| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: rtmain.c,v 2.52 2024/04/05 16:43:33 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* rtmain.c - main for rtrace per-ray calculation program
| 6 |
| 7 |
| 8 |
#include "copyright.h"
| 9 |
| 10 |
#include <signal.h>
| 11 |
| 12 |
#include "platform.h"
| 13 |
#include "rtprocess.h" /* getpid() */
| 14 |
#include "resolu.h"
| 15 |
#include "ray.h"
| 16 |
#include "source.h"
| 17 |
#include "ambient.h"
| 18 |
#include "random.h"
| 19 |
#include "paths.h"
| 20 |
#include "pmapray.h"
| 21 |
| 22 |
extern char *progname; /* global argv[0] */
| 23 |
| 24 |
extern char *shm_boundary; /* boundary of shared memory */
| 25 |
| 26 |
/* persistent processes define */
| 27 |
#ifdef F_SETLKW
| 28 |
#define PERSIST 1 /* normal persist */
| 29 |
#define PARALLEL 2 /* parallel persist */
| 30 |
#define PCHILD 3 /* child of normal persist */
| 31 |
#endif
| 32 |
| 33 |
char *sigerr[NSIG]; /* signal error messages */
| 34 |
char *errfile = NULL; /* error output file */
| 35 |
| 36 |
int nproc = 1; /* number of processes */
| 37 |
| 38 |
extern int setrtoutput(void); /* set output values */
| 39 |
| 40 |
int inform = 'a'; /* input format */
| 41 |
int outform = 'a'; /* output format */
| 42 |
char *outvals = "v"; /* output specification */
| 43 |
| 44 |
int hresolu = 0; /* horizontal (scan) size */
| 45 |
int vresolu = 0; /* vertical resolution */
| 46 |
| 47 |
extern int castonly; /* only doing ray-casting? */
| 48 |
| 49 |
int imm_irrad = 0; /* compute immediate irradiance? */
| 50 |
int lim_dist = 0; /* limit distance? */
| 51 |
| 52 |
#ifndef MAXMODLIST
| 53 |
#define MAXMODLIST 1024 /* maximum modifiers we'll track */
| 54 |
#endif
| 55 |
| 56 |
extern void (*addobjnotify[])(); /* object notification calls */
| 57 |
extern void tranotify(OBJECT obj);
| 58 |
| 59 |
char *tralist[MAXMODLIST]; /* list of modifers to trace (or no) */
| 60 |
int traincl = -1; /* include == 1, exclude == 0 */
| 61 |
| 62 |
double (*sens_curve)(SCOLOR scol) = NULL; /* spectral conversion for 1-channel */
| 63 |
double out_scalefactor = 1; /* output calibration scale factor */
| 64 |
RGBPRIMP out_prims = stdprims; /* output color primitives (NULL if spectral) */
| 65 |
static RGBPRIMS our_prims; /* private output color primitives */
| 66 |
| 67 |
static int loadflags = ~IO_FILES; /* what to load from octree */
| 68 |
| 69 |
static void onsig(int signo);
| 70 |
static void sigdie(int signo, char *msg);
| 71 |
static void printdefaults(void);
| 72 |
| 73 |
#ifdef PERSIST
| 74 |
#define RTRACE_FEATURES "Persist\nParallelPersist\nMultiprocessing\n" \
| 75 |
"IrradianceCalc\nImmediateIrradiance\nDistanceLimiting\n" \
| 76 |
"ParticipatingMedia=Mist\n" \
