| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: rtmain.c,v 2.39 2022/10/19 23:10:34 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* rtmain.c - main for rtrace per-ray calculation program
| 6 |
| 7 |
| 8 |
#include "copyright.h"
| 9 |
| 10 |
#include <signal.h>
| 11 |
| 12 |
#include "platform.h"
| 13 |
#include "rtprocess.h" /* getpid() */
| 14 |
#include "resolu.h"
| 15 |
#include "ray.h"
| 16 |
#include "source.h"
| 17 |
#include "ambient.h"
| 18 |
#include "random.h"
| 19 |
#include "paths.h"
| 20 |
#include "pmapray.h"
| 21 |
| 22 |
extern char *progname; /* global argv[0] */
| 23 |
| 24 |
extern char *shm_boundary; /* boundary of shared memory */
| 25 |
| 26 |
/* persistent processes define */
| 27 |
#ifdef F_SETLKW
| 28 |
#define PERSIST 1 /* normal persist */
| 29 |
#define PARALLEL 2 /* parallel persist */
| 30 |
#define PCHILD 3 /* child of normal persist */
| 31 |
#endif
| 32 |
| 33 |
char *sigerr[NSIG]; /* signal error messages */
| 34 |
char *errfile = NULL; /* error output file */
| 35 |
| 36 |
int nproc = 1; /* number of processes */
| 37 |
| 38 |
extern char *formstr(int f); /* string from format */
| 39 |
extern int setrtoutput(void); /* set output values */
| 40 |
| 41 |
int inform = 'a'; /* input format */
| 42 |
int outform = 'a'; /* output format */
| 43 |
char *outvals = "v"; /* output specification */
| 44 |
| 45 |
int hresolu = 0; /* horizontal (scan) size */
| 46 |
int vresolu = 0; /* vertical resolution */
| 47 |
| 48 |
extern int castonly; /* only doing ray-casting? */
| 49 |
| 50 |
int imm_irrad = 0; /* compute immediate irradiance? */
| 51 |
int lim_dist = 0; /* limit distance? */
| 52 |
| 53 |
#ifndef MAXMODLIST
| 54 |
#define MAXMODLIST 1024 /* maximum modifiers we'll track */
| 55 |
#endif
| 56 |
| 57 |
extern void (*addobjnotify[])(); /* object notification calls */
| 58 |
extern void tranotify(OBJECT obj);
| 59 |
| 60 |
char *tralist[MAXMODLIST]; /* list of modifers to trace (or no) */
| 61 |
int traincl = -1; /* include == 1, exclude == 0 */
| 62 |
| 63 |
static int loadflags = ~IO_FILES; /* what to load from octree */
| 64 |
| 65 |
static void onsig(int signo);
| 66 |
static void sigdie(int signo, char *msg);
| 67 |
static void printdefaults(void);
| 68 |
| 69 |
#ifdef PERSIST
| 70 |
#define RTRACE_FEATURES "Persist\nParallelPersist\nMultiProcessing\n" \
| 71 |
"IrradianceCalc\nImmediateIrradiance\nDistanceLimiting\n" \
| 72 |
"HessianAmbientCache\nAmbientAveraging\n" \
| 73 |
"AmbientValueSharing\nAdaptiveShadowTesting\n" \
| 74 |
"Outputs=o,d,v,V,w,W,l,L,c,p,n,N,s,m,M,r,x,R,X,~\n"
| 75 |
#else
| 76 |
#define RTRACE_FEATURES "IrradianceCalc\nIrradianceCalc\nDistanceLimiting\n" \
| 77 |
| 78 |
| 79 |
| 80 |
#endif
| 81 |
| 82 |
| 83 |
int
| 84 |
main(int argc, char *argv[])
| 85 |
| 86 |
#define check(ol,al) if (argv[i][ol] || \
| 87 |
badarg(argc-i-1,argv+i+1,al)) \
| 88 |
goto badopt
| 89 |
#define check_bool(olen,var) switch (argv[i][olen]) { \
| 90 |
case '\0': var = !var; break; \
| 91 |
case 'y': case 'Y': case 't': case 'T': \
| 92 |
case '+': case '1': var = 1; break; \
