1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: rtrace.c,v 2.36 2004/03/28 16:31:14 greg Exp $"; |
3 |
#endif |
4 |
5 |
* rtrace.c - program and variables for individual ray tracing. |
6 |
7 |
8 |
#include "copyright.h" |
9 |
10 |
11 |
* Input is in the form: |
12 |
13 |
* xorg yorg zorg xdir ydir zdir |
14 |
15 |
* The direction need not be normalized. Output is flexible. |
16 |
* If the direction vector is (0,0,0), then the output is flushed. |
17 |
* All values default to ascii representation of real |
18 |
* numbers. Binary representations can be selected |
19 |
* with '-ff' for float or '-fd' for double. By default, |
20 |
* radiance is computed. The '-i' or '-I' options indicate that |
21 |
* irradiance values are desired. |
22 |
23 |
24 |
#include <time.h> |
25 |
26 |
#include "platform.h" |
27 |
#include "ray.h" |
28 |
#include "ambient.h" |
29 |
#include "source.h" |
30 |
#include "otypes.h" |
31 |
#include "resolu.h" |
32 |
33 |
CUBE thescene; /* our scene */ |
34 |
OBJECT nsceneobjs; /* number of objects in our scene */ |
35 |
36 |
int dimlist[MAXDIM]; /* sampling dimensions */ |
37 |
int ndims = 0; /* number of sampling dimensions */ |
38 |
int samplendx = 0; /* index for this sample */ |
39 |
40 |
int imm_irrad = 0; /* compute immediate irradiance? */ |
41 |
int lim_dist = 0; /* limit distance? */ |
42 |
43 |
int inform = 'a'; /* input format */ |
44 |
int outform = 'a'; /* output format */ |
45 |
char *outvals = "v"; /* output specification */ |
46 |
47 |
int do_irrad = 0; /* compute irradiance? */ |
48 |
49 |
void (*trace)() = NULL; /* trace call */ |
50 |
51 |
char *tralist[128]; /* list of modifers to trace (or no) */ |
52 |
int traincl = -1; /* include == 1, exclude == 0 */ |
53 |
#define MAXTSET 511 /* maximum number in trace set */ |
54 |
OBJECT traset[MAXTSET+1]={0}; /* trace include/exclude set */ |
55 |
56 |
int hresolu = 0; /* horizontal (scan) size */ |
57 |
int vresolu = 0; /* vertical resolution */ |
58 |
59 |
double dstrsrc = 0.0; /* square source distribution */ |
60 |
double shadthresh = .03; /* shadow threshold */ |
61 |
double shadcert = .75; /* shadow certainty */ |
62 |
int directrelay = 2; /* number of source relays */ |
63 |
int vspretest = 512; /* virtual source pretest density */ |
64 |
int directvis = 1; /* sources visible? */ |
65 |
double srcsizerat = .2; /* maximum ratio source size/dist. */ |
66 |
67 |
COLOR cextinction = BLKCOLOR; /* global extinction coefficient */ |
68 |
COLOR salbedo = BLKCOLOR; /* global scattering albedo */ |
69 |
double seccg = 0.; /* global scattering eccentricity */ |
70 |
double ssampdist = 0.; /* scatter sampling distance */ |
71 |
72 |
double specthresh = .15; /* specular sampling threshold */ |
73 |
double specjitter = 1.; /* specular sampling jitter */ |
74 |
75 |
int backvis = 1; /* back face visibility */ |
76 |
77 |
int maxdepth = 8; /* maximum recursion depth */ |
78 |
double minweight = 2e-3; /* minimum ray weight */ |
79 |
80 |
char *ambfile = NULL; /* ambient file name */ |
81 |
COLOR ambval = BLKCOLOR; /* ambient value */ |
82 |
int ambvwt = 0; /* initial weight for ambient value */ |
83 |
double ambacc = 0.15; /* ambient accuracy */ |
