1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: rtmain.c,v 2.40 2022/10/20 17:18:33 greg Exp $"; |
3 |
#endif |
4 |
5 |
* rtmain.c - main for rtrace per-ray calculation program |
6 |
7 |
8 |
#include "copyright.h" |
9 |
10 |
#include <signal.h> |
11 |
12 |
#include "platform.h" |
13 |
#include "rtprocess.h" /* getpid() */ |
14 |
#include "resolu.h" |
15 |
#include "ray.h" |
16 |
#include "source.h" |
17 |
#include "ambient.h" |
18 |
#include "random.h" |
19 |
#include "paths.h" |
20 |
#include "pmapray.h" |
21 |
22 |
extern char *progname; /* global argv[0] */ |
23 |
24 |
extern char *shm_boundary; /* boundary of shared memory */ |
25 |
26 |
/* persistent processes define */ |
27 |
#ifdef F_SETLKW |
28 |
#define PERSIST 1 /* normal persist */ |
29 |
#define PARALLEL 2 /* parallel persist */ |
30 |
#define PCHILD 3 /* child of normal persist */ |
31 |
#endif |
32 |
33 |
char *sigerr[NSIG]; /* signal error messages */ |
34 |
char *errfile = NULL; /* error output file */ |
35 |
36 |
int nproc = 1; /* number of processes */ |
37 |
38 |
extern char *formstr(int f); /* string from format */ |
39 |
extern int setrtoutput(void); /* set output values */ |
40 |
41 |
int inform = 'a'; /* input format */ |
42 |
int outform = 'a'; /* output format */ |
43 |
char *outvals = "v"; /* output specification */ |
44 |
45 |
int hresolu = 0; /* horizontal (scan) size */ |
46 |
int vresolu = 0; /* vertical resolution */ |
47 |
48 |
extern int castonly; /* only doing ray-casting? */ |
49 |
50 |
int imm_irrad = 0; /* compute immediate irradiance? */ |
51 |
int lim_dist = 0; /* limit distance? */ |
52 |
53 |
#ifndef MAXMODLIST |
54 |
#define MAXMODLIST 1024 /* maximum modifiers we'll track */ |
55 |
#endif |
56 |
57 |
extern void (*addobjnotify[])(); /* object notification calls */ |
58 |
extern void tranotify(OBJECT obj); |
59 |
60 |
char *tralist[MAXMODLIST]; /* list of modifers to trace (or no) */ |
61 |
int traincl = -1; /* include == 1, exclude == 0 */ |
62 |
63 |
static int loadflags = ~IO_FILES; /* what to load from octree */ |
64 |
65 |
static void onsig(int signo); |
66 |
static void sigdie(int signo, char *msg); |
67 |
static void printdefaults(void); |
68 |
69 |
#ifdef PERSIST |
70 |
#define RTRACE_FEATURES "Persist\nParallelPersist\nMultiProcessing\n" \ |
71 |
"IrradianceCalc\nImmediateIrradiance\nDistanceLimiting\n" \ |
72 |
"HessianAmbientCache\nAmbientAveraging\n" \ |
73 |
"AmbientValueSharing\nAdaptiveShadowTesting\n" \ |
74 |
"Outputs=o,d,v,V,w,W,l,L,c,p,n,N,s,m,M,r,x,R,X,~\n" |
75 |
#else |
76 |
#define RTRACE_FEATURES "IrradianceCalc\nIrradianceCalc\nDistanceLimiting\n" \ |
77 |
78 |
79 |
80 |
#endif |
81 |
82 |
83 |
int |
84 |
main(int argc, char *argv[]) |
85 |
86 |
#define check(ol,al) if (argv[i][ol] || \ |
87 |
badarg(argc-i-1,argv+i+1,al)) \ |
88 |
goto badopt |
89 |
#define check_bool(olen,var) switch (argv[i][olen]) { \ |
90 |
case '\0': var = !var; break; \ |
91 |
case 'y': case 'Y': case 't': case 'T': \ |
92 |
case '+': case '1': var = 1; break; \ |
93 |
