1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id$"; |
3 |
#endif |
4 |
5 |
* rtmain.c - main for rtrace per-ray calculation program |
6 |
7 |
8 |
#include "copyright.h" |
9 |
10 |
#include "ray.h" |
11 |
12 |
#include "source.h" |
13 |
14 |
#include "ambient.h" |
15 |
16 |
#include "random.h" |
17 |
18 |
#include "paths.h" |
19 |
20 |
#include <sys/types.h> |
21 |
22 |
#include <signal.h> |
23 |
/* persistent processes define */ |
24 |
#ifdef F_SETLKW |
25 |
#define PERSIST 1 /* normal persist */ |
26 |
#define PARALLEL 2 /* parallel persist */ |
27 |
#define PCHILD 3 /* child of normal persist */ |
28 |
#endif |
29 |
30 |
char *progname; /* argv[0] */ |
31 |
32 |
char *octname; /* octree name */ |
33 |
34 |
char *sigerr[NSIG]; /* signal error messages */ |
35 |
36 |
char *shm_boundary = NULL; /* boundary of shared memory */ |
37 |
38 |
char *errfile = NULL; /* error output file */ |
39 |
40 |
extern char *formstr(); /* string from format */ |
41 |
extern int inform; /* input format */ |
42 |
extern int outform; /* output format */ |
43 |
extern char *outvals; /* output values */ |
44 |
45 |
extern int hresolu; /* horizontal resolution */ |
46 |
extern int vresolu; /* vertical resolution */ |
47 |
48 |
extern int imm_irrad; /* compute immediate irradiance? */ |
49 |
extern int lim_dist; /* limit distance? */ |
50 |
51 |
extern char *tralist[]; /* list of modifers to trace (or no) */ |
52 |
extern int traincl; /* include == 1, exclude == 0 */ |
53 |
54 |
void onsig(); |
55 |
void sigdie(); |
56 |
void printdefaults(); |
57 |
58 |
59 |
int |
60 |
main(argc, argv) |
61 |
int argc; |
62 |
char *argv[]; |
63 |
64 |
#define check(ol,al) if (argv[i][ol] || \ |
65 |
badarg(argc-i-1,argv+i+1,al)) \ |
66 |
goto badopt |
67 |
#define bool(olen,var) switch (argv[i][olen]) { \ |
68 |
case '\0': var = !var; break; \ |
69 |
case 'y': case 'Y': case 't': case 'T': \ |
70 |
case '+': case '1': var = 1; break; \ |
71 |
case 'n': case 'N': case 'f': case 'F': \ |
72 |
case '-': case '0': var = 0; break; \ |
73 |
default: goto badopt; } |
74 |
int loadflags = ~IO_FILES; |
75 |
int persist = 0; |
76 |
char **tralp; |
77 |
int duped1; |
78 |
int rval; |
79 |
int i; |
80 |
/* global program name */ |
81 |
progname = argv[0] = fixargv0(argv[0]); |
82 |
/* option city */ |
83 |
for (i = 1; i < argc; i++) { |
84 |
/* expand arguments */ |
85 |
while ((rval = expandarg(&argc, &argv, i)) > 0) |
86 |
87 |
if (rval < 0) { |
88 |
sprintf(errmsg, "cannot expand '%s'", argv[i]); |
89 |
error(SYSTEM, errmsg); |
90 |
91 |
if (argv[i] == NULL || argv[i][0] != '-') |
92 |
break; /* break from options */ |
93 |
if (!strcmp(argv[i], "-version")) { |
94 |
puts(VersionID); |
95 |
quit(0); |
96 |
97 |
if (!strcmp(argv[i], "-defaults") || |
98 |
!strcmp(argv[i], "-help")) { |
99 |
printdefaults(); |
100 |
quit(0); |
101 |
102 |
rval = getrenderopt(argc-i, argv+i); |
103 |
if (rval >= 0) { |
104 |
i += rval; |
105 |
continue; |
106 |
107 |
