root/radiance/ray/src/rt/rtmain.c
Revision: 2.39
Committed: Wed Oct 19 23:10:34 2022 UTC (2 years, 6 months ago) by greg
Changes since 2.38: +5 -3 lines
fix(rcontrib): removed AdaptiveShadowTesting from feature list (didn't belong)
2 static const char RCSid[] = "$Id: rtmain.c,v 2.38 2022/10/19 21:25:20 greg Exp $";
5 * rtmain.c - main for rtrace per-ray calculation program
6 */
7
8 #include "copyright.h"
9
10 #include <signal.h>
11
12 #include "platform.h"
13 #include "rtprocess.h" /* getpid() */
14 #include "resolu.h"
15 #include "ray.h"
16 #include "source.h"
17 #include "ambient.h"
18 #include "random.h"
19 #include "paths.h"
20 #include "pmapray.h"
21
22 extern char *progname; /* global argv[0] */
23
24 extern char *shm_boundary; /* boundary of shared memory */
25
26 /* persistent processes define */
27 #ifdef F_SETLKW
28 #define PERSIST 1 /* normal persist */
29 #define PARALLEL 2 /* parallel persist */
30 #define PCHILD 3 /* child of normal persist */
31 #endif
32
33 char *sigerr[NSIG]; /* signal error messages */
34 char *errfile = NULL; /* error output file */
35
36 int nproc = 1; /* number of processes */
37
38 extern char *formstr(int f); /* string from format */
39 extern int setrtoutput(void); /* set output values */
40
41 int inform = 'a'; /* input format */
42 int outform = 'a'; /* output format */
43 char *outvals = "v"; /* output specification */
44
45 int hresolu = 0; /* horizontal (scan) size */
46 int vresolu = 0; /* vertical resolution */
47
48 extern int castonly; /* only doing ray-casting? */
49
50 int imm_irrad = 0; /* compute immediate irradiance? */
51 int lim_dist = 0; /* limit distance? */
52
53 #ifndef MAXMODLIST
54 #define MAXMODLIST 1024 /* maximum modifiers we'll track */
55 #endif
56
57 extern void (*addobjnotify[])(); /* object notification calls */
58 extern void tranotify(OBJECT obj);
59
60 char *tralist[MAXMODLIST]; /* list of modifers to trace (or no) */
61 int traincl = -1; /* include == 1, exclude == 0 */
62
63 static int loadflags = ~IO_FILES; /* what to load from octree */
64
65 static void onsig(int signo);
66 static void sigdie(int signo, char *msg);
67 static void printdefaults(void);
68
69 #ifdef PERSIST
70 #define RTRACE_FEATURES "Persist\nParallelPersist\nMultiProcessing\n" \
71 "IrradianceCalc\nImmediateIrradiance\nDistanceLimiting\n" \
72 "HessianAmbientCache\nAmbientAveraging\n" \
73 "AmbientValueSharing\nAdaptiveShadowTesting\n"
74 #else
75 #define RTRACE_FEATURES "IrradianceCalc\nIrradianceCalc\nDistanceLimiting\n" \
76 "HessianAmbientCache\nAmbientAveraging\n" \
77 "AmbientValueSharing\nAdaptiveShadowTesting\n"
78 #endif
79
80
81 int
82 main(int argc, char *argv[])
83 {
84 #define check(ol,al) if (argv[i][ol] || \
85 badarg(argc-i-1,argv+i+1,al)) \
86 goto badopt
87 #define check_bool(olen,var) switch (argv[i][olen]) { \
88 case '\0': var = !var; break; \
89 case 'y': case 'Y': case 't': case 'T': \
90 case '+': case '1': var = 1; break; \
91 case 'n': case 'N': case 'f': case 'F': \
92 case '-': case '0': var = 0; break; \
93 default: goto badopt; }
94 extern char *octname;
95 int persist = 0;
96 char *octnm = NULL;
97 char **tralp = NULL;
98 int duped1 = -1;
99 int rval;
100 int i;
101 /* global program name */
102 progname = argv[0] = fixargv0(argv[0]);
103 /* feature check only? */
104 strcat(RFeatureList, RTRACE_FEATURES);
105 if (!strcmp(argv[1], "-features"))
106 return feature_status(argc-2, argv+2);
107 /* add trace notify function */