case 'n': case 'N': case 'f': case 'F': \ |
94 |
case '-': case '0': var = 0; break; \ |
95 |
default: goto badopt; } |
96 |
extern char *octname; |
97 |
int persist = 0; |
98 |
char *octnm = NULL; |
99 |
char **tralp = NULL; |
100 |
int duped1 = -1; |
101 |
int rval; |
102 |
int i; |
103 |
/* global program name */ |
104 |
progname = argv[0] = fixargv0(argv[0]); |
105 |
/* feature check only? */ |
106 |
strcat(RFeatureList, RTRACE_FEATURES); |
107 |
if (!strcmp(argv[1], "-features")) |
108 |
return feature_status(argc-2, argv+2); |
109 |
/* add trace notify function */ |
110 |
for (i = 0; addobjnotify[i] != NULL; i++) |
111 |
112 |
addobjnotify[i] = tranotify; |
113 |
/* option city */ |
114 |
for (i = 1; i < argc; i++) { |
115 |
/* expand arguments */ |
116 |
while ((rval = expandarg(&argc, &argv, i)) > 0) |
117 |
118 |
if (rval < 0) { |
119 |
sprintf(errmsg, "cannot expand '%s'", argv[i]); |
120 |
error(SYSTEM, errmsg); |
121 |
122 |
if (argv[i] == NULL || argv[i][0] != '-') |
123 |
break; /* break from options */ |
124 |
if (!strcmp(argv[i], "-version")) { |
125 |
puts(VersionID); |
126 |
quit(0); |
127 |
128 |
if (!strcmp(argv[i], "-defaults") || |
129 |
!strcmp(argv[i], "-help")) { |
130 |
printdefaults(); |
131 |
quit(0); |
132 |
133 |
rval = getrenderopt(argc-i, argv+i); |
134 |
if (rval >= 0) { |
135 |
i += rval; |
136 |
continue; |
137 |
138 |
switch (argv[i][1]) { |
139 |
case 'n': /* number of cores */ |
140 |
check(2,"i"); |
141 |
nproc = atoi(argv[++i]); |
142 |
if (nproc <= 0) |
143 |
error(USER, "bad number of processes"); |
144 |
break; |
145 |
case 'x': /* x resolution */ |
146 |
check(2,"i"); |
147 |
hresolu = atoi(argv[++i]); |
148 |
break; |
149 |
case 'y': /* y resolution */ |
150 |
check(2,"i"); |
151 |
vresolu = atoi(argv[++i]); |
152 |
break; |
153 |
case 'w': /* warnings */ |
154 |
rval = erract[WARNING].pf != NULL; |
155 |
check_bool(2,rval); |
156 |
if (rval) erract[WARNING].pf = wputs; |
157 |
else erract[WARNING].pf = NULL; |
158 |
break; |
159 |
case 'e': /* error file */ |
160 |
check(2,"s"); |
161 |
errfile = argv[++i]; |
162 |
break; |
163 |
case 'l': /* limit distance */ |
164 |
if (argv[i][2] != 'd') |
165 |
goto badopt; |
166 |
check_bool(3,lim_dist); |
167 |
break; |
168 |
case 'I': /* immed. irradiance */ |
169 |
check_bool(2,imm_irrad); |
170 |
break; |
171 |
case 'f': /* format i/o */ |
172 |
switch (argv[i][2]) { |
173 |
case 'a': /* ascii */ |
174 |
case 'f': /* float */ |
175 |
case 'd': /* double */ |
176 |
inform = argv[i][2]; |
177 |
break; |
178 |
default: |
179 |
goto badopt; |
180 |
181 |
switch (argv[i][3]) { |
182 |
case '\0': |
183 |
outform = inform; |
184 |
break; |
185 |
186 |
187 |
188 |
case 'c': /* color */ |
189 |
check(4,""); |
190 |
outform = argv[i][3]; |
191 |
break; |
192 |
default: |
193 |
goto badopt; |
194 |
195 |
break; |
196 |
case 'o': /* output */ |
197 |
outvals = argv[i]+2; |
198 |
break; |
199 |
case 'h': /* header output */ |
200 |
rval = loadflags & IO_INFO; |
201 |
202 |
loadflags = rval ? loadflags | IO_INFO : |
