root/radiance/ray/src/rt/rtmain.c
Tue Apr 22 17:12:25 2025 UTC (5 weeks, 3 days ago) by greg
Changes since 2.57: +4 -1 lines
Diff to previous 2.57 , to selected 2.2
Wed Mar 5 18:56:28 2025 UTC (2 months, 3 weeks ago) by greg
Changes since 2.56: +4 -2 lines
Diff to previous 2.56 , to selected 2.2
feat(rtrace,rxtrace): Improved header output
Wed Oct 30 16:47:03 2024 UTC (6 months, 4 weeks ago) by greg
Changes since 2.55: +3 -1 lines
Diff to previous 2.55 , to selected 2.2
fix(rpict,rtrace,rcontrib): Removed spurious warnings
Wed Aug 21 20:42:20 2024 UTC (9 months, 1 week ago) by greg
Changes since 2.54: +2 -6 lines
Diff to previous 2.54 , to selected 2.2
refactor: moved memory sharing routines to preload.c with common call interface
Tue Aug 20 18:57:11 2024 UTC (9 months, 1 week ago) by greg
Diff to previous 2.53 , to selected 2.2
fix(rtrace): compile error due to const
Tue Apr 30 22:25:46 2024 UTC (13 months ago) by greg
Changes since 2.52: +2 -2 lines
Diff to previous 2.52 , to selected 2.2
feat(rtrace): Improved diagnostic output
Fri Apr 5 16:43:33 2024 UTC (13 months, 3 weeks ago) by greg
Diff to previous 2.51 , to selected 2.2
fix: Added missing eol escape for Windows
Fri Apr 5 16:41:17 2024 UTC (13 months, 3 weeks ago) by greg
Changes since 2.50: +4 -2 lines
Diff to previous 2.50 , to selected 2.2
feat(rpict,rtrace,rcontrib): Added OutputCS to features list
Mon Dec 11 18:33:53 2023 UTC (17 months, 2 weeks ago) by greg
Changes since 2.49: +7 -1 lines
Diff to previous 2.49 , to selected 2.2
fix(rtrace): bug for float spectral output
Mon Dec 11 17:21:59 2023 UTC (17 months, 2 weeks ago) by greg
Changes since 2.48: +13 -10 lines
Diff to previous 2.48 , to selected 2.2
fix(rtrace): made spectral settings interaction more robust
Fri Nov 17 20:02:07 2023 UTC (18 months, 1 week ago) by greg
Changes since 2.47: +10 -27 lines
Diff to previous 2.47 , to selected 2.2
Wed Nov 15 18:02:53 2023 UTC (18 months, 2 weeks ago) by greg
Changes since 2.46: +122 -9 lines
Diff to previous 2.46 , to selected 2.2
Tue Aug 15 01:19:37 2023 UTC (21 months, 2 weeks ago) by greg
Changes since 2.45: +3 -1 lines
Diff to previous 2.45 , to selected 2.2
fix(rcontrib): Removed participating media from rcontrib -features
Tue Aug 15 00:46:56 2023 UTC (21 months, 2 weeks ago) by greg
Changes since 2.44: +4 -2 lines
Diff to previous 2.44 , to selected 2.2
fix(rtrace,rcontrib): Added i/o format options to features list
Mon Feb 6 22:40:21 2023 UTC (2 years, 3 months ago) by greg
Changes since 2.43: +3 -4 lines
Diff to previous 2.43 , to selected 2.2
Mon Feb 6 20:37:06 2023 UTC (2 years, 3 months ago) by greg
Diff to previous 2.42 , to selected 2.2
fix: Actually, need to allow -features to have arguments
Mon Feb 6 20:34:17 2023 UTC (2 years, 3 months ago) by greg
Changes since 2.41: +2 -2 lines
Diff to previous 2.41 , to selected 2.2
fix: fixed crash when executed with no arguments
Thu Feb 2 18:55:09 2023 UTC (2 years, 3 months ago) by greg
Changes since 2.40: +3 -2 lines
Diff to previous 2.40 , to selected 2.2
fix: Paired savqstr() and freeqstr() calls for octname
Thu Oct 20 17:18:33 2022 UTC (2 years, 7 months ago) by greg
Changes since 2.39: +5 -3 lines
Diff to previous 2.39 , to selected 2.2
feat(rpict,rtrace,rcontrib): Added Output= list to -features
Wed Oct 19 23:10:34 2022 UTC (2 years, 7 months ago) by greg
Changes since 2.38: +5 -3 lines
Diff to previous 2.38 , to selected 2.2
fix(rcontrib): removed AdaptiveShadowTesting from feature list (didn't belong)
Wed Oct 19 21:25:20 2022 UTC (2 years, 7 months ago) by greg
Changes since 2.37: +16 -3 lines
Diff to previous 2.37 , to selected 2.2
Tue Oct 18 18:07:50 2022 UTC (2 years, 7 months ago) by greg
Diff to previous 2.36 , to selected 2.2
fix(rtrace): corrected defaults reporting with tilde
Wed Apr 6 15:28:18 2022 UTC (3 years, 1 month ago) by greg
Diff to previous 2.35 , to selected 2.2
style: indentation
Tue Apr 5 03:02:15 2022 UTC (3 years, 1 month ago) by greg
Changes since 2.34: +4 -2 lines
Diff to previous 2.34 , to selected 2.2
fix(rpict): Bug in header output with -o option
Wed Apr 8 00:57:39 2020 UTC (5 years, 1 month ago) by greg
Changes since 2.33: +3 -9 lines
Diff to previous 2.33 , to selected 2.2
Removed superfluous warnings
