root/radiance/ray/src/rt/rtmain.c
Revision: 2.10
Committed: Wed May 25 04:44:26 2005 UTC (18 years, 11 months ago) by greg
Changes since 2.9: +11 -5 lines
2 static const char RCSid[] = "$Id: rtmain.c,v 2.9 2004/03/30 16:13:01 schorsch Exp $";
5 * rtmain.c - main for rtrace per-ray calculation program
6 */
7
8 #include "copyright.h"
9
10 #include <sys/types.h>
11 #include <signal.h>
12
13 #include "platform.h"
14 #include "rtprocess.h" /* getpid() */
15 #include "resolu.h"
16 #include "ray.h"
17 #include "source.h"
18 #include "ambient.h"
19 #include "random.h"
20 #include "paths.h"
21
22 /* persistent processes define */
23 #ifdef F_SETLKW
24 #define PERSIST 1 /* normal persist */
25 #define PARALLEL 2 /* parallel persist */
26 #define PCHILD 3 /* child of normal persist */
27 #endif
28
29 char *progname; /* argv[0] */
30 char *octname; /* octree name */
31 char *sigerr[NSIG]; /* signal error messages */
32 char *shm_boundary = NULL; /* boundary of shared memory */
33 char *errfile = NULL; /* error output file */
34
35 extern char *formstr(); /* string from format */
36 extern int inform; /* input format */
37 extern int outform; /* output format */
38 extern char *outvals; /* output values */
39
40 extern int hresolu; /* horizontal resolution */
41 extern int vresolu; /* vertical resolution */
42
43 extern int imm_irrad; /* compute immediate irradiance? */
44 extern int lim_dist; /* limit distance? */
45
46 extern char *tralist[]; /* list of modifers to trace (or no) */
47 extern int traincl; /* include == 1, exclude == 0 */
48
49 static int loadflags = ~IO_FILES; /* what to load from octree */
50
51 static void onsig(int signo);
52 static void sigdie(int signo, char *msg);
53 static void printdefaults(void);
54
55
56 int
57 main(int argc, char *argv[])
58 {
59 #define check(ol,al) if (argv[i][ol] || \
60 badarg(argc-i-1,argv+i+1,al)) \
61 goto badopt
62 #define bool(olen,var) switch (argv[i][olen]) { \
63 case '\0': var = !var; break; \
64 case 'y': case 'Y': case 't': case 'T': \
65 case '+': case '1': var = 1; break; \
66 case 'n': case 'N': case 'f': case 'F': \
67 case '-': case '0': var = 0; break; \
68 default: goto badopt; }
69 int persist = 0;
70 char **tralp;
71 int duped1;
72 int rval;
73 int i;
74 /* global program name */
75 progname = argv[0] = fixargv0(argv[0]);
76 /* option city */
77 for (i = 1; i < argc; i++) {
78 /* expand arguments */
79 while ((rval = expandarg(&argc, &argv, i)) > 0)
80 ;
81 if (rval < 0) {
82 sprintf(errmsg, "cannot expand '%s'", argv[i]);
83 error(SYSTEM, errmsg);
84 }
85 if (argv[i] == NULL || argv[i][0] != '-')
86 break; /* break from options */
87 if (!strcmp(argv[i], "-version")) {
88 puts(VersionID);
89 quit(0);
90 }
91 if (!strcmp(argv[i], "-defaults") ||
92 !strcmp(argv[i], "-help")) {
93 printdefaults();
94 quit(0);
95 }
96 rval = getrenderopt(argc-i, argv+i);
97 if (rval >= 0) {
98 i += rval;
99 continue;
100 }
101 switch (argv[i][1]) {
102 case 'x': /* x resolution */
103 check(2,"i");
104 hresolu = atoi(argv[++i]);
105 break;
106 case 'y': /* y resolution */
107 check(2,"i");
108 vresolu = atoi(argv[++i]);
109 break;
110 case 'w': /* warnings */
111 rval = erract[WARNING].pf != NULL;
112 bool(2,rval);
113 if (rval) erract[WARNING].pf = wputs;
114 else erract[WARNING].pf = NULL;
115 break;
116 case 'e': /* error file */
117 check(2,"s");
118 errfile = argv[++i];
119 break;
120 case 'l': /* limit distance */
121 if (argv[i][2] != 'd')
122 goto badopt;
123 bool(3,lim_dist);
124 break;
125 case 'I': /* immed. irradiance */
126 bool(2,imm_irrad);
127 break;
128 case 'f': /* format i/o */
129 switch (argv[i][2]) {
130 case 'a': /* ascii */
131 case 'f': /* float */
132 case 'd': /* double */
133 inform = argv[i][2];
134 break;
135 default:
136 goto badopt;
137 }
138 switch (argv[i][3]) {
139 case '\0':