108 for (i = 0; addobjnotify[i] != NULL; i++)
109 ;
110 addobjnotify[i] = tranotify;
111 /* option city */
112 for (i = 1; i < argc; i++) {
113 /* expand arguments */
114 while ((rval = expandarg(&argc, &argv, i)) > 0)
115 ;
116 if (rval < 0) {
117 sprintf(errmsg, "cannot expand '%s'", argv[i]);
118 error(SYSTEM, errmsg);
119 }
120 if (argv[i] == NULL || argv[i][0] != '-')
121 break; /* break from options */
122 if (!strcmp(argv[i], "-version")) {
123 puts(VersionID);
124 quit(0);
125 }
126 if (!strcmp(argv[i], "-defaults") ||
127 !strcmp(argv[i], "-help")) {
128 printdefaults();
129 quit(0);
130 }
131 rval = getrenderopt(argc-i, argv+i);
132 if (rval >= 0) {
133 i += rval;
134 continue;
135 }
136 switch (argv[i][1]) {
137 case 'n': /* number of cores */
138 check(2,"i");
139 nproc = atoi(argv[++i]);
140 if (nproc <= 0)
141 error(USER, "bad number of processes");
142 break;
143 case 'x': /* x resolution */
144 check(2,"i");
145 hresolu = atoi(argv[++i]);
146 break;
147 case 'y': /* y resolution */
148 check(2,"i");
149 vresolu = atoi(argv[++i]);
150 break;
151 case 'w': /* warnings */
152 rval = erract[WARNING].pf != NULL;
153 check_bool(2,rval);
154 if (rval) erract[WARNING].pf = wputs;
155 else erract[WARNING].pf = NULL;
156 break;
157 case 'e': /* error file */
158 check(2,"s");
159 errfile = argv[++i];
160 break;
161 case 'l': /* limit distance */
162 if (argv[i][2] != 'd')
163 goto badopt;
164 check_bool(3,lim_dist);
165 break;
166 case 'I': /* immed. irradiance */
167 check_bool(2,imm_irrad);
168 break;
169 case 'f': /* format i/o */
170 switch (argv[i][2]) {
171 case 'a': /* ascii */
172 case 'f': /* float */
173 case 'd': /* double */
174 inform = argv[i][2];
175 break;
176 default:
177 goto badopt;
178 }
179 switch (argv[i][3]) {
180 case '\0':
181 outform = inform;
182 break;
183 case 'a': /* ascii */
184 case 'f': /* float */
185 case 'd': /* double */
186 case 'c': /* color */
187 check(4,"");
188 outform = argv[i][3];
189 break;
190 default:
191 goto badopt;
192 }
193 break;
194 case 'o': /* output */
195 outvals = argv[i]+2;
196 break;
197 case 'h': /* header output */
198 rval = loadflags & IO_INFO;
199 check_bool(2,rval);
200 loadflags = rval ? loadflags | IO_INFO :
201 loadflags & ~IO_INFO;
202 break;
203 case 't': /* trace */
204 switch (argv[i][2]) {
205 case 'i': /* include */
206 case 'I':
207 check(3,"s");
208 if (traincl != 1) {
209 traincl = 1;
210 tralp = tralist;
211 }
212 if (argv[i][2] == 'I') { /* file */
213 rval = wordfile(tralp, MAXMODLIST-(tralp-tralist),
214 getpath(argv[++i],getrlibpath(),R_OK));
215 if (rval < 0) {
216 sprintf(errmsg,
217 "cannot open trace include file \"%s\"",
218 argv[i]);
219 error(SYSTEM, errmsg);
220 }
221 tralp += rval;
222 } else {
223 *tralp++ = argv[++i];
224 *tralp = NULL;
225 }
226 break;
227 case 'e': /* exclude */
228 case 'E':
229 check(3,"s");
230 if (traincl != 0) {
231 traincl = 0;
232 tralp = tralist;
233 }
234 if (argv[i][2] == 'E') { /* file */
235 rval = wordfile(tralp, MAXMODLIST-(tralp-tralist),
236 getpath(argv[++i],getrlibpath(),R_OK));
237 if (rval < 0) {
238 sprintf(errmsg,
239 "cannot open trace exclude file \"%s\"",
240 argv[i]);
241 error(SYSTEM, errmsg);
242 }
243 tralp += rval;
244 } else {
245 *tralp++ = argv[++i];
246 *tralp = NULL;
247 }
248 break;
249 default:
250 goto badopt;
251 }
252 break;
253 #ifdef PERSIST
254 case 'P': /* persist file */
255 if (argv[i][2] == 'P') {
256 check(3,"s");
257 persist = PARALLEL;
