--- ray/src/rt/rtmain.c 2003/02/22 02:07:29 2.1 +++ ray/src/rt/rtmain.c 2023/02/06 22:40:21 2.44 @@ -1,80 +1,28 @@ #ifndef lint -static const char RCSid[] = "$Id: rtmain.c,v 2.1 2003/02/22 02:07:29 greg Exp $"; +static const char RCSid[] = "$Id: rtmain.c,v 2.44 2023/02/06 22:40:21 greg Exp $"; #endif /* * rtmain.c - main for rtrace per-ray calculation program */ -/* ==================================================================== - * The Radiance Software License, Version 1.0 - * - * Copyright (c) 1990 - 2002 The Regents of the University of California, - * through Lawrence Berkeley National Laboratory. All rights reserved. - * - * Redistribution and use in source and binary forms, with or without - * modification, are permitted provided that the following conditions - * are met: - * - * 1. Redistributions of source code must retain the above copyright - * notice, this list of conditions and the following disclaimer. - * - * 2. Redistributions in binary form must reproduce the above copyright - * notice, this list of conditions and the following disclaimer in - * the documentation and/or other materials provided with the - * distribution. - * - * 3. The end-user documentation included with the redistribution, - * if any, must include the following acknowledgment: - * "This product includes Radiance software - * (http://radsite.lbl.gov/) - * developed by the Lawrence Berkeley National Laboratory - * (http://www.lbl.gov/)." - * Alternately, this acknowledgment may appear in the software itself, - * if and wherever such third-party acknowledgments normally appear. - * - * 4. The names "Radiance," "Lawrence Berkeley National Laboratory" - * and "The Regents of the University of California" must - * not be used to endorse or promote products derived from this - * software without prior written permission. For written - * permission, please contact radiance@radsite.lbl.gov. - * - * 5. Products derived from this software may not be called "Radiance", - * nor may "Radiance" appear in their name, without prior written - * permission of Lawrence Berkeley National Laboratory. - * - * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED - * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES - * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE - * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR - * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, - * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT - * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF - * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND - * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, - * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT - * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF - * SUCH DAMAGE. - * ==================================================================== - * - * This software consists of voluntary contributions made by many - * individuals on behalf of Lawrence Berkeley National Laboratory. For more - * information on Lawrence Berkeley National Laboratory, please see - * . - */ +#include "copyright.h" -#include "ray.h" +#include +#include "platform.h" +#include "rtprocess.h" /* getpid() */ +#include "resolu.h" +#include "ray.h" #include "source.h" - #include "ambient.h" - #include "random.h" - #include "paths.h" +#include "pmapray.h" -#include +extern char *progname; /* global argv[0] */ -#include +extern char *shm_boundary; /* boundary of shared memory */ + /* persistent processes define */ #ifdef F_SETLKW #define PERSIST 1 /* normal persist */ @@ -82,58 +30,85 @@ static const char RCSid[] = "$Id: rtmain.c,v 2.1 2003/ #define PCHILD 3 /* child of normal persist */ #endif -char *progname; /* argv[0] */ +char *sigerr[NSIG]; /* signal error messages */ +char *errfile = NULL; /* error output file */ -char *octname; /* octree name */ +int nproc = 1; /* number of processes */ -char *sigerr[NSIG]; /* signal error messages */ +extern int setrtoutput(void); /* set output values */ -char *shm_boundary = NULL; /* boundary of shared memory */ +int inform = 'a'; /* input format */ +int outform = 'a'; /* output format */ +char *outvals = "v"; /* output specification */ -char *errfile = NULL; /* error output file */ +int hresolu = 0; /* horizontal (scan) size */ +int vresolu = 0; /* vertical resolution */ -extern char *formstr(); /* string from format */ -extern int inform; /* input format */ -extern int outform; /* output format */ -extern char *outvals; /* output values */ +extern int castonly; /* only doing ray-casting? */ -extern int hresolu; /* horizontal resolution */ -extern int vresolu; /* vertical resolution */ +int imm_irrad = 0; /* compute immediate irradiance? */ +int lim_dist = 0; /* limit distance? */ -extern int imm_irrad; /* compute immediate irradiance? */ -extern int lim_dist; /* limit distance? */ +#ifndef MAXMODLIST +#define MAXMODLIST 1024 /* maximum modifiers we'll track */ +#endif -extern char *tralist[]; /* list of modifers to trace (or no) */ -extern int traincl; /* include == 1, exclude == 0 */ +extern void (*addobjnotify[])(); /* object notification calls */ +extern void tranotify(OBJECT obj); -void onsig(); -void sigdie(); -void printdefaults(); +char *tralist[MAXMODLIST]; /* list of modifers to trace (or no) */ +int traincl = -1; /* include == 1, exclude == 0 */ +static int loadflags = ~IO_FILES; /* what to load from octree */ +static void onsig(int signo); +static void sigdie(int signo, char *msg); +static void printdefaults(void); + +#ifdef PERSIST +#define RTRACE_FEATURES "Persist\nParallelPersist\nMultiProcessing\n" \ + "IrradianceCalc\nImmediateIrradiance\nDistanceLimiting\n" \ + "HessianAmbientCache\nAmbientAveraging\n" \ + "AmbientValueSharing\nAdaptiveShadowTesting\n" \ + "Outputs=o,d,v,V,w,W,l,L,c,p,n,N,s,m,M,r,x,R,X,~\n" +#else +#define RTRACE_FEATURES "IrradianceCalc\nIrradianceCalc\nDistanceLimiting\n" \ + "HessianAmbientCache\nAmbientAveraging\n" \ + "AmbientValueSharing\nAdaptiveShadowTesting\n" \ + "Outputs=o,d,v,V,w,W,l,L,c,p,n,N,s,m,M,r,x,R,X,~\n" +#endif + + int -main(argc, argv) -int argc; -char *argv[]; +main(int argc, char *argv[]) { #define check(ol,al) if (argv[i][ol] || \ badarg(argc-i-1,argv+i+1,al)) \ goto badopt -#define bool(olen,var) switch (argv[i][olen]) { \ +#define check_bool(olen,var) switch (argv[i][olen]) { \ case '\0': var = !var; break; \ case 'y': case 'Y': case 't': case 'T': \ case '+': case '1': var = 1; break; \ case 'n': case 'N': case 'f': case 'F': \ case '-': case '0': var = 0; break; \ default: goto badopt; } - int loadflags = ~IO_FILES; + extern char *octname; int persist = 0; - char **tralp; - int duped1; + char *octnm = NULL; + char **tralp = NULL; + int duped1 = -1; int rval; int i; /* global program name */ progname = argv[0] = fixargv0(argv[0]); + /* feature check only? */ + strcat(RFeatureList, RTRACE_FEATURES); + if (argc > 1 && !strcmp(argv[1], "-features")) + return feature_status(argc-2, argv+2); + /* add trace notify function */ + for (i = 0; addobjnotify[i] != NULL; i++) + ; + addobjnotify[i] = tranotify; /* option city */ for (i = 1; i < argc; i++) { /* expand arguments */ @@ -160,6 +135,12 @@ char *argv[]; continue; } switch (argv[i][1]) { + case 'n': /* number of cores */ + check(2,"i"); + nproc = atoi(argv[++i]); + if (nproc <= 0) + error(USER, "bad number of processes"); + break; case 'x': /* x resolution */ check(2,"i"); hresolu = atoi(argv[++i]); @@ -170,7 +151,7 @@ char *argv[]; break; case 