203 |
loadflags & ~IO_INFO; |
204 |
break; |
205 |
case 't': /* trace */ |
206 |
207 |
case 'i': /* include */ |
208 |
case 'I': |
209 |
check(3,"s"); |
210 |
if (traincl != 1) { |
211 |
traincl = 1; |
212 |
tralp = tralist; |
213 |
214 |
if (argv[i][2] == 'I') { /* file */ |
215 |
rval = wordfile(tralp, MAXMODLIST-(tralp-tralist), |
216 |
getpath(argv[++i],getrlibpath(),R_OK)); |
217 |
if (rval < 0) { |
218 |
sprintf(errmsg, |
219 |
"cannot open trace include file \"%s\"", |
220 |
argv[i]); |
221 |
222 |
223 |
tralp += rval; |
224 |
} else { |
225 |
*tralp++ = argv[++i]; |
226 |
*tralp = NULL; |
227 |
228 |
break; |
229 |
case 'e': /* exclude */ |
230 |
case 'E': |
231 |
check(3,"s"); |
232 |
if (traincl != 0) { |
233 |
traincl = 0; |
234 |
tralp = tralist; |
235 |
236 |
if (argv[i][2] == 'E') { /* file */ |
237 |
238 |
239 |
if (rval < 0) { |
240 |
sprintf(errmsg, |
241 |
"cannot open trace exclude file \"%s\"", |
242 |
argv[i]); |
243 |
244 |
245 |
tralp += rval; |
246 |
} else { |
247 |
248 |
*tralp = NULL; |
249 |
250 |
break; |
251 |
default: |
252 |
goto badopt; |
253 |
254 |
break; |
255 |
#ifdef PERSIST |
256 |
case 'P': /* persist file */ |
257 |
if (argv[i][2] == 'P') { |
258 |
check(3,"s"); |
259 |
persist = PARALLEL; |
260 |
} else { |
261 |
check(2,"s"); |
262 |
persist = PERSIST; |
263 |
264 |
persistfile(argv[++i]); |
265 |
break; |
266 |
#endif |
267 |
default: |
268 |
goto badopt; |
269 |
270 |
271 |
if (nproc > 1 && persist) |
272 |
error(USER, "multiprocessing incompatible with persist file"); |
273 |
/* initialize object types */ |
274 |
initotypes(); |
275 |
/* initialize urand */ |
276 |
if (rand_samp) { |
277 |
srandom((long)time(0)); |
278 |
initurand(0); |
279 |
} else { |
280 |
srandom(0L); |
281 |
initurand(2048); |
282 |
283 |
/* set up signal handling */ |
284 |
sigdie(SIGINT, "Interrupt"); |
285 |
#ifdef SIGHUP |
286 |
sigdie(SIGHUP, "Hangup"); |
287 |
#endif |
288 |
sigdie(SIGTERM, "Terminate"); |
289 |
#ifdef SIGPIPE |
290 |
sigdie(SIGPIPE, "Broken pipe"); |
291 |
#endif |
292 |
#ifdef SIGALRM |
293 |
sigdie(SIGALRM, "Alarm clock"); |
294 |
#endif |
295 |
#ifdef SIGXCPU |
296 |
sigdie(SIGXCPU, "CPU limit exceeded"); |
297 |
sigdie(SIGXFSZ, "File size exceeded"); |
298 |
#endif |
299 |
/* open error file */ |
300 |
if (errfile != NULL) { |
301 |
if (freopen(errfile, "a", stderr) == NULL) |
302 |
quit(2); |
303 |
fprintf(stderr, "**************\n*** PID %5d: ", |
304 |
getpid()); |
305 |
printargs(argc, argv, stderr); |
306 |
putc('\n', stderr); |
307 |
fflush(stderr); |
308 |
309 |
#ifdef NICE |
310 |
nice(NICE); /* lower priority */ |
311 |
#endif |
312 |
/* get octree */ |
313 |
if (i == argc) |
314 |
octnm = NULL; |
315 |
else if (i == argc-1) |
316 |
octnm = argv[i]; |
317 |
else |
318 |
goto badopt; |
319 |
if (octnm == NULL) |
320 |
error(USER, "missing octree argument"); |
321 |
/* set up output */ |
322 |
#ifdef PERSIST |
323 |
if (persist) { |
324 |
duped1 = dup(fileno(stdout)); /* don't lose our output */ |
325 |
