root/Development/ray/src/rt/rtmain.c
Revision: 2.46
Committed: Tue Aug 15 01:19:37 2023 UTC (2 years, 4 months ago) by greg
Changes since 2.45: +3 -1 lines
fix(rcontrib): Removed participating media from rcontrib -features
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.46 static const char RCSid[] = "$Id: rtmain.c,v 2.45 2023/08/15 00:46:56 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * rtmain.c - main for rtrace per-ray calculation program
6     */
7
8 greg 2.2 #include "copyright.h"
9 greg 2.1
10 schorsch 2.4 #include <signal.h>
11
12     #include "platform.h"
13 schorsch 2.7 #include "rtprocess.h" /* getpid() */
14 schorsch 2.9 #include "resolu.h"
15 greg 2.1 #include "ray.h"
16     #include "source.h"
17     #include "ambient.h"
18     #include "random.h"
19     #include "paths.h"
20 greg 2.23 #include "pmapray.h"
21 greg 2.1
22 greg 2.18 extern char *progname; /* global argv[0] */
23
24     extern char *shm_boundary; /* boundary of shared memory */
25
26 greg 2.1 /* persistent processes define */
27     #ifdef F_SETLKW
28     #define PERSIST 1 /* normal persist */
29     #define PARALLEL 2 /* parallel persist */
30     #define PCHILD 3 /* child of normal persist */
31     #endif
32
33     char *sigerr[NSIG]; /* signal error messages */
34     char *errfile = NULL; /* error output file */
35
36 greg 2.18 int nproc = 1; /* number of processes */
37
38 greg 2.31 extern int setrtoutput(void); /* set output values */
39 greg 2.32
40 greg 2.18 int inform = 'a'; /* input format */
41     int outform = 'a'; /* output format */
42     char *outvals = "v"; /* output specification */
43 greg 2.1
44 greg 2.18 int hresolu = 0; /* horizontal (scan) size */
45     int vresolu = 0; /* vertical resolution */
46 greg 2.1
47 greg 2.33 extern int castonly; /* only doing ray-casting? */
48 greg 2.32
49 greg 2.18 int imm_irrad = 0; /* compute immediate irradiance? */
50     int lim_dist = 0; /* limit distance? */
51
52     #ifndef MAXMODLIST
53     #define MAXMODLIST 1024 /* maximum modifiers we'll track */
54     #endif
55 greg 2.1
56 greg 2.18 extern void (*addobjnotify[])(); /* object notification calls */
57     extern void tranotify(OBJECT obj);
58
59     char *tralist[MAXMODLIST]; /* list of modifers to trace (or no) */
60     int traincl = -1; /* include == 1, exclude == 0 */
61 greg 2.1
62 greg 2.10 static int loadflags = ~IO_FILES; /* what to load from octree */
63
64 schorsch 2.9 static void onsig(int signo);
65     static void sigdie(int signo, char *msg);
66     static void printdefaults(void);
67 greg 2.1
68 greg 2.38 #ifdef PERSIST
69 greg 2.45 #define RTRACE_FEATURES "Persist\nParallelPersist\nMultiprocessing\n" \
70 greg 2.38 "IrradianceCalc\nImmediateIrradiance\nDistanceLimiting\n" \
71 greg 2.46 "ParticipatingMedia=Mist\n" \
72 greg 2.39 "HessianAmbientCache\nAmbientAveraging\n" \
73 greg 2.40 "AmbientValueSharing\nAdaptiveShadowTesting\n" \
74 greg 2.45 "InputFormats=a,f,d\nOutputFormats=a,f,d,c\n" \
75 greg 2.40 "Outputs=o,d,v,V,w,W,l,L,c,p,n,N,s,m,M,r,x,R,X,~\n"
76 greg 2.38 #else
77     #define RTRACE_FEATURES "IrradianceCalc\nIrradianceCalc\nDistanceLimiting\n" \
78 greg 2.46 "ParticipatingMedia=Mist\n" \
79 greg 2.39 "HessianAmbientCache\nAmbientAveraging\n" \
80 greg 2.40 "AmbientValueSharing\nAdaptiveShadowTesting\n" \
81 greg 2.45 "InputFormats=a,f,d\nOutputFormats=a,f,d,c\n" \
82 greg 2.40 "Outputs=o,d,v,V,w,W,l,L,c,p,n,N,s,m,M,r,x,R,X,~\n"
