root/radiance/ray/src/rt/rtmain.c
Revision: 2.22
Committed: Wed Aug 7 05:10:09 2013 UTC (10 years, 10 months ago) by greg
CVS Tags: rad4R2P2, rad4R2, rad4R2P1
Changes since 2.21: +3 -3 lines
2 static const char RCSid[] = "$Id: rtmain.c,v 2.21 2010/09/26 15:51:15 greg Exp $";
5 * rtmain.c - main for rtrace per-ray calculation program
6 */
7
8 #include "copyright.h"
9
10 #include <signal.h>
11
12 #include "platform.h"
13 #include "rtprocess.h" /* getpid() */
14 #include "resolu.h"
15 #include "ray.h"
16 #include "source.h"
17 #include "ambient.h"
18 #include "random.h"
19 #include "paths.h"
20
21 extern char *progname; /* global argv[0] */
22
23 extern char *shm_boundary; /* boundary of shared memory */
24
25 /* persistent processes define */
26 #ifdef F_SETLKW
27 #define PERSIST 1 /* normal persist */
28 #define PARALLEL 2 /* parallel persist */
29 #define PCHILD 3 /* child of normal persist */
30 #endif
31
32 char *sigerr[NSIG]; /* signal error messages */
33 char *errfile = NULL; /* error output file */
34
35 int nproc = 1; /* number of processes */
36
37 extern char *formstr(); /* string from format */
38 int inform = 'a'; /* input format */
39 int outform = 'a'; /* output format */
40 char *outvals = "v"; /* output specification */
41
42 int hresolu = 0; /* horizontal (scan) size */
43 int vresolu = 0; /* vertical resolution */
44
45 int imm_irrad = 0; /* compute immediate irradiance? */
46 int lim_dist = 0; /* limit distance? */
47
48 #ifndef MAXMODLIST
49 #define MAXMODLIST 1024 /* maximum modifiers we'll track */
50 #endif
51
52 extern void (*addobjnotify[])(); /* object notification calls */
53 extern void tranotify(OBJECT obj);
54
55 char *tralist[MAXMODLIST]; /* list of modifers to trace (or no) */
56 int traincl = -1; /* include == 1, exclude == 0 */
57
58 static int loadflags = ~IO_FILES; /* what to load from octree */
59
60 static void onsig(int signo);
61 static void sigdie(int signo, char *msg);
62 static void printdefaults(void);
63
64
65 int
66 main(int argc, char *argv[])
67 {
68 #define check(ol,al) if (argv[i][ol] || \
69 badarg(argc-i-1,argv+i+1,al)) \
70 goto badopt
71 #define bool(olen,var) switch (argv[i][olen]) { \
72 case '\0': var = !var; break; \
73 case 'y': case 'Y': case 't': case 'T': \
74 case '+': case '1': var = 1; break; \
75 case 'n': case 'N': case 'f': case 'F': \
76 case '-': case '0': var = 0; break; \
77 default: goto badopt; }
78 int persist = 0;
79 char *octnm = NULL;
80 char **tralp = NULL;
81 int duped1 = -1;
82 int rval;
83 int i;
84 /* global program name */
85 progname = argv[0] = fixargv0(argv[0]);
86 /* add trace notify function */
87 for (i = 0; addobjnotify[i] != NULL; i++)
88 ;
89 addobjnotify[i] = tranotify;
90 /* set our defaults */
91 rand_samp = 1;
92 maxdepth = -10;
93 minweight = 2e-3;
94 /* option city */
95 for (i = 1; i < argc; i++) {
96 /* expand arguments */
97 while ((rval = expandarg(&argc, &argv, i)) > 0)
98 ;
99 if (rval < 0) {
100 sprintf(errmsg, "cannot expand '%s'", argv[i]);
101 error(SYSTEM, errmsg);
102 }
103 if (argv[i] == NULL || argv[i][0] != '-')
104 break; /* break from options */
105 if (!strcmp(argv[i], "-version")) {
