--- ray/src/rt/rtmain.c 2003/02/22 02:07:29 2.1
+++ ray/src/rt/rtmain.c 2009/12/13 19:13:04 2.19
@@ -1,80 +1,27 @@
#ifndef lint
-static const char RCSid[] = "$Id: rtmain.c,v 2.1 2003/02/22 02:07:29 greg Exp $";
+static const char RCSid[] = "$Id: rtmain.c,v 2.19 2009/12/13 19:13:04 greg Exp $";
#endif
* rtmain.c - main for rtrace per-ray calculation program
- * The Radiance Software License, Version 1.0
- * Copyright (c) 1990 - 2002 The Regents of the University of California,
- * through Lawrence Berkeley National Laboratory. All rights reserved.
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions
- * are met:
- * 1. Redistributions of source code must retain the above copyright
- * notice, this list of conditions and the following disclaimer.
- * 2. Redistributions in binary form must reproduce the above copyright
- * notice, this list of conditions and the following disclaimer in
- * the documentation and/or other materials provided with the
- * distribution.
- * 3. The end-user documentation included with the redistribution,
- * if any, must include the following acknowledgment:
- * "This product includes Radiance software
- * (http://radsite.lbl.gov/)
- * developed by the Lawrence Berkeley National Laboratory
- * (http://www.lbl.gov/)."
- * Alternately, this acknowledgment may appear in the software itself,
- * if and wherever such third-party acknowledgments normally appear.
- * 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
- * and "The Regents of the University of California" must
- * not be used to endorse or promote products derived from this
- * software without prior written permission. For written
- * permission, please contact radiance@radsite.lbl.gov.
- * 5. Products derived from this software may not be called "Radiance",
- * nor may "Radiance" appear in their name, without prior written
- * permission of Lawrence Berkeley National Laboratory.
- * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
- * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
- * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
- * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
- * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
- * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
- * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
- * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
- * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
- * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
- * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
- * SUCH DAMAGE.
- * This software consists of voluntary contributions made by many
- * individuals on behalf of Lawrence Berkeley National Laboratory. For more
- * information on Lawrence Berkeley National Laboratory, please see
+#include "copyright.h"
-#include "ray.h"
+#include
+#include "platform.h"
+#include "rtprocess.h" /* getpid() */
+#include "resolu.h"
+#include "ray.h"
#include "source.h"
#include "ambient.h"
#include "random.h"
#include "paths.h"
-#include
+extern char *progname; /* global argv[0] */
-#include
+extern char *shm_boundary; /* boundary of shared memory */
/* persistent processes define */
#ifdef F_SETLKW
#define PERSIST 1 /* normal persist */
@@ -82,39 +29,41 @@ static const char RCSid[] = "$Id: rtmain.c,v 2.1 2003/
#define PCHILD 3 /* child of normal persist */
#endif
-char *progname; /* argv[0] */
+char *sigerr[NSIG]; /* signal error messages */
+char *errfile = NULL; /* error output file */
-char *octname; /* octree name */
+int nproc = 1; /* number of processes */
-char *sigerr[NSIG]; /* signal error messages */
+extern char *formstr(); /* string from format */
+int inform = 'a'; /* input format */
+int outform = 'a'; /* output format */
+char *outvals = "v"; /* output specification */
-char *shm_boundary = NULL; /* boundary of shared memory */
+int hresolu = 0; /* horizontal (scan) size */
