root/Development/ray/src/rt/rtmain.c
Mon Mar 21 19:06:08 2016 UTC (9 years, 7 months ago) by greg
CVS Tags: rad5R1, rad5R2
Changes since 2.26: +3 -3 lines
Diff to previous 2.26
Thu Mar 10 18:25:46 2016 UTC (9 years, 7 months ago) by schorsch
Changes since 2.25: +7 -7 lines
Diff to previous 2.25
newer C++ compilers have a standard type named "bool". rename macro to get rid of warnings.
Thu Apr 23 20:29:14 2015 UTC (10 years, 6 months ago) by greg
Changes since 2.24: +2 -1 lines
Diff to previous 2.24
Added missing external declaration
Thu Apr 23 17:42:04 2015 UTC (10 years, 6 months ago) by greg
Diff to previous 2.23
Fixed assignment of octname and removed redundant call to ray_init_pmap()
Tue Feb 24 19:39:27 2015 UTC (10 years, 8 months ago) by greg
Changes since 2.22: +9 -3 lines
Diff to previous 2.22
Wed Aug 7 05:10:09 2013 UTC (12 years, 2 months ago) by greg
Changes since 2.21: +3 -3 lines
Diff to previous 2.21
Sun Sep 26 15:51:15 2010 UTC (15 years, 1 month ago) by greg
Changes since 2.20: +4 -3 lines
Diff to previous 2.20
Sun Dec 13 19:39:51 2009 UTC (15 years, 10 months ago) by greg
Changes since 2.19: +2 -1 lines
Diff to previous 2.19
Reset default -u+ setting
Sun Dec 13 19:13:04 2009 UTC (15 years, 10 months ago) by greg
Changes since 2.18: +2 -6 lines
Diff to previous 2.18
Sat Dec 12 19:01:00 2009 UTC (15 years, 10 months ago) by greg
Changes since 2.17: +54 -17 lines
Diff to previous 2.17
Mon Jun 22 20:52:56 2009 UTC (16 years, 4 months ago) by greg
Changes since 2.16: +1 -2 lines
Diff to previous 2.16
Bug fix in -P option implementation
Fri Apr 18 18:06:29 2008 UTC (17 years, 6 months ago) by greg
Diff to previous 2.15
Modified rtcontrib -c option to accumulate a specified number of rays
Thu Sep 13 20:02:11 2007 UTC (18 years, 1 month ago) by greg
Changes since 2.14: +3 -2 lines
Diff to previous 2.14
Added ambient pre-synchronization in parallel persist mode
Wed Apr 5 06:22:57 2006 UTC (19 years, 7 months ago) by greg
Changes since 2.13: +8 -3 lines
Diff to previous 2.13
Made -u+ option truly random
Sun Feb 5 22:22:20 2006 UTC (19 years, 9 months ago) by greg
Diff to previous 2.12
Added -V option to rtcontrib and -oV option to rtrace to report contributions
Wed Jun 15 15:36:52 2005 UTC (20 years, 4 months ago) by greg
Thu Jun 2 04:47:27 2005 UTC (20 years, 5 months ago) by greg
Changes since 2.10: +1 -5 lines
Wed May 25 04:44:26 2005 UTC (20 years, 5 months ago) by greg
Changes since 2.9: +11 -5 lines
Tue Mar 30 16:13:01 2004 UTC (21 years, 7 months ago) by schorsch
Changes since 2.8: +23 -23 lines
Tue Oct 21 19:19:28 2003 UTC (22 years ago) by schorsch
Mon Jul 14 20:02:30 2003 UTC (22 years, 3 months ago) by schorsch
Changes since 2.6: +2 -4 lines
Mon Jun 30 14:59:12 2003 UTC (22 years, 4 months ago) by schorsch
Thu Jun 26 00:58:10 2003 UTC (22 years, 4 months ago) by schorsch
Changes since 2.4: +9 -1 lines
Thu Jun 5 19:29:34 2003 UTC (22 years, 5 months ago) by schorsch
Changes since 2.3: +8 -11 lines
Tue May 13 17:58:33 2003 UTC (22 years, 5 months ago) by greg
Tue Feb 25 02:47:23 2003 UTC (22 years, 8 months ago) by greg
Sat Feb 22 02:07:29 2003 UTC (22 years, 8 months ago) by greg