84 |
int ambres = 256; /* ambient resolution */ |
85 |
int ambdiv = 1024; /* ambient divisions */ |
86 |
int ambssamp = 512; /* ambient super-samples */ |
87 |
int ambounce = 0; /* ambient bounces */ |
88 |
char *amblist[128]; /* ambient include/exclude list */ |
89 |
int ambincl = -1; /* include == 1, exclude == 0 */ |
90 |
91 |
static int castonly = 0; |
92 |
93 |
static RAY thisray; /* for our convenience */ |
94 |
95 |
typedef void putf_t(double v); |
96 |
static putf_t puta, putd, putf; |
97 |
98 |
typedef void oputf_t(RAY *r); |
99 |
static oputf_t oputo, oputd, oputv, oputl, oputL, oputc, |
100 |
oputp, oputn, oputN, oputs, oputw, oputm; |
101 |
102 |
static void setoutput(char *vs); |
103 |
static void tranotify(OBJECT obj); |
104 |
static void bogusray(void); |
105 |
static void rad(FVECT org, FVECT dir, double dmax); |
106 |
static void irrad(FVECT org, FVECT dir); |
107 |
static void printvals(RAY *r); |
108 |
static int getvec(FVECT vec, int fmt, FILE *fp); |
109 |
static void tabin(RAY *r); |
110 |
static void ourtrace(RAY *r); |
111 |
112 |
static oputf_t *ray_out[16], *every_out[16]; |
113 |
static putf_t *putreal; |
114 |
115 |
void (*addobjnotify[])() = {ambnotify, tranotify, NULL}; |
116 |
117 |
118 |
void |
119 |
quit( /* quit program */ |
120 |
int code |
121 |
122 |
123 |
#ifndef NON_POSIX /* XXX we don't clean up elsewhere? */ |
124 |
headclean(); /* delete header file */ |
125 |
pfclean(); /* clean up persist files */ |
126 |
#endif |
127 |
exit(code); |
128 |
129 |
130 |
131 |
extern char * |
132 |
formstr( /* return format identifier */ |
133 |
int f |
134 |
135 |
136 |
switch (f) { |
137 |
case 'a': return("ascii"); |
138 |
case 'f': return("float"); |
139 |
case 'd': return("double"); |
140 |
case 'c': return(COLRFMT); |
141 |
142 |
return("unknown"); |
143 |
144 |
145 |
146 |
extern void |
147 |
rtrace( /* trace rays from file */ |
148 |
char *fname |
149 |
150 |
151 |
long vcount = hresolu>1 ? hresolu*vresolu : vresolu; |
152 |
long nextflush = hresolu; |
153 |
FILE *fp; |
154 |
double d; |
155 |
FVECT orig, direc; |
156 |
/* set up input */ |
157 |
if (fname == NULL) |
158 |
fp = stdin; |
159 |
else if ((fp = fopen(fname, "r")) == NULL) { |
160 |
sprintf(errmsg, "cannot open input file \"%s\"", fname); |
161 |
error(SYSTEM, errmsg); |
162 |
163 |
#ifdef _WIN32 |
164 |
if (inform != 'a') |
165 |
SET_FILE_BINARY(fp); |
166 |
#endif |
167 |
/* set up output */ |
168 |
setoutput(outvals); |
169 |
switch (outform) { |
170 |
case 'a': putreal = puta; break; |
171 |
case 'f': putreal = putf; break; |
172 |
case 'd': putreal = putd; break; |
173 |
case 'c': |
174 |
if (strcmp(outvals, "v")) |
175 |
error(USER, "color format with value output only"); |
176 |
break; |
177 |
default: |
178 |
error(CONSISTENCY, "botched output format"); |
179 |
180 |
if (hresolu > 0) { |
181 |
if (vresolu > 0) |
182 |
fprtresolu(hresolu, vresolu, stdout); |
183 |
fflush(stdout); |
184 |
185 |
/* process file */ |
186 |
while (getvec(orig, inform, fp) == 0 && |
187 |
getvec(direc, inform, fp) == 0) { |
188 |
189 |
d = normalize(direc); |
190 |
if (d == 0.0) { /* zero ==> flush */ |
191 |
bogusray(); |