| 93 |
case 'n': case 'N': case 'f': case 'F': \
| 94 |
case '-': case '0': var = 0; break; \
| 95 |
default: goto badopt; }
| 96 |
extern char *octname;
| 97 |
int persist = 0;
| 98 |
char *octnm = NULL;
| 99 |
char **tralp = NULL;
| 100 |
int duped1 = -1;
| 101 |
int rval;
| 102 |
int i;
| 103 |
/* global program name */
| 104 |
progname = argv[0] = fixargv0(argv[0]);
| 105 |
/* feature check only? */
| 106 |
strcat(RFeatureList, RTRACE_FEATURES);
| 107 |
if (!strcmp(argv[1], "-features"))
| 108 |
return feature_status(argc-2, argv+2);
| 109 |
/* add trace notify function */
| 110 |
for (i = 0; addobjnotify[i] != NULL; i++)
| 111 |
| 112 |
addobjnotify[i] = tranotify;
| 113 |
/* option city */
| 114 |
for (i = 1; i < argc; i++) {
| 115 |
/* expand arguments */
| 116 |
while ((rval = expandarg(&argc, &argv, i)) > 0)
| 117 |
| 118 |
if (rval < 0) {
| 119 |
sprintf(errmsg, "cannot expand '%s'", argv[i]);
| 120 |
error(SYSTEM, errmsg);
| 121 |
| 122 |
if (argv[i] == NULL || argv[i][0] != '-')
| 123 |
break; /* break from options */
| 124 |
if (!strcmp(argv[i], "-version")) {
| 125 |
puts(VersionID);
| 126 |
quit(0);
| 127 |
| 128 |
if (!strcmp(argv[i], "-defaults") ||
| 129 |
!strcmp(argv[i], "-help")) {
| 130 |
printdefaults();
| 131 |
quit(0);
| 132 |
| 133 |
rval = getrenderopt(argc-i, argv+i);
| 134 |
if (rval >= 0) {
| 135 |
i += rval;
| 136 |
continue;
| 137 |
| 138 |
switch (argv[i][1]) {
| 139 |
case 'n': /* number of cores */
| 140 |
check(2,"i");
| 141 |
nproc = atoi(argv[++i]);
| 142 |
if (nproc <= 0)
| 143 |
error(USER, "bad number of processes");
| 144 |
break;
| 145 |
case 'x': /* x resolution */
| 146 |
check(2,"i");
| 147 |
hresolu = atoi(argv[++i]);
| 148 |
break;
| 149 |
case 'y': /* y resolution */
| 150 |
check(2,"i");
| 151 |
vresolu = atoi(argv[++i]);
| 152 |
break;
| 153 |
case 'w': /* warnings */
| 154 |
rval = erract[WARNING].pf != NULL;
| 155 |
check_bool(2,rval);
| 156 |
if (rval) erract[WARNING].pf = wputs;
| 157 |
else erract[WARNING].pf = NULL;
| 158 |
break;
| 159 |
case 'e': /* error file */
| 160 |
check(2,"s");
| 161 |
errfile = argv[++i];
| 162 |
break;
| 163 |
case 'l': /* limit distance */
| 164 |
if (argv[i][2] != 'd')
| 165 |
goto badopt;
| 166 |
check_bool(3,lim_dist);
| 167 |
break;
| 168 |
case 'I': /* immed. irradiance */
| 169 |
check_bool(2,imm_irrad);
| 170 |
break;
| 171 |
case 'f': /* format i/o */
| 172 |
switch (argv[i][2]) {
| 173 |
case 'a': /* ascii */
| 174 |
case 'f': /* float */
| 175 |
case 'd': /* double */
| 176 |
inform = argv[i][2];
| 177 |
break;
| 178 |
default:
| 179 |
goto badopt;
| 180 |
| 181 |
switch (argv[i][3]) {
| 182 |
case '\0':
| 183 |
outform = inform;
| 184 |
break;
| 185 |
| 186 |
| 187 |
| 188 |
case 'c': /* color */
| 189 |
check(4,"");
| 190 |
outform = argv[i][3];
| 191 |
break;
| 192 |
default:
| 193 |
goto badopt;
| 194 |
| 195 |
break;
| 196 |
case 'o': /* output */
| 197 |
outvals = argv[i]+2;
| 198 |
break;
| 199 |
case 'h': /* header output */
| 200 |
rval = loadflags & IO_INFO;
| 201 |
check_bool(2,rval);
| 202 |
