root/radiance/ray/src/rt/rtmain.c
Revision: 2.12
Committed: Wed Jun 15 15:36:52 2005 UTC (20 years, 1 month ago) by greg
CVS Tags: rad3R7P2, rad3R7P1
2 static const char RCSid[] = "$Id: rtmain.c,v 2.11 2005/06/02 04:47:27 greg Exp $";
5 * rtmain.c - main for rtrace per-ray calculation program
6 */
7
8 #include "copyright.h"
9
10 #include <signal.h>
11
12 #include "platform.h"
13 #include "rtprocess.h" /* getpid() */
14 #include "resolu.h"
15 #include "ray.h"
16 #include "source.h"
17 #include "ambient.h"
18 #include "random.h"
19 #include "paths.h"
20
21 /* persistent processes define */
22 #ifdef F_SETLKW
23 #define PERSIST 1 /* normal persist */
24 #define PARALLEL 2 /* parallel persist */
25 #define PCHILD 3 /* child of normal persist */
26 #endif
27
28 char *progname; /* argv[0] */
29 char *octname; /* octree name */
30 char *sigerr[NSIG]; /* signal error messages */
31 char *shm_boundary = NULL; /* boundary of shared memory */
32 char *errfile = NULL; /* error output file */
33
34 extern char *formstr(); /* string from format */
35 extern int inform; /* input format */
36 extern int outform; /* output format */
37 extern char *outvals; /* output values */
38
39 extern int hresolu; /* horizontal resolution */
40 extern int vresolu; /* vertical resolution */
41
42 extern int imm_irrad; /* compute immediate irradiance? */
43 extern int lim_dist; /* limit distance? */
44
45 extern char *tralist[]; /* list of modifers to trace (or no) */
46 extern int traincl; /* include == 1, exclude == 0 */
47
48 static int loadflags = ~IO_FILES; /* what to load from octree */
49
50 static void onsig(int signo);
51 static void sigdie(int signo, char *msg);
52 static void printdefaults(void);
53
54
55 int
56 main(int argc, char *argv[])
57 {
58 #define check(ol,al) if (argv[i][ol] || \
59 badarg(argc-i-1,argv+i+1,al)) \
60 goto badopt
61 #define bool(olen,var) switch (argv[i][olen]) { \
62 case '\0': var = !var; break; \
63 case 'y': case 'Y': case 't': case 'T': \
64 case '+': case '1': var = 1; break; \
65 case 'n': case 'N': case 'f': case 'F': \
66 case '-': case '0': var = 0; break; \
67 default: goto badopt; }
68 int persist = 0;
69 char **tralp;
70 int duped1;
71 int rval;
72 int i;
73 /* global program name */
74 progname = argv[0] = fixargv0(argv[0]);
75 /* option city */
76 for (i = 1; i < argc; i++) {
77 /* expand arguments */
78 while ((rval = expandarg(&argc, &argv, i)) > 0)
79 ;
80 if (rval < 0) {
81 sprintf(errmsg, "cannot expand '%s'", argv[i]);
82 error(SYSTEM, errmsg);
83 }
84 if (argv[i] == NULL || argv[i][0] != '-')
85 break; /* break from options */
86 if (!strcmp(argv[i], "-version")) {
87 puts(VersionID);
88 quit(0);
89 }
90 if (!strcmp(argv[i], "-defaults") ||
91 !strcmp(argv[i], "-help")) {
92 printdefaults();
93 quit(0);
94 }
95 rval = getrenderopt(argc-i, argv+i);
96 if (rval >= 0) {
97 i += rval;
98 continue;
99 }
100 switch (argv[i][1]) {
101 case 'x': /* x resolution */
102 check(2,"i");
103 hresolu = atoi(argv[++i]);
104 break;
105 case 'y': /* y resolution */
106 check(2,"i");
107 vresolu = atoi(argv[++i]);
108 break;
109 case 'w': /* warnings */
110 rval = erract[WARNING].pf != NULL;
111 bool(2,rval);
112 if (rval) erract[WARNING].pf = wputs;
113 else erract[WARNING].pf = NULL;
114 break;
115 case 'e': /* error file */
116 check(2,"s");
117 errfile = argv[++i];
118 break;
119 case 'l': /* limit distance */
120 if (argv[i][2] != 'd')
121 goto badopt;
122 bool(3,lim_dist);
123 break;
124 case 'I': /* immed. irradiance */
125 bool(2,imm_irrad);
126 break;
127 case 'f': /* format i/o */
128 switch (argv[i][2]) {
129 case 'a': /* ascii */
130 case 'f': /* float */
131 case 'd': /* double */
132 inform = argv[i][2];
133 break;
134 default:
135 goto badopt;
136 }
137 switch (argv[i][3]) {
138 case '\0':