192 |
if (--nextflush <= 0 || vcount <= 0) { |
193 |
fflush(stdout); |
194 |
195 |
196 |
} else { |
197 |
samplendx++; |
198 |
/* compute and print */ |
199 |
if (imm_irrad) |
200 |
irrad(orig, direc); |
201 |
else |
202 |
rad(orig, direc, lim_dist ? d : 0.0); |
203 |
/* flush if time */ |
204 |
if (--nextflush == 0) { |
205 |
fflush(stdout); |
206 |
207 |
208 |
209 |
if (ferror(stdout)) |
210 |
error(SYSTEM, "write error"); |
211 |
if (--vcount == 0) /* check for end */ |
212 |
break; |
213 |
214 |
fflush(stdout); |
215 |
if (vcount > 0) |
216 |
error(USER, "read error"); |
217 |
if (fname != NULL) |
218 |
fclose(fp); |
219 |
220 |
221 |
222 |
static void |
223 |
setoutput( /* set up output tables */ |
224 |
register char *vs |
225 |
226 |
227 |
register oputf_t **table = ray_out; |
228 |
229 |
castonly = 1; |
230 |
while (*vs) |
231 |
switch (*vs++) { |
232 |
case 't': /* trace */ |
233 |
*table = NULL; |
234 |
table = every_out; |
235 |
trace = ourtrace; |
236 |
castonly = 0; |
237 |
break; |
238 |
case 'o': /* origin */ |
239 |
*table++ = oputo; |
240 |
break; |
241 |
case 'd': /* direction */ |
242 |
*table++ = oputd; |
243 |
break; |
244 |
case 'v': /* value */ |
245 |
*table++ = oputv; |
246 |
castonly = 0; |
247 |
break; |
248 |
case 'l': /* effective distance */ |
249 |
*table++ = oputl; |
250 |
castonly = 0; |
251 |
break; |
252 |
case 'c': /* local coordinates */ |
253 |
*table++ = oputc; |
254 |
break; |
255 |
case 'L': /* single ray length */ |
256 |
*table++ = oputL; |
257 |
break; |
258 |
case 'p': /* point */ |
259 |
*table++ = oputp; |
260 |
break; |
261 |
case 'n': /* perturbed normal */ |
262 |
*table++ = oputn; |
263 |
castonly = 0; |
264 |
break; |
265 |
case 'N': /* unperturbed normal */ |
266 |
*table++ = oputN; |
267 |
break; |
268 |
case 's': /* surface */ |
269 |
*table++ = oputs; |
270 |
break; |
271 |
case 'w': /* weight */ |
272 |
*table++ = oputw; |
273 |
break; |
274 |
case 'm': /* modifier */ |
275 |
*table++ = oputm; |
276 |
break; |
277 |
278 |
*table = NULL; |
279 |
280 |
281 |
282 |
static void |
283 |
bogusray(void) /* print out empty record */ |
284 |
285 |
thisray.rorg[0] = thisray.rorg[1] = thisray.rorg[2] = |
286 |
thisray.rdir[0] = thisray.rdir[1] = thisray.rdir[2] = 0.0; |
287 |
rayorigin(&thisray, NULL, PRIMARY, 1.0); |
288 |
printvals(&thisray); |
289 |
290 |
291 |
292 |
static void |
293 |
rad( /* compute and print ray value(s) */ |
294 |
FVECT org, |
295 |
FVECT dir, |
296 |
double dmax |
297 |
298 |
299 |
VCOPY(thisray.rorg, org); |
300 |
VCOPY(thisray.rdir, dir); |
301 |
thisray.rmax = dmax; |
302 |
303 |
if (castonly) { |
304 |
if (!localhit(&thisray, &thescene)) { |
305 |
if (thisray.ro == &Aftplane) { /* clipped */ |
306 |
thisray.ro = NULL; |
307 |
thisray.rot = FHUGE; |
308 |
} else |
309 |
sourcehit(&thisray); |
310 |
311 |
} else |
312 |
rayvalue(&thisray); |
313 |
314 |
315 |
316 |
317 |
static void |
318 |
irrad( /* compute immediate irradiance value */ |
319 |
FVECT org, |
320 |
FVECT dir |
321 |
322 |
323 |
register int i; |
324 |
325 |
for (i = 0; i < 3; i++) { |
326 |
thisray.rorg[i] = org[i] + dir[i]; |
327 |
thisray.rdir[i] = -dir[i]; |
328 |
329 |
330 |