+int vresolu = 0; /* vertical resolution */
-char *errfile = NULL; /* error output file */
+int imm_irrad = 0; /* compute immediate irradiance? */
+int lim_dist = 0; /* limit distance? */
-extern char *formstr(); /* string from format */
-extern int inform; /* input format */
-extern int outform; /* output format */
-extern char *outvals; /* output values */
+#ifndef MAXMODLIST
+#define MAXMODLIST 1024 /* maximum modifiers we'll track */
+#endif
-extern int hresolu; /* horizontal resolution */
-extern int vresolu; /* vertical resolution */
+extern void (*addobjnotify[])(); /* object notification calls */
+extern void tranotify(OBJECT obj);
-extern int imm_irrad; /* compute immediate irradiance? */
-extern int lim_dist; /* limit distance? */
+char *tralist[MAXMODLIST]; /* list of modifers to trace (or no) */
+int traincl = -1; /* include == 1, exclude == 0 */
-extern char *tralist[]; /* list of modifers to trace (or no) */
-extern int traincl; /* include == 1, exclude == 0 */
+static int loadflags = ~IO_FILES; /* what to load from octree */
-void onsig();
-void sigdie();
-void printdefaults();
+static void onsig(int signo);
+static void sigdie(int signo, char *msg);
+static void printdefaults(void);
int
-main(argc, argv)
-int argc;
-char *argv[];
+main(int argc, char *argv[])
#define check(ol,al) if (argv[i][ol] || \
badarg(argc-i-1,argv+i+1,al)) \
@@ -126,14 +75,21 @@ char *argv[];
case 'n': case 'N': case 'f': case 'F': \
case '-': case '0': var = 0; break; \
default: goto badopt; }
- int loadflags = ~IO_FILES;
int persist = 0;
+ char *octnm = NULL;
char **tralp;
int duped1;
int rval;
int i;
/* global program name */
progname = argv[0] = fixargv0(argv[0]);
+ /* add trace notify function */
+ for (i = 0; addobjnotify[i] != NULL; i++)
+ addobjnotify[i] = tranotify;
+ /* set our defaults */
+ maxdepth = -10;
+ minweight = 2e-3;
/* option city */
for (i = 1; i < argc; i++) {
/* expand arguments */
@@ -160,6 +116,12 @@ char *argv[];
continue;
switch (argv[i][1]) {
+ case 'n': /* number of cores */
+ check(2,"i");
+ nproc = atoi(argv[++i]);
+ if (nproc <= 0)
+ error(USER, "bad number of processes");
+ break;
case 'x': /* x resolution */
check(2,"i");
hresolu = atoi(argv[++i]);
@@ -231,7 +193,7 @@ char *argv[];
if (argv[i][2] == 'I') { /* file */
rval = wordfile(tralp,
- getpath(argv[++i],getlibpath(),R_OK));
+ getpath(argv[++i],getrlibpath(),R_OK));
if (rval < 0) {
sprintf(errmsg,
"cannot open trace include file \"%s\"",
@@ -253,7 +215,7 @@ char *argv[];
if (argv[i][2] == 'E') { /* file */
if (rval < 0) {
sprintf(errmsg,
"cannot open trace exclude file \"%s\"",
@@ -286,16 +248,36 @@ char *argv[];
goto badopt;
+ if (nproc > 1) {
+ if (persist)
+ error(USER, "multiprocessing incompatible with persist file");
+ if (hresolu > 0 && hresolu < nproc)
+ error(WARNING, "number of cores should not exceed horizontal resolution");
+ if (trace != NULL)
+ error(WARNING, "multiprocessing does not work properly with trace mode");
/* initialize object types */
initotypes();
/* initialize urand */
- initurand(2048);
+ if (rand_samp) {
+ srandom((long)time(0));
+ initurand(0);
+ } else {
+ srandom(0L);
+ initurand(2048);
/* set up signal handling */
sigdie(SIGINT, "Interrupt");
+#ifdef SIGHUP
sigdie(SIGHUP, "Hangup");
+#endif
sigdie(SIGTERM, "Terminate");
+#ifdef SIGPIPE
sigdie(SIGPIPE, "Broken pipe");
+#endif
+#ifdef SIGALRM
sigdie(SIGALRM, "Alarm clock");
+#endif
#ifdef SIGXCPU
sigdie(SIGXCPU, "CPU limit exceeded");
sigdie(SIGXFSZ, "File size exceeded");
@@ -315,12 +297,12 @@ char *argv[];
#endif
/* get octree */
if (i == argc)
- octname = NULL;
+ octnm = NULL;
else if (i == argc-1)
- octname = argv[i];
+ octnm = argv[i];
else
goto badopt;
- if (octname == NULL)
+ if (octnm == NULL)
error(USER, "missing octree argument");
/* set up output */
#ifdef PERSIST
@@ -329,13 +311,9 @@ char *argv[];
openheader();
#endif
-#ifdef MSDOS