106 puts(VersionID);
107 quit(0);
108 }
109 if (!strcmp(argv[i], "-defaults") ||
110 !strcmp(argv[i], "-help")) {
111 printdefaults();
112 quit(0);
113 }
114 rval = getrenderopt(argc-i, argv+i);
115 if (rval >= 0) {
116 i += rval;
117 continue;
118 }
119 switch (argv[i][1]) {
120 case 'n': /* number of cores */
121 check(2,"i");
122 nproc = atoi(argv[++i]);
123 if (nproc <= 0)
124 error(USER, "bad number of processes");
125 break;
126 case 'x': /* x resolution */
127 check(2,"i");
128 hresolu = atoi(argv[++i]);
129 break;
130 case 'y': /* y resolution */
131 check(2,"i");
132 vresolu = atoi(argv[++i]);
133 break;
134 case 'w': /* warnings */
135 rval = erract[WARNING].pf != NULL;
136 bool(2,rval);
137 if (rval) erract[WARNING].pf = wputs;
138 else erract[WARNING].pf = NULL;
139 break;
140 case 'e': /* error file */
141 check(2,"s");
142 errfile = argv[++i];
143 break;
144 case 'l': /* limit distance */
145 if (argv[i][2] != 'd')
146 goto badopt;
147 bool(3,lim_dist);
148 break;
149 case 'I': /* immed. irradiance */
150 bool(2,imm_irrad);
151 break;
152 case 'f': /* format i/o */
153 switch (argv[i][2]) {
154 case 'a': /* ascii */
155 case 'f': /* float */
156 case 'd': /* double */
157 inform = argv[i][2];
158 break;
159 default:
160 goto badopt;
161 }
162 switch (argv[i][3]) {
163 case '\0':
164 outform = inform;
165 break;
166 case 'a': /* ascii */
167 case 'f': /* float */
168 case 'd': /* double */
169 case 'c': /* color */
170 check(4,"");
171 outform = argv[i][3];
172 break;
173 default:
174 goto badopt;
175 }
176 break;
177 case 'o': /* output */
178 outvals = argv[i]+2;
179 break;
180 case 'h': /* header output */
181 rval = loadflags & IO_INFO;
182 bool(2,rval);
183 loadflags = rval ? loadflags | IO_INFO :
184 loadflags & ~IO_INFO;
185 break;
186 case 't': /* trace */
187 switch (argv[i][2]) {
188 case 'i': /* include */
189 case 'I':
190 check(3,"s");
191 if (traincl != 1) {
192 traincl = 1;
193 tralp = tralist;
194 }
195 if (argv[i][2] == 'I') { /* file */
196 rval = wordfile(tralp,
197 getpath(argv[++i],getrlibpath(),R_OK));
198 if (rval < 0) {
199 sprintf(errmsg,
200 "cannot open trace include file \"%s\"",
201 argv[i]);
202 error(SYSTEM, errmsg);
203 }
204 tralp += rval;
205 } else {
206 *tralp++ = argv[++i];
207 *tralp = NULL;
208 }
209 break;
210 case 'e': /* exclude */
211 case 'E':
212 check(3,"s");
213 if (traincl != 0) {
214 traincl = 0;
215 tralp = tralist;
216 }
217 if (argv[i][2] == 'E') { /* file */
218 rval = wordfile(tralp,
219 getpath(argv[++i],getrlibpath(),R_OK));
220 if (rval < 0) {
221 sprintf(errmsg,
222 "cannot open trace exclude file \"%s\"",
223 argv[i]);
224 error(SYSTEM, errmsg);
225 }
226 tralp += rval;
227 } else {
228 *tralp++ = argv[++i];
229 *tralp = NULL;
230 }
231 break;
232 default:
233 goto badopt;
234 }
235 break;
236 #ifdef PERSIST
237 case 'P': /* persist file */
238 if (argv[i][2] == 'P') {
239 check(3,"s");
240 persist = PARALLEL;
241 } else {
242 check(2,"s");
243 persist = PERSIST;
244 }
245 persistfile(argv[++i]);
246 break;
247 #endif
248 default:
249 goto badopt;
250 }
251 }
252 if (nproc > 1) {
253 if (persist)