'w': /* warnings */ rval = erract[WARNING].pf != NULL; - bool(2,rval); + check_bool(2,rval); if (rval) erract[WARNING].pf = wputs; else erract[WARNING].pf = NULL; break; @@ -181,10 +162,10 @@ char *argv[]; case 'l': /* limit distance */ if (argv[i][2] != 'd') goto badopt; - bool(3,lim_dist); + check_bool(3,lim_dist); break; case 'I': /* immed. irradiance */ - bool(2,imm_irrad); + check_bool(2,imm_irrad); break; case 'f': /* format i/o */ switch (argv[i][2]) { @@ -216,7 +197,7 @@ char *argv[]; break; case 'h': /* header output */ rval = loadflags & IO_INFO; - bool(2,rval); + check_bool(2,rval); loadflags = rval ? loadflags | IO_INFO : loadflags & ~IO_INFO; break; @@ -230,8 +211,8 @@ char *argv[]; tralp = tralist; } if (argv[i][2] == 'I') { /* file */ - rval = wordfile(tralp, - getpath(argv[++i],getlibpath(),R_OK)); + rval = wordfile(tralp, MAXMODLIST-(tralp-tralist), + getpath(argv[++i],getrlibpath(),R_OK)); if (rval < 0) { sprintf(errmsg, "cannot open trace include file \"%s\"", @@ -252,8 +233,8 @@ char *argv[]; tralp = tralist; } if (argv[i][2] == 'E') { /* file */ - rval = wordfile(tralp, - getpath(argv[++i],getlibpath(),R_OK)); + rval = wordfile(tralp, MAXMODLIST-(tralp-tralist), + getpath(argv[++i],getrlibpath(),R_OK)); if (rval < 0) { sprintf(errmsg, "cannot open trace exclude file \"%s\"", @@ -286,16 +267,30 @@ char *argv[]; goto badopt; } } + if (nproc > 1 && persist) + error(USER, "multiprocessing incompatible with persist file"); /* initialize object types */ initotypes(); /* initialize urand */ - initurand(2048); + if (rand_samp) { + srandom((long)time(0)); + initurand(0); + } else { + srandom(0L); + initurand(2048); + } /* set up signal handling */ sigdie(SIGINT, "Interrupt"); +#ifdef SIGHUP sigdie(SIGHUP, "Hangup"); +#endif sigdie(SIGTERM, "Terminate"); +#ifdef SIGPIPE sigdie(SIGPIPE, "Broken pipe"); +#endif +#ifdef SIGALRM sigdie(SIGALRM, "Alarm clock"); +#endif #ifdef SIGXCPU sigdie(SIGXCPU, "CPU limit exceeded"); sigdie(SIGXFSZ, "File size exceeded"); @@ -315,12 +310,12 @@ char *argv[]; #endif /* get octree */ if (i == argc) - octname = NULL; + octnm = NULL; else if (i == argc-1) - octname = argv[i]; + octnm = argv[i]; else goto badopt; - if (octname == NULL) + if (octnm == NULL) error(USER, "missing octree argument"); /* set up output */ #ifdef PERSIST @@ -329,12 +324,10 @@ char *argv[]; openheader(); } #endif -#ifdef MSDOS if (outform != 'a') - setmode(fileno(stdout), O_BINARY); - if (octname == NULL) - setmode(fileno(stdin), O_BINARY); -#endif + SET_FILE_BINARY(stdout); + rval = setrtoutput(); + octname = savqstr(octnm); readoct(octname, loadflags, &thescene, NULL); nsceneobjs = nobjects; @@ -342,17 +335,28 @@ char *argv[]; printargs(i, argv, stdout); printf("SOFTWARE= %s\n", VersionID); fputnow(stdout); + if (rval > 0) /* saved from setrtoutput() call */ + printf("NCOMP=%d\n", rval); + if ((outform == 'f') | (outform == 'd')) + fputendian(stdout); fputformat(formstr(outform), stdout); putchar('\n'); } - marksources(); /* find and mark sources */ + if (!castonly) { /* any actual ray traversal to do? */ - setambient(); /* initialize ambient calculation */ + ray_init_pmap(); /* PMAP: set up & load photon maps */ + + marksources(); /* find and mark sources */ + setambient(); /* initialize ambient calculation */ + } else + distantsources(); /* else mark only distant sources */ + + fflush(stdout); /* in case we're duplicating header */ + #ifdef PERSIST if (persist) { - fflush(stdout); /* reconnect stdout */ dup2(duped1, fileno(stdout)); close(duped1); @@ -363,10 +367,11 @@ char *argv[]; while ((rval=fork()) == 0) { /* keep on forkin' */ pflock(1); pfhold(); + ambsync(); /* load new values */ } if (rval < 0) error(SYSTEM, "cannot