1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: rtmain.c,v 2.24 2015/04/23 17:42:04 greg Exp $"; |
3 |
#endif |
4 |
5 |
* rtmain.c - main for rtrace per-ray calculation program |
6 |
7 |
8 |
#include "copyright.h" |
9 |
10 |
#include <signal.h> |
11 |
12 |
#include "platform.h" |
13 |
#include "rtprocess.h" /* getpid() */ |
14 |
#include "resolu.h" |
15 |
#include "ray.h" |
16 |
#include "source.h" |
17 |
#include "ambient.h" |
18 |
#include "random.h" |
19 |
#include "paths.h" |
20 |
#include "pmapray.h" |
21 |
22 |
extern char *progname; /* global argv[0] */ |
23 |
24 |
extern char *shm_boundary; /* boundary of shared memory */ |
25 |
26 |
/* persistent processes define */ |
27 |
#ifdef F_SETLKW |
28 |
#define PERSIST 1 /* normal persist */ |
29 |
#define PARALLEL 2 /* parallel persist */ |
30 |
#define PCHILD 3 /* child of normal persist */ |
31 |
#endif |
32 |
33 |
char *sigerr[NSIG]; /* signal error messages */ |
34 |
char *errfile = NULL; /* error output file */ |
35 |
36 |
int nproc = 1; /* number of processes */ |
37 |
38 |
extern char *formstr(); /* string from format */ |
39 |
int inform = 'a'; /* input format */ |
40 |
int outform = 'a'; /* output format */ |
41 |
char *outvals = "v"; /* output specification */ |
42 |
43 |
int hresolu = 0; /* horizontal (scan) size */ |
44 |
int vresolu = 0; /* vertical resolution */ |
45 |
46 |
int imm_irrad = 0; /* compute immediate irradiance? */ |
47 |
int lim_dist = 0; /* limit distance? */ |
48 |
49 |
#ifndef MAXMODLIST |
50 |
#define MAXMODLIST 1024 /* maximum modifiers we'll track */ |
51 |
#endif |
52 |
53 |
extern void (*addobjnotify[])(); /* object notification calls */ |
54 |
extern void tranotify(OBJECT obj); |
55 |
56 |
char *tralist[MAXMODLIST]; /* list of modifers to trace (or no) */ |
57 |
int traincl = -1; /* include == 1, exclude == 0 */ |
58 |
59 |
static int loadflags = ~IO_FILES; /* what to load from octree */ |
60 |
61 |
static void onsig(int signo); |
62 |
static void sigdie(int signo, char *msg); |
63 |
static void printdefaults(void); |
64 |
65 |
66 |
int |
67 |
main(int argc, char *argv[]) |
68 |
69 |
#define check(ol,al) if (argv[i][ol] || \ |
70 |
badarg(argc-i-1,argv+i+1,al)) \ |
71 |
goto badopt |
72 |
#define bool(olen,var) switch (argv[i][olen]) { \ |
73 |
case '\0': var = !var; break; \ |
74 |
case 'y': case 'Y': case 't': case 'T': \ |
75 |
case '+': case '1': var = 1; break; \ |
76 |
case 'n': case 'N': case 'f': case 'F': \ |
77 |
case '-': case '0': var = 0; break; \ |
78 |
default: goto badopt; } |
79 |
extern char *octname; |
80 |
int persist = 0; |
81 |
char *octnm = NULL; |
82 |
char **tralp = NULL; |
83 |
int duped1 = -1; |
84 |
int rval; |
85 |
int i; |
86 |
/* global program name */ |
87 |
progname = argv[0] = fixargv0(argv[0]); |
88 |
/* add trace notify function */ |
89 |
for (i = 0; addobjnotify[i] != NULL; i++) |
90 |
91 |
addobjnotify[i] = tranotify; |
92 |
/* set our defaults */ |
93 |
rand_samp = 1; |
94 |
maxdepth = -10; |
95 |
minweight = 2e-3; |
96 |
/* option city */ |
97 |
for (i = 1; i < argc; i++) { |
98 |
/* expand arguments */ |
99 |
while ((rval = expandarg(&argc, &argv, i)) > 0) |
100 |
101 |
if (rval < 0) { |
102 |
sprintf(errmsg, "cannot expand '%s'", argv[i]); |
103 |
error(SYSTEM, errmsg); |
104 |
105 |
if (argv[i] == NULL || argv[i][0] != '-') |
106 |
break; /* break from options */ |
107 |
if (!strcmp(argv[i], "-version")) { |
108 |
puts(VersionID); |
109 |
quit(0); |
110 |
111 |
if (!strcmp(argv[i], "-defaults") || |
112 |
