--- ray/src/rt/rtmain.c 2003/06/26 00:58:10 2.5 +++ ray/src/rt/rtmain.c 2004/03/30 16:13:01 2.9 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rtmain.c,v 2.5 2003/06/26 00:58:10 schorsch Exp $"; +static const char RCSid[] = "$Id: rtmain.c,v 2.9 2004/03/30 16:13:01 schorsch Exp $"; #endif /* * rtmain.c - main for rtrace per-ray calculation program @@ -11,6 +11,8 @@ static const char RCSid[] = "$Id: rtmain.c,v 2.5 2003/ #include #include "platform.h" +#include "rtprocess.h" /* getpid() */ +#include "resolu.h" #include "ray.h" #include "source.h" #include "ambient.h" @@ -25,13 +27,9 @@ static const char RCSid[] = "$Id: rtmain.c,v 2.5 2003/ #endif char *progname; /* argv[0] */ - char *octname; /* octree name */ - char *sigerr[NSIG]; /* signal error messages */ - char *shm_boundary = NULL; /* boundary of shared memory */ - char *errfile = NULL; /* error output file */ extern char *formstr(); /* string from format */ @@ -48,15 +46,13 @@ extern int lim_dist; /* limit distance? */ extern char *tralist[]; /* list of modifers to trace (or no) */ extern int traincl; /* include == 1, exclude == 0 */ -void onsig(); -void sigdie(); -void printdefaults(); +static void onsig(int signo); +static void sigdie(int signo, char *msg); +static void printdefaults(void); int -main(argc, argv) -int argc; -char *argv[]; +main(int argc, char *argv[]) { #define check(ol,al) if (argv[i][ol] || \ badarg(argc-i-1,argv+i+1,al)) \ @@ -348,6 +344,7 @@ runagain: badopt: sprintf(errmsg, "command line error at '%s'", argv[i]); error(USER, errmsg); + return 1; /* pro forma return */ #undef check #undef bool @@ -355,8 +352,9 @@ badopt: void -wputs(s) /* warning output function */ -char *s; +wputs( /* warning output function */ + char *s +) { int lasterrno = errno; eputs(s); @@ -365,8 +363,9 @@ char *s; void -eputs(s) /* put string to stderr */ -register char *s; +eputs( /* put string to stderr */ + register char *s +) { static int midline = 0; @@ -384,9 +383,10 @@ register char *s; } -void -onsig(signo) /* fatal signal */ -int signo; +static void +onsig( /* fatal signal */ + int signo +) { static int gotsig = 0; @@ -404,10 +404,11 @@ int signo; } -void -sigdie(signo, msg) /* set fatal signal */ -int signo; -char *msg; +static void +sigdie( /* set fatal signal */ + int signo, + char *msg +) { if (signal(signo, onsig) == SIG_IGN) signal(signo, SIG_IGN); @@ -415,8 +416,8 @@ char *msg; } -void -printdefaults() /* print default values to stdout */ +static void +printdefaults(void) /* print default values to stdout */ { register char *cp;