140 outform = inform;
141 break;
142 case 'a': /* ascii */
143 case 'f': /* float */
144 case 'd': /* double */
145 case 'c': /* color */
146 check(4,"");
147 outform = argv[i][3];
148 break;
149 default:
150 goto badopt;
151 }
152 break;
153 case 'o': /* output */
154 outvals = argv[i]+2;
155 break;
156 case 'h': /* header output */
157 rval = loadflags & IO_INFO;
158 bool(2,rval);
159 loadflags = rval ? loadflags | IO_INFO :
160 loadflags & ~IO_INFO;
161 break;
162 case 't': /* trace */
163 switch (argv[i][2]) {
164 case 'i': /* include */
165 case 'I':
166 check(3,"s");
167 if (traincl != 1) {
168 traincl = 1;
169 tralp = tralist;
170 }
171 if (argv[i][2] == 'I') { /* file */
172 rval = wordfile(tralp,
173 getpath(argv[++i],getrlibpath(),R_OK));
174 if (rval < 0) {
175 sprintf(errmsg,
176 "cannot open trace include file \"%s\"",
177 argv[i]);
178 error(SYSTEM, errmsg);
179 }
180 tralp += rval;
181 } else {
182 *tralp++ = argv[++i];
183 *tralp = NULL;
184 }
185 break;
186 case 'e': /* exclude */
187 case 'E':
188 check(3,"s");
189 if (traincl != 0) {
190 traincl = 0;
191 tralp = tralist;
192 }
193 if (argv[i][2] == 'E') { /* file */
194 rval = wordfile(tralp,
195 getpath(argv[++i],getrlibpath(),R_OK));
196 if (rval < 0) {
197 sprintf(errmsg,
198 "cannot open trace exclude file \"%s\"",
199 argv[i]);
200 error(SYSTEM, errmsg);
201 }
202 tralp += rval;
203 } else {
204 *tralp++ = argv[++i];
205 *tralp = NULL;
206 }
207 break;
208 default:
209 goto badopt;
210 }
211 break;
212 #ifdef PERSIST
213 case 'P': /* persist file */
214 if (argv[i][2] == 'P') {
215 check(3,"s");
216 persist = PARALLEL;
217 } else {
218 check(2,"s");
219 persist = PERSIST;
220 }
221 persistfile(argv[++i]);
222 break;
223 #endif
224 default:
225 goto badopt;
226 }
227 }
228 /* initialize object types */
229 initotypes();
230 /* initialize urand */
231 initurand(2048);
232 /* set up signal handling */
233 sigdie(SIGINT, "Interrupt");
234 #ifdef SIGHUP
235 sigdie(SIGHUP, "Hangup");
236 #endif
237 sigdie(SIGTERM, "Terminate");
238 #ifdef SIGPIPE
239 sigdie(SIGPIPE, "Broken pipe");
240 #endif
241 #ifdef SIGALRM
242 sigdie(SIGALRM, "Alarm clock");
243 #endif
244 #ifdef SIGXCPU
245 sigdie(SIGXCPU, "CPU limit exceeded");
246 sigdie(SIGXFSZ, "File size exceeded");
247 #endif
248 /* open error file */
249 if (errfile != NULL) {
250 if (freopen(errfile, "a", stderr) == NULL)
251 quit(2);
252 fprintf(stderr, "**************\n*** PID %5d: ",
253 getpid());
254 printargs(argc, argv, stderr);
255 putc('\n', stderr);
256 fflush(stderr);
257 }
258 #ifdef NICE
259 nice(NICE); /* lower priority */
260 #endif
261 /* get octree */
262 if (i == argc)
263 octname = NULL;
264 else if (i == argc-1)
265 octname = argv[i];
266 else
267 goto badopt;
268 if (octname == NULL)
269 error(USER, "missing octree argument");
270 /* set up output */
271 #ifdef PERSIST
272 if (persist) {
273 duped1 = dup(fileno(stdout)); /* don't lose our output */
274 openheader();
275 }
276 #endif
277 #ifdef _WIN32
278 if (outform != 'a')
279 SET_FILE_BINARY(stdout);
280 if (octname == NULL)
281 SET_FILE_BINARY(stdin);
282 #endif
283 readoct(octname, loadflags, &thescene, NULL);
284 nsceneobjs = nobjects;
285
286 if (loadflags & IO_INFO) { /* print header */
287 printargs(i, argv, stdout);
288 printf("SOFTWARE= %s\n", VersionID);
289 fputnow(stdout);
290 fputformat(formstr(outform), stdout);
291 putchar('\n');
292 }
293
294 marksources(); /* find and mark sources */
295
296 setambient(); /* initialize ambient calculation */
297
298 #ifdef PERSIST
299 if (persist) {
300 fflush(stdout);
301 /* reconnect stdout */
302 dup2(duped1, fileno(stdout));
303 close(duped1);
304 if (persist == PARALLEL) { /* multiprocessing */
305 preload_objs(); /* preload scene */
306 shm_boundary = (char *)malloc(16);
307 strcpy(shm_boundary, "SHM_BOUNDARY");