| 77 |
"HessianAmbientCache\nAmbientAveraging\n" \
| 78 |
"AmbientValueSharing\nAdaptiveShadowTesting\n" \
| 79 |
"InputFormats=a,f,d\nOutputFormats=a,f,d,c\n" \
| 80 |
"Outputs=o,d,v,V,w,W,l,L,c,p,n,N,s,m,M,r,x,R,X,~\n" \
| 81 |
"OutputCS=RGB,XYZ,Y,S,M,prims,spec\n"
| 82 |
#else
| 83 |
#define RTRACE_FEATURES "IrradianceCalc\nIrradianceCalc\nDistanceLimiting\n" \
| 84 |
| 85 |
| 86 |
| 87 |
| 88 |
| 89 |
| 90 |
#endif
| 91 |
| 92 |
| 93 |
int
| 94 |
main(int argc, char *argv[])
| 95 |
| 96 |
#define check(ol,al) if (argv[i][ol] || \
| 97 |
badarg(argc-i-1,argv+i+1,al)) \
| 98 |
goto badopt
| 99 |
#define check_bool(olen,var) switch (argv[i][olen]) { \
| 100 |
case '\0': var = !var; break; \
| 101 |
case 'y': case 'Y': case 't': case 'T': \
| 102 |
case '+': case '1': var = 1; break; \
| 103 |
case 'n': case 'N': case 'f': case 'F': \
| 104 |
case '-': case '0': var = 0; break; \
| 105 |
default: goto badopt; }
| 106 |
extern char *octname;
| 107 |
int persist = 0;
| 108 |
char *octnm = NULL;
| 109 |
char **tralp = NULL;
| 110 |
int duped1 = -1;
| 111 |
int rval;
| 112 |
int i;
| 113 |
/* global program name */
| 114 |
progname = argv[0] = fixargv0(argv[0]);
| 115 |
/* feature check only? */
| 116 |
strcat(RFeatureList, RTRACE_FEATURES);
| 117 |
if (argc > 1 && !strcmp(argv[1], "-features"))
| 118 |
return feature_status(argc-2, argv+2);
| 119 |
/* add trace notify function */
| 120 |
for (i = 0; addobjnotify[i] != NULL; i++)
| 121 |
| 122 |
addobjnotify[i] = tranotify;
| 123 |
/* option city */
| 124 |
for (i = 1; i < argc; i++) {
| 125 |
/* expand arguments */
| 126 |
while ((rval = expandarg(&argc, &argv, i)) > 0)
| 127 |
| 128 |
if (rval < 0) {
| 129 |
sprintf(errmsg, "cannot expand '%s'", argv[i]);
| 130 |
error(SYSTEM, errmsg);
| 131 |
| 132 |
if (argv[i] == NULL || argv[i][0] != '-')
| 133 |
break; /* break from options */
| 134 |
if (!strcmp(argv[i], "-version")) {
| 135 |
puts(VersionID);
| 136 |
quit(0);
| 137 |
| 138 |
if (!strcmp(argv[i], "-defaults") ||
| 139 |
!strcmp(argv[i], "-help")) {
| 140 |
printdefaults();
| 141 |
quit(0);
| 142 |
| 143 |
rval = getrenderopt(argc-i, argv+i);
| 144 |
if (rval >= 0) {
| 145 |
i += rval;
| 146 |
continue;
| 147 |
| 148 |
switch (argv[i][1]) {
| 149 |
case 'n': /* number of cores */
| 150 |
check(2,"i");
| 151 |
nproc = atoi(argv[++i]);
| 152 |
if (nproc <= 0)
| 153 |
error(USER, "bad number of processes");
| 154 |
break;
| 155 |
case 'x': /* x resolution */
| 156 |
check(2,"i");
| 157 |
hresolu = atoi(argv[++i]);
| 158 |
break;
| 159 |
case 'y': /* y resolution */
| 160 |
check(2,"i");
| 161 |
vresolu = atoi(argv[++i]);
| 162 |
break;
| 163 |
case 'w': /* warnings & spectral */
| 164 |
rval = erract[WARNING].pf != NULL;