openheader(); |
326 |
327 |
#endif |
328 |
if (outform != 'a') |
329 |
SET_FILE_BINARY(stdout); |
330 |
rval = setrtoutput(); |
331 |
octname = savqstr(octnm); |
332 |
readoct(octname, loadflags, &thescene, NULL); |
333 |
nsceneobjs = nobjects; |
334 |
335 |
if (loadflags & IO_INFO) { /* print header */ |
336 |
printargs(i, argv, stdout); |
337 |
printf("SOFTWARE= %s\n", VersionID); |
338 |
fputnow(stdout); |
339 |
if (rval > 0) /* saved from setrtoutput() call */ |
340 |
printf("NCOMP=%d\n", rval); |
341 |
if ((outform == 'f') | (outform == 'd')) |
342 |
fputendian(stdout); |
343 |
fputformat(formstr(outform), stdout); |
344 |
putchar('\n'); |
345 |
346 |
347 |
if (!castonly) { /* any actual ray traversal to do? */ |
348 |
349 |
ray_init_pmap(); /* PMAP: set up & load photon maps */ |
350 |
351 |
marksources(); /* find and mark sources */ |
352 |
353 |
setambient(); /* initialize ambient calculation */ |
354 |
} else |
355 |
distantsources(); /* else mark only distant sources */ |
356 |
357 |
fflush(stdout); /* in case we're duplicating header */ |
358 |
359 |
#ifdef PERSIST |
360 |
if (persist) { |
361 |
/* reconnect stdout */ |
362 |
dup2(duped1, fileno(stdout)); |
363 |
close(duped1); |
364 |
if (persist == PARALLEL) { /* multiprocessing */ |
365 |
preload_objs(); /* preload scene */ |
366 |
shm_boundary = (char *)malloc(16); |
367 |
strcpy(shm_boundary, "SHM_BOUNDARY"); |
368 |
while ((rval=fork()) == 0) { /* keep on forkin' */ |
369 |
pflock(1); |
370 |
pfhold(); |
371 |
ambsync(); /* load new values */ |
372 |
373 |
if (rval < 0) |
374 |
error(SYSTEM, "cannot fork child for persist function"); |
375 |
pfdetach(); /* parent will run then exit */ |
376 |
377 |
378 |
runagain: |
379 |
if (persist) |
380 |
dupheader(); /* send header to stdout */ |
381 |
#endif |
382 |
/* trace rays */ |
383 |
rtrace(NULL, nproc); |
384 |
/* flush ambient file */ |
385 |
ambsync(); |
386 |
#ifdef PERSIST |
387 |
if (persist == PERSIST) { /* first run-through */ |
388 |
if ((rval=fork()) == 0) { /* child loops until killed */ |
389 |
pflock(1); |
390 |
persist = PCHILD; |
391 |
} else { /* original process exits */ |
392 |
if (rval < 0) |
393 |
394 |
pfdetach(); /* parent exits */ |
395 |
396 |
397 |
if (persist == PCHILD) { /* wait for a signal then go again */ |
398 |
pfhold(); |
399 |
raynum = nrays = 0; /* reinitialize */ |
400 |
goto runagain; |
401 |
402 |
#endif |
403 |
404 |
ray_done_pmap(); /* PMAP: free photon maps */ |
405 |
406 |
quit(0); |
407 |
408 |
badopt: |
409 |
sprintf(errmsg, "command line error at '%s'", argv[i]); |
410 |
error(USER, errmsg); |
411 |
return 1; /* pro forma return */ |
412 |
413 |
#undef check |
414 |
#undef check_bool |
415 |
416 |
417 |
418 |
void |
419 |
wputs( /* warning output function */ |
420 |
char *s |
421 |
422 |
423 |
int lasterrno = errno; |
424 |
eputs(s); |
425 |
errno = lasterrno; |
426 |
427 |
428 |
429 |
void |
430 |
eputs( /* put string to stderr */ |
431 |
char *s |
432 |
433 |
434 |
static int midline = 0; |
435 |
436 |
if (!*s) |