loadflags = rval ? loadflags | IO_INFO :
| 203 |
loadflags & ~IO_INFO;
| 204 |
break;
| 205 |
case 't': /* trace */
| 206 |
| 207 |
case 'i': /* include */
| 208 |
case 'I':
| 209 |
check(3,"s");
| 210 |
if (traincl != 1) {
| 211 |
traincl = 1;
| 212 |
tralp = tralist;
| 213 |
| 214 |
if (argv[i][2] == 'I') { /* file */
| 215 |
rval = wordfile(tralp, MAXMODLIST-(tralp-tralist),
| 216 |
getpath(argv[++i],getrlibpath(),R_OK));
| 217 |
if (rval < 0) {
| 218 |
sprintf(errmsg,
| 219 |
"cannot open trace include file \"%s\"",
| 220 |
argv[i]);
| 221 |
| 222 |
| 223 |
tralp += rval;
| 224 |
} else {
| 225 |
*tralp++ = argv[++i];
| 226 |
*tralp = NULL;
| 227 |
| 228 |
break;
| 229 |
case 'e': /* exclude */
| 230 |
case 'E':
| 231 |
check(3,"s");
| 232 |
if (traincl != 0) {
| 233 |
traincl = 0;
| 234 |
tralp = tralist;
| 235 |
| 236 |
if (argv[i][2] == 'E') { /* file */
| 237 |
| 238 |
| 239 |
if (rval < 0) {
| 240 |
sprintf(errmsg,
| 241 |
"cannot open trace exclude file \"%s\"",
| 242 |
argv[i]);
| 243 |
| 244 |
| 245 |
tralp += rval;
| 246 |
} else {
| 247 |
| 248 |
*tralp = NULL;
| 249 |
| 250 |
break;
| 251 |
default:
| 252 |
goto badopt;
| 253 |
| 254 |
break;
| 255 |
#ifdef PERSIST
| 256 |
case 'P': /* persist file */
| 257 |
if (argv[i][2] == 'P') {
| 258 |
check(3,"s");
| 259 |
persist = PARALLEL;
| 260 |
} else {
| 261 |
check(2,"s");
| 262 |
persist = PERSIST;
| 263 |
| 264 |
persistfile(argv[++i]);
| 265 |
break;
| 266 |
#endif
| 267 |
default:
| 268 |
goto badopt;
| 269 |
| 270 |
| 271 |
if (nproc > 1 && persist)
| 272 |
error(USER, "multiprocessing incompatible with persist file");
| 273 |
/* initialize object types */
| 274 |
initotypes();
| 275 |
/* initialize urand */
| 276 |
if (rand_samp) {
| 277 |
srandom((long)time(0));
| 278 |
initurand(0);
| 279 |
} else {
| 280 |
srandom(0L);
| 281 |
initurand(2048);
| 282 |
| 283 |
/* set up signal handling */
| 284 |
sigdie(SIGINT, "Interrupt");
| 285 |
#ifdef SIGHUP
| 286 |
sigdie(SIGHUP, "Hangup");
| 287 |
#endif
| 288 |
sigdie(SIGTERM, "Terminate");
| 289 |
#ifdef SIGPIPE
| 290 |
sigdie(SIGPIPE, "Broken pipe");
| 291 |
#endif
| 292 |
#ifdef SIGALRM
| 293 |
sigdie(SIGALRM, "Alarm clock");
| 294 |
#endif
| 295 |
#ifdef SIGXCPU
| 296 |
sigdie(SIGXCPU, "CPU limit exceeded");
| 297 |
sigdie(SIGXFSZ, "File size exceeded");
| 298 |
#endif
| 299 |
/* open error file */
| 300 |
if (errfile != NULL) {
| 301 |
if (freopen(errfile, "a", stderr) == NULL)
| 302 |
quit(2);
| 303 |
fprintf(stderr, "**************\n*** PID %5d: ",
| 304 |
getpid());
| 305 |
printargs(argc, argv, stderr);
| 306 |
putc('\n', stderr);
| 307 |
fflush(stderr);
| 308 |
| 309 |
#ifdef NICE
| 310 |
nice(NICE); /* lower priority */
| 311 |
#endif
| 312 |
/* get octree */
| 313 |
if (i == argc)
| 314 |
octnm = NULL;
| 315 |
else if (i == argc-1)
| 316 |
octnm = argv[i];
| 317 |
else
| 318 |
goto badopt;
| 319 |
if (octnm == NULL)
| 320 |
error(USER, "missing octree argument");
| 321 |
/* set up output */
| 322 |
#ifdef PERSIST
| 323 |
if (persist) {
| 324 |
duped1 = dup(fileno(stdout)); /* don't lose our output */