| 165 |
check_bool(2,rval);
| 166 |
if (rval) erract[WARNING].pf = wputs;
| 167 |
else erract[WARNING].pf = NULL;
| 168 |
break;
| 169 |
case 'e': /* error file */
| 170 |
check(2,"s");
| 171 |
errfile = argv[++i];
| 172 |
break;
| 173 |
case 'l': /* limit distance */
| 174 |
if (argv[i][2] != 'd')
| 175 |
goto badopt;
| 176 |
check_bool(3,lim_dist);
| 177 |
break;
| 178 |
case 'I': /* immed. irradiance */
| 179 |
check_bool(2,imm_irrad);
| 180 |
break;
| 181 |
case 'f': /* format i/o */
| 182 |
switch (argv[i][2]) {
| 183 |
case 'a': /* ascii */
| 184 |
case 'f': /* float */
| 185 |
case 'd': /* double */
| 186 |
inform = argv[i][2];
| 187 |
break;
| 188 |
default:
| 189 |
goto badopt;
| 190 |
| 191 |
switch (argv[i][3]) {
| 192 |
case '\0':
| 193 |
outform = inform;
| 194 |
break;
| 195 |
| 196 |
| 197 |
| 198 |
case 'c': /* color */
| 199 |
check(4,"");
| 200 |
outform = argv[i][3];
| 201 |
break;
| 202 |
default:
| 203 |
goto badopt;
| 204 |
| 205 |
break;
| 206 |
case 'o': /* output */
| 207 |
outvals = argv[i]+2;
| 208 |
break;
| 209 |
case 'h': /* header output */
| 210 |
rval = loadflags & IO_INFO;
| 211 |
check_bool(2,rval);
| 212 |
loadflags = rval ? loadflags | IO_INFO :
| 213 |
loadflags & ~IO_INFO;
| 214 |
break;
| 215 |
case 't': /* trace */
| 216 |
| 217 |
case 'i': /* include */
| 218 |
case 'I':
| 219 |
check(3,"s");
| 220 |
if (traincl != 1) {
| 221 |
traincl = 1;
| 222 |
tralp = tralist;
| 223 |
| 224 |
if (argv[i][2] == 'I') { /* file */
| 225 |
rval = wordfile(tralp, MAXMODLIST-(tralp-tralist),
| 226 |
getpath(argv[++i],getrlibpath(),R_OK));
| 227 |
if (rval < 0) {
| 228 |
sprintf(errmsg,
| 229 |
"cannot open trace include file \"%s\"",
| 230 |
argv[i]);
| 231 |
| 232 |
| 233 |
tralp += rval;
| 234 |
} else {
| 235 |
*tralp++ = argv[++i];
| 236 |
*tralp = NULL;
| 237 |
| 238 |
break;
| 239 |
case 'e': /* exclude */
| 240 |
case 'E':
| 241 |
check(3,"s");
| 242 |
if (traincl != 0) {
| 243 |
traincl = 0;
| 244 |
tralp = tralist;
| 245 |
| 246 |
if (argv[i][2] == 'E') { /* file */
| 247 |
| 248 |
| 249 |
if (rval < 0) {
| 250 |
sprintf(errmsg,
| 251 |
"cannot open trace exclude file \"%s\"",
| 252 |
argv[i]);
| 253 |
| 254 |
| 255 |
tralp += rval;
| 256 |
} else {
| 257 |
| 258 |
*tralp = NULL;
| 259 |
| 260 |
break;
| 261 |
default:
| 262 |
goto badopt;
| 263 |
| 264 |
break;
| 265 |
case 'p': /* value output */
| 266 |
| 267 |
case 'R': /* standard RGB output */
| 268 |
if (strcmp(argv[i]+2, "RGB"))
| 269 |
goto badopt;
| 270 |
| 271 |
| 272 |
sens_curve = NULL;
| 273 |
break;
| 274 |
case 'X': /* XYZ output */
| 275 |
if (strcmp(argv[i]+2, "XYZ"))
| 276 |
goto badopt;
| 277 |
out_prims = xyzprims;
| 278 |
out_scalefactor = WHTEFFICACY;