139 outform = inform;
140 break;
141 case 'a': /* ascii */
142 case 'f': /* float */
143 case 'd': /* double */
144 case 'c': /* color */
145 check(4,"");
146 outform = argv[i][3];
147 break;
148 default:
149 goto badopt;
150 }
151 break;
152 case 'o': /* output */
153 outvals = argv[i]+2;
154 break;
155 case 'h': /* header output */
156 rval = loadflags & IO_INFO;
157 bool(2,rval);
158 loadflags = rval ? loadflags | IO_INFO :
159 loadflags & ~IO_INFO;
160 break;
161 case 't': /* trace */
162 switch (argv[i][2]) {
163 case 'i': /* include */
164 case 'I':
165 check(3,"s");
166 if (traincl != 1) {
167 traincl = 1;
168 tralp = tralist;
169 }
170 if (argv[i][2] == 'I') { /* file */
171 rval = wordfile(tralp,
172 getpath(argv[++i],getrlibpath(),R_OK));
173 if (rval < 0) {
174 sprintf(errmsg,
175 "cannot open trace include file \"%s\"",
176 argv[i]);
177 error(SYSTEM, errmsg);
178 }
179 tralp += rval;
180 } else {
181 *tralp++ = argv[++i];
182 *tralp = NULL;
183 }
184 break;
185 case 'e': /* exclude */
186 case 'E':
187 check(3,"s");
188 if (traincl != 0) {
189 traincl = 0;
190 tralp = tralist;
191 }
192 if (argv[i][2] == 'E') { /* file */
193 rval = wordfile(tralp,
194 getpath(argv[++i],getrlibpath(),R_OK));
195 if (rval < 0) {
196 sprintf(errmsg,
197 "cannot open trace exclude file \"%s\"",
198 argv[i]);
199 error(SYSTEM, errmsg);
200 }
201 tralp += rval;
202 } else {
203 *tralp++ = argv[++i];
204 *tralp = NULL;
205 }
206 break;
207 default:
208 goto badopt;
209 }
210 break;
211 #ifdef PERSIST
212 case 'P': /* persist file */
213 if (argv[i][2] == 'P') {
214 check(3,"s");
215 persist = PARALLEL;
216 } else {
217 check(2,"s");
218 persist = PERSIST;
219 }
220 persistfile(argv[++i]);
221 break;
222 #endif
223 default:
224 goto badopt;
225 }
226 }
227 /* initialize object types */
228 initotypes();
229 /* initialize urand */
230 initurand(2048);
231 srandom(rand_samp ? (long)time(0) : 0L);
232 /* set up signal handling */
233 sigdie(SIGINT, "Interrupt");
234 #ifdef SIGHUP
235 sigdie(SIGHUP, "Hangup");
236 #endif
237 sigdie(SIGTERM, "Terminate");
238 #ifdef SIGPIPE
239 sigdie(SIGPIPE, "Broken pipe");
240 #endif
241 #ifdef SIGALRM
242 sigdie(SIGALRM, "Alarm clock");
243 #endif
244 #ifdef SIGXCPU
245 sigdie(SIGXCPU, "CPU limit exceeded");
246 sigdie(SIGXFSZ, "File size exceeded");
247 #endif
248 /* open error file */
249 if (errfile != NULL) {
250 if (freopen(errfile, "a", stderr) == NULL)
251 quit(2);
252 fprintf(stderr, "**************\n*** PID %5d: ",
253 getpid());
254 printargs(argc, argv, stderr);
255 putc('\n', stderr);
256 fflush(stderr);
257 }
258 #ifdef NICE
259 nice(NICE); /* lower priority */
260 #endif
261 /* get octree */
262 if (i == argc)
263 octname = NULL;
264 else if (i == argc-1)
265 octname = argv[i];
266 else
267 goto badopt;
268 if (octname == NULL)
269 error(USER, "missing octree argument");
270 /* set up output */
271 #ifdef PERSIST
272 if (persist) {
273 duped1 = dup(fileno(stdout)); /* don't lose our output */
274 openheader();
275 }
276 #endif
277 if (outform != 'a')
278 SET_FILE_BINARY(stdout);
279 readoct(octname, loadflags, &thescene, NULL);
280 nsceneobjs = nobjects;
281
282 if (loadflags & IO_INFO) { /* print header */
283 printargs(i, argv, stdout);
284 printf("SOFTWARE= %s\n", VersionID);
285 fputnow(stdout);
286 fputformat(formstr(outform), stdout);
287 putchar('\n');
288 }
289
290 marksources(); /* find and mark sources */
291
292 setambient(); /* initialize ambient calculation */
293
294 #ifdef PERSIST
295 if (persist) {
296 fflush(stdout);
297 /* reconnect stdout */
298 dup2(duped1, fileno(stdout));
299 close(duped1);
300 if (persist == PARALLEL) { /* multiprocessing */
301 preload_objs(); /* preload scene */
302 shm_boundary = (char *)malloc(16);
303 strcpy(shm_boundary, "SHM_BOUNDARY");
