--- ray/src/rt/rtmain.c 2005/05/25 04:44:26 2.10 +++ ray/src/rt/rtmain.c 2008/04/18 18:06:29 2.16 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: rtmain.c,v 2.10 2005/05/25 04:44:26 greg Exp $"; +static const char RCSid[] = "$Id: rtmain.c,v 2.16 2008/04/18 18:06:29 greg Exp $"; #endif /* * rtmain.c - main for rtrace per-ray calculation program @@ -7,7 +7,6 @@ static const char RCSid[] = "$Id: rtmain.c,v 2.10 2005 #include "copyright.h" -#include #include #include "platform.h" @@ -228,7 +227,13 @@ main(int argc, char *argv[]) /* initialize object types */ initotypes(); /* initialize urand */ - initurand(2048); + if (rand_samp) { + srandom((long)time(0)); + initurand(0); + } else { + srandom(0L); + initurand(2048); + } /* set up signal handling */ sigdie(SIGINT, "Interrupt"); #ifdef SIGHUP @@ -274,12 +279,8 @@ main(int argc, char *argv[]) openheader(); } #endif -#ifdef _WIN32 if (outform != 'a') SET_FILE_BINARY(stdout); - if (octname == NULL) - SET_FILE_BINARY(stdin); -#endif readoct(octname, loadflags, &thescene, NULL); nsceneobjs = nobjects; @@ -308,10 +309,11 @@ main(int argc, char *argv[]) while ((rval=fork()) == 0) { /* keep on forkin' */ pflock(1); pfhold(); + ambsync(); /* load new values */ } if (rval < 0) error(SYSTEM, "cannot fork child for persist function"); - pfdetach(); /* parent exits */ + pfdetach(); /* parent will run then exit */ } } runagain: @@ -424,8 +426,8 @@ printdefaults(void) /* print default values to stdou if (imm_irrad) printf("-I+\t\t\t\t# immediate irradiance on\n"); - printf("-x %-9d\t\t\t# x resolution (flush interval)\n", hresolu); - printf("-y %-9d\t\t\t# y resolution\n", vresolu); + printf("-x %-9d\t\t\t# x resolution (flush interval)\n", hresolu); + printf("-y %-9d\t\t\t# y resolution\n", vresolu); printf(lim_dist ? "-ld+\t\t\t\t# limit distance on\n" : "-ld-\t\t\t\t# limit distance off\n"); printf("-h%c\t\t\t\t# %s header\n", loadflags & IO_INFO ? '+' : '-', @@ -439,6 +441,7 @@ printdefaults(void) /* print default values to stdou case 'o': printf(" origin"); break; case 'd': printf(" direction"); break; case 'v': printf(" value"); break; + case 'V': printf(" contribution"); break; case 'l': printf(" length"); break; case 'L': printf(" first_length"); break; case 'p': printf(" point"); break; @@ -446,9 +449,9 @@ printdefaults(void) /* print default values to stdou case 'N': printf(" unperturbed_normal"); break; case 's': printf(" surface"); break; case 'w': printf(" weight"); break; + case 'W': printf(" coefficient"); break; case 'm': printf(" modifier"); break; case 'M': printf(" material"); break; - case 'W': printf(" contribution"); break; case '-': printf(" stroke"); break; } putchar('\n');