254 error(USER, "multiprocessing incompatible with persist file");
255 if (!vresolu && hresolu > 0 && hresolu < nproc)
256 error(WARNING, "number of cores should not exceed horizontal resolution");
257 if (trace != NULL)
258 error(WARNING, "multiprocessing does not work properly with trace mode");
259 }
260 /* initialize object types */
261 initotypes();
262 /* initialize urand */
263 if (rand_samp) {
264 srandom((long)time(0));
265 initurand(0);
266 } else {
267 srandom(0L);
268 initurand(2048);
269 }
270 /* set up signal handling */
271 sigdie(SIGINT, "Interrupt");
272 #ifdef SIGHUP
273 sigdie(SIGHUP, "Hangup");
274 #endif
275 sigdie(SIGTERM, "Terminate");
276 #ifdef SIGPIPE
277 sigdie(SIGPIPE, "Broken pipe");
278 #endif
279 #ifdef SIGALRM
280 sigdie(SIGALRM, "Alarm clock");
281 #endif
282 #ifdef SIGXCPU
283 sigdie(SIGXCPU, "CPU limit exceeded");
284 sigdie(SIGXFSZ, "File size exceeded");
285 #endif
286 /* open error file */
287 if (errfile != NULL) {
288 if (freopen(errfile, "a", stderr) == NULL)
289 quit(2);
290 fprintf(stderr, "**************\n*** PID %5d: ",
291 getpid());
292 printargs(argc, argv, stderr);
293 putc('\n', stderr);
294 fflush(stderr);
295 }
296 #ifdef NICE
297 nice(NICE); /* lower priority */
298 #endif
299 /* get octree */
300 if (i == argc)
301 octnm = NULL;
302 else if (i == argc-1)
303 octnm = argv[i];
304 else
305 goto badopt;
306 if (octnm == NULL)
307 error(USER, "missing octree argument");
308 /* set up output */
309 #ifdef PERSIST
310 if (persist) {
311 duped1 = dup(fileno(stdout)); /* don't lose our output */
312 openheader();
313 }
314 #endif
315 if (outform != 'a')
316 SET_FILE_BINARY(stdout);
317 readoct(octnm, loadflags, &thescene, NULL);
318 nsceneobjs = nobjects;
319
320 if (loadflags & IO_INFO) { /* print header */
321 printargs(i, argv, stdout);
322 printf("SOFTWARE= %s\n", VersionID);
323 fputnow(stdout);
324 fputformat(formstr(outform), stdout);
325 putchar('\n');
326 }
327
328 marksources(); /* find and mark sources */
329
330 setambient(); /* initialize ambient calculation */
331
332 #ifdef PERSIST
333 if (persist) {
334 fflush(stdout);
335 /* reconnect stdout */
336 dup2(duped1, fileno(stdout));
337 close(duped1);
338 if (persist == PARALLEL) { /* multiprocessing */
339 preload_objs(); /* preload scene */
340 shm_boundary = (char *)malloc(16);
341 strcpy(shm_boundary, "SHM_BOUNDARY");
342 while ((rval=fork()) == 0) { /* keep on forkin' */
343 pflock(1);
344 pfhold();
345 ambsync(); /* load new values */
346 }
347 if (rval < 0)
348 error(SYSTEM, "cannot fork child for persist function");
349 pfdetach(); /* parent will run then exit */
350 }
351 }
352 runagain:
353 if (persist)
354 dupheader(); /* send header to stdout */
355 #endif
356 /* trace rays */
357 rtrace(NULL, nproc);
358 /* flush ambient file */
359 ambsync();
360 #ifdef PERSIST
361 if (persist == PERSIST) { /* first run-through */
362 if ((rval=fork()) == 0) { /* child loops until killed */
363 pflock(1);
364 persist = PCHILD;
365 } else { /* original process exits */
366 if (rval < 0)
367 error(SYSTEM, "cannot fork child for persist function");
368 pfdetach(); /* parent exits */
369 }
370 }
