root/radiance/ray/src/rt/rtmain.c
Revision: 2.3
Committed: Tue May 13 17:58:33 2003 UTC (22 years ago) by greg
5 * rtmain.c - main for rtrace per-ray calculation program
6 */
7
8 #include "copyright.h"
9
10 #include "ray.h"
11
12 #include "source.h"
13
14 #include "ambient.h"
15
16 #include "random.h"
17
18 #include "paths.h"
19
20 #include <sys/types.h>
21
22 #include <signal.h>
23 /* persistent processes define */
24 #ifdef F_SETLKW
25 #define PERSIST 1 /* normal persist */
26 #define PARALLEL 2 /* parallel persist */
27 #define PCHILD 3 /* child of normal persist */
28 #endif
29
30 char *progname; /* argv[0] */
31
32 char *octname; /* octree name */
33
34 char *sigerr[NSIG]; /* signal error messages */
35
36 char *shm_boundary = NULL; /* boundary of shared memory */
37
38 char *errfile = NULL; /* error output file */
39
40 extern char *formstr(); /* string from format */
41 extern int inform; /* input format */
42 extern int outform; /* output format */
43 extern char *outvals; /* output values */
44
45 extern int hresolu; /* horizontal resolution */
46 extern int vresolu; /* vertical resolution */
47
48 extern int imm_irrad; /* compute immediate irradiance? */
49 extern int lim_dist; /* limit distance? */
50
51 extern char *tralist[]; /* list of modifers to trace (or no) */
52 extern int traincl; /* include == 1, exclude == 0 */
53
54 void onsig();
55 void sigdie();
56 void printdefaults();
57
58
59 int
60 main(argc, argv)
61 int argc;
62 char *argv[];
63 {
64 #define check(ol,al) if (argv[i][ol] || \
65 badarg(argc-i-1,argv+i+1,al)) \
66 goto badopt
67 #define bool(olen,var) switch (argv[i][olen]) { \
68 case '\0': var = !var; break; \
69 case 'y': case 'Y': case 't': case 'T': \
70 case '+': case '1': var = 1; break; \
71 case 'n': case 'N': case 'f': case 'F': \
72 case '-': case '0': var = 0; break; \
73 default: goto badopt; }
74 int loadflags = ~IO_FILES;
75 int persist = 0;
76 char **tralp;
77 int duped1;
78 int rval;
79 int i;
80 /* global program name */
81 progname = argv[0] = fixargv0(argv[0]);
82 /* option city */
83 for (i = 1; i < argc; i++) {
84 /* expand arguments */
85 while ((rval = expandarg(&argc, &argv, i)) > 0)
86 ;
87 if (rval < 0) {
88 sprintf(errmsg, "cannot expand '%s'", argv[i]);
89 error(SYSTEM, errmsg);
90 }
91 if (argv[i] == NULL || argv[i][0] != '-')
92 break; /* break from options */
93 if (!strcmp(argv[i], "-version")) {
94 puts(VersionID);
95 quit(0);
96 }
97 if (!strcmp(argv[i], "-defaults") ||
98 !strcmp(argv[i], "-help")) {
99 printdefaults();
100 quit(0);
101 }
102 rval = getrenderopt(argc-i, argv+i);
103 if (rval >= 0) {
104 i += rval;
105 continue;
106 }
107 switch (argv[i][1]) {
108 case 'x': /* x resolution */
109 check(2,"i");
110 hresolu = atoi(argv[++i]);
111 break;
112 case 'y': /* y resolution */
113 check(2,"i");
114 vresolu = atoi(argv[++i]);
115 break;
116 case 'w': /* warnings */
117 rval = erract[WARNING].pf != NULL;
118 bool(2,rval);
119 if (rval) erract[WARNING].pf = wputs;
120 else erract[WARNING].pf = NULL;
121 break;
122 case 'e': /* error file */
123 check(2,"s");
124 errfile = argv[++i];
125 break;
126 case 'l': /* limit distance */
127 if (argv[i][2] != 'd')
128 goto badopt;
129 bool(3,lim_dist);
130 break;
131 case 'I': /* immed. irradiance */
132 bool(2,imm_irrad);
133 break;
134 case 'f': /* format i/o */
135 switch (argv[i][2]) {
136 case 'a': /* ascii */
137 case 'f': /* float */
138 case 'd': /* double */
139 inform = argv[i][2];
140 break;
141 default:
142 goto badopt;
143 }
144 switch (argv[i][3]) {
145 case '\0':
146 outform = inform;
147 break;
148 case 'a': /* ascii */
149 case 'f': /* float */
150 case 'd': /* double */
151 case 'c': /* color */
152 check(4,"");
153 outform = argv[i][3];
154 break;
155 default:
156 goto badopt;
157 }
158 break;
159 case 'o': /* output */
160 outvals = argv[i]+2;
161 break;
162 case 'h': /* header output */
163 rval = loadflags & IO_INFO;
164 bool(2,rval);
165 loadflags = rval ? loadflags | IO_INFO :
166 loadflags & ~IO_INFO;
167 break;
168 case 't': /* trace */
169 switch (argv[i][2]) {
170 case 'i': /* include */
171 case 'I':
172 check(3,"s");
173 if (traincl != 1) {
174 traincl = 1;
175 tralp = tralist;
176 }
177 if (argv[i][2] == 'I') { /* file */
178 rval = wordfile(tralp,
179 getpath(argv[++i],getrlibpath(),R_OK));
180 if (rval < 0) {
181 sprintf(errmsg,
182 "cannot open trace include file \"%s\"",
183 argv[i]);
184 error(SYSTEM, errmsg);
185 }