Mon Apr 6 21:09:07 2020 UTC (5 years, 1 month ago) by greg
Changes since 2.32: +4 -3 lines
Diff to previous 2.32 , to selected 2.2
Fixes and improvements from last change, making ray-casting faster
Mon Apr 6 04:10:44 2020 UTC (5 years, 1 month ago) by greg
Changes since 2.31: +12 -7 lines
Diff to previous 2.31 , to selected 2.2
Made start-up much faster when only doing ray-casting
Sun Apr 5 15:47:02 2020 UTC (5 years, 1 month ago) by greg
Changes since 2.30: +6 -2 lines
Diff to previous 2.30 , to selected 2.2
Added NCOMP= to header and better checking of -o* options
Wed Aug 14 20:07:20 2019 UTC (5 years, 9 months ago) by greg
Changes since 2.29: +3 -1 lines
Diff to previous 2.29 , to selected 2.2
Added BigEndian= line to binary header output
Thu Apr 18 23:58:22 2019 UTC (6 years, 1 month ago) by greg
Changes since 2.28: +1 -5 lines
Diff to previous 2.28 , to selected 2.2
Made settings consistent with claims of matching rtrace and added missing rand_samp
Tue Nov 13 19:58:33 2018 UTC (6 years, 6 months ago) by greg
Changes since 2.27: +5 -1 lines
Diff to previous 2.27 , to selected 2.2
Mon Mar 21 19:06:08 2016 UTC (9 years, 2 months ago) by greg
CVS Tags: rad5R1, rad5R2
Changes since 2.26: +3 -3 lines
Diff to previous 2.26 , to selected 2.2
Thu Mar 10 18:25:46 2016 UTC (9 years, 2 months ago) by schorsch
Changes since 2.25: +7 -7 lines
Diff to previous 2.25 , to selected 2.2
newer C++ compilers have a standard type named "bool". rename macro to get rid of warnings.
Thu Apr 23 20:29:14 2015 UTC (10 years, 1 month ago) by greg
Changes since 2.24: +2 -1 lines
Diff to previous 2.24 , to selected 2.2
Added missing external declaration
Thu Apr 23 17:42:04 2015 UTC (10 years, 1 month ago) by greg
Diff to previous 2.23 , to selected 2.2
Fixed assignment of octname and removed redundant call to ray_init_pmap()
Tue Feb 24 19:39:27 2015 UTC (10 years, 3 months ago) by greg
Changes since 2.22: +9 -3 lines
Diff to previous 2.22 , to selected 2.2
Wed Aug 7 05:10:09 2013 UTC (11 years, 9 months ago) by greg
Changes since 2.21: +3 -3 lines
Diff to previous 2.21 , to selected 2.2
Sun Sep 26 15:51:15 2010 UTC (14 years, 8 months ago) by greg
Changes since 2.20: +4 -3 lines
Diff to previous 2.20 , to selected 2.2
Sun Dec 13 19:39:51 2009 UTC (15 years, 5 months ago) by greg
Changes since 2.19: +2 -1 lines
Diff to previous 2.19 , to selected 2.2
Reset default -u+ setting
Sun Dec 13 19:13:04 2009 UTC (15 years, 5 months ago) by greg
Changes since 2.18: +2 -6 lines
Diff to previous 2.18 , to selected 2.2
Sat Dec 12 19:01:00 2009 UTC (15 years, 5 months ago) by greg
Changes since 2.17: +54 -17 lines
Mon Jun 22 20:52:56 2009 UTC (15 years, 11 months ago) by greg
Changes since 2.16: +1 -2 lines
Bug fix in -P option implementation
Fri Apr 18 18:06:29 2008 UTC (17 years, 1 month ago) by greg
Modified rtcontrib -c option to accumulate a specified number of rays
Thu Sep 13 20:02:11 2007 UTC (17 years, 8 months ago) by greg
Changes since 2.14: +3 -2 lines
Added ambient pre-synchronization in parallel persist mode
Wed Apr 5 06:22:57 2006 UTC (19 years, 2 months ago) by greg
Changes since 2.13: +8 -3 lines
Made -u+ option truly random
Sun Feb 5 22:22:20 2006 UTC (19 years, 3 months ago) by greg
Added -V option to rtcontrib and -oV option to rtrace to report contributions
Wed Jun 15 15:36:52 2005 UTC (19 years, 11 months ago) by greg
Thu Jun 2 04:47:27 2005 UTC (20 years ago) by greg
Changes since 2.10: +1 -5 lines
Wed May 25 04:44:26 2005 UTC (20 years ago) by greg
Changes since 2.9: +11 -5 lines
Tue Mar 30 16:13:01 2004 UTC (21 years, 2 months ago) by schorsch
Changes since 2.8: +23 -23 lines
Tue Oct 21 19:19:28 2003 UTC (21 years, 7 months ago) by schorsch
Mon Jul 14 20:02:30 2003 UTC (21 years, 10 months ago) by schorsch
Changes since 2.6: +2 -4 lines
Mon Jun 30 14:59:12 2003 UTC (21 years, 11 months ago) by schorsch
Thu Jun 26 00:58:10 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 2.4: +9 -1 lines
Thu Jun 5 19:29:34 2003 UTC (22 years ago) by schorsch
Changes since 2.3: +8 -11 lines
Tue May 13 17:58:33 2003 UTC (22 years ago) by greg
Tue Feb 25 02:47:23 2003 UTC (22 years, 3 months ago) by greg
Sat Feb 22 02:07:29 2003 UTC (22 years, 3 months ago) by greg
Diff to selected 2.2
