--- ray/src/rt/rtmain.c 2003/06/26 00:58:10 2.5 +++ ray/src/rt/rtmain.c 2005/05/25 04:44:26 2.10 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rtmain.c,v 2.5 2003/06/26 00:58:10 schorsch Exp $"; +static const char RCSid[] = "$Id: rtmain.c,v 2.10 2005/05/25 04:44:26 greg Exp $"; #endif /* * rtmain.c - main for rtrace per-ray calculation program @@ -11,6 +11,8 @@ static const char RCSid[] = "$Id: rtmain.c,v 2.5 2003/ #include #include "platform.h" +#include "rtprocess.h" /* getpid() */ +#include "resolu.h" #include "ray.h" #include "source.h" #include "ambient.h" @@ -25,13 +27,9 @@ static const char RCSid[] = "$Id: rtmain.c,v 2.5 2003/ #endif char *progname; /* argv[0] */ - char *octname; /* octree name */ - char *sigerr[NSIG]; /* signal error messages */ - char *shm_boundary = NULL; /* boundary of shared memory */ - char *errfile = NULL; /* error output file */ extern char *formstr(); /* string from format */ @@ -48,15 +46,15 @@ extern int lim_dist; /* limit distance? */ extern char *tralist[]; /* list of modifers to trace (or no) */ extern int traincl; /* include == 1, exclude == 0 */ -void onsig(); -void sigdie(); -void printdefaults(); +static int loadflags = ~IO_FILES; /* what to load from octree */ +static void onsig(int signo); +static void sigdie(int signo, char *msg); +static void printdefaults(void); + int -main(argc, argv) -int argc; -char *argv[]; +main(int argc, char *argv[]) { #define check(ol,al) if (argv[i][ol] || \ badarg(argc-i-1,argv+i+1,al)) \ @@ -68,7 +66,6 @@ char *argv[]; case 'n': case 'N': case 'f': case 'F': \ case '-': case '0': var = 0; break; \ default: goto badopt; } - int loadflags = ~IO_FILES; int persist = 0; char **tralp; int duped1; @@ -348,6 +345,7 @@ runagain: badopt: sprintf(errmsg, "command line error at '%s'", argv[i]); error(USER, errmsg); + return 1; /* pro forma return */ #undef check #undef bool @@ -355,8 +353,9 @@ badopt: void -wputs(s) /* warning output function */ -char *s; +wputs( /* warning output function */ + char *s +) { int lasterrno = errno; eputs(s); @@ -365,8 +364,9 @@ char *s; void -eputs(s) /* put string to stderr */ -register char *s; +eputs( /* put string to stderr */ + register char *s +) { static int midline = 0; @@ -384,9 +384,10 @@ register char *s; } -void -onsig(signo) /* fatal signal */ -int signo; +static void +onsig( /* fatal signal */ + int signo +) { static int gotsig = 0; @@ -404,10 +405,11 @@ int signo; } -void -sigdie(signo, msg) /* set fatal signal */ -int signo; -char *msg; +static void +sigdie( /* set fatal signal */ + int signo, + char *msg +) { if (signal(signo, onsig) == SIG_IGN) signal(signo, SIG_IGN); @@ -415,23 +417,25 @@ char *msg; } -void -printdefaults() /* print default values to stdout */ +static void +printdefaults(void) /* print default values to stdout */ { register char *cp; if (imm_irrad) printf("-I+\t\t\t\t# immediate irradiance on\n"); - printf("-x %-9d\t\t\t# x resolution\n", hresolu); + printf("-x %-9d\t\t\t# x resolution (flush interval)\n", hresolu); printf("-y %-9d\t\t\t# y resolution\n", vresolu); printf(lim_dist ? "-ld+\t\t\t\t# limit distance on\n" : "-ld-\t\t\t\t# limit distance off\n"); + printf("-h%c\t\t\t\t# %s header\n", loadflags & IO_INFO ? '+' : '-', + loadflags & IO_INFO ? "output" : "no"); printf("-f%c%c\t\t\t\t# format input/output = %s/%s\n", inform, outform, formstr(inform), formstr(outform)); - printf("-o%s\t\t\t\t# output", outvals); + printf("-o%-9s\t\t\t# output", outvals); for (cp = outvals; *cp; cp++) switch (*cp) { - case 't': printf(" trace"); break; + case 't': case 'T': printf(" trace"); break; case 'o': printf(" origin"); break; case 'd': printf(" direction"); break; case 'v': printf(" value"); break; @@ -443,6 +447,9 @@ printdefaults() /* print default values to stdout */ case 's': printf(" surface"); break; case 'w': printf(" weight"); break; case 'm': printf(" modifier"); break; + case 'M': printf(" material"); break; + case 'W': printf(" contribution"); break; + case '-': printf(" stroke"); break; } putchar('\n'); printf(erract[WARNING].pf != NULL ?
