newer C++ compilers have a standard type named "bool". rename macro to get rid of warnings.
Added missing external declaration
Fixed assignment of octname and removed redundant call to ray_init_pmap()
Reset default -u+ setting
Bug fix in -P option implementation
Modified rtcontrib -c option to accumulate a specified number of rays
Added ambient pre-synchronization in parallel persist mode
Made -u+ option truly random
Added -V option to rtcontrib and -oV option to rtrace to report contributions
Moved some more platform dependencies to common header files. Included a few necessary system headers.
Abstracted process and path handling for Windows. Renamed FLOAT to RREAL because of conflict on Windows. Added conditional compiles for some signal handlers.
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