371 if (persist == PCHILD) { /* wait for a signal then go again */
372 pfhold();
373 raynum = nrays = 0; /* reinitialize */
374 goto runagain;
375 }
376 #endif
377 quit(0);
378
379 badopt:
380 sprintf(errmsg, "command line error at '%s'", argv[i]);
381 error(USER, errmsg);
382 return 1; /* pro forma return */
383
384 #undef check
385 #undef bool
386 }
387
388
389 void
390 wputs( /* warning output function */
391 char *s
392 )
393 {
394 int lasterrno = errno;
395 eputs(s);
396 errno = lasterrno;
397 }
398
399
400 void
401 eputs( /* put string to stderr */
402 register char *s
403 )
404 {
405 static int midline = 0;
406
407 if (!*s)
408 return;
409 if (!midline++) {
410 fputs(progname, stderr);
411 fputs(": ", stderr);
412 }
413 fputs(s, stderr);
414 if (s[strlen(s)-1] == '\n') {
415 fflush(stderr);
416 midline = 0;
417 }
418 }
419
420
421 static void
422 onsig( /* fatal signal */
423 int signo
424 )
425 {
426 static int gotsig = 0;
427
428 if (gotsig++) /* two signals and we're gone! */
429 _exit(signo);
430
431 #ifdef SIGALRM
432 alarm(15); /* allow 15 seconds to clean up */
433 signal(SIGALRM, SIG_DFL); /* make certain we do die */
434 #endif
435 eputs("signal - ");
436 eputs(sigerr[signo]);
437 eputs("\n");
438 quit(3);
439 }
440
441
442 static void
443 sigdie( /* set fatal signal */
444 int signo,
445 char *msg
446 )
447 {
448 if (signal(signo, onsig) == SIG_IGN)
449 signal(signo, SIG_IGN);
450 sigerr[signo] = msg;
451 }
452
453
454 static void
455 printdefaults(void) /* print default values to stdout */
456 {
457 register char *cp;
458
459 if (imm_irrad)
460 printf("-I+\t\t\t\t# immediate irradiance on\n");
461 printf("-n %-2d\t\t\t\t# number of rendering processes\n", nproc);
462 printf("-x %-9d\t\t\t# %s\n", hresolu,
463 vresolu && hresolu ? "x resolution" : "flush interval");
464 printf("-y %-9d\t\t\t# y resolution\n", vresolu);
465 printf(lim_dist ? "-ld+\t\t\t\t# limit distance on\n" :
466 "-ld-\t\t\t\t# limit distance off\n");
467 printf("-h%c\t\t\t\t# %s header\n", loadflags & IO_INFO ? '+' : '-',
468 loadflags & IO_INFO ? "output" : "no");
469 printf("-f%c%c\t\t\t\t# format input/output = %s/%s\n",
470 inform, outform, formstr(inform), formstr(outform));
471 printf("-o%-9s\t\t\t# output", outvals);
472 for (cp = outvals; *cp; cp++)
473 switch (*cp) {
474 case 't': case 'T': printf(" trace"); break;
475 case 'o': printf(" origin"); break;
476 case 'd': printf(" direction"); break;
477 case 'v': printf(" value"); break;
478 case 'V': printf(" contribution"); break;
479 case 'l': printf(" length"); break;
480 case 'L': printf(" first_length"); break;
481 case 'p': printf(" point"); break;
482 case 'n': printf(" normal"); break;
483 case 'N': printf(" unperturbed_normal"); break;
484 case 's': printf(" surface"); break;
485 case 'w': printf(" weight"); break;
486 case 'W': printf(" coefficient"); break;
487 case 'm': printf(" modifier"); break;
488 case 'M': printf(" material"); break;
489 case '-': printf(" stroke"); break;
490 }
491 putchar('\n');
492 printf(erract[WARNING].pf != NULL ?
493 "-w+\t\t\t\t# warning messages on\n" :
494 "-w-\t\t\t\t# warning messages off\n");
495 print_rdefaults();
496 }
