root/Development/ray/src/rt/rtmain.c
Revision: 2.27
Committed: Mon Mar 21 19:06:08 2016 UTC (9 years, 9 months ago) by greg
CVS Tags: rad5R2, rad5R1
Changes since 2.26: +3 -3 lines
2 static const char RCSid[] = "$Id: rtmain.c,v 2.26 2016/03/10 18:25:46 schorsch Exp $";
5 * rtmain.c - main for rtrace per-ray calculation program
6 */
7
8 #include "copyright.h"
9
10 #include <signal.h>
11
12 #include "platform.h"
13 #include "rtprocess.h" /* getpid() */
14 #include "resolu.h"
15 #include "ray.h"
16 #include "source.h"
17 #include "ambient.h"
18 #include "random.h"
19 #include "paths.h"
20 #include "pmapray.h"
21
22 extern char *progname; /* global argv[0] */
23
24 extern char *shm_boundary; /* boundary of shared memory */
25
26 /* persistent processes define */
27 #ifdef F_SETLKW
28 #define PERSIST 1 /* normal persist */
29 #define PARALLEL 2 /* parallel persist */
30 #define PCHILD 3 /* child of normal persist */
31 #endif
32
33 char *sigerr[NSIG]; /* signal error messages */
34 char *errfile = NULL; /* error output file */
35
36 int nproc = 1; /* number of processes */
37
38 extern char *formstr(); /* string from format */
39 int inform = 'a'; /* input format */
40 int outform = 'a'; /* output format */
41 char *outvals = "v"; /* output specification */
42
43 int hresolu = 0; /* horizontal (scan) size */
44 int vresolu = 0; /* vertical resolution */
45
46 int imm_irrad = 0; /* compute immediate irradiance? */
47 int lim_dist = 0; /* limit distance? */
48
49 #ifndef MAXMODLIST
50 #define MAXMODLIST 1024 /* maximum modifiers we'll track */
51 #endif
52
53 extern void (*addobjnotify[])(); /* object notification calls */
54 extern void tranotify(OBJECT obj);
55
56 char *tralist[MAXMODLIST]; /* list of modifers to trace (or no) */
57 int traincl = -1; /* include == 1, exclude == 0 */
58
59 static int loadflags = ~IO_FILES; /* what to load from octree */
60
61 static void onsig(int signo);
62 static void sigdie(int signo, char *msg);
63 static void printdefaults(void);
64
65
66 int
67 main(int argc, char *argv[])
68 {
69 #define check(ol,al) if (argv[i][ol] || \
70 badarg(argc-i-1,argv+i+1,al)) \
71 goto badopt
72 #define check_bool(olen,var) switch (argv[i][olen]) { \
73 case '\0': var = !var; break; \
74 case 'y': case 'Y': case 't': case 'T': \
75 case '+': case '1': var = 1; break; \
76 case 'n': case 'N': case 'f': case 'F': \
77 case '-': case '0': var = 0; break; \
78 default: goto badopt; }
79 extern char *octname;
80 int persist = 0;
81 char *octnm = NULL;
82 char **tralp = NULL;
83 int duped1 = -1;
84 int rval;
85 int i;
86 /* global program name */
87 progname = argv[0] = fixargv0(argv[0]);
88 /* add trace notify function */
89 for (i = 0; addobjnotify[i] != NULL; i++)
90 ;
91 addobjnotify[i] = tranotify;
92 /* set our defaults */
93 rand_samp = 1;
94 maxdepth = -10;
95 minweight = 2e-3;
96 /* option city */
97 for (i = 1; i < argc; i++) {
98 /* expand arguments */
99 while ((rval = expandarg(&argc, &argv, i)) > 0)
100 ;
101 if (rval < 0) {
102 sprintf(errmsg, "cannot expand '%s'", argv[i]);
103 error(SYSTEM, errmsg);
104 }
105 if (argv[i] == NULL || argv[i][0] != '-')
106 break; /* break from options */
107 if (!strcmp(argv[i], "-version")) {
108 puts(VersionID);