83 greg 2.38 #endif
84
85 greg 2.1
86     int
87 schorsch 2.9 main(int argc, char *argv[])
88 greg 2.1 {
89     #define check(ol,al) if (argv[i][ol] || \
90     badarg(argc-i-1,argv+i+1,al)) \
91     goto badopt
92 schorsch 2.26 #define check_bool(olen,var) switch (argv[i][olen]) { \
93 greg 2.1 case '\0': var = !var; break; \
94     case 'y': case 'Y': case 't': case 'T': \
95     case '+': case '1': var = 1; break; \
96     case 'n': case 'N': case 'f': case 'F': \
97     case '-': case '0': var = 0; break; \
98     default: goto badopt; }
99 greg 2.25 extern char *octname;
100 greg 2.1 int persist = 0;
101 greg 2.18 char *octnm = NULL;
102 greg 2.22 char **tralp = NULL;
103     int duped1 = -1;
104 greg 2.1 int rval;
105     int i;
106     /* global program name */
107     progname = argv[0] = fixargv0(argv[0]);
108 greg 2.38 /* feature check only? */
109     strcat(RFeatureList, RTRACE_FEATURES);
110 greg 2.43 if (argc > 1 && !strcmp(argv[1], "-features"))
111 greg 2.38 return feature_status(argc-2, argv+2);
112 greg 2.18 /* add trace notify function */
113     for (i = 0; addobjnotify[i] != NULL; i++)
114     ;
115     addobjnotify[i] = tranotify;
116 greg 2.1 /* option city */
117     for (i = 1; i < argc; i++) {
118     /* expand arguments */
119     while ((rval = expandarg(&argc, &argv, i)) > 0)
120     ;
121     if (rval < 0) {
122     sprintf(errmsg, "cannot expand '%s'", argv[i]);
123     error(SYSTEM, errmsg);
124     }
125     if (argv[i] == NULL || argv[i][0] != '-')
126     break; /* break from options */
127     if (!strcmp(argv[i], "-version")) {
128     puts(VersionID);
129     quit(0);
130     }
131     if (!strcmp(argv[i], "-defaults") ||
132     !strcmp(argv[i], "-help")) {
133     printdefaults();
134     quit(0);
135     }
136     rval = getrenderopt(argc-i, argv+i);
137     if (rval >= 0) {
138     i += rval;
139     continue;
140     }
141     switch (argv[i][1]) {
142 greg 2.18 case 'n': /* number of cores */
143     check(2,"i");
144     nproc = atoi(argv[++i]);
145     if (nproc <= 0)
146     error(USER, "bad number of processes");
147     break;
148 greg 2.1 case 'x': /* x resolution */
149     check(2,"i");
150     hresolu = atoi(argv[++i]);
151     break;
152     case 'y': /* y resolution */
153     check(2,"i");
154     vresolu = atoi(argv[++i]);
155     break;
156     case 'w': /* warnings */
157     rval = erract[WARNING].pf != NULL;
158 schorsch 2.26 check_bool(2,rval);
159 greg 2.1 if (rval) erract[WARNING].pf = wputs;
160     else erract[WARNING].pf = NULL;
161     break;
162     case 'e': /* error file */
163     check(2,"s");
164     errfile = argv[++i];
165     break;
166     case 'l': /* limit distance */
167     if (argv[i][2] != 'd')
168     goto badopt;
169 schorsch 2.26 check_bool(3,lim_dist);
170 greg 2.1 break;
171     case 'I': /* immed. irradiance */
172 schorsch 2.26 check_bool(2,imm_irrad);
173 greg 2.1 break;
174     case 'f': /* format i/o */
175     switch (argv[i][2]) {
176     case 'a': /* ascii */
177     case 'f': /* float */
178     case 'd': /* double */
179     inform = argv[i][2];
180     break;
181     default:
182     goto badopt;
183     }
184     switch (argv[i][3]) {
185     case '\0':
186     outform = inform;
187     break;
188     case 'a': /* ascii */
189     case 'f': /* float */
190     case 'd': /* double */
191     case 'c': /* color */
192     check(4,"");
193     outform = argv[i][3];
194     break;