/* pretend we hit surface */ |
331 |
thisray.rot = 1.0-1e-4; |
332 |
thisray.rod = 1.0; |
333 |
VCOPY(thisray.ron, dir); |
334 |
for (i = 0; i < 3; i++) /* fudge factor */ |
335 |
thisray.rop[i] = org[i] + 1e-4*dir[i]; |
336 |
337 |
(*ofun[Lamb.otype].funp)(&Lamb, &thisray); |
338 |
339 |
340 |
341 |
342 |
static void |
343 |
printvals( /* print requested ray values */ |
344 |
RAY *r |
345 |
346 |
347 |
register oputf_t **tp; |
348 |
349 |
if (ray_out[0] == NULL) |
350 |
return; |
351 |
for (tp = ray_out; *tp != NULL; tp++) |
352 |
(**tp)(r); |
353 |
if (outform == 'a') |
354 |
putchar('\n'); |
355 |
356 |
357 |
358 |
static int |
359 |
getvec( /* get a vector from fp */ |
360 |
register FVECT vec, |
361 |
int fmt, |
362 |
FILE *fp |
363 |
364 |
365 |
static float vf[3]; |
366 |
static double vd[3]; |
367 |
char buf[32]; |
368 |
register int i; |
369 |
370 |
switch (fmt) { |
371 |
case 'a': /* ascii */ |
372 |
373 |
if (fgetword(buf, sizeof(buf), fp) == NULL || |
374 |
!isflt(buf)) |
375 |
return(-1); |
376 |
vec[i] = atof(buf); |
377 |
378 |
break; |
379 |
case 'f': /* binary float */ |
380 |
if (fread((char *)vf, sizeof(float), 3, fp) != 3) |
381 |
return(-1); |
382 |
vec[0] = vf[0]; vec[1] = vf[1]; vec[2] = vf[2]; |
383 |
break; |
384 |
case 'd': /* binary double */ |
385 |
if (fread((char *)vd, sizeof(double), 3, fp) != 3) |
386 |
return(-1); |
387 |
vec[0] = vd[0]; vec[1] = vd[1]; vec[2] = vd[2]; |
388 |
break; |
389 |
default: |
390 |
error(CONSISTENCY, "botched input format"); |
391 |
392 |
return(0); |
393 |
394 |
395 |
396 |
static void |
397 |
tranotify( /* record new modifier */ |
398 |
OBJECT obj |
399 |
400 |
401 |
static int hitlimit = 0; |
402 |
register OBJREC *o = objptr(obj); |
403 |
register char **tralp; |
404 |
405 |
if (obj == OVOID) { /* starting over */ |
406 |
traset[0] = 0; |
407 |
hitlimit = 0; |
408 |
return; |
409 |
410 |
if (hitlimit || !ismodifier(o->otype)) |
411 |
return; |
412 |
for (tralp = tralist; *tralp != NULL; tralp++) |
413 |
if (!strcmp(o->oname, *tralp)) { |
414 |
if (traset[0] >= MAXTSET) { |
415 |
error(WARNING, "too many modifiers in trace list"); |
416 |
hitlimit++; |
417 |
return; /* should this be fatal? */ |
418 |
419 |
insertelem(traset, obj); |
420 |
return; |
421 |
422 |
423 |
424 |
425 |
static void |
426 |
ourtrace( /* print ray values */ |
427 |
RAY *r |
428 |
429 |
430 |
431 |
432 |
if (every_out[0] == NULL) |
433 |
return; |
434 |
if (r->ro == NULL) { |
435 |
if (traincl == 1) |
436 |
return; |
437 |
} else if (traincl != -1 && traincl != inset(traset, r->ro->omod)) |
438 |
return; |
439 |
tabin(r); |
440 |
for (tp = every_out; *tp != NULL; tp++) |
441 |
(**tp)(r); |
442 |
putchar('\n'); |
443 |
444 |
445 |
446 |
static void |
447 |
tabin( /* tab in appropriate amount */ |
448 |
RAY *r |
449 |
450 |
451 |
register RAY *rp; |
452 |
453 |
for (rp = r->parent; rp != NULL; rp = rp->parent) |
454 |
putchar('\t'); |
455 |
456 |
457 |
458 |
static void |
459 |
oputo( /* print origin */ |
460 |
RAY *r |
461 |
462 |
463 |
(*putreal)(r->rorg[0]); |
464 |
(*putreal)(r->rorg[1]); |
465 |
(*putreal)(r->rorg[2]); |
466 |
467 |
468 |
469 |
static void |
470 |
