--- ray/src/rt/rtmain.c 2003/06/26 00:58:10 2.5 +++ ray/src/rt/rtmain.c 2009/12/12 19:01:00 2.18 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rtmain.c,v 2.5 2003/06/26 00:58:10 schorsch Exp $"; +static const char RCSid[] = "$Id: rtmain.c,v 2.18 2009/12/12 19:01:00 greg Exp $"; #endif /* * rtmain.c - main for rtrace per-ray calculation program @@ -7,16 +7,21 @@ static const char RCSid[] = "$Id: rtmain.c,v 2.5 2003/ #include "copyright.h" -#include #include #include "platform.h" +#include "rtprocess.h" /* getpid() */ +#include "resolu.h" #include "ray.h" #include "source.h" #include "ambient.h" #include "random.h" #include "paths.h" +extern char *progname; /* global argv[0] */ + +extern char *shm_boundary; /* boundary of shared memory */ + /* persistent processes define */ #ifdef F_SETLKW #define PERSIST 1 /* normal persist */ @@ -24,39 +29,41 @@ static const char RCSid[] = "$Id: rtmain.c,v 2.5 2003/ #define PCHILD 3 /* child of normal persist */ #endif -char *progname; /* argv[0] */ +char *sigerr[NSIG]; /* signal error messages */ +char *errfile = NULL; /* error output file */ -char *octname; /* octree name */ +int nproc = 1; /* number of processes */ -char *sigerr[NSIG]; /* signal error messages */ +extern char *formstr(); /* string from format */ +int inform = 'a'; /* input format */ +int outform = 'a'; /* output format */ +char *outvals = "v"; /* output specification */ -char *shm_boundary = NULL; /* boundary of shared memory */ +int hresolu = 0; /* horizontal (scan) size */ +int vresolu = 0; /* vertical resolution */ -char *errfile = NULL; /* error output file */ +int imm_irrad = 0; /* compute immediate irradiance? */ +int lim_dist = 0; /* limit distance? */ -extern char *formstr(); /* string from format */ -extern int inform; /* input format */ -extern int outform; /* output format */ -extern char *outvals; /* output values */ +#ifndef MAXMODLIST +#define MAXMODLIST 1024 /* maximum modifiers we'll track */ +#endif -extern int hresolu; /* horizontal resolution */ -extern int vresolu; /* vertical resolution */ +extern void (*addobjnotify[])(); /* object notification calls */ +extern void tranotify(OBJECT obj); -extern int imm_irrad; /* compute immediate irradiance? */ -extern int lim_dist; /* limit distance? */ +char *tralist[MAXMODLIST]; /* list of modifers to trace (or no) */ +int traincl = -1; /* include == 1, exclude == 0 */ -extern char *tralist[]; /* list of modifers to trace (or no) */ -extern int traincl; /* include == 1, exclude == 0 */ +static int loadflags = ~IO_FILES; /* what to load from octree */ -void onsig(); -void sigdie(); -void printdefaults(); +static void onsig(int signo); +static void sigdie(int signo, char *msg); +static void printdefaults(void); int -main(argc, argv) -int argc; -char *argv[]; +main(int argc, char *argv[]) { #define check(ol,al) if (argv[i][ol] || \ badarg(argc-i-1,argv+i+1,al)) \ @@ -68,14 +75,21 @@ char *argv[]; case 'n': case 'N': case 'f': case 'F': \ case '-': case '0': var = 0; break; \ default: goto badopt; } - int loadflags = ~IO_FILES; int persist = 0; + char *octnm = NULL; char **tralp; int duped1; int rval; int i; /* global program name */ progname = argv[0] = fixargv0(argv[0]); + /* add trace notify function */ + for (i = 0; addobjnotify[i] != NULL; i++) + ; + addobjnotify[i] = tranotify; + /* set our defaults */ + maxdepth = -10; + minweight = 2e-3; /* option city */ for (i = 1; i < argc; i++) { /* expand arguments */ @@ -102,6 +116,12 @@ char *argv[]; continue; } switch (argv[i][1]) { + case 'n': /* number of cores */ + check(2,"i"); + nproc = atoi(argv[++i]); + if (nproc <= 0) + error(USER, "bad number of processes"); + break; case 'x': /* x resolution */ check(2,"i"); hresolu = atoi(argv[++i]); @@ -228,10 +248,26 @@ char *argv[]; goto badopt; } } + if (nproc > 1) { + if (persist) + error(USER, "multiprocessing incompatible with persist file"); + if (imm_irrad) + error(USER, "multiprocessing incompatible with immediate irradiance"); + if (hresolu > 0 && hresolu < nproc) + error(WARNING, "number of cores should not exceed horizontal resolution"); + if (trace != NULL) + error(WARNING, "multiprocessing does not work properly with trace mode"); + } /* initialize object types */ initotypes(); /* initialize