switch (argv[i][1]) { |
108 |
case 'x': /* x resolution */ |
109 |
check(2,"i"); |
110 |
hresolu = atoi(argv[++i]); |
111 |
break; |
112 |
case 'y': /* y resolution */ |
113 |
check(2,"i"); |
114 |
vresolu = atoi(argv[++i]); |
115 |
break; |
116 |
case 'w': /* warnings */ |
117 |
rval = erract[WARNING].pf != NULL; |
118 |
bool(2,rval); |
119 |
if (rval) erract[WARNING].pf = wputs; |
120 |
else erract[WARNING].pf = NULL; |
121 |
break; |
122 |
case 'e': /* error file */ |
123 |
check(2,"s"); |
124 |
errfile = argv[++i]; |
125 |
break; |
126 |
case 'l': /* limit distance */ |
127 |
if (argv[i][2] != 'd') |
128 |
goto badopt; |
129 |
bool(3,lim_dist); |
130 |
break; |
131 |
case 'I': /* immed. irradiance */ |
132 |
bool(2,imm_irrad); |
133 |
break; |
134 |
case 'f': /* format i/o */ |
135 |
switch (argv[i][2]) { |
136 |
case 'a': /* ascii */ |
137 |
case 'f': /* float */ |
138 |
case 'd': /* double */ |
139 |
inform = argv[i][2]; |
140 |
break; |
141 |
default: |
142 |
goto badopt; |
143 |
144 |
switch (argv[i][3]) { |
145 |
case '\0': |
146 |
outform = inform; |
147 |
break; |
148 |
149 |
150 |
151 |
case 'c': /* color */ |
152 |
check(4,""); |
153 |
outform = argv[i][3]; |
154 |
break; |
155 |
default: |
156 |
goto badopt; |
157 |
158 |
break; |
159 |
case 'o': /* output */ |
160 |
outvals = argv[i]+2; |
161 |
break; |
162 |
case 'h': /* header output */ |
163 |
rval = loadflags & IO_INFO; |
164 |
bool(2,rval); |
165 |
loadflags = rval ? loadflags | IO_INFO : |
166 |
loadflags & ~IO_INFO; |
167 |
break; |
168 |
case 't': /* trace */ |
169 |
170 |
case 'i': /* include */ |
171 |
case 'I': |
172 |
check(3,"s"); |
173 |
if (traincl != 1) { |
174 |
traincl = 1; |
175 |
tralp = tralist; |
176 |
177 |
if (argv[i][2] == 'I') { /* file */ |
178 |
rval = wordfile(tralp, |
179 |
getpath(argv[++i],getrlibpath(),R_OK)); |
180 |
if (rval < 0) { |
181 |
sprintf(errmsg, |
182 |
"cannot open trace include file \"%s\"", |
183 |
argv[i]); |
184 |
185 |
186 |
tralp += rval; |
187 |
} else { |
188 |
*tralp++ = argv[++i]; |
189 |
*tralp = NULL; |
190 |
191 |
break; |
192 |
case 'e': /* exclude */ |
193 |
case 'E': |
194 |
check(3,"s"); |
195 |
if (traincl != 0) { |
196 |
traincl = 0; |
197 |
tralp = tralist; |
198 |
199 |
if (argv[i][2] == 'E') { /* file */ |
200 |
201 |
202 |
if (rval < 0) { |
203 |
sprintf(errmsg, |
204 |
"cannot open trace exclude file \"%s\"", |
205 |
argv[i]); |
206 |
207 |
208 |
tralp += rval; |
209 |
} else { |
210 |
211 |
*tralp = NULL; |
212 |
213 |
break; |
214 |
default: |
215 |
goto badopt; |
216 |
217 |
break; |
218 |
#ifdef PERSIST |
219 |
case 'P': /* persist file */ |
220 |
if (argv[i][2] == 'P') { |
221 |
check(3,"s"); |
222 |
persist = PARALLEL; |
223 |
} else { |
224 |
check(2,"s"); |
225 |
persist = PERSIST; |
226 |
227 |
persistfile(argv[++i]); |
228 |
break; |
229 |
#endif |
230 |
default: |
231 |
goto badopt; |
232 |
233 |
234 |
/* initialize object types */ |
235 |
initotypes(); |
236 |
/* initialize urand */ |