437 |
return; |
438 |
if (!midline++) { |
439 |
fputs(progname, stderr); |
440 |
fputs(": ", stderr); |
441 |
442 |
fputs(s, stderr); |
443 |
if (s[strlen(s)-1] == '\n') { |
444 |
fflush(stderr); |
445 |
midline = 0; |
446 |
447 |
448 |
449 |
450 |
static void |
451 |
onsig( /* fatal signal */ |
452 |
int signo |
453 |
454 |
455 |
static int gotsig = 0; |
456 |
457 |
if (gotsig++) /* two signals and we're gone! */ |
458 |
_exit(signo); |
459 |
460 |
#ifdef SIGALRM |
461 |
alarm(15); /* allow 15 seconds to clean up */ |
462 |
signal(SIGALRM, SIG_DFL); /* make certain we do die */ |
463 |
#endif |
464 |
eputs("signal - "); |
465 |
eputs(sigerr[signo]); |
466 |
eputs("\n"); |
467 |
quit(3); |
468 |
469 |
470 |
471 |
static void |
472 |
sigdie( /* set fatal signal */ |
473 |
int signo, |
474 |
char *msg |
475 |
476 |
477 |
if (signal(signo, onsig) == SIG_IGN) |
478 |
signal(signo, SIG_IGN); |
479 |
sigerr[signo] = msg; |
480 |
481 |
482 |
483 |
static void |
484 |
printdefaults(void) /* print default values to stdout */ |
485 |
486 |
char *cp; |
487 |
488 |
if (imm_irrad) |
489 |
printf("-I+\t\t\t\t# immediate irradiance on\n"); |
490 |
printf("-n %-2d\t\t\t\t# number of rendering processes\n", nproc); |
491 |
printf("-x %-9d\t\t\t# %s\n", hresolu, |
492 |
vresolu && hresolu ? "x resolution" : "flush interval"); |
493 |
printf("-y %-9d\t\t\t# y resolution\n", vresolu); |
494 |
printf(lim_dist ? "-ld+\t\t\t\t# limit distance on\n" : |
495 |
"-ld-\t\t\t\t# limit distance off\n"); |
496 |
printf("-h%c\t\t\t\t# %s header\n", loadflags & IO_INFO ? '+' : '-', |
497 |
loadflags & IO_INFO ? "output" : "no"); |
498 |
printf("-f%c%c\t\t\t\t# format input/output = %s/%s\n", |
499 |
inform, outform, formstr(inform), formstr(outform)); |
500 |
printf("-o%-9s\t\t\t# output", outvals); |
501 |
for (cp = outvals; *cp; cp++) |
502 |
switch (*cp) { |
503 |
case 't': case 'T': printf(" trace"); break; |
504 |
case 'o': printf(" origin"); break; |
505 |
case 'd': printf(" direction"); break; |
506 |
case 'r': printf(" reflect_contrib"); break; |
507 |
case 'R': printf(" reflect_length"); break; |
508 |
case 'x': printf(" unreflect_contrib"); break; |
509 |
case 'X': printf(" unreflect_length"); break; |
510 |
case 'v': printf(" value"); break; |
511 |
case 'V': printf(" contribution"); break; |
512 |
case 'l': printf(" length"); break; |
513 |
case 'L': printf(" first_length"); break; |
514 |
case 'p': printf(" point"); break; |
515 |
case 'n': printf(" normal"); break; |
516 |
case 'N': printf(" unperturbed_normal"); break; |
517 |
case 's': printf(" surface"); break; |
518 |
case 'w': printf(" weight"); break; |
519 |
case 'W': printf(" coefficient"); break; |
520 |
case 'm': printf(" modifier"); break; |
521 |
case 'M': printf(" material"); break; |
522 |
case '~': printf(" tilde"); break; |
523 |
524 |
putchar('\n'); |
525 |
printf(erract[WARNING].pf != NULL ? |
526 |
"-w+\t\t\t\t# warning messages on\n" : |
527 |
"-w-\t\t\t\t# warning messages off\n"); |
528 |
print_rdefaults(); |
529 |
