root/radiance/ray/src/rt/rtmain.c
Wed Aug 7 05:10:09 2013 UTC (10 years, 10 months ago) by greg
Changes since 2.21: +3 -3 lines
Diff to previous 2.21 , to selected 2.10
Sun Sep 26 15:51:15 2010 UTC (13 years, 8 months ago) by greg
Changes since 2.20: +4 -3 lines
Diff to previous 2.20 , to selected 2.10
Sun Dec 13 19:39:51 2009 UTC (14 years, 6 months ago) by greg
Changes since 2.19: +2 -1 lines
Diff to previous 2.19 , to selected 2.10
Reset default -u+ setting
Sun Dec 13 19:13:04 2009 UTC (14 years, 6 months ago) by greg
Changes since 2.18: +2 -6 lines
Diff to previous 2.18 , to selected 2.10
Sat Dec 12 19:01:00 2009 UTC (14 years, 6 months ago) by greg
Changes since 2.17: +54 -17 lines
Diff to previous 2.17 , to selected 2.10
Mon Jun 22 20:52:56 2009 UTC (14 years, 11 months ago) by greg
Changes since 2.16: +1 -2 lines
Diff to previous 2.16 , to selected 2.10
Bug fix in -P option implementation
Fri Apr 18 18:06:29 2008 UTC (16 years, 1 month ago) by greg
Diff to previous 2.15 , to selected 2.10
Modified rtcontrib -c option to accumulate a specified number of rays
Thu Sep 13 20:02:11 2007 UTC (16 years, 9 months ago) by greg
Changes since 2.14: +3 -2 lines
Added ambient pre-synchronization in parallel persist mode
Wed Apr 5 06:22:57 2006 UTC (18 years, 2 months ago) by greg
Changes since 2.13: +8 -3 lines
Made -u+ option truly random
Sun Feb 5 22:22:20 2006 UTC (18 years, 4 months ago) by greg
Added -V option to rtcontrib and -oV option to rtrace to report contributions
Wed Jun 15 15:36:52 2005 UTC (19 years ago) by greg
Thu Jun 2 04:47:27 2005 UTC (19 years ago) by greg
Changes since 2.10: +1 -5 lines
Wed May 25 04:44:26 2005 UTC (19 years ago) by greg
Changes since 2.9: +11 -5 lines
Changes since 2.8: +23 -23 lines
Tue Oct 21 19:19:28 2003 UTC (20 years, 7 months ago) by schorsch
Mon Jul 14 20:02:30 2003 UTC (20 years, 11 months ago) by schorsch
Changes since 2.6: +2 -4 lines
Changes since 2.4: +9 -1 lines
Changes since 2.3: +8 -11 lines
Tue May 13 17:58:33 2003 UTC (21 years, 1 month ago) by greg
Diff to selected 2.10