195     default:
196     goto badopt;
197     }
198     break;
199     case 'o': /* output */
200     outvals = argv[i]+2;
201     break;
202     case 'h': /* header output */
203     rval = loadflags & IO_INFO;
204 schorsch 2.26 check_bool(2,rval);
205 greg 2.1 loadflags = rval ? loadflags | IO_INFO :
206     loadflags & ~IO_INFO;
207     break;
208     case 't': /* trace */
209     switch (argv[i][2]) {
210     case 'i': /* include */
211     case 'I':
212     check(3,"s");
213     if (traincl != 1) {
214     traincl = 1;
215     tralp = tralist;
216     }
217     if (argv[i][2] == 'I') { /* file */
218 greg 2.27 rval = wordfile(tralp, MAXMODLIST-(tralp-tralist),
219 greg 2.3 getpath(argv[++i],getrlibpath(),R_OK));
220 greg 2.1 if (rval < 0) {
221     sprintf(errmsg,
222     "cannot open trace include file \"%s\"",
223     argv[i]);
224     error(SYSTEM, errmsg);
225     }
226     tralp += rval;
227     } else {
228     *tralp++ = argv[++i];
229     *tralp = NULL;
230     }
231     break;
232     case 'e': /* exclude */
233     case 'E':
234     check(3,"s");
235     if (traincl != 0) {
236     traincl = 0;
237     tralp = tralist;
238     }
239     if (argv[i][2] == 'E') { /* file */
240 greg 2.27 rval = wordfile(tralp, MAXMODLIST-(tralp-tralist),
241 greg 2.3 getpath(argv[++i],getrlibpath(),R_OK));
242 greg 2.1 if (rval < 0) {
243     sprintf(errmsg,
244     "cannot open trace exclude file \"%s\"",
245     argv[i]);
246     error(SYSTEM, errmsg);
247     }
248     tralp += rval;
249     } else {
250     *tralp++ = argv[++i];
251     *tralp = NULL;
252     }
253     break;
254     default:
255     goto badopt;
256     }
257     break;
258     #ifdef PERSIST
259     case 'P': /* persist file */
260     if (argv[i][2] == 'P') {
261     check(3,"s");
262     persist = PARALLEL;
263     } else {
264     check(2,"s");
265     persist = PERSIST;
266     }
267     persistfile(argv[++i]);
268     break;
269     #endif
270     default:
271     goto badopt;
272     }
273     }
274 greg 2.34 if (nproc > 1 && persist)
275     error(USER, "multiprocessing incompatible with persist file");
276 greg 2.1 /* initialize object types */
277     initotypes();
278     /* initialize urand */
279 greg 2.14 if (rand_samp) {
280     srandom((long)time(0));
281     initurand(0);
282     } else {
283     srandom(0L);
284     initurand(2048);
285     }
286 greg 2.1 /* set up signal handling */
287     sigdie(SIGINT, "Interrupt");
288 schorsch 2.5 #ifdef SIGHUP
289 greg 2.1 sigdie(SIGHUP, "Hangup");
290 schorsch 2.5 #endif
291 greg 2.1 sigdie(SIGTERM, "Terminate");
292 schorsch 2.5 #ifdef SIGPIPE
293 greg 2.1 sigdie(SIGPIPE, "Broken pipe");
294 schorsch 2.5 #endif
295     #ifdef SIGALRM
296 greg 2.1 sigdie(SIGALRM, "Alarm clock");
297 schorsch 2.5 #endif
298 greg 2.1 #ifdef SIGXCPU
299     sigdie(SIGXCPU, "CPU limit exceeded");
300     sigdie(SIGXFSZ, "File size exceeded");
301     #endif
302     /* open error file */
303     if (errfile != NULL) {
304     if (freopen(errfile, "a", stderr) == NULL)
305     quit(2);
306     fprintf(stderr, "**************\n*** PID %5d: ",
307     getpid());
308     printargs(argc, argv, stderr);
309     putc('\n', stderr);
310     fflush(stderr);
311     }
312     #ifdef NICE
313     nice(NICE); /* lower priority */
314     #endif
315     /* get octree */
316     if (i == argc)
317 greg 2.18 octnm = NULL;
318 greg 2.1 else if (i == argc-1)
319 greg 2.18 octnm = argv[i];