| 279 |
sens_curve = NULL;
| 280 |
break;
| 281 |
case 'c': {
| 282 |
int j;
| 283 |
check(3,"ffffffff");
| 284 |
rval = 0;
| 285 |
for (j = 0; j < 8; j++) {
| 286 |
our_prims[0][j] = atof(argv[++i]);
| 287 |
rval |= fabs(our_prims[0][j]-stdprims[0][j]) > .001;
| 288 |
| 289 |
if (rval) {
| 290 |
if (!colorprimsOK(our_prims))
| 291 |
error(USER, "illegal primary chromaticities");
| 292 |
out_prims = our_prims;
| 293 |
} else
| 294 |
| 295 |
| 296 |
sens_curve = NULL;
| 297 |
} break;
| 298 |
case 'Y': /* photopic response */
| 299 |
if (argv[i][3])
| 300 |
goto badopt;
| 301 |
sens_curve = scolor_photopic;
| 302 |
| 303 |
break;
| 304 |
case 'S': /* scotopic response */
| 305 |
if (argv[i][3])
| 306 |
goto badopt;
| 307 |
sens_curve = scolor_scotopic;
| 308 |
out_scalefactor = WHTSCOTOPIC;
| 309 |
break;
| 310 |
case 'M': /* melanopic response */
| 311 |
if (argv[i][3])
| 312 |
goto badopt;
| 313 |
sens_curve = scolor_melanopic;
| 314 |
out_scalefactor = WHTMELANOPIC;
| 315 |
break;
| 316 |
default:
| 317 |
goto badopt;
| 318 |
| 319 |
break;
| 320 |
#if MAXCSAMP>3
| 321 |
case 'c': /* output spectral results */
| 322 |
if (argv[i][2] != 'o')
| 323 |
goto badopt;
| 324 |
rval = (out_prims == NULL) & (sens_curve == NULL);
| 325 |
check_bool(3,rval);
| 326 |
if (rval) {
| 327 |
out_prims = NULL;
| 328 |
sens_curve = NULL;
| 329 |
} else if (out_prims == NULL)
| 330 |
| 331 |
break;
| 332 |
#endif
| 333 |
#ifdef PERSIST
| 334 |
case 'P': /* persist file */
| 335 |
if (argv[i][2] == 'P') {
| 336 |
check(3,"s");
| 337 |
persist = PARALLEL;
| 338 |
} else {
| 339 |
check(2,"s");
| 340 |
persist = PERSIST;
| 341 |
| 342 |
persistfile(argv[++i]);
| 343 |
break;
| 344 |
#endif
| 345 |
default:
| 346 |
goto badopt;
| 347 |
| 348 |
| 349 |
/* set/check spectral sampling */
| 350 |
rval = setspectrsamp(CNDX, WLPART);
| 351 |
if (rval < 0)
| 352 |
error(USER, "unsupported spectral sampling");
| 353 |
if (out_prims != NULL) {
| 354 |
if (!rval)
| 355 |
error(WARNING, "spectral range incompatible with color output");
| 356 |
} else if (NCSAMP == 3)
| 357 |
out_prims = stdprims; /* 3 samples do not a spectrum make */
| 358 |
if (nproc > 1 && persist)
| 359 |
error(USER, "multiprocessing incompatible with persist file");
| 360 |
/* initialize object types */
| 361 |
initotypes();
| 362 |
/* initialize urand */
| 363 |
if (rand_samp) {
| 364 |
srandom((long)time(0));
| 365 |
initurand(0);
| 366 |
} else {
| 367 |
srandom(0L);
| 368 |
initurand(2048);
| 369 |
| 370 |
/* set up signal handling */
| 371 |
sigdie(SIGINT, "Interrupt");
| 372 |
#ifdef SIGHUP
| 373 |
sigdie(SIGHUP, "Hangup");
| 374 |
#endif
| 375 |
sigdie(SIGTERM, "Terminate");
| 376 |
#ifdef SIGPIPE
| 377 |
sigdie(SIGPIPE, "Broken pipe");