109 quit(0);
110 }
111 if (!strcmp(argv[i], "-defaults") ||
112 !strcmp(argv[i], "-help")) {
113 printdefaults();
114 quit(0);
115 }
116 rval = getrenderopt(argc-i, argv+i);
117 if (rval >= 0) {
118 i += rval;
119 continue;
120 }
121 switch (argv[i][1]) {
122 case 'n': /* number of cores */
123 check(2,"i");
124 nproc = atoi(argv[++i]);
125 if (nproc <= 0)
126 error(USER, "bad number of processes");
127 break;
128 case 'x': /* x resolution */
129 check(2,"i");
130 hresolu = atoi(argv[++i]);
131 break;
132 case 'y': /* y resolution */
133 check(2,"i");
134 vresolu = atoi(argv[++i]);
135 break;
136 case 'w': /* warnings */
137 rval = erract[WARNING].pf != NULL;
138 check_bool(2,rval);
139 if (rval) erract[WARNING].pf = wputs;
140 else erract[WARNING].pf = NULL;
141 break;
142 case 'e': /* error file */
143 check(2,"s");
144 errfile = argv[++i];
145 break;
146 case 'l': /* limit distance */
147 if (argv[i][2] != 'd')
148 goto badopt;
149 check_bool(3,lim_dist);
150 break;
151 case 'I': /* immed. irradiance */
152 check_bool(2,imm_irrad);
153 break;
154 case 'f': /* format i/o */
155 switch (argv[i][2]) {
156 case 'a': /* ascii */
157 case 'f': /* float */
158 case 'd': /* double */
159 inform = argv[i][2];
160 break;
161 default:
162 goto badopt;
163 }
164 switch (argv[i][3]) {
165 case '\0':
166 outform = inform;
167 break;
168 case 'a': /* ascii */
169 case 'f': /* float */
170 case 'd': /* double */
171 case 'c': /* color */
172 check(4,"");
173 outform = argv[i][3];
174 break;
175 default:
176 goto badopt;
177 }
178 break;
179 case 'o': /* output */
180 outvals = argv[i]+2;
181 break;
182 case 'h': /* header output */
183 rval = loadflags & IO_INFO;
184 check_bool(2,rval);
185 loadflags = rval ? loadflags | IO_INFO :
186 loadflags & ~IO_INFO;
187 break;
188 case 't': /* trace */
189 switch (argv[i][2]) {
190 case 'i': /* include */
191 case 'I':
192 check(3,"s");
193 if (traincl != 1) {
194 traincl = 1;
195 tralp = tralist;
196 }
197 if (argv[i][2] == 'I') { /* file */
198 rval = wordfile(tralp, MAXMODLIST-(tralp-tralist),
199 getpath(argv[++i],getrlibpath(),R_OK));
200 if (rval < 0) {
201 sprintf(errmsg,
202 "cannot open trace include file \"%s\"",
203 argv[i]);
204 error(SYSTEM, errmsg);
205 }
206 tralp += rval;
207 } else {
208 *tralp++ = argv[++i];
209 *tralp = NULL;
210 }
211 break;
212 case 'e': /* exclude */
213 case 'E':
214 check(3,"s");
215 if (traincl != 0) {
216 traincl = 0;
217 tralp = tralist;
218 }
219 if (argv[i][2] == 'E') { /* file */
220 rval = wordfile(tralp, MAXMODLIST-(tralp-tralist),
221 getpath(argv[++i],getrlibpath(),R_OK));
222 if (rval < 0) {
223 sprintf(errmsg,
224 "cannot open trace exclude file \"%s\"",
225 argv[i]);
226 error(SYSTEM, errmsg);
227 }
228 tralp += rval;
229 } else {
230 *tralp++ = argv[++i];
231 *tralp = NULL;
232 }
233 break;
234 default:
235 goto badopt;
236 }
237 break;
238 #ifdef PERSIST
239 case 'P': /* persist file */
240 if (argv[i][2] == 'P') {
241 check(3,"s");
242 persist = PARALLEL;
243 } else {
244 check(2,"s");
245 persist = PERSIST;
246 }
247 persistfile(argv[++i]);
248 break;
249 #endif
250 default:
251 goto badopt;
252 }
253 }
254 if (nproc > 1) {
255 if (persist)