308 while ((rval=fork()) == 0) { /* keep on forkin' */
309 pflock(1);
310 pfhold();
311 }
312 if (rval < 0)
313 error(SYSTEM, "cannot fork child for persist function");
314 pfdetach(); /* parent exits */
315 }
316 }
317 runagain:
318 if (persist)
319 dupheader(); /* send header to stdout */
320 #endif
321 /* trace rays */
322 rtrace(NULL);
323 /* flush ambient file */
324 ambsync();
325 #ifdef PERSIST
326 if (persist == PERSIST) { /* first run-through */
327 if ((rval=fork()) == 0) { /* child loops until killed */
328 pflock(1);
329 persist = PCHILD;
330 } else { /* original process exits */
331 if (rval < 0)
332 error(SYSTEM, "cannot fork child for persist function");
333 pfdetach(); /* parent exits */
334 }
335 }
336 if (persist == PCHILD) { /* wait for a signal then go again */
337 close(duped1); /* release output handle */
338 pfhold();
339 raynum = nrays = 0; /* reinitialize */
340 goto runagain;
341 }
342 #endif
343 quit(0);
344
345 badopt:
346 sprintf(errmsg, "command line error at '%s'", argv[i]);
347 error(USER, errmsg);
348 return 1; /* pro forma return */
349
350 #undef check
351 #undef bool
352 }
353
354
355 void
356 wputs( /* warning output function */
357 char *s
358 )
359 {
360 int lasterrno = errno;
361 eputs(s);
362 errno = lasterrno;
363 }
364
365
366 void
367 eputs( /* put string to stderr */
368 register char *s
369 )
370 {
371 static int midline = 0;
372
373 if (!*s)
374 return;
375 if (!midline++) {
376 fputs(progname, stderr);
377 fputs(": ", stderr);
378 }
379 fputs(s, stderr);
380 if (s[strlen(s)-1] == '\n') {
381 fflush(stderr);
382 midline = 0;
383 }
384 }
385
386
387 static void
388 onsig( /* fatal signal */
389 int signo
390 )
391 {
392 static int gotsig = 0;
393
394 if (gotsig++) /* two signals and we're gone! */
395 _exit(signo);
396
397 #ifdef SIGALRM
398 alarm(15); /* allow 15 seconds to clean up */
399 signal(SIGALRM, SIG_DFL); /* make certain we do die */
400 #endif
401 eputs("signal - ");
402 eputs(sigerr[signo]);
403 eputs("\n");
404 quit(3);
405 }
406
407
408 static void
409 sigdie( /* set fatal signal */
410 int signo,
411 char *msg
412 )
413 {
414 if (signal(signo, onsig) == SIG_IGN)
415 signal(signo, SIG_IGN);
416 sigerr[signo] = msg;
417 }
418
419
420 static void
421 printdefaults(void) /* print default values to stdout */
422 {
423 register char *cp;
424
425 if (imm_irrad)
426 printf("-I+\t\t\t\t# immediate irradiance on\n");
427 printf("-x %-9d\t\t\t# x resolution (flush interval)\n", hresolu);
428 printf("-y %-9d\t\t\t# y resolution\n", vresolu);
429 printf(lim_dist ? "-ld+\t\t\t\t# limit distance on\n" :
430 "-ld-\t\t\t\t# limit distance off\n");
431 printf("-h%c\t\t\t\t# %s header\n", loadflags & IO_INFO ? '+' : '-',
432 loadflags & IO_INFO ? "output" : "no");
433 printf("-f%c%c\t\t\t\t# format input/output = %s/%s\n",
434 inform, outform, formstr(inform), formstr(outform));
435 printf("-o%-9s\t\t\t# output", outvals);
436 for (cp = outvals; *cp; cp++)
437 switch (*cp) {
438 case 't': case 'T': printf(" trace"); break;
439 case 'o': printf(" origin"); break;
440 case 'd': printf(" direction"); break;
441 case 'v': printf(" value"); break;
442 case 'l': printf(" length"); break;
443 case 'L': printf(" first_length"); break;
444 case 'p': printf(" point"); break;
445 case 'n': printf(" normal"); break;
446 case 'N': printf(" unperturbed_normal"); break;
447 case 's': printf(" surface"); break;
448 case 'w': printf(" weight"); break;
449 case 'm': printf(" modifier"); break;
450 case 'M': printf(" material"); break;
451 case 'W': printf(" contribution"); break;
452 case '-': printf(" stroke"); break;
453 }
454 putchar('\n');
455 printf(erract[WARNING].pf != NULL ?
456 "-w+\t\t\t\t# warning messages on\n" :
457 "-w-\t\t\t\t# warning messages off\n");
458 print_rdefaults();
459 }