!strcmp(argv[i], "-help")) { |
113 |
printdefaults(); |
114 |
quit(0); |
115 |
116 |
rval = getrenderopt(argc-i, argv+i); |
117 |
if (rval >= 0) { |
118 |
i += rval; |
119 |
continue; |
120 |
121 |
switch (argv[i][1]) { |
122 |
case 'n': /* number of cores */ |
123 |
check(2,"i"); |
124 |
nproc = atoi(argv[++i]); |
125 |
if (nproc <= 0) |
126 |
error(USER, "bad number of processes"); |
127 |
break; |
128 |
case 'x': /* x resolution */ |
129 |
check(2,"i"); |
130 |
hresolu = atoi(argv[++i]); |
131 |
break; |
132 |
case 'y': /* y resolution */ |
133 |
check(2,"i"); |
134 |
vresolu = atoi(argv[++i]); |
135 |
break; |
136 |
case 'w': /* warnings */ |
137 |
rval = erract[WARNING].pf != NULL; |
138 |
bool(2,rval); |
139 |
if (rval) erract[WARNING].pf = wputs; |
140 |
else erract[WARNING].pf = NULL; |
141 |
break; |
142 |
case 'e': /* error file */ |
143 |
check(2,"s"); |
144 |
errfile = argv[++i]; |
145 |
break; |
146 |
case 'l': /* limit distance */ |
147 |
if (argv[i][2] != 'd') |
148 |
goto badopt; |
149 |
bool(3,lim_dist); |
150 |
break; |
151 |
case 'I': /* immed. irradiance */ |
152 |
bool(2,imm_irrad); |
153 |
break; |
154 |
case 'f': /* format i/o */ |
155 |
switch (argv[i][2]) { |
156 |
case 'a': /* ascii */ |
157 |
case 'f': /* float */ |
158 |
case 'd': /* double */ |
159 |
inform = argv[i][2]; |
160 |
break; |
161 |
default: |
162 |
goto badopt; |
163 |
164 |
switch (argv[i][3]) { |
165 |
case '\0': |
166 |
outform = inform; |
167 |
break; |
168 |
169 |
170 |
171 |
case 'c': /* color */ |
172 |
check(4,""); |
173 |
outform = argv[i][3]; |
174 |
break; |
175 |
default: |
176 |
goto badopt; |
177 |
178 |
break; |
179 |
case 'o': /* output */ |
180 |
outvals = argv[i]+2; |
181 |
break; |
182 |
case 'h': /* header output */ |
183 |
rval = loadflags & IO_INFO; |
184 |
bool(2,rval); |
185 |
loadflags = rval ? loadflags | IO_INFO : |
186 |
loadflags & ~IO_INFO; |
187 |
break; |
188 |
case 't': /* trace */ |
189 |
190 |
case 'i': /* include */ |
191 |
case 'I': |
192 |
check(3,"s"); |
193 |
if (traincl != 1) { |
194 |
traincl = 1; |
195 |
tralp = tralist; |
196 |
197 |
if (argv[i][2] == 'I') { /* file */ |
198 |
rval = wordfile(tralp, |
199 |
getpath(argv[++i],getrlibpath(),R_OK)); |
200 |
if (rval < 0) { |
201 |
sprintf(errmsg, |
202 |
"cannot open trace include file \"%s\"", |
203 |
argv[i]); |
204 |
205 |
206 |
tralp += rval; |
207 |
} else { |
208 |
*tralp++ = argv[++i]; |
209 |
*tralp = NULL; |
210 |
211 |
break; |
212 |
case 'e': /* exclude */ |
213 |
case 'E': |
214 |
check(3,"s"); |
215 |
if (traincl != 0) { |
216 |
traincl = 0; |
217 |
tralp = tralist; |
218 |
219 |
if (argv[i][2] == 'E') { /* file */ |
220 |
221 |
222 |
if (rval < 0) { |
223 |
sprintf(errmsg, |
224 |
"cannot open trace exclude file \"%s\"", |
225 |
argv[i]); |
226 |
227 |
228 |
tralp += rval; |
229 |
} else { |
230 |
231 |
*tralp = NULL; |
232 |
233 |
break; |
234 |
default: |
235 |
goto badopt; |
236 |
237 |
break; |
238 |
#ifdef PERSIST |
239 |
case 'P': /* persist file */ |
240 |
if (argv[i][2] == 'P') { |
241 |
check(3,"s"); |
242 |
persist = PARALLEL; |
243 |
} else { |
244 |
check(2,"s"); |
245 |
persist = PERSIST; |
246 |
247 |
persistfile(argv[++i]); |
248 |
break; |
249 |
#endif |
250 |
default: |
251 |
goto badopt; |
252 |
253 |
254 |
if (nproc > 1) { |
255 |
if (persist) |
256 |
error(USER, "multiprocessing incompatible with persist file"); |
257 |
if (!vresolu && hresolu > 0 && hresolu < nproc) |
258 |
error(WARNING, "number of cores should not exceed horizontal resolution"); |