fork child for persist function"); - pfdetach(); /* parent exits */ + pfdetach(); /* parent will run then exit */ } } runagain: @@ -374,7 +379,7 @@ runagain: dupheader(); /* send header to stdout */ #endif /* trace rays */ - rtrace(NULL); + rtrace(NULL, nproc); /* flush ambient file */ ambsync(); #ifdef PERSIST @@ -389,26 +394,30 @@ runagain: } } if (persist == PCHILD) { /* wait for a signal then go again */ - close(duped1); /* release output handle */ pfhold(); raynum = nrays = 0; /* reinitialize */ goto runagain; } #endif + + ray_done_pmap(); /* PMAP: free photon maps */ + quit(0); badopt: sprintf(errmsg, "command line error at '%s'", argv[i]); error(USER, errmsg); + return 1; /* pro forma return */ #undef check -#undef bool +#undef check_bool } void -wputs(s) /* warning output function */ -char *s; +wputs( /* warning output function */ + const char *s +) { int lasterrno = errno; eputs(s); @@ -417,8 +426,9 @@ char *s; void -eputs(s) /* put string to stderr */ -register char *s; +eputs( /* put string to stderr */ + const char *s +) { static int midline = 0; @@ -436,17 +446,20 @@ register char *s; } -void -onsig(signo) /* fatal signal */ -int signo; +static void +onsig( /* fatal signal */ + int signo +) { static int gotsig = 0; if (gotsig++) /* two signals and we're gone! */ _exit(signo); +#ifdef SIGALRM alarm(15); /* allow 15 seconds to clean up */ signal(SIGALRM, SIG_DFL); /* make certain we do die */ +#endif eputs("signal - "); eputs(sigerr[signo]); eputs("\n"); @@ -454,10 +467,11 @@ int signo; } -void -sigdie(signo, msg) /* set fatal signal */ -int signo; -char *msg; +static void +sigdie( /* set fatal signal */ + int signo, + char *msg +) { if (signal(signo, onsig) == SIG_IGN) signal(signo, SIG_IGN); @@ -465,26 +479,35 @@ char *msg; } -void -printdefaults() /* print default values to stdout */ +static void +printdefaults(void) /* print default values to stdout */ { - register char *cp; + char *cp; if (imm_irrad) printf("-I+\t\t\t\t# immediate irradiance on\n"); - printf("-x %-9d\t\t\t# x resolution\n", hresolu); - printf("-y %-9d\t\t\t# y resolution\n", vresolu); + printf("-n %-2d\t\t\t\t# number of rendering processes\n", nproc); + printf("-x %-9d\t\t\t# %s\n", hresolu, + vresolu && hresolu ? "x resolution" : "flush interval"); + printf("-y %-9d\t\t\t# y resolution\n", vresolu); printf(lim_dist ? "-ld+\t\t\t\t# limit distance on\n" : "-ld-\t\t\t\t# limit distance off\n"); + printf("-h%c\t\t\t\t# %s header\n", loadflags & IO_INFO ? '+' : '-', + loadflags & IO_INFO ? "output" : "no"); printf("-f%c%c\t\t\t\t# format input/output = %s/%s\n", inform, outform, formstr(inform), formstr(outform)); - printf("-o%s\t\t\t\t# output", outvals); + printf("-o%-9s\t\t\t# output", outvals); for (cp = outvals; *cp; cp++) switch (*cp) { - case 't': printf(" trace"); break; + case 't': case 'T': printf(" trace"); break; case 'o': printf(" origin"); break; case 'd': printf(" direction"); break; + case 'r': printf(" reflect_contrib"); break; + case 'R': printf(" reflect_length"); break; + case 'x': printf(" unreflect_contrib"); break; + case 'X': printf(" unreflect_length"); break; case 'v': printf(" value"); break; + case 'V': printf(" contribution"); break; case 'l': printf(" length"); break; case 'L': printf(" first_length"); break; case 'p': printf(" point"); break; @@ -492,7 +515,10 @@ printdefaults() /* print default values to stdout */ case 'N': printf(" unperturbed_normal"); break; case 's': printf(" surface"); break; case 'w': printf(" weight"); break; + case 'W': printf(" coefficient"); break; case 'm': printf(" modifier"); break; + case 'M': printf(" material"); break; + case '~': printf(" tilde"); break; } putchar('\n'); printf(erract[WARNING].pf != NULL ?