237 |
initurand(2048); |
238 |
/* set up signal handling */ |
239 |
sigdie(SIGINT, "Interrupt"); |
240 |
sigdie(SIGHUP, "Hangup"); |
241 |
sigdie(SIGTERM, "Terminate"); |
242 |
sigdie(SIGPIPE, "Broken pipe"); |
243 |
sigdie(SIGALRM, "Alarm clock"); |
244 |
#ifdef SIGXCPU |
245 |
sigdie(SIGXCPU, "CPU limit exceeded"); |
246 |
sigdie(SIGXFSZ, "File size exceeded"); |
247 |
#endif |
248 |
/* open error file */ |
249 |
if (errfile != NULL) { |
250 |
if (freopen(errfile, "a", stderr) == NULL) |
251 |
quit(2); |
252 |
fprintf(stderr, "**************\n*** PID %5d: ", |
253 |
getpid()); |
254 |
printargs(argc, argv, stderr); |
255 |
putc('\n', stderr); |
256 |
fflush(stderr); |
257 |
258 |
#ifdef NICE |
259 |
nice(NICE); /* lower priority */ |
260 |
#endif |
261 |
/* get octree */ |
262 |
if (i == argc) |
263 |
octname = NULL; |
264 |
else if (i == argc-1) |
265 |
octname = argv[i]; |
266 |
else |
267 |
goto badopt; |
268 |
if (octname == NULL) |
269 |
error(USER, "missing octree argument"); |
270 |
/* set up output */ |
271 |
#ifdef PERSIST |
272 |
if (persist) { |
273 |
duped1 = dup(fileno(stdout)); /* don't lose our output */ |
274 |
openheader(); |
275 |
276 |
#endif |
277 |
#ifdef MSDOS |
278 |
if (outform != 'a') |
279 |
setmode(fileno(stdout), O_BINARY); |
280 |
281 |
setmode(fileno(stdin), O_BINARY); |
282 |
#endif |
283 |
readoct(octname, loadflags, &thescene, NULL); |
284 |
nsceneobjs = nobjects; |
285 |
286 |
if (loadflags & IO_INFO) { /* print header */ |
287 |
printargs(i, argv, stdout); |
288 |
printf("SOFTWARE= %s\n", VersionID); |
289 |
fputnow(stdout); |
290 |
fputformat(formstr(outform), stdout); |
291 |
putchar('\n'); |
292 |
293 |
294 |
marksources(); /* find and mark sources */ |
295 |
296 |
setambient(); /* initialize ambient calculation */ |
297 |
298 |
#ifdef PERSIST |
299 |
if (persist) { |
300 |
fflush(stdout); |
301 |
/* reconnect stdout */ |
302 |
dup2(duped1, fileno(stdout)); |
303 |
close(duped1); |
304 |
if (persist == PARALLEL) { /* multiprocessing */ |
305 |
preload_objs(); /* preload scene */ |
306 |
shm_boundary = (char *)malloc(16); |
307 |
strcpy(shm_boundary, "SHM_BOUNDARY"); |
308 |
while ((rval=fork()) == 0) { /* keep on forkin' */ |
309 |
pflock(1); |
310 |
pfhold(); |
311 |
312 |
if (rval < 0) |
313 |
error(SYSTEM, "cannot fork child for persist function"); |
314 |
pfdetach(); /* parent exits */ |
315 |
316 |
317 |
runagain: |
318 |
if (persist) |
319 |
dupheader(); /* send header to stdout */ |
320 |
#endif |
321 |
/* trace rays */ |
322 |
rtrace(NULL); |
323 |
/* flush ambient file */ |
324 |
ambsync(); |
325 |
#ifdef PERSIST |
326 |
if (persist == PERSIST) { /* first run-through */ |
327 |
if ((rval=fork()) == 0) { /* child loops until killed */ |
328 |
pflock(1); |
329 |
persist = PCHILD; |
330 |
} else { /* original process exits */ |
331 |
if (rval < 0) |
332 |
333 |
334 |
335 |
336 |
if (persist == PCHILD) { /* wait for a signal then go again */ |
337 |