256 error(USER, "multiprocessing incompatible with persist file");
257 if (!vresolu && hresolu > 0 && hresolu < nproc)
258 error(WARNING, "number of cores should not exceed horizontal resolution");
259 if (trace != NULL)
260 error(WARNING, "multiprocessing does not work properly with trace mode");
261 }
262 /* initialize object types */
263 initotypes();
264 /* initialize urand */
265 if (rand_samp) {
266 srandom((long)time(0));
267 initurand(0);
268 } else {
269 srandom(0L);
270 initurand(2048);
271 }
272 /* set up signal handling */
273 sigdie(SIGINT, "Interrupt");
274 #ifdef SIGHUP
275 sigdie(SIGHUP, "Hangup");
276 #endif
277 sigdie(SIGTERM, "Terminate");
278 #ifdef SIGPIPE
279 sigdie(SIGPIPE, "Broken pipe");
280 #endif
281 #ifdef SIGALRM
282 sigdie(SIGALRM, "Alarm clock");
283 #endif
284 #ifdef SIGXCPU
285 sigdie(SIGXCPU, "CPU limit exceeded");
286 sigdie(SIGXFSZ, "File size exceeded");
287 #endif
288 /* open error file */
289 if (errfile != NULL) {
290 if (freopen(errfile, "a", stderr) == NULL)
291 quit(2);
292 fprintf(stderr, "**************\n*** PID %5d: ",
293 getpid());
294 printargs(argc, argv, stderr);
295 putc('\n', stderr);
296 fflush(stderr);
297 }
298 #ifdef NICE
299 nice(NICE); /* lower priority */
300 #endif
301 /* get octree */
302 if (i == argc)
303 octnm = NULL;
304 else if (i == argc-1)
305 octnm = argv[i];
306 else
307 goto badopt;
308 if (octnm == NULL)
309 error(USER, "missing octree argument");
310 /* set up output */
311 #ifdef PERSIST
312 if (persist) {
313 duped1 = dup(fileno(stdout)); /* don't lose our output */
314 openheader();
315 }
316 #endif
317 if (outform != 'a')
318 SET_FILE_BINARY(stdout);
319 readoct(octname = octnm, loadflags, &thescene, NULL);
320 nsceneobjs = nobjects;
321
322 if (loadflags & IO_INFO) { /* print header */
323 printargs(i, argv, stdout);
324 printf("SOFTWARE= %s\n", VersionID);
325 fputnow(stdout);
326 fputformat(formstr(outform), stdout);
327 putchar('\n');
328 }
329
330 ray_init_pmap(); /* PMAP: set up & load photon maps */
331
332 marksources(); /* find and mark sources */
333
334 setambient(); /* initialize ambient calculation */
335
336 #ifdef PERSIST
337 if (persist) {
338 fflush(stdout);
339 /* reconnect stdout */
340 dup2(duped1, fileno(stdout));
341 close(duped1);
342 if (persist == PARALLEL) { /* multiprocessing */
343 preload_objs(); /* preload scene */
344 shm_boundary = (char *)malloc(16);
345 strcpy(shm_boundary, "SHM_BOUNDARY");
346 while ((rval=fork()) == 0) { /* keep on forkin' */
347 pflock(1);
348 pfhold();
349 ambsync(); /* load new values */
350 }
351 if (rval < 0)
352 error(SYSTEM, "cannot fork child for persist function");
353 pfdetach(); /* parent will run then exit */
354 }
355 }
356 runagain:
357 if (persist)
358 dupheader(); /* send header to stdout */
359 #endif
360 /* trace rays */
361 rtrace(NULL, nproc);
362 /* flush ambient file */
363 ambsync();
364 #ifdef PERSIST
365 if (persist == PERSIST) { /* first run-through */
366 if ((rval=fork()) == 0) { /* child loops until killed */
367 pflock(1);
368 persist = PCHILD;
369 } else { /* original process exits */
370 if (rval < 0)
371 error(SYSTEM, "cannot fork child for persist function");
372 pfdetach(); /* parent exits */
373 }
374 }