| 378 |
#endif
| 379 |
#ifdef SIGALRM
| 380 |
sigdie(SIGALRM, "Alarm clock");
| 381 |
#endif
| 382 |
#ifdef SIGXCPU
| 383 |
sigdie(SIGXCPU, "CPU limit exceeded");
| 384 |
sigdie(SIGXFSZ, "File size exceeded");
| 385 |
#endif
| 386 |
/* open error file */
| 387 |
if (errfile != NULL) {
| 388 |
if (freopen(errfile, "a", stderr) == NULL)
| 389 |
quit(2);
| 390 |
fprintf(stderr, "**************\n*** PID %5d: ",
| 391 |
getpid());
| 392 |
printargs(argc, argv, stderr);
| 393 |
putc('\n', stderr);
| 394 |
fflush(stderr);
| 395 |
| 396 |
#ifdef NICE
| 397 |
nice(NICE); /* lower priority */
| 398 |
#endif
| 399 |
/* get octree */
| 400 |
if (i == argc)
| 401 |
octnm = NULL;
| 402 |
else if (i == argc-1)
| 403 |
octnm = argv[i];
| 404 |
else
| 405 |
goto badopt;
| 406 |
if (octnm == NULL)
| 407 |
error(USER, "missing octree argument");
| 408 |
/* set up output */
| 409 |
#ifdef PERSIST
| 410 |
if (persist) {
| 411 |
duped1 = dup(fileno(stdout)); /* don't lose our output */
| 412 |
openheader();
| 413 |
| 414 |
#endif
| 415 |
if (outform != 'a')
| 416 |
SET_FILE_BINARY(stdout);
| 417 |
rval = setrtoutput();
| 418 |
octname = savqstr(octnm);
| 419 |
readoct(octname, loadflags, &thescene, NULL);
| 420 |
nsceneobjs = nobjects;
| 421 |
| 422 |
if (loadflags & IO_INFO) { /* print header */
| 423 |
printargs(i, argv, stdout);
| 424 |
printf("SOFTWARE= %s\n", VersionID);
| 425 |
fputnow(stdout);
| 426 |
if (rval > 0) /* saved from setrtoutput() call */
| 427 |
fputncomp(rval, stdout);
| 428 |
if (NCSAMP > 3)
| 429 |
fputwlsplit(WLPART, stdout);
| 430 |
if ((out_prims != stdprims) & (out_prims != NULL))
| 431 |
fputprims(out_prims, stdout);
| 432 |
if ((outform == 'f') | (outform == 'd'))
| 433 |
fputendian(stdout);
| 434 |
fputformat(formstr(outform), stdout);
| 435 |
fputc('\n', stdout); /* end of header */
| 436 |
| 437 |
| 438 |
if (!castonly) { /* any actual ray traversal to do? */
| 439 |
| 440 |
ray_init_pmap(); /* PMAP: set up & load photon maps */
| 441 |
| 442 |
marksources(); /* find and mark sources */
| 443 |
| 444 |
setambient(); /* initialize ambient calculation */
| 445 |
} else
| 446 |
distantsources(); /* else mark only distant sources */
| 447 |
| 448 |
fflush(stdout); /* in case we're duplicating header */
| 449 |
| 450 |
#ifdef PERSIST
| 451 |
if (persist) {
| 452 |
/* reconnect stdout */
| 453 |
dup2(duped1, fileno(stdout));
| 454 |
close(duped1);
| 455 |
if (persist == PARALLEL) { /* multiprocessing */
| 456 |
preload_objs(); /* preload scene */
| 457 |
shm_boundary = (char *)malloc(16);
| 458 |
strcpy(shm_boundary, "SHM_BOUNDARY");
| 459 |
while ((rval=fork()) == 0) { /* keep on forkin' */
| 460 |
pflock(1);
| 461 |
pfhold();
| 462 |