258 } else {
259 check(2,"s");
260 persist = PERSIST;
261 }
262 persistfile(argv[++i]);
263 break;
264 #endif
265 default:
266 goto badopt;
267 }
268 }
269 if (nproc > 1 && persist)
270 error(USER, "multiprocessing incompatible with persist file");
271 /* initialize object types */
272 initotypes();
273 /* initialize urand */
274 if (rand_samp) {
275 srandom((long)time(0));
276 initurand(0);
277 } else {
278 srandom(0L);
279 initurand(2048);
280 }
281 /* set up signal handling */
282 sigdie(SIGINT, "Interrupt");
283 #ifdef SIGHUP
284 sigdie(SIGHUP, "Hangup");
285 #endif
286 sigdie(SIGTERM, "Terminate");
287 #ifdef SIGPIPE
288 sigdie(SIGPIPE, "Broken pipe");
289 #endif
290 #ifdef SIGALRM
291 sigdie(SIGALRM, "Alarm clock");
292 #endif
293 #ifdef SIGXCPU
294 sigdie(SIGXCPU, "CPU limit exceeded");
295 sigdie(SIGXFSZ, "File size exceeded");
296 #endif
297 /* open error file */
298 if (errfile != NULL) {
299 if (freopen(errfile, "a", stderr) == NULL)
300 quit(2);
301 fprintf(stderr, "**************\n*** PID %5d: ",
302 getpid());
303 printargs(argc, argv, stderr);
304 putc('\n', stderr);
305 fflush(stderr);
306 }
307 #ifdef NICE
308 nice(NICE); /* lower priority */
309 #endif
310 /* get octree */
311 if (i == argc)
312 octnm = NULL;
313 else if (i == argc-1)
314 octnm = argv[i];
315 else
316 goto badopt;
317 if (octnm == NULL)
318 error(USER, "missing octree argument");
319 /* set up output */
320 #ifdef PERSIST
321 if (persist) {
322 duped1 = dup(fileno(stdout)); /* don't lose our output */
323 openheader();
324 }
325 #endif
326 if (outform != 'a')
327 SET_FILE_BINARY(stdout);
328 rval = setrtoutput();
329 readoct(octname = octnm, loadflags, &thescene, NULL);
330 nsceneobjs = nobjects;
331
332 if (loadflags & IO_INFO) { /* print header */
333 printargs(i, argv, stdout);
334 printf("SOFTWARE= %s\n", VersionID);
335 fputnow(stdout);
336 if (rval > 0) /* saved from setrtoutput() call */
337 printf("NCOMP=%d\n", rval);
338 if ((outform == 'f') | (outform == 'd'))
339 fputendian(stdout);
340 fputformat(formstr(outform), stdout);
341 putchar('\n');
342 }
343
344 if (!castonly) { /* any actual ray traversal to do? */
345
346 ray_init_pmap(); /* PMAP: set up & load photon maps */
347
348 marksources(); /* find and mark sources */
349
350 setambient(); /* initialize ambient calculation */
351 } else
352 distantsources(); /* else mark only distant sources */
353
354 fflush(stdout); /* in case we're duplicating header */
355
356 #ifdef PERSIST
357 if (persist) {
358 /* reconnect stdout */
359 dup2(duped1, fileno(stdout));
360 close(duped1);
361 if (persist == PARALLEL) { /* multiprocessing */
362 preload_objs(); /* preload scene */
363 shm_boundary = (char *)malloc(16);
364 strcpy(shm_boundary, "SHM_BOUNDARY");
365 while ((rval=fork()) == 0) { /* keep on forkin' */
366 pflock(1);
367 pfhold();
368 ambsync(); /* load new values */
369 }
370 if (rval < 0)
371 error(SYSTEM, "cannot fork child for persist function");
372 pfdetach(); /* parent will run then exit */
373 }
374 }
375 runagain:
376 if (persist)
377 dupheader(); /* send header to stdout */
378 #endif
379 /* trace rays */
380 rtrace(NULL, nproc);
381 /* flush ambient file */
382 ambsync();
383 #ifdef PERSIST
384 if (persist == PERSIST) { /* first run-through */
385 if ((rval=fork()) == 0) { /* child loops until killed */
386 pflock(1);
387 persist = PCHILD;
388 } else { /* original process exits */
389 if (rval < 0)
390 error(SYSTEM, "cannot fork child for persist function");