close(duped1); /* release output handle */ |
338 |
pfhold(); |
339 |
raynum = nrays = 0; /* reinitialize */ |
340 |
goto runagain; |
341 |
342 |
#endif |
343 |
quit(0); |
344 |
345 |
badopt: |
346 |
sprintf(errmsg, "command line error at '%s'", argv[i]); |
347 |
error(USER, errmsg); |
348 |
349 |
#undef check |
350 |
#undef bool |
351 |
352 |
353 |
354 |
void |
355 |
wputs(s) /* warning output function */ |
356 |
char *s; |
357 |
358 |
int lasterrno = errno; |
359 |
eputs(s); |
360 |
errno = lasterrno; |
361 |
362 |
363 |
364 |
void |
365 |
eputs(s) /* put string to stderr */ |
366 |
register char *s; |
367 |
368 |
static int midline = 0; |
369 |
370 |
if (!*s) |
371 |
return; |
372 |
if (!midline++) { |
373 |
fputs(progname, stderr); |
374 |
fputs(": ", stderr); |
375 |
376 |
fputs(s, stderr); |
377 |
if (s[strlen(s)-1] == '\n') { |
378 |
fflush(stderr); |
379 |
midline = 0; |
380 |
381 |
382 |
383 |
384 |
void |
385 |
onsig(signo) /* fatal signal */ |
386 |
int signo; |
387 |
388 |
static int gotsig = 0; |
389 |
390 |
if (gotsig++) /* two signals and we're gone! */ |
391 |
_exit(signo); |
392 |
393 |
alarm(15); /* allow 15 seconds to clean up */ |
394 |
signal(SIGALRM, SIG_DFL); /* make certain we do die */ |
395 |
eputs("signal - "); |
396 |
eputs(sigerr[signo]); |
397 |
eputs("\n"); |
398 |
quit(3); |
399 |
400 |
401 |
402 |
void |
403 |
sigdie(signo, msg) /* set fatal signal */ |
404 |
int signo; |
405 |
char *msg; |
406 |
407 |
if (signal(signo, onsig) == SIG_IGN) |
408 |
signal(signo, SIG_IGN); |
409 |
sigerr[signo] = msg; |
410 |
411 |
412 |
413 |
void |
414 |
printdefaults() /* print default values to stdout */ |
415 |
416 |
register char *cp; |
417 |
418 |
if (imm_irrad) |
419 |
printf("-I+\t\t\t\t# immediate irradiance on\n"); |
420 |
printf("-x %-9d\t\t\t# x resolution\n", hresolu); |
421 |
printf("-y %-9d\t\t\t# y resolution\n", vresolu); |
422 |
printf(lim_dist ? "-ld+\t\t\t\t# limit distance on\n" : |
423 |
"-ld-\t\t\t\t# limit distance off\n"); |
424 |
printf("-f%c%c\t\t\t\t# format input/output = %s/%s\n", |
425 |
inform, outform, formstr(inform), formstr(outform)); |
426 |
printf("-o%s\t\t\t\t# output", outvals); |
427 |
for (cp = outvals; *cp; cp++) |
428 |
switch (*cp) { |
429 |
case 't': printf(" trace"); break; |
430 |
case 'o': printf(" origin"); break; |
431 |
case 'd': printf(" direction"); break; |
432 |
case 'v': printf(" value"); break; |
433 |
case 'l': printf(" length"); break; |
434 |
case 'L': printf(" first_length"); break; |
435 |
case 'p': printf(" point"); break; |
436 |
case 'n': printf(" normal"); break; |
437 |
case 'N': printf(" unperturbed_normal"); break; |
438 |
case 's': printf(" surface"); break; |
439 |
case 'w': printf(" weight"); break; |
440 |
case 'm': printf(" modifier"); break; |
441 |
442 |
putchar('\n'); |
443 |
printf(erract[WARNING].pf != NULL ? |
444 |
"-w+\t\t\t\t# warning messages on\n" : |
445 |
"-w-\t\t\t\t# warning messages off\n"); |
446 |
print_rdefaults(); |
447 |