320 greg 2.1 else
321     goto badopt;
322 greg 2.18 if (octnm == NULL)
323 greg 2.1 error(USER, "missing octree argument");
324     /* set up output */
325     #ifdef PERSIST
326     if (persist) {
327     duped1 = dup(fileno(stdout)); /* don't lose our output */
328     openheader();
329     }
330     #endif
331     if (outform != 'a')
332 schorsch 2.4 SET_FILE_BINARY(stdout);
333 greg 2.31 rval = setrtoutput();
334 greg 2.41 octname = savqstr(octnm);
335     readoct(octname, loadflags, &thescene, NULL);
336 greg 2.1 nsceneobjs = nobjects;
337
338     if (loadflags & IO_INFO) { /* print header */
339     printargs(i, argv, stdout);
340     printf("SOFTWARE= %s\n", VersionID);
341     fputnow(stdout);
342 greg 2.31 if (rval > 0) /* saved from setrtoutput() call */
343     printf("NCOMP=%d\n", rval);
344 greg 2.30 if ((outform == 'f') | (outform == 'd'))
345     fputendian(stdout);
346 greg 2.1 fputformat(formstr(outform), stdout);
347     putchar('\n');
348     }
349
350 greg 2.32 if (!castonly) { /* any actual ray traversal to do? */
351
352     ray_init_pmap(); /* PMAP: set up & load photon maps */
353
354     marksources(); /* find and mark sources */
355
356     setambient(); /* initialize ambient calculation */
357 greg 2.33 } else
358     distantsources(); /* else mark only distant sources */
359 greg 2.35
360 greg 2.36 fflush(stdout); /* in case we're duplicating header */
361 greg 2.35
362 greg 2.1 #ifdef PERSIST
363     if (persist) {
364     /* reconnect stdout */
365     dup2(duped1, fileno(stdout));
366     close(duped1);
367     if (persist == PARALLEL) { /* multiprocessing */
368     preload_objs(); /* preload scene */
369     shm_boundary = (char *)malloc(16);
370     strcpy(shm_boundary, "SHM_BOUNDARY");
371     while ((rval=fork()) == 0) { /* keep on forkin' */
372     pflock(1);
373     pfhold();
374 greg 2.15 ambsync(); /* load new values */
375 greg 2.1 }
376     if (rval < 0)
377     error(SYSTEM, "cannot fork child for persist function");
378 greg 2.15 pfdetach(); /* parent will run then exit */
379 greg 2.1 }
380     }
381     runagain:
382     if (persist)
383     dupheader(); /* send header to stdout */
384     #endif
385     /* trace rays */
386 greg 2.19 rtrace(NULL, nproc);
387 greg 2.1 /* flush ambient file */
388     ambsync();
389     #ifdef PERSIST
390     if (persist == PERSIST) { /* first run-through */
391     if ((rval=fork()) == 0) { /* child loops until killed */
392     pflock(1);
393     persist = PCHILD;
394     } else { /* original process exits */
395     if (rval < 0)
396     error(SYSTEM, "cannot fork child for persist function");
397     pfdetach(); /* parent exits */
398     }
399     }
400     if (persist == PCHILD) { /* wait for a signal then go again */
401     pfhold();
402     raynum = nrays = 0; /* reinitialize */
403     goto runagain;
404     }
405     #endif
406 greg 2.23
407     ray_done_pmap(); /* PMAP: free photon maps */
408
409 greg 2.1 quit(0);
410
411     badopt:
412     sprintf(errmsg, "command line error at '%s'", argv[i]);
413     error(USER, errmsg);
414 schorsch 2.9 return 1; /* pro forma return */
415 greg 2.1
416     #undef check
417 schorsch 2.26 #undef check_bool
418 greg 2.1 }
419
420
421     void
422 schorsch 2.9 wputs( /* warning output function */
423 greg 2.44 const char *s
424 schorsch 2.9 )
425 greg 2.1 {
426     int lasterrno = errno;
427     eputs(s);
428     errno = lasterrno;
429     }
430