259 |
if (trace != NULL) |
260 |
error(WARNING, "multiprocessing does not work properly with trace mode"); |
261 |
262 |
/* initialize object types */ |
263 |
initotypes(); |
264 |
/* initialize urand */ |
265 |
if (rand_samp) { |
266 |
srandom((long)time(0)); |
267 |
initurand(0); |
268 |
} else { |
269 |
srandom(0L); |
270 |
initurand(2048); |
271 |
272 |
/* set up signal handling */ |
273 |
sigdie(SIGINT, "Interrupt"); |
274 |
#ifdef SIGHUP |
275 |
sigdie(SIGHUP, "Hangup"); |
276 |
#endif |
277 |
sigdie(SIGTERM, "Terminate"); |
278 |
#ifdef SIGPIPE |
279 |
sigdie(SIGPIPE, "Broken pipe"); |
280 |
#endif |
281 |
#ifdef SIGALRM |
282 |
sigdie(SIGALRM, "Alarm clock"); |
283 |
#endif |
284 |
#ifdef SIGXCPU |
285 |
sigdie(SIGXCPU, "CPU limit exceeded"); |
286 |
sigdie(SIGXFSZ, "File size exceeded"); |
287 |
#endif |
288 |
/* open error file */ |
289 |
if (errfile != NULL) { |
290 |
if (freopen(errfile, "a", stderr) == NULL) |
291 |
quit(2); |
292 |
fprintf(stderr, "**************\n*** PID %5d: ", |
293 |
getpid()); |
294 |
printargs(argc, argv, stderr); |
295 |
putc('\n', stderr); |
296 |
fflush(stderr); |
297 |
298 |
#ifdef NICE |
299 |
nice(NICE); /* lower priority */ |
300 |
#endif |
301 |
/* get octree */ |
302 |
if (i == argc) |
303 |
octnm = NULL; |
304 |
else if (i == argc-1) |
305 |
octnm = argv[i]; |
306 |
else |
307 |
goto badopt; |
308 |
if (octnm == NULL) |
309 |
error(USER, "missing octree argument"); |
310 |
/* set up output */ |
311 |
#ifdef PERSIST |
312 |
if (persist) { |
313 |
duped1 = dup(fileno(stdout)); /* don't lose our output */ |
314 |
openheader(); |
315 |
316 |
#endif |
317 |
if (outform != 'a') |
318 |
SET_FILE_BINARY(stdout); |
319 |
readoct(octname = octnm, loadflags, &thescene, NULL); |
320 |
nsceneobjs = nobjects; |
321 |
322 |
if (loadflags & IO_INFO) { /* print header */ |
323 |
printargs(i, argv, stdout); |
324 |
printf("SOFTWARE= %s\n", VersionID); |
325 |
fputnow(stdout); |
326 |
fputformat(formstr(outform), stdout); |
327 |
putchar('\n'); |
328 |
329 |
330 |
ray_init_pmap(); /* PMAP: set up & load photon maps */ |
331 |
332 |
marksources(); /* find and mark sources */ |
333 |
334 |
setambient(); /* initialize ambient calculation */ |
335 |
336 |
#ifdef PERSIST |
337 |
if (persist) { |
338 |
fflush(stdout); |
339 |
/* reconnect stdout */ |
340 |
dup2(duped1, fileno(stdout)); |
341 |
close(duped1); |
342 |
if (persist == PARALLEL) { /* multiprocessing */ |
343 |
preload_objs(); /* preload scene */ |
344 |
shm_boundary = (char *)malloc(16); |
345 |
strcpy(shm_boundary, "SHM_BOUNDARY"); |
346 |
while ((rval=fork()) == 0) { /* keep on forkin' */ |
347 |
pflock(1); |
348 |
pfhold(); |
349 |
ambsync(); /* load new values */ |
350 |
351 |
if (rval < 0) |
352 |
error(SYSTEM, "cannot fork child for persist function"); |
353 |
pfdetach(); /* parent will run then exit */ |
354 |
355 |
356 |
runagain: |
357 |
if (persist) |
358 |
dupheader(); /* send header to stdout */ |
359 |
#endif |
360 |
/* trace rays */ |
361 |
rtrace(NULL, nproc); |
362 |
/* flush ambient file */ |
363 |
ambsync(); |
364 |
#ifdef PERSIST |
365 |
if (persist == PERSIST) { /* first run-through */ |
366 |
if ((rval=fork()) == 0) { /* child loops until killed */ |
367 |
pflock(1); |
368 |
persist = PCHILD; |
369 |
} else { /* original process exits */ |
370 |
if (rval < 0) |
371 |
372 |
pfdetach(); /* parent exits */ |
373 |
374 |
375 |
if (persist == PCHILD) { /* wait for a signal then go again */ |
376 |
pfhold(); |
377 |
raynum = nrays = 0; /* reinitialize */ |