| 325 |
openheader();
| 326 |
| 327 |
#endif
| 328 |
if (outform != 'a')
| 329 |
SET_FILE_BINARY(stdout);
| 330 |
rval = setrtoutput();
| 331 |
readoct(octname = octnm, loadflags, &thescene, NULL);
| 332 |
nsceneobjs = nobjects;
| 333 |
| 334 |
if (loadflags & IO_INFO) { /* print header */
| 335 |
printargs(i, argv, stdout);
| 336 |
printf("SOFTWARE= %s\n", VersionID);
| 337 |
fputnow(stdout);
| 338 |
if (rval > 0) /* saved from setrtoutput() call */
| 339 |
printf("NCOMP=%d\n", rval);
| 340 |
if ((outform == 'f') | (outform == 'd'))
| 341 |
fputendian(stdout);
| 342 |
fputformat(formstr(outform), stdout);
| 343 |
putchar('\n');
| 344 |
| 345 |
| 346 |
if (!castonly) { /* any actual ray traversal to do? */
| 347 |
| 348 |
ray_init_pmap(); /* PMAP: set up & load photon maps */
| 349 |
| 350 |
marksources(); /* find and mark sources */
| 351 |
| 352 |
setambient(); /* initialize ambient calculation */
| 353 |
} else
| 354 |
distantsources(); /* else mark only distant sources */
| 355 |
| 356 |
fflush(stdout); /* in case we're duplicating header */
| 357 |
| 358 |
#ifdef PERSIST
| 359 |
if (persist) {
| 360 |
/* reconnect stdout */
| 361 |
dup2(duped1, fileno(stdout));
| 362 |
close(duped1);
| 363 |
if (persist == PARALLEL) { /* multiprocessing */
| 364 |
preload_objs(); /* preload scene */
| 365 |
shm_boundary = (char *)malloc(16);
| 366 |
strcpy(shm_boundary, "SHM_BOUNDARY");
| 367 |
while ((rval=fork()) == 0) { /* keep on forkin' */
| 368 |
pflock(1);
| 369 |
pfhold();
| 370 |
ambsync(); /* load new values */
| 371 |
| 372 |
if (rval < 0)
| 373 |
error(SYSTEM, "cannot fork child for persist function");
| 374 |
pfdetach(); /* parent will run then exit */
| 375 |
| 376 |
| 377 |
runagain:
| 378 |
if (persist)
| 379 |
dupheader(); /* send header to stdout */
| 380 |
#endif
| 381 |
/* trace rays */
| 382 |
rtrace(NULL, nproc);
| 383 |
/* flush ambient file */
| 384 |
ambsync();
| 385 |
#ifdef PERSIST
| 386 |
if (persist == PERSIST) { /* first run-through */
| 387 |
if ((rval=fork()) == 0) { /* child loops until killed */
| 388 |
pflock(1);
| 389 |
persist = PCHILD;
| 390 |
} else { /* original process exits */
| 391 |
if (rval < 0)
| 392 |
| 393 |
pfdetach(); /* parent exits */
| 394 |
| 395 |
| 396 |
if (persist == PCHILD) { /* wait for a signal then go again */
| 397 |
pfhold();
| 398 |
raynum = nrays = 0; /* reinitialize */
| 399 |
goto runagain;
| 400 |
| 401 |
#endif
| 402 |
| 403 |
ray_done_pmap(); /* PMAP: free photon maps */
| 404 |
| 405 |
quit(0);
| 406 |
| 407 |
badopt:
| 408 |
sprintf(errmsg, "command line error at '%s'", argv[i]);
| 409 |
error(USER, errmsg);
| 410 |
return 1; /* pro forma return */
| 411 |
| 412 |
#undef check
| 413 |
#undef check_bool
| 414 |
| 415 |
| 416 |
| 417 |
void
| 418 |
wputs( /* warning output function */
| 419 |
char *s
| 420 |
| 421 |
| 422 |
int lasterrno = errno;
| 423 |
eputs(s);
| 424 |
errno = lasterrno;
| 425 |
| 426 |
| 427 |
| 428 |
void
| 429 |
eputs( /* put string to stderr */
| 430 |
char *s
| 431 |
| 432 |
| 433 |
static int midline = 0;
| 434 |
| 435 |
