Jul 9 11:25:49 1997 UTC (28 years, 6 months ago) by gregl
Changes since 2.23: +26 -13 lines
Diff to previous 2.23
Tue Jan 14 19:54:27 1997 UTC (28 years, 11 months ago) by greg
Changes since 2.22: +4 -1 lines
Diff to previous 2.22
fixed bug in printing void materials.
Wed Apr 17 14:02:09 1996 UTC (29 years, 8 months ago) by greg
Changes since 2.21: +1 -1 lines
Diff to previous 2.21
Wed Feb 14 15:18:12 1996 UTC (29 years, 10 months ago) by greg
Changes since 2.20: +1 -0 lines
Diff to previous 2.20
Fri Dec 8 18:49:12 1995 UTC (30 years, 1 month ago) by greg
Changes since 2.19: +6 -1 lines
Diff to previous 2.19
Mon Aug 21 10:29:20 1995 UTC (30 years, 4 months ago) by greg
Changes since 2.18: +4 -4 lines
Diff to previous 2.18
increase default parameters for more accurate calculations
Wed Dec 21 09:52:00 1994 UTC (31 years ago) by greg
Changes since 2.17: +2 -0 lines
Diff to previous 2.17
added -bv option for back face visibility (normally on)
Tue Dec 20 20:18:34 1994 UTC (31 years ago) by greg
Changes since 2.16: +2 -1 lines
Diff to previous 2.16
Wed Jul 14 10:38:49 1993 UTC (32 years, 6 months ago) by greg
Changes since 2.15: +22 -20 lines
Diff to previous 2.15
consistency improvements related to -I option
Fri Jun 18 10:14:42 1993 UTC (32 years, 6 months ago) by greg
Changes since 2.14: +31 -0 lines
Diff to previous 2.14
added -ti, -te, -tI and -tE options to rtrace for exclude/include traces
Tue May 4 13:26:52 1993 UTC (32 years, 8 months ago) by greg
Changes since 2.13: +6 -3 lines
Diff to previous 2.13
made sure that -I option completely overrides -o option
Mon Mar 8 12:37:33 1993 UTC (32 years, 10 months ago) by greg
Diff to previous 2.12
Fri Jan 22 09:51:20 1993 UTC (32 years, 11 months ago) by greg
Changes since 2.11: +8 -3 lines
bug fixes and improvements on stdio flushing
Wed Jan 20 15:19:51 1993 UTC (32 years, 11 months ago) by greg
Changes since 2.10: +4 -0 lines
Thu Nov 19 20:26:10 1992 UTC (33 years, 1 month ago) by greg
changed -di to ! -dv
Fri Nov 6 16:48:32 1992 UTC (33 years, 2 months ago) by greg
Changes since 2.8: +26 -3 lines
added -oN for unperturbed surface normal and made -on perturbed
Thu Oct 15 21:13:21 1992 UTC (33 years, 2 months ago) by greg
Changes since 2.7: +4 -0 lines
added setmode(fd,O_BINARY) where needed for MSDOS
Tue Jul 21 10:36:37 1992 UTC (33 years, 5 months ago) by greg
Changes since 2.6: +0 -2 lines
fixed bug introduced in last change with -h- option of rtrace
Fri Jul 10 14:56:24 1992 UTC (33 years, 6 months ago) by greg
Changes since 2.5: +38 -1 lines
added ability to print COLRFMT output of values
Thu Mar 12 09:46:19 1992 UTC (33 years, 10 months ago) by greg
Changes since 2.4: +17 -4 lines
added -oL output option for single-ray length
Thu Jan 16 12:05:20 1992 UTC (33 years, 11 months ago) by greg
changed default values and handling of specthresh
Tue Jan 14 16:16:07 1992 UTC (33 years, 11 months ago) by greg
Changes since 2.2: +3 -0 lines
added -sj and -st options and changed old -s options to -p
Thu Dec 19 14:54:53 1991 UTC (34 years ago) by greg
removed atof() declarations for NeXT
Tue Nov 12 17:09:39 1991 UTC (34 years, 2 months ago) by greg
Diff to previous 1.20
Mon Oct 21 12:58:10 1991 UTC (34 years, 2 months ago) by greg
Changes since 1.19: +2 -1 lines
Diff to previous 1.19
Mon Jul 22 13:09:58 1991 UTC (34 years, 5 months ago) by greg
Changes since 1.18: +10 -2 lines
Diff to previous 1.18
got rid of scanf() call
Thu Jul 18 14:43:03 1991 UTC (34 years, 5 months ago) by greg
Changes since 1.17: +1 -0 lines
Diff to previous 1.17
Tue Jun 25 14:06:18 1991 UTC (34 years, 6 months ago) by greg
Diff to previous 1.16
increased defaults for -dp parameter
Mon Jun 24 16:16:54 1991 UTC (34 years, 6 months ago) by greg
Changes since 1.15: +1 -0 lines
Diff to previous 1.15
Wed Jun 19 16:36:48 1991 UTC (34 years, 6 months ago) by greg
Changes since 1.14: +1 -0 lines
Diff to previous 1.14
added virtual sources
Tue May 21 17:41:23 1991 UTC (34 years, 7 months ago) by greg
Changes since 1.13: +5 -0 lines
Diff to previous 1.13
Wed May 1 11:16:58 1991 UTC (34 years, 8 months ago) by greg
Changes since 1.12: +9 -29 lines
Diff to previous 1.12
Thu Mar 28 10:16:35 1991 UTC (34 years, 9 months ago) by greg
Changes since 1.11: +25 -6 lines
Diff to previous 1.11
added -oI option for irradiance after intersection
Sat Aug 18 10:34:47 1990 UTC (35 years, 4 months ago) by greg
Changes since 1.10: +11 -1 lines
Diff to previous 1.10
added conditional ray casting to rtrace for efficiency
Tue Jun 26 09:00:15 1990 UTC (35 years, 6 months ago) by greg
Diff to previous 1.9
Tue Mar 27 11:40:10 1990 UTC (35 years, 9 months ago) by greg
Changes since 1.8: +1 -4 lines
Diff to previous 1.8
Fri Jan 19 00:00:26 1990 UTC (35 years, 11 months ago) by greg
Diff to previous 1.7
Thu Jan 4 11:16:05 1990 UTC (36 years ago) by greg
Changes since 1.6: +6 -3 lines
Diff to previous 1.6
added flushing for zero input direction vector
Mon Jul 10 15:21:28 1989 UTC (36 years, 6 months ago) by greg
Diff to previous 1.5
Reduced default ambient resolution
Tue Jun 13 10:57:43 1989 UTC (36 years, 7 months ago) by greg
Diff to previous 1.4
Wed Jun 7 21:00:59 1989 UTC (36 years, 7 months ago) by greg
Diff to previous 1.3
Wed Jun 7 08:35:23 1989 UTC (36 years, 7 months ago) by greg
Glow type changed
Spot type eliminated
Wed Mar 15 13:47:57 1989 UTC (36 years, 10 months ago) by greg
eliminated unused variable
Thu Feb 2 10:41:37 1989 UTC (36 years, 11 months ago) by greg