304 while ((rval=fork()) == 0) { /* keep on forkin' */
305 pflock(1);
306 pfhold();
307 }
308 if (rval < 0)
309 error(SYSTEM, "cannot fork child for persist function");
310 pfdetach(); /* parent exits */
311 }
312 }
313 runagain:
314 if (persist)
315 dupheader(); /* send header to stdout */
316 #endif
317 /* trace rays */
318 rtrace(NULL);
319 /* flush ambient file */
320 ambsync();
321 #ifdef PERSIST
322 if (persist == PERSIST) { /* first run-through */
323 if ((rval=fork()) == 0) { /* child loops until killed */
324 pflock(1);
325 persist = PCHILD;
326 } else { /* original process exits */
327 if (rval < 0)
328 error(SYSTEM, "cannot fork child for persist function");
329 pfdetach(); /* parent exits */
330 }
331 }
332 if (persist == PCHILD) { /* wait for a signal then go again */
333 close(duped1); /* release output handle */
334 pfhold();
335 raynum = nrays = 0; /* reinitialize */
336 goto runagain;
337 }
338 #endif
339 quit(0);
340
341 badopt:
342 sprintf(errmsg, "command line error at '%s'", argv[i]);
343 error(USER, errmsg);
344 return 1; /* pro forma return */
345
346 #undef check
347 #undef bool
348 }
349
350
351 void
352 wputs( /* warning output function */
353 char *s
354 )
355 {
356 int lasterrno = errno;
357 eputs(s);
358 errno = lasterrno;
359 }
360
361
362 void
363 eputs( /* put string to stderr */
364 register char *s
365 )
366 {
367 static int midline = 0;
368
369 if (!*s)
370 return;
371 if (!midline++) {
372 fputs(progname, stderr);
373 fputs(": ", stderr);
374 }
375 fputs(s, stderr);
376 if (s[strlen(s)-1] == '\n') {
377 fflush(stderr);
378 midline = 0;
379 }
380 }
381
382
383 static void
384 onsig( /* fatal signal */
385 int signo
386 )
387 {
388 static int gotsig = 0;
389
390 if (gotsig++) /* two signals and we're gone! */
391 _exit(signo);
392
393 #ifdef SIGALRM
394 alarm(15); /* allow 15 seconds to clean up */
395 signal(SIGALRM, SIG_DFL); /* make certain we do die */
396 #endif
397 eputs("signal - ");
398 eputs(sigerr[signo]);
399 eputs("\n");
400 quit(3);
401 }
402
403
404 static void
405 sigdie( /* set fatal signal */
406 int signo,
407 char *msg
408 )
409 {
410 if (signal(signo, onsig) == SIG_IGN)
411 signal(signo, SIG_IGN);
412 sigerr[signo] = msg;
413 }
414
415
416 static void
417 printdefaults(void) /* print default values to stdout */
418 {
419 register char *cp;
420
421 if (imm_irrad)
422 printf("-I+\t\t\t\t# immediate irradiance on\n");
423 printf("-x %-9d\t\t\t# x resolution (flush interval)\n", hresolu);
424 printf("-y %-9d\t\t\t# y resolution\n", vresolu);
425 printf(lim_dist ? "-ld+\t\t\t\t# limit distance on\n" :
426 "-ld-\t\t\t\t# limit distance off\n");
427 printf("-h%c\t\t\t\t# %s header\n", loadflags & IO_INFO ? '+' : '-',
428 loadflags & IO_INFO ? "output" : "no");
429 printf("-f%c%c\t\t\t\t# format input/output = %s/%s\n",
430 inform, outform, formstr(inform), formstr(outform));
431 printf("-o%-9s\t\t\t# output", outvals);
432 for (cp = outvals; *cp; cp++)
433 switch (*cp) {
434 case 't': case 'T': printf(" trace"); break;
435 case 'o': printf(" origin"); break;
436 case 'd': printf(" direction"); break;
437 case 'v': printf(" value"); break;
438 case 'l': printf(" length"); break;
439 case 'L': printf(" first_length"); break;
440 case 'p': printf(" point"); break;
441 case 'n': printf(" normal"); break;
442 case 'N': printf(" unperturbed_normal"); break;
443 case 's': printf(" surface"); break;
444 case 'w': printf(" weight"); break;
445 case 'm': printf(" modifier"); break;
446 case 'M': printf(" material"); break;
447 case 'W': printf(" contribution"); break;
448 case '-': printf(" stroke"); break;
449 }
450 putchar('\n');
451 printf(erract[WARNING].pf != NULL ?
452 "-w+\t\t\t\t# warning messages on\n" :
453 "-w-\t\t\t\t# warning messages off\n");
454 print_rdefaults();
455 }