391 pfdetach(); /* parent exits */
392 }
393 }
394 if (persist == PCHILD) { /* wait for a signal then go again */
395 pfhold();
396 raynum = nrays = 0; /* reinitialize */
397 goto runagain;
398 }
399 #endif
400
401 ray_done_pmap(); /* PMAP: free photon maps */
402
403 quit(0);
404
405 badopt:
406 sprintf(errmsg, "command line error at '%s'", argv[i]);
407 error(USER, errmsg);
408 return 1; /* pro forma return */
409
410 #undef check
411 #undef check_bool
412 }
413
414
415 void
416 wputs( /* warning output function */
417 char *s
418 )
419 {
420 int lasterrno = errno;
421 eputs(s);
422 errno = lasterrno;
423 }
424
425
426 void
427 eputs( /* put string to stderr */
428 char *s
429 )
430 {
431 static int midline = 0;
432
433 if (!*s)
434 return;
435 if (!midline++) {
436 fputs(progname, stderr);
437 fputs(": ", stderr);
438 }
439 fputs(s, stderr);
440 if (s[strlen(s)-1] == '\n') {
441 fflush(stderr);
442 midline = 0;
443 }
444 }
445
446
447 static void
448 onsig( /* fatal signal */
449 int signo
450 )
451 {
452 static int gotsig = 0;
453
454 if (gotsig++) /* two signals and we're gone! */
455 _exit(signo);
456
457 #ifdef SIGALRM
458 alarm(15); /* allow 15 seconds to clean up */
459 signal(SIGALRM, SIG_DFL); /* make certain we do die */
460 #endif
461 eputs("signal - ");
462 eputs(sigerr[signo]);
463 eputs("\n");
464 quit(3);
465 }
466
467
468 static void
469 sigdie( /* set fatal signal */
470 int signo,
471 char *msg
472 )
473 {
474 if (signal(signo, onsig) == SIG_IGN)
475 signal(signo, SIG_IGN);
476 sigerr[signo] = msg;
477 }
478
479
480 static void
481 printdefaults(void) /* print default values to stdout */
482 {
483 char *cp;
484
485 if (imm_irrad)
486 printf("-I+\t\t\t\t# immediate irradiance on\n");
487 printf("-n %-2d\t\t\t\t# number of rendering processes\n", nproc);
488 printf("-x %-9d\t\t\t# %s\n", hresolu,
489 vresolu && hresolu ? "x resolution" : "flush interval");
490 printf("-y %-9d\t\t\t# y resolution\n", vresolu);
491 printf(lim_dist ? "-ld+\t\t\t\t# limit distance on\n" :
492 "-ld-\t\t\t\t# limit distance off\n");
493 printf("-h%c\t\t\t\t# %s header\n", loadflags & IO_INFO ? '+' : '-',
494 loadflags & IO_INFO ? "output" : "no");
495 printf("-f%c%c\t\t\t\t# format input/output = %s/%s\n",
496 inform, outform, formstr(inform), formstr(outform));
497 printf("-o%-9s\t\t\t# output", outvals);
498 for (cp = outvals; *cp; cp++)
499 switch (*cp) {
500 case 't': case 'T': printf(" trace"); break;
501 case 'o': printf(" origin"); break;
502 case 'd': printf(" direction"); break;
503 case 'r': printf(" reflect_contrib"); break;
504 case 'R': printf(" reflect_length"); break;
505 case 'x': printf(" unreflect_contrib"); break;
506 case 'X': printf(" unreflect_length"); break;
507 case 'v': printf(" value"); break;
508 case 'V': printf(" contribution"); break;
509 case 'l': printf(" length"); break;
510 case 'L': printf(" first_length"); break;
511 case 'p': printf(" point"); break;
512 case 'n': printf(" normal"); break;
513 case 'N': printf(" unperturbed_normal"); break;
514 case 's': printf(" surface"); break;
515 case 'w': printf(" weight"); break;
516 case 'W': printf(" coefficient"); break;
517 case 'm': printf(" modifier"); break;
518 case 'M': printf(" material"); break;
519 case '~': printf(" tilde"); break;
520 }
521 putchar('\n');
522 printf(erract[WARNING].pf != NULL ?
523 "-w+\t\t\t\t# warning messages on\n" :
524 "-w-\t\t\t\t# warning messages off\n");
525 print_rdefaults();
526 }
