--- ray/src/rt/rtmain.c 2005/05/25 04:44:26 2.10 +++ ray/src/rt/rtmain.c 2023/08/15 01:19:37 2.46 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rtmain.c,v 2.10 2005/05/25 04:44:26 greg Exp $"; +static const char RCSid[] = "$Id: rtmain.c,v 2.46 2023/08/15 01:19:37 greg Exp $"; #endif /* * rtmain.c - main for rtrace per-ray calculation program @@ -7,7 +7,6 @@ static const char RCSid[] = "$Id: rtmain.c,v 2.10 2005 #include "copyright.h" -#include #include #include "platform.h" @@ -18,7 +17,12 @@ static const char RCSid[] = "$Id: rtmain.c,v 2.10 2005 #include "ambient.h" #include "random.h" #include "paths.h" +#include "pmapray.h" +extern char *progname; /* global argv[0] */ + +extern char *shm_boundary; /* boundary of shared memory */ + /* persistent processes define */ #ifdef F_SETLKW #define PERSIST 1 /* normal persist */ @@ -26,53 +30,89 @@ static const char RCSid[] = "$Id: rtmain.c,v 2.10 2005 #define PCHILD 3 /* child of normal persist */ #endif -char *progname; /* argv[0] */ -char *octname; /* octree name */ char *sigerr[NSIG]; /* signal error messages */ -char *shm_boundary = NULL; /* boundary of shared memory */ char *errfile = NULL; /* error output file */ -extern char *formstr(); /* string from format */ -extern int inform; /* input format */ -extern int outform; /* output format */ -extern char *outvals; /* output values */ +int nproc = 1; /* number of processes */ -extern int hresolu; /* horizontal resolution */ -extern int vresolu; /* vertical resolution */ +extern int setrtoutput(void); /* set output values */ -extern int imm_irrad; /* compute immediate irradiance? */ -extern int lim_dist; /* limit distance? */ +int inform = 'a'; /* input format */ +int outform = 'a'; /* output format */ +char *outvals = "v"; /* output specification */ -extern char *tralist[]; /* list of modifers to trace (or no) */ -extern int traincl; /* include == 1, exclude == 0 */ +int hresolu = 0; /* horizontal (scan) size */ +int vresolu = 0; /* vertical resolution */ +extern int castonly; /* only doing ray-casting? */ + +int imm_irrad = 0; /* compute immediate irradiance? */ +int lim_dist = 0; /* limit distance? */ + +#ifndef MAXMODLIST +#define MAXMODLIST 1024 /* maximum modifiers we'll track */ +#endif + +extern void (*addobjnotify[])(); /* object notification calls */ +extern void tranotify(OBJECT obj); + +char *tralist[MAXMODLIST]; /* list of modifers to trace (or no) */ +int traincl = -1; /* include == 1, exclude == 0 */ + static int loadflags = ~IO_FILES; /* what to load from octree */ static void onsig(int signo); static void sigdie(int signo, char *msg); static void printdefaults(void); +#ifdef PERSIST +#define RTRACE_FEATURES "Persist\nParallelPersist\nMultiprocessing\n" \ + "IrradianceCalc\nImmediateIrradiance\nDistanceLimiting\n" \ + "ParticipatingMedia=Mist\n" \ + "HessianAmbientCache\nAmbientAveraging\n" \ + "AmbientValueSharing\nAdaptiveShadowTesting\n" \ + "InputFormats=a,f,d\nOutputFormats=a,f,d,c\n" \ + "Outputs=o,d,v,V,w,W,l,L,c,p,n,N,s,m,M,r,x,R,X,~\n" +#else +#define RTRACE_FEATURES "IrradianceCalc\nIrradianceCalc\nDistanceLimiting\n" \ + "ParticipatingMedia=Mist\n" \ + "HessianAmbientCache\nAmbientAveraging\n" \ + "AmbientValueSharing\nAdaptiveShadowTesting\n" \ + "InputFormats=a,f,d\nOutputFormats=a,f,d,c\n" \ + "Outputs=o,d,v,V,w,W,l,L,c,p,n,N,s,m,M,r,x,R,X,~\n" +#endif + int main(int argc, char *argv[]) { #define check(ol,al) if (argv[i][ol] || \ badarg(argc-i-1,argv+i+1,al)) \ goto badopt -#define bool(olen,var) switch (argv[i][olen]) { \ +#define check_bool(olen,var) switch (argv[i][olen]) { \ case '\0': var = !var; break; \ case 'y': case 'Y': case 't': case 'T': \ case '+': case '1': var = 1; break; \ case 'n': case 'N': case 'f': case 'F': \ case '-': case '0': var = 0; break; \ default: goto badopt; } + extern char *octname; int persist = 0; - char **tralp; - int duped1; + char *octnm = NULL; + char **tralp = NULL; + int duped1 = -1; int rval; int i; /* global program name */ progname = argv[0] = fixargv0(argv[0]); + /* feature check only? */ + strcat(RFeatureList, RTRACE_FEATURES); + if (argc > 1 && !strcmp(argv[1], "-features")) + return feature_status(argc-2, argv+2); + /* add trace notify function */ + for (i = 0; addobjnotify[i] != NULL; i++) + ; + addobjnotify[i] = tranotify; /* option city */ for (i = 1; i < argc; i++) { /* expand arguments */ @@ -99,6 +139,12 @@ main(int argc, char *argv[]) continue; } switch (argv[i][1]) { + case 'n': /* number of cores */ + check(2,"i"); + nproc = atoi(argv[++i]); + if (nproc <= 0) + error(USER, "bad number of processes"); + break; case 'x': /* x resolution */ check(2,"i"); hresolu = atoi(argv[++i]); @@ -109,7 +155,7 @@ main(int argc, char *argv[]) break; case 'w': /* warnings */ rval = erract[WARNING].pf != NULL; - bool(2,rval); + check_bool(2,rval); if (rval) erract[WARNING].pf = wputs; else erract[WARNING].pf = NULL; break; @@ -120,10 +166,10 @@ main(int argc, char *argv[]) case 'l': /* limit distance */ if (argv[i][2] != 'd') goto badopt; - bool(3,lim_dist); + check_bool(3,lim_dist); break; case 'I': /* immed. irradiance */ - bool(2,imm_irrad); + check_bool(2,imm_irrad); break; case 'f': /* format i/o */ switch (argv[i][2]) { @@ -155,7 +201,7 @@ main(int argc, char *argv[]) break; case 'h': /* header output */ rval = loadflags & IO_INFO; - bool(2,rval); + check_bool(2,rval); loadflags = rval ? loadflags | IO_INFO : loadflags & ~IO_INFO; break; @@ -169,7 +215,7 @@ main(int argc, char *argv[]) tralp = tralist; } if (argv[i][2] == 'I') { /* file */ - rval = wordfile(tralp, + rval = wordfile(tralp, MAXMODLIST-(tralp-tralist), getpath(argv[++i],getrlibpath(),R_OK)); if (rval < 0) { sprintf(errmsg, @@ -191,7 +237,7 @@ main(int argc, char *argv[]) tralp = tralist; } if (argv[i][2] == 'E') { /* file */ - rval = wordfile(tralp, + rval = wordfile(tralp, MAXMODLIST-(tralp-tralist), getpath(argv[++i],getrlibpath(),R_OK)); if (rval < 0) { sprintf(errmsg, @@ -225,10 +271,18 @@ main(int argc, char *argv[]) goto badopt; } } + if (nproc > 1 && persist) + error(USER, "multiprocessing incompatible with persist file"); /* initialize object types */ initotypes(); /* initialize urand */ - initurand(2048); + if (rand_samp) { + srandom((long)time(0)); + initurand(0); + } else { + srandom(0L); + initurand(2048); + } /* set up signal handling */ sigdie(SIGINT, "Interrupt"); #ifdef SIGHUP @@ -260,12 +314,12 @@ main(int argc, char *argv[]) #endif /* get octree */ if (i == argc) - octname = NULL; + octnm = NULL; else if (i == argc-1) - octname = argv[i]; + octnm = argv[i]; else goto badopt; - if (octname == NULL) + if (octnm == NULL) error(USER, "missing octree argument"); /* set up output */ #ifdef PERSIST @@ -274,12 +328,10 @@ main(int argc, char *argv[]) openheader(); } #endif -#ifdef _WIN32 if (outform != 'a') SET_FILE_BINARY(stdout); - if (octname == NULL) - SET_FILE_BINARY(stdin); -#endif + rval = setrtoutput(); + octname = savqstr(octnm); readoct(octname, loadflags, &thescene, NULL); nsceneobjs = nobjects; @@ -287,17 +339,28 @@ main(int argc, char *argv[]) printargs(i, argv, stdout); printf("SOFTWARE= %s\n", VersionID); fputnow(stdout); + if (rval > 0) /* saved from setrtoutput() call */ + printf("NCOMP=%d\n", rval); + if ((outform == 'f') | (outform == 'd')) + fputendian(stdout); fputformat(formstr(outform), stdout); putchar('\n'); } - marksources(); /* find and mark sources */ + if (!castonly) { /* any actual ray traversal to do? */ - setambient(); /* initialize ambient calculation */ + ray_init_pmap(); /* PMAP: set up & load photon maps */ + + marksources(); /* find and mark sources */ + setambient(); /* initialize ambient calculation */ + } else + distantsources(); /* else mark only distant sources */ + + fflush(stdout); /* in case we're duplicating header */ + #ifdef PERSIST if (persist) { - fflush(stdout); /* reconnect stdout */ dup2(duped1, fileno(stdout)); close(duped1); @@ -308,10 +371,11 @@ main(int argc, char *argv[]) while ((rval=fork()) == 0) { /* keep on forkin' */ pflock(1); pfhold(); + ambsync(); /* load new values */ } if (rval < 0) error(SYSTEM, "cannot fork child for persist function"); - pfdetach(); /* parent exits */ + pfdetach(); /* parent will run then exit */ } } runagain: @@ -319,7 +383,7 @@ runagain: dupheader(); /* send header to stdout */ #endif /* trace rays */ - rtrace(NULL); + rtrace(NULL, nproc); /* flush ambient file */ ambsync(); #ifdef PERSIST @@ -334,12 +398,14 @@ runagain: } } if (persist == PCHILD) { /* wait for a signal then go again */ - close(duped1); /* release output handle */ pfhold(); raynum = nrays = 0; /* reinitialize */ goto runagain; } #endif + + ray_done_pmap(); /* PMAP: free photon maps */ + quit(0); badopt: @@ -348,13 +414,13 @@ badopt: return 1; /* pro forma return */ #undef check -#undef bool +#undef check_bool } void wputs( /* warning output function */ - char *s + const char *s ) { int lasterrno = errno; @@ -365,7 +431,7 @@ wputs( /* warning output function */ void eputs( /* put string to stderr */ - register char *s + const char *s ) { static int midline = 0; @@ -420,12 +486,14 @@ sigdie( /* set fatal signal */ static void printdefaults(void) /* print default values to stdout */ { - register char *cp; + char *cp; if (imm_irrad) printf("-I+\t\t\t\t# immediate irradiance on\n"); - printf("-x %-9d\t\t\t# x resolution (flush interval)\n", hresolu); - printf("-y %-9d\t\t\t# y resolution\n", vresolu); + printf("-n %-2d\t\t\t\t# number of rendering processes\n", nproc); + printf("-x %-9d\t\t\t# %s\n", hresolu, + vresolu && hresolu ? "x resolution" : "flush interval"); + printf("-y %-9d\t\t\t# y resolution\n", vresolu); printf(lim_dist ? "-ld+\t\t\t\t# limit distance on\n" : "-ld-\t\t\t\t# limit distance off\n"); printf("-h%c\t\t\t\t# %s header\n", loadflags & IO_INFO ? '+' : '-', @@ -438,7 +506,12 @@ printdefaults(void) /* print default values to stdou case 't': case 'T': printf(" trace"); break; case 'o': printf(" origin"); break; case 'd': printf(" direction"); break; + case 'r': printf(" reflect_contrib"); break; + case 'R': printf(" reflect_length"); break; + case 'x': printf(" unreflect_contrib"); break; + case 'X': printf(" unreflect_length"); break; case 'v': printf(" value"); break; + case 'V': printf(" contribution"); break; case 'l': printf(" length"); break; case 'L': printf(" first_length"); break; case 'p': printf(" point"); break; @@ -446,10 +519,10 @@ printdefaults(void) /* print default values to stdou case 'N': printf(" unperturbed_normal"); break; case 's': printf(" surface"); break; case 'w': printf(" weight"); break; + case 'W': printf(" coefficient"); break; case 'm': printf(" modifier"); break; case 'M': printf(" material"); break; - case 'W': printf(" contribution"); break; - case '-': printf(" stroke"); break; + case '~': printf(" tilde"); break; } putchar('\n'); printf(erract[WARNING].pf != NULL ?