urand */ - initurand(2048); + if (rand_samp) { + srandom((long)time(0)); + initurand(0); + } else { + srandom(0L); + initurand(2048); + } /* set up signal handling */ sigdie(SIGINT, "Interrupt"); #ifdef SIGHUP @@ -263,12 +299,12 @@ char *argv[]; #endif /* get octree */ if (i == argc) - octname = NULL; + octnm = NULL; else if (i == argc-1) - octname = argv[i]; + octnm = argv[i]; else goto badopt; - if (octname == NULL) + if (octnm == NULL) error(USER, "missing octree argument"); /* set up output */ #ifdef PERSIST @@ -277,13 +313,9 @@ char *argv[]; openheader(); } #endif -#ifdef _WIN32 if (outform != 'a') SET_FILE_BINARY(stdout); - if (octname == NULL) - SET_FILE_BINARY(stdin); -#endif - readoct(octname, loadflags, &thescene, NULL); + readoct(octnm, loadflags, &thescene, NULL); nsceneobjs = nobjects; if (loadflags & IO_INFO) { /* print header */ @@ -311,16 +343,19 @@ char *argv[]; while ((rval=fork()) == 0) { /* keep on forkin' */ pflock(1); pfhold(); + ambsync(); /* load new values */ } if (rval < 0) error(SYSTEM, "cannot fork child for persist function"); - pfdetach(); /* parent exits */ + pfdetach(); /* parent will run then exit */ } } runagain: if (persist) dupheader(); /* send header to stdout */ #endif + if (nproc > 1) /* start multiprocessing */ + ray_popen(nproc); /* trace rays */ rtrace(NULL); /* flush ambient file */ @@ -337,7 +372,6 @@ runagain: } } if (persist == PCHILD) { /* wait for a signal then go again */ - close(duped1); /* release output handle */ pfhold(); raynum = nrays = 0; /* reinitialize */ goto runagain; @@ -348,6 +382,7 @@ runagain: badopt: sprintf(errmsg, "command line error at '%s'", argv[i]); error(USER, errmsg); + return 1; /* pro forma return */ #undef check #undef bool @@ -355,8 +390,9 @@ badopt: void -wputs(s) /* warning output function */ -char *s; +wputs( /* warning output function */ + char *s +) { int lasterrno = errno; eputs(s); @@ -365,8 +401,9 @@ char *s; void -eputs(s) /* put string to stderr */ -register char *s; +eputs( /* put string to stderr */ + register char *s +) { static int midline = 0; @@ -384,9 +421,10 @@ register char *s; } -void -onsig(signo) /* fatal signal */ -int signo; +static void +onsig( /* fatal signal */ + int signo +) { static int gotsig = 0; @@ -404,10 +442,11 @@ int signo; } -void -sigdie(signo, msg) /* set fatal signal */ -int signo; -char *msg; +static void +sigdie( /* set fatal signal */ + int signo, + char *msg +) { if (signal(signo, onsig) == SIG_IGN) signal(signo, SIG_IGN); @@ -415,26 +454,30 @@ char *msg; } -void -printdefaults() /* print default values to stdout */ +static void +printdefaults(void) /* print default values to stdout */ { register char *cp; if (imm_irrad) printf("-I+\t\t\t\t# immediate irradiance on\n"); - printf("-x %-9d\t\t\t# x resolution\n", hresolu); - printf("-y %-9d\t\t\t# y resolution\n", vresolu); + printf("-n %-2d\t\t\t\t# number of rendering processes\n", nproc); + printf("-x %-9d\t\t\t# x resolution (flush interval)\n", hresolu); + printf("-y %-9d\t\t\t# y resolution\n", vresolu); printf(lim_dist ? "-ld+\t\t\t\t# limit distance on\n" : "-ld-\t\t\t\t# limit distance off\n"); + printf("-h%c\t\t\t\t# %s header\n", loadflags & IO_INFO ? '+' : '-', + loadflags & IO_INFO ? "output" : "no"); printf("-f%c%c\t\t\t\t# format input/output = %s/%s\n", inform, outform, formstr(inform), formstr(outform)); - printf("-o%s\t\t\t\t# output", outvals); + printf("-o%-9s\t\t\t# output", outvals); for (cp = outvals; *cp; cp++) switch (*cp) { - case 't': printf(" trace"); break; + case 't': case 'T': printf(" trace"); break; case 'o': printf(" origin"); break; case 'd': printf(" direction"); break; case 'v': printf(" value"); break; + case 'V': printf(" contribution"); break; case 'l': printf(" length"); break; case 'L': printf(" first_length"); break; case 'p': printf(" point"); break; @@ -442,7 +485,10 @@ printdefaults() /* print default values to stdout */ case 'N': printf(" unperturbed_normal"); break; case 's': printf(" surface"); break; case 'w': printf(" weight"); break; + case 'W': printf(" coefficient"); break; case 'm': printf(" modifier"); break; + case 'M': printf(" material"); break; + case '-': printf(" stroke"); break; } putchar('\n'); printf(erract[WARNING].pf != NULL ?