if (outform != 'a')
- setmode(fileno(stdout), O_BINARY);
- setmode(fileno(stdin), O_BINARY);
-#endif
- readoct(octname, loadflags, &thescene, NULL);
+ SET_FILE_BINARY(stdout);
+ readoct(octnm, loadflags, &thescene, NULL);
nsceneobjs = nobjects;
if (loadflags & IO_INFO) { /* print header */
@@ -363,10 +341,11 @@ char *argv[];
while ((rval=fork()) == 0) { /* keep on forkin' */
pflock(1);
pfhold();
+ ambsync(); /* load new values */
if (rval < 0)
error(SYSTEM, "cannot fork child for persist function");
- pfdetach(); /* parent exits */
+ pfdetach(); /* parent will run then exit */
runagain:
@@ -374,7 +353,7 @@ runagain:
dupheader(); /* send header to stdout */
#endif
/* trace rays */
- rtrace(NULL);
+ rtrace(NULL, nproc);
/* flush ambient file */
ambsync();
#ifdef PERSIST
@@ -389,7 +368,6 @@ runagain:
if (persist == PCHILD) { /* wait for a signal then go again */
- close(duped1); /* release output handle */
pfhold();
raynum = nrays = 0; /* reinitialize */
goto runagain;
@@ -400,6 +378,7 @@ runagain:
badopt:
sprintf(errmsg, "command line error at '%s'", argv[i]);
error(USER, errmsg);
+ return 1; /* pro forma return */
#undef check
#undef bool
@@ -407,8 +386,9 @@ badopt:
void
-wputs(s) /* warning output function */
-char *s;
+wputs( /* warning output function */
+ char *s
int lasterrno = errno;
eputs(s);
@@ -417,8 +397,9 @@ char *s;
void
-eputs(s) /* put string to stderr */
-register char *s;
+eputs( /* put string to stderr */
+ register char *s
static int midline = 0;
@@ -436,17 +417,20 @@ register char *s;
-void
-onsig(signo) /* fatal signal */
-int signo;
+static void
+onsig( /* fatal signal */
+ int signo
static int gotsig = 0;
if (gotsig++) /* two signals and we're gone! */
_exit(signo);
+#ifdef SIGALRM
alarm(15); /* allow 15 seconds to clean up */
signal(SIGALRM, SIG_DFL); /* make certain we do die */
+#endif
eputs("signal - ");
eputs(sigerr[signo]);
eputs("\n");
@@ -454,10 +438,11 @@ int signo;
-void
-sigdie(signo, msg) /* set fatal signal */
-int signo;
-char *msg;
+static void
+sigdie( /* set fatal signal */
+ int signo,
+ char *msg
if (signal(signo, onsig) == SIG_IGN)
signal(signo, SIG_IGN);
@@ -465,26 +450,30 @@ char *msg;
-void
-printdefaults() /* print default values to stdout */
+static void
+printdefaults(void) /* print default values to stdout */
register char *cp;
if (imm_irrad)
printf("-I+\t\t\t\t# immediate irradiance on\n");
- printf("-x %-9d\t\t\t# x resolution\n", hresolu);
- printf("-y %-9d\t\t\t# y resolution\n", vresolu);
+ printf("-n %-2d\t\t\t\t# number of rendering processes\n", nproc);
+ printf("-x %-9d\t\t\t# x resolution (flush interval)\n", hresolu);
+ printf("-y %-9d\t\t\t# y resolution\n", vresolu);
printf(lim_dist ? "-ld+\t\t\t\t# limit distance on\n" :
"-ld-\t\t\t\t# limit distance off\n");
+ printf("-h%c\t\t\t\t# %s header\n", loadflags & IO_INFO ? '+' : '-',
+ loadflags & IO_INFO ? "output" : "no");
printf("-f%c%c\t\t\t\t# format input/output = %s/%s\n",
inform, outform, formstr(inform), formstr(outform));
- printf("-o%s\t\t\t\t# output", outvals);
+ printf("-o%-9s\t\t\t# output", outvals);
for (cp = outvals; *cp; cp++)
switch (*cp) {
- case 't': printf(" trace"); break;
+ case 't': case 'T': printf(" trace"); break;
case 'o': printf(" origin"); break;
case 'd': printf(" direction"); break;
case 'v': printf(" value"); break;
+ case 'V': printf(" contribution"); break;
case 'l': printf(" length"); break;
case 'L': printf(" first_length"); break;
case 'p': printf(" point"); break;
@@ -492,7 +481,10 @@ printdefaults() /* print default values to stdout */
case 'N': printf(" unperturbed_normal"); break;
case 's': printf(" surface"); break;
case 'w': printf(" weight"); break;
+ case 'W': printf(" coefficient"); break;
case 'm': printf(" modifier"); break;
+ case 'M': printf(" material"); break;
+ case '-': printf(" stroke"); break;
putchar('\n');
printf(erract[WARNING].pf != NULL ?