375 if (persist == PCHILD) { /* wait for a signal then go again */
376 pfhold();
377 raynum = nrays = 0; /* reinitialize */
378 goto runagain;
379 }
380 #endif
381
382 ray_done_pmap(); /* PMAP: free photon maps */
383
384 quit(0);
385
386 badopt:
387 sprintf(errmsg, "command line error at '%s'", argv[i]);
388 error(USER, errmsg);
389 return 1; /* pro forma return */
390
391 #undef check
392 #undef check_bool
393 }
394
395
396 void
397 wputs( /* warning output function */
398 char *s
399 )
400 {
401 int lasterrno = errno;
402 eputs(s);
403 errno = lasterrno;
404 }
405
406
407 void
408 eputs( /* put string to stderr */
409 register char *s
410 )
411 {
412 static int midline = 0;
413
414 if (!*s)
415 return;
416 if (!midline++) {
417 fputs(progname, stderr);
418 fputs(": ", stderr);
419 }
420 fputs(s, stderr);
421 if (s[strlen(s)-1] == '\n') {
422 fflush(stderr);
423 midline = 0;
424 }
425 }
426
427
428 static void
429 onsig( /* fatal signal */
430 int signo
431 )
432 {
433 static int gotsig = 0;
434
435 if (gotsig++) /* two signals and we're gone! */
436 _exit(signo);
437
438 #ifdef SIGALRM
439 alarm(15); /* allow 15 seconds to clean up */
440 signal(SIGALRM, SIG_DFL); /* make certain we do die */
441 #endif
442 eputs("signal - ");
443 eputs(sigerr[signo]);
444 eputs("\n");
445 quit(3);
446 }
447
448
449 static void
450 sigdie( /* set fatal signal */
451 int signo,
452 char *msg
453 )
454 {
455 if (signal(signo, onsig) == SIG_IGN)
456 signal(signo, SIG_IGN);
457 sigerr[signo] = msg;
458 }
459
460
461 static void
462 printdefaults(void) /* print default values to stdout */
463 {
464 register char *cp;
465
466 if (imm_irrad)
467 printf("-I+\t\t\t\t# immediate irradiance on\n");
468 printf("-n %-2d\t\t\t\t# number of rendering processes\n", nproc);
469 printf("-x %-9d\t\t\t# %s\n", hresolu,
470 vresolu && hresolu ? "x resolution" : "flush interval");
471 printf("-y %-9d\t\t\t# y resolution\n", vresolu);
472 printf(lim_dist ? "-ld+\t\t\t\t# limit distance on\n" :
473 "-ld-\t\t\t\t# limit distance off\n");
474 printf("-h%c\t\t\t\t# %s header\n", loadflags & IO_INFO ? '+' : '-',
475 loadflags & IO_INFO ? "output" : "no");
476 printf("-f%c%c\t\t\t\t# format input/output = %s/%s\n",
477 inform, outform, formstr(inform), formstr(outform));
478 printf("-o%-9s\t\t\t# output", outvals);
479 for (cp = outvals; *cp; cp++)
480 switch (*cp) {
481 case 't': case 'T': printf(" trace"); break;
482 case 'o': printf(" origin"); break;
483 case 'd': printf(" direction"); break;
484 case 'v': printf(" value"); break;
485 case 'V': printf(" contribution"); break;
486 case 'l': printf(" length"); break;
487 case 'L': printf(" first_length"); break;
488 case 'p': printf(" point"); break;
489 case 'n': printf(" normal"); break;
490 case 'N': printf(" unperturbed_normal"); break;
491 case 's': printf(" surface"); break;
492 case 'w': printf(" weight"); break;
493 case 'W': printf(" coefficient"); break;
494 case 'm': printf(" modifier"); break;
495 case 'M': printf(" material"); break;
496 case '-': printf(" stroke"); break;
497 }
498 putchar('\n');
499 printf(erract[WARNING].pf != NULL ?
500 "-w+\t\t\t\t# warning messages on\n" :
501 "-w-\t\t\t\t# warning messages off\n");
502 print_rdefaults();
503 }