ambsync(); /* load new values */
| 463 |
| 464 |
if (rval < 0)
| 465 |
error(SYSTEM, "cannot fork child for persist function");
| 466 |
pfdetach(); /* parent will run then exit */
| 467 |
| 468 |
| 469 |
runagain:
| 470 |
if (persist)
| 471 |
dupheader(); /* send header to stdout */
| 472 |
#endif
| 473 |
/* trace rays */
| 474 |
rtrace(NULL, nproc);
| 475 |
/* flush ambient file */
| 476 |
ambsync();
| 477 |
#ifdef PERSIST
| 478 |
if (persist == PERSIST) { /* first run-through */
| 479 |
if ((rval=fork()) == 0) { /* child loops until killed */
| 480 |
pflock(1);
| 481 |
persist = PCHILD;
| 482 |
} else { /* original process exits */
| 483 |
if (rval < 0)
| 484 |
| 485 |
pfdetach(); /* parent exits */
| 486 |
| 487 |
| 488 |
if (persist == PCHILD) { /* wait for a signal then go again */
| 489 |
pfhold();
| 490 |
raynum = nrays = 0; /* reinitialize */
| 491 |
goto runagain;
| 492 |
| 493 |
#endif
| 494 |
| 495 |
ray_done_pmap(); /* PMAP: free photon maps */
| 496 |
| 497 |
quit(0);
| 498 |
| 499 |
badopt:
| 500 |
sprintf(errmsg, "command line error at '%s'", argv[i]);
| 501 |
error(USER, errmsg);
| 502 |
return 1; /* pro forma return */
| 503 |
| 504 |
#undef check
| 505 |
#undef check_bool
| 506 |
| 507 |
| 508 |
| 509 |
void
| 510 |
wputs( /* warning output function */
| 511 |
const char *s
| 512 |
| 513 |
| 514 |
int lasterrno = errno;
| 515 |
eputs(s);
| 516 |
errno = lasterrno;
| 517 |
| 518 |
| 519 |
| 520 |
void
| 521 |
eputs( /* put string to stderr */
| 522 |
const char *s
| 523 |
| 524 |
| 525 |
static int midline = 0;
| 526 |
| 527 |
if (!*s)
| 528 |
return;
| 529 |
if (!midline++) {
| 530 |
fputs(progname, stderr);
| 531 |
fputs(": ", stderr);
| 532 |
| 533 |
fputs(s, stderr);
| 534 |
if (s[strlen(s)-1] == '\n') {
| 535 |
fflush(stderr);
| 536 |
midline = 0;
| 537 |
| 538 |
| 539 |
| 540 |
| 541 |
static void
| 542 |
onsig( /* fatal signal */
| 543 |
int signo
| 544 |
| 545 |
| 546 |
static int gotsig = 0;
| 547 |
| 548 |
if (gotsig++) /* two signals and we're gone! */
| 549 |
_exit(signo);
| 550 |
| 551 |
#ifdef SIGALRM
| 552 |
alarm(15); /* allow 15 seconds to clean up */
| 553 |
signal(SIGALRM, SIG_DFL); /* make certain we do die */
| 554 |
#endif
| 555 |
eputs("signal - ");
| 556 |
eputs(sigerr[signo]);
| 557 |
eputs("\n");
| 558 |
quit(3);
| 559 |
| 560 |
| 561 |
| 562 |
static void
| 563 |
sigdie( /* set fatal signal */
| 564 |
int signo,
| 565 |
char *msg
| 566 |
| 567 |
| 568 |
if (signal(signo, onsig) == SIG_IGN)
| 569 |
signal(signo, SIG_IGN);
| 570 |
sigerr[signo] = msg;
| 571 |
| 572 |
| 573 |
| 574 |
static void
| 575 |
printdefaults(void) /* print default values to stdout */
| 576 |
| 577 |
char *cp;
| 578 |
| 579 |
printf(erract[WARNING].pf != NULL ?