oputd( /* print direction */ |
471 |
RAY *r |
472 |
473 |
474 |
(*putreal)(r->rdir[0]); |
475 |
(*putreal)(r->rdir[1]); |
476 |
(*putreal)(r->rdir[2]); |
477 |
478 |
479 |
480 |
static void |
481 |
oputv( /* print value */ |
482 |
RAY *r |
483 |
484 |
485 |
COLR cout; |
486 |
487 |
if (outform == 'c') { |
488 |
setcolr(cout, colval(r->rcol,RED), |
489 |
colval(r->rcol,GRN), |
490 |
colval(r->rcol,BLU)); |
491 |
fwrite((char *)cout, sizeof(cout), 1, stdout); |
492 |
return; |
493 |
494 |
(*putreal)(colval(r->rcol,RED)); |
495 |
(*putreal)(colval(r->rcol,GRN)); |
496 |
(*putreal)(colval(r->rcol,BLU)); |
497 |
498 |
499 |
500 |
static void |
501 |
oputl( /* print effective distance */ |
502 |
RAY *r |
503 |
504 |
505 |
(*putreal)(r->rt); |
506 |
507 |
508 |
509 |
static void |
510 |
oputL( /* print single ray length */ |
511 |
RAY *r |
512 |
513 |
514 |
(*putreal)(r->rot); |
515 |
516 |
517 |
518 |
static void |
519 |
oputc( /* print local coordinates */ |
520 |
RAY *r |
521 |
522 |
523 |
(*putreal)(r->uv[0]); |
524 |
(*putreal)(r->uv[1]); |
525 |
526 |
527 |
528 |
static void |
529 |
oputp( /* print point */ |
530 |
RAY *r |
531 |
532 |
533 |
if (r->rot < FHUGE) { |
534 |
(*putreal)(r->rop[0]); |
535 |
(*putreal)(r->rop[1]); |
536 |
(*putreal)(r->rop[2]); |
537 |
} else { |
538 |
(*putreal)(0.0); |
539 |
(*putreal)(0.0); |
540 |
(*putreal)(0.0); |
541 |
542 |
543 |
544 |
545 |
static void |
546 |
oputN( /* print unperturbed normal */ |
547 |
RAY *r |
548 |
549 |
550 |
551 |
(*putreal)(r->ron[0]); |
552 |
(*putreal)(r->ron[1]); |
553 |
(*putreal)(r->ron[2]); |
554 |
} else { |
555 |
(*putreal)(0.0); |
556 |
(*putreal)(0.0); |
557 |
(*putreal)(0.0); |
558 |
559 |
560 |
561 |
562 |
static void |
563 |
oputn( /* print perturbed normal */ |
564 |
RAY *r |
565 |
566 |
567 |
FVECT pnorm; |
568 |
569 |
if (r->rot >= FHUGE) { |
570 |
(*putreal)(0.0); |
571 |
(*putreal)(0.0); |
572 |
(*putreal)(0.0); |
573 |
return; |
574 |
575 |
raynormal(pnorm, r); |
576 |
(*putreal)(pnorm[0]); |
577 |
(*putreal)(pnorm[1]); |
578 |
(*putreal)(pnorm[2]); |
579 |
580 |
581 |
582 |
static void |
583 |
oputs( /* print name */ |
584 |
RAY *r |
585 |
586 |
587 |
if (r->ro != NULL) |
588 |
fputs(r->ro->oname, stdout); |
589 |
else |
590 |
putchar('*'); |
591 |
putchar('\t'); |
592 |
593 |
594 |
595 |
static void |
596 |
oputw( /* print weight */ |
597 |
RAY *r |
598 |
599 |
600 |
(*putreal)(r->rweight); |
601 |
602 |
603 |
604 |
static void |
605 |
oputm( /* print modifier */ |
606 |
RAY *r |
607 |
608 |
609 |
610 |
if (r->ro->omod != OVOID) |
611 |
fputs(objptr(r->ro->omod)->oname, stdout); |
612 |
else |
613 |
fputs(VOIDID, stdout); |
614 |
else |
615 |
putchar('*'); |
616 |
putchar('\t'); |
617 |
618 |
619 |
620 |
static void |
621 |
puta( /* print ascii value */ |
622 |
double v |
623 |
624 |
625 |
printf("%e\t", v); |
626 |
627 |
628 |
629 |
static void |
630 |
putd(v) /* print binary double */ |
631 |
double v; |
632 |
633 |
fwrite((char *)&v, sizeof(v), 1, stdout); |
634 |
635 |
636 |
637 |
static void |
638 |
putf(v) /* print binary float */ |
639 |
double v; |
640 |
641 |
float f = v; |
642 |
643 |
fwrite((char *)&f, sizeof(f), 1, stdout); |
644 |