378 |
goto runagain; |
379 |
380 |
#endif |
381 |
382 |
ray_done_pmap(); /* PMAP: free photon maps */ |
383 |
384 |
quit(0); |
385 |
386 |
badopt: |
387 |
sprintf(errmsg, "command line error at '%s'", argv[i]); |
388 |
error(USER, errmsg); |
389 |
return 1; /* pro forma return */ |
390 |
391 |
#undef check |
392 |
#undef bool |
393 |
394 |
395 |
396 |
void |
397 |
wputs( /* warning output function */ |
398 |
char *s |
399 |
400 |
401 |
int lasterrno = errno; |
402 |
eputs(s); |
403 |
errno = lasterrno; |
404 |
405 |
406 |
407 |
void |
408 |
eputs( /* put string to stderr */ |
409 |
register char *s |
410 |
411 |
412 |
static int midline = 0; |
413 |
414 |
if (!*s) |
415 |
return; |
416 |
if (!midline++) { |
417 |
fputs(progname, stderr); |
418 |
fputs(": ", stderr); |
419 |
420 |
fputs(s, stderr); |
421 |
if (s[strlen(s)-1] == '\n') { |
422 |
fflush(stderr); |
423 |
midline = 0; |
424 |
425 |
426 |
427 |
428 |
static void |
429 |
onsig( /* fatal signal */ |
430 |
int signo |
431 |
432 |
433 |
static int gotsig = 0; |
434 |
435 |
if (gotsig++) /* two signals and we're gone! */ |
436 |
_exit(signo); |
437 |
438 |
#ifdef SIGALRM |
439 |
alarm(15); /* allow 15 seconds to clean up */ |
440 |
signal(SIGALRM, SIG_DFL); /* make certain we do die */ |
441 |
#endif |
442 |
eputs("signal - "); |
443 |
eputs(sigerr[signo]); |
444 |
eputs("\n"); |
445 |
quit(3); |
446 |
447 |
448 |
449 |
static void |
450 |
sigdie( /* set fatal signal */ |
451 |
int signo, |
452 |
char *msg |
453 |
454 |
455 |
if (signal(signo, onsig) == SIG_IGN) |
456 |
signal(signo, SIG_IGN); |
457 |
sigerr[signo] = msg; |
458 |
459 |
460 |
461 |
static void |
462 |
printdefaults(void) /* print default values to stdout */ |
463 |
464 |
register char *cp; |
465 |
466 |
if (imm_irrad) |
467 |
printf("-I+\t\t\t\t# immediate irradiance on\n"); |
468 |
printf("-n %-2d\t\t\t\t# number of rendering processes\n", nproc); |
469 |
printf("-x %-9d\t\t\t# %s\n", hresolu, |
470 |
vresolu && hresolu ? "x resolution" : "flush interval"); |
471 |
printf("-y %-9d\t\t\t# y resolution\n", vresolu); |
472 |
printf(lim_dist ? "-ld+\t\t\t\t# limit distance on\n" : |
473 |
"-ld-\t\t\t\t# limit distance off\n"); |
474 |
printf("-h%c\t\t\t\t# %s header\n", loadflags & IO_INFO ? '+' : '-', |
475 |
loadflags & IO_INFO ? "output" : "no"); |
476 |
printf("-f%c%c\t\t\t\t# format input/output = %s/%s\n", |
477 |
inform, outform, formstr(inform), formstr(outform)); |
478 |
printf("-o%-9s\t\t\t# output", outvals); |
479 |
for (cp = outvals; *cp; cp++) |
480 |
switch (*cp) { |
481 |
case 't': case 'T': printf(" trace"); break; |
482 |
case 'o': printf(" origin"); break; |
483 |
case 'd': printf(" direction"); break; |
484 |
case 'v': printf(" value"); break; |
485 |
case 'V': printf(" contribution"); break; |
486 |
case 'l': printf(" length"); break; |
487 |
case 'L': printf(" first_length"); break; |
488 |
case 'p': printf(" point"); break; |
489 |
case 'n': printf(" normal"); break; |
490 |
case 'N': printf(" unperturbed_normal"); break; |
491 |
case 's': printf(" surface"); break; |
492 |
case 'w': printf(" weight"); break; |
493 |
case 'W': printf(" coefficient"); break; |
494 |
case 'm': printf(" modifier"); break; |
495 |
case 'M': printf(" material"); break; |
496 |
case '-': printf(" stroke"); break; |
497 |
498 |
putchar('\n'); |
499 |
printf(erract[WARNING].pf != NULL ? |
500 |
"-w+\t\t\t\t# warning messages on\n" : |
501 |
"-w-\t\t\t\t# warning messages off\n"); |
502 |
print_rdefaults(); |
503 |