| 580 |
"-w+\t\t\t\t# warning messages on\n" :
| 581 |
"-w-\t\t\t\t# warning messages off\n");
| 582 |
if (imm_irrad)
| 583 |
printf("-I+\t\t\t\t# immediate irradiance on\n");
| 584 |
printf("-n %-2d\t\t\t\t# number of rendering processes\n", nproc);
| 585 |
printf("-x %-9d\t\t\t# %s\n", hresolu,
| 586 |
vresolu && hresolu ? "x resolution" : "flush interval");
| 587 |
printf("-y %-9d\t\t\t# y resolution\n", vresolu);
| 588 |
printf(lim_dist ? "-ld+\t\t\t\t# limit distance on\n" :
| 589 |
"-ld-\t\t\t\t# limit distance off\n");
| 590 |
printf(loadflags & IO_INFO ? "-h+\t\t\t\t# output header\n" :
| 591 |
"-h-\t\t\t\t# no header\n");
| 592 |
printf("-f%c%c\t\t\t\t# format input/output = %s/%s\n",
| 593 |
inform, outform, formstr(inform), formstr(outform));
| 594 |
printf("-o%-9s\t\t\t# output", outvals);
| 595 |
for (cp = outvals; *cp; cp++)
| 596 |
switch (*cp) {
| 597 |
case 't': case 'T': printf(" trace"); break;
| 598 |
case 'o': printf(" origin"); break;
| 599 |
case 'd': printf(" direction"); break;
| 600 |
case 'r': printf(" reflect_contrib"); break;
| 601 |
case 'R': printf(" reflect_length"); break;
| 602 |
case 'x': printf(" unreflect_contrib"); break;
| 603 |
case 'X': printf(" unreflect_length"); break;
| 604 |
case 'v': printf(" value"); break;
| 605 |
case 'V': printf(" contribution"); break;
| 606 |
case 'l': printf(" length"); break;
| 607 |
case 'L': printf(" first_length"); break;
| 608 |
case 'p': printf(" point"); break;
| 609 |
case 'n': printf(" normal"); break;
| 610 |
case 'N': printf(" unperturbed_normal"); break;
| 611 |
case 's': printf(" surface"); break;
| 612 |
case 'w': printf(" weight"); break;
| 613 |
case 'W': printf(" coefficient"); break;
| 614 |
case 'm': printf(" modifier"); break;
| 615 |
case 'M': printf(" material"); break;
| 616 |
case '~': printf(" tilde"); break;
| 617 |
| 618 |
| 619 |
if (sens_curve == scolor_photopic)
| 620 |
printf("-pY\t\t\t\t# photopic output\n");
| 621 |
else if (sens_curve == scolor_scotopic)
| 622 |
printf("-pS\t\t\t\t# scotopic output\n");
| 623 |
else if (sens_curve == scolor_melanopic)
| 624 |
printf("-pM\t\t\t\t# melanopic output\n");
| 625 |
else if (out_prims == stdprims)
| 626 |
printf("-pRGB\t\t\t\t# standard RGB color output\n");
| 627 |
else if (out_prims == xyzprims)
| 628 |
printf("-pXYZ\t\t\t\t# CIE XYZ color output\n");
| 629 |
else if (out_prims != NULL)
| 630 |
printf("-pc %.4f %.4f %.4f %.4f %.4f %.4f %.4f %.4f\t# output color primaries and white point\n",
| 631 |
out_prims[RED][0], out_prims[RED][1],
| 632 |
out_prims[GRN][0], out_prims[GRN][1],
| 633 |
out_prims[BLU][0], out_prims[BLU][1],
| 634 |
out_prims[WHT][0], out_prims[WHT][1]);
| 635 |
if ((sens_curve == NULL) & (NCSAMP > 3))
| 636 |
printf(out_prims != NULL ? "-co-\t\t\t\t# output tristimulus colors\n" :
| 637 |
"-co+\t\t\t\t# output spectral values\n");
| 638 |
print_rdefaults();
| 639 |