if (!*s)
| 436 |
return;
| 437 |
if (!midline++) {
| 438 |
fputs(progname, stderr);
| 439 |
fputs(": ", stderr);
| 440 |
| 441 |
fputs(s, stderr);
| 442 |
if (s[strlen(s)-1] == '\n') {
| 443 |
fflush(stderr);
| 444 |
midline = 0;
| 445 |
| 446 |
| 447 |
| 448 |
| 449 |
static void
| 450 |
onsig( /* fatal signal */
| 451 |
int signo
| 452 |
| 453 |
| 454 |
static int gotsig = 0;
| 455 |
| 456 |
if (gotsig++) /* two signals and we're gone! */
| 457 |
_exit(signo);
| 458 |
| 459 |
#ifdef SIGALRM
| 460 |
alarm(15); /* allow 15 seconds to clean up */
| 461 |
signal(SIGALRM, SIG_DFL); /* make certain we do die */
| 462 |
#endif
| 463 |
eputs("signal - ");
| 464 |
eputs(sigerr[signo]);
| 465 |
eputs("\n");
| 466 |
quit(3);
| 467 |
| 468 |
| 469 |
| 470 |
static void
| 471 |
sigdie( /* set fatal signal */
| 472 |
int signo,
| 473 |
char *msg
| 474 |
| 475 |
| 476 |
if (signal(signo, onsig) == SIG_IGN)
| 477 |
signal(signo, SIG_IGN);
| 478 |
sigerr[signo] = msg;
| 479 |
| 480 |
| 481 |
| 482 |
static void
| 483 |
printdefaults(void) /* print default values to stdout */
| 484 |
| 485 |
char *cp;
| 486 |
| 487 |
if (imm_irrad)
| 488 |
printf("-I+\t\t\t\t# immediate irradiance on\n");
| 489 |
printf("-n %-2d\t\t\t\t# number of rendering processes\n", nproc);
| 490 |
printf("-x %-9d\t\t\t# %s\n", hresolu,
| 491 |
vresolu && hresolu ? "x resolution" : "flush interval");
| 492 |
printf("-y %-9d\t\t\t# y resolution\n", vresolu);
| 493 |
printf(lim_dist ? "-ld+\t\t\t\t# limit distance on\n" :
| 494 |
"-ld-\t\t\t\t# limit distance off\n");
| 495 |
printf("-h%c\t\t\t\t# %s header\n", loadflags & IO_INFO ? '+' : '-',
| 496 |
loadflags & IO_INFO ? "output" : "no");
| 497 |
printf("-f%c%c\t\t\t\t# format input/output = %s/%s\n",
| 498 |
inform, outform, formstr(inform), formstr(outform));
| 499 |
printf("-o%-9s\t\t\t# output", outvals);
| 500 |
for (cp = outvals; *cp; cp++)
| 501 |
switch (*cp) {
| 502 |
case 't': case 'T': printf(" trace"); break;
| 503 |
case 'o': printf(" origin"); break;
| 504 |
case 'd': printf(" direction"); break;
| 505 |
case 'r': printf(" reflect_contrib"); break;
| 506 |
case 'R': printf(" reflect_length"); break;
| 507 |
case 'x': printf(" unreflect_contrib"); break;
| 508 |
case 'X': printf(" unreflect_length"); break;
| 509 |
case 'v': printf(" value"); break;
| 510 |
case 'V': printf(" contribution"); break;
| 511 |
case 'l': printf(" length"); break;
| 512 |
case 'L': printf(" first_length"); break;
| 513 |
case 'p': printf(" point"); break;
| 514 |
case 'n': printf(" normal"); break;
| 515 |
case 'N': printf(" unperturbed_normal"); break;
| 516 |
case 's': printf(" surface"); break;
| 517 |
case 'w': printf(" weight"); break;
| 518 |
case 'W': printf(" coefficient"); break;
| 519 |
case 'm': printf(" modifier"); break;
| 520 |
case 'M': printf(" material"); break;
| 521 |
case '~': printf(" tilde"); break;
| 522 |
| 523 |
putchar('\n');
| 524 |
printf(erract[WARNING].pf != NULL ?
| 525 |
"-w+\t\t\t\t# warning messages on\n" :
| 526 |
"-w-\t\t\t\t# warning messages off\n");
| 527 |
print_rdefaults();
| 528 |