431
432     void
433 schorsch 2.9 eputs( /* put string to stderr */
434 greg 2.44 const char *s
435 schorsch 2.9 )
436 greg 2.1 {
437     static int midline = 0;
438
439     if (!*s)
440     return;
441     if (!midline++) {
442     fputs(progname, stderr);
443     fputs(": ", stderr);
444     }
445     fputs(s, stderr);
446     if (s[strlen(s)-1] == '\n') {
447     fflush(stderr);
448     midline = 0;
449     }
450     }
451
452
453 schorsch 2.9 static void
454     onsig( /* fatal signal */
455     int signo
456     )
457 greg 2.1 {
458     static int gotsig = 0;
459
460     if (gotsig++) /* two signals and we're gone! */
461     _exit(signo);
462
463 schorsch 2.5 #ifdef SIGALRM
464 greg 2.1 alarm(15); /* allow 15 seconds to clean up */
465     signal(SIGALRM, SIG_DFL); /* make certain we do die */
466 schorsch 2.5 #endif
467 greg 2.1 eputs("signal - ");
468     eputs(sigerr[signo]);
469     eputs("\n");
470     quit(3);
471     }
472
473
474 schorsch 2.9 static void
475     sigdie( /* set fatal signal */
476     int signo,
477     char *msg
478     )
479 greg 2.1 {
480     if (signal(signo, onsig) == SIG_IGN)
481     signal(signo, SIG_IGN);
482     sigerr[signo] = msg;
483     }
484
485
486 schorsch 2.9 static void
487 schorsch 2.8 printdefaults(void) /* print default values to stdout */
488 greg 2.1 {
489 greg 2.38 char *cp;
490 greg 2.1
491     if (imm_irrad)
492     printf("-I+\t\t\t\t# immediate irradiance on\n");
493 greg 2.18 printf("-n %-2d\t\t\t\t# number of rendering processes\n", nproc);
494 greg 2.21 printf("-x %-9d\t\t\t# %s\n", hresolu,
495     vresolu && hresolu ? "x resolution" : "flush interval");
496 greg 2.16 printf("-y %-9d\t\t\t# y resolution\n", vresolu);
497 greg 2.1 printf(lim_dist ? "-ld+\t\t\t\t# limit distance on\n" :
498     "-ld-\t\t\t\t# limit distance off\n");
499 greg 2.10 printf("-h%c\t\t\t\t# %s header\n", loadflags & IO_INFO ? '+' : '-',
500     loadflags & IO_INFO ? "output" : "no");
501 greg 2.1 printf("-f%c%c\t\t\t\t# format input/output = %s/%s\n",
502     inform, outform, formstr(inform), formstr(outform));
503 greg 2.10 printf("-o%-9s\t\t\t# output", outvals);
504 greg 2.1 for (cp = outvals; *cp; cp++)
505     switch (*cp) {
506 greg 2.10 case 't': case 'T': printf(" trace"); break;
507 greg 2.1 case 'o': printf(" origin"); break;
508     case 'd': printf(" direction"); break;
509 greg 2.28 case 'r': printf(" reflect_contrib"); break;
510     case 'R': printf(" reflect_length"); break;
511     case 'x': printf(" unreflect_contrib"); break;
512     case 'X': printf(" unreflect_length"); break;
513 greg 2.1 case 'v': printf(" value"); break;
514 greg 2.13 case 'V': printf(" contribution"); break;
515 greg 2.1 case 'l': printf(" length"); break;
516     case 'L': printf(" first_length"); break;
517     case 'p': printf(" point"); break;
518     case 'n': printf(" normal"); break;
519     case 'N': printf(" unperturbed_normal"); break;
520     case 's': printf(" surface"); break;
521     case 'w': printf(" weight"); break;
522 greg 2.13 case 'W': printf(" coefficient"); break;
523 greg 2.1 case 'm': printf(" modifier"); break;
524 greg 2.10 case 'M': printf(" material"); break;
525 greg 2.37 case '~': printf(" tilde"); break;
526 greg 2.1 }
527     putchar('\n');
528     printf(erract[WARNING].pf != NULL ?
529     "-w+\t\t\t\t# warning messages on\n" :
530     "-w-\t\t\t\t# warning messages off\n");
531     print_rdefaults();
532     }