186 tralp += rval;
187 } else {
188 *tralp++ = argv[++i];
189 *tralp = NULL;
190 }
191 break;
192 case 'e': /* exclude */
193 case 'E':
194 check(3,"s");
195 if (traincl != 0) {
196 traincl = 0;
197 tralp = tralist;
198 }
199 if (argv[i][2] == 'E') { /* file */
200 rval = wordfile(tralp,
201 getpath(argv[++i],getrlibpath(),R_OK));
202 if (rval < 0) {
203 sprintf(errmsg,
204 "cannot open trace exclude file \"%s\"",
205 argv[i]);
206 error(SYSTEM, errmsg);
207 }
208 tralp += rval;
209 } else {
210 *tralp++ = argv[++i];
211 *tralp = NULL;
212 }
213 break;
214 default:
215 goto badopt;
216 }
217 break;
218 #ifdef PERSIST
219 case 'P': /* persist file */
220 if (argv[i][2] == 'P') {
221 check(3,"s");
222 persist = PARALLEL;
223 } else {
224 check(2,"s");
225 persist = PERSIST;
226 }
227 persistfile(argv[++i]);
228 break;
229 #endif
230 default:
231 goto badopt;
232 }
233 }
234 /* initialize object types */
235 initotypes();
236 /* initialize urand */
237 initurand(2048);
238 /* set up signal handling */
239 sigdie(SIGINT, "Interrupt");
240 sigdie(SIGHUP, "Hangup");
241 sigdie(SIGTERM, "Terminate");
242 sigdie(SIGPIPE, "Broken pipe");
243 sigdie(SIGALRM, "Alarm clock");
244 #ifdef SIGXCPU
245 sigdie(SIGXCPU, "CPU limit exceeded");
246 sigdie(SIGXFSZ, "File size exceeded");
247 #endif
248 /* open error file */
249 if (errfile != NULL) {
250 if (freopen(errfile, "a", stderr) == NULL)
251 quit(2);
252 fprintf(stderr, "**************\n*** PID %5d: ",
253 getpid());
254 printargs(argc, argv, stderr);
255 putc('\n', stderr);
256 fflush(stderr);
257 }
258 #ifdef NICE
259 nice(NICE); /* lower priority */
260 #endif
261 /* get octree */
262 if (i == argc)
263 octname = NULL;
264 else if (i == argc-1)
265 octname = argv[i];
266 else
267 goto badopt;
268 if (octname == NULL)
269 error(USER, "missing octree argument");
270 /* set up output */
271 #ifdef PERSIST
272 if (persist) {
273 duped1 = dup(fileno(stdout)); /* don't lose our output */
274 openheader();
275 }
276 #endif
277 #ifdef MSDOS
278 if (outform != 'a')
279 setmode(fileno(stdout), O_BINARY);
280 if (octname == NULL)
281 setmode(fileno(stdin), O_BINARY);
282 #endif
283 readoct(octname, loadflags, &thescene, NULL);
284 nsceneobjs = nobjects;
285
286 if (loadflags & IO_INFO) { /* print header */
287 printargs(i, argv, stdout);
288 printf("SOFTWARE= %s\n", VersionID);
289 fputnow(stdout);
290 fputformat(formstr(outform), stdout);
291 putchar('\n');
292 }
293
294 marksources(); /* find and mark sources */
295
296 setambient(); /* initialize ambient calculation */
297
298 #ifdef PERSIST
299 if (persist) {
300 fflush(stdout);
301 /* reconnect stdout */
302 dup2(duped1, fileno(stdout));
303 close(duped1);
304 if (persist == PARALLEL) { /* multiprocessing */
305 preload_objs(); /* preload scene */
306 shm_boundary = (char *)malloc(16);
307 strcpy(shm_boundary, "SHM_BOUNDARY");
308 while ((rval=fork()) == 0) { /* keep on forkin' */
309 pflock(1);
310 pfhold();
311 }
312 if (rval < 0)
313 error(SYSTEM, "cannot fork child for persist function");
314 pfdetach(); /* parent exits */
315 }
316 }
317 runagain:
318 if (persist)
319 dupheader(); /* send header to stdout */
320 #endif
321 /* trace rays */
322 rtrace(NULL);
323 /* flush ambient file */
324 ambsync();
325 #ifdef PERSIST
326 if (persist == PERSIST) { /* first run-through */
327 if ((rval=fork()) == 0) { /* child loops until killed */
328 pflock(1);
329 persist = PCHILD;
330 } else { /* original process exits */
331 if (rval < 0)
332 error(SYSTEM, "cannot fork child for persist function");
333 pfdetach(); /* parent exits */
334 }
335 }
336 if (persist == PCHILD) { /* wait for a signal then go again */
337 close(duped1); /* release output handle */
338 pfhold();
339 raynum = nrays = 0; /* reinitialize */
340 goto runagain;
341 }
342 #endif
343 quit(0);
344
345 badopt:
346 sprintf(errmsg, "command line error at '%s'", argv[i]);
347 error(USER, errmsg);
348
349 #undef check
350 #undef bool
351 }
352
353
354 void
355 wputs(s) /* warning output function */
356 char *s;
357 {
358 int lasterrno = errno;
359 eputs(s);
360 errno = lasterrno;
361 }
362
363
364 void
365 eputs(s) /* put string to stderr */
366 register char *s;
367 {
368 static int midline = 0;
369
370 if (!*s)
371 return;
372 if (!midline++) {
373 fputs(progname, stderr);
374 fputs(": ", stderr);
375 }
376 fputs(s, stderr);
377 if (s[strlen(s)-1] == '\n') {
378 fflush(stderr);
379 midline = 0;
380 }
381 }
382
383
384 void
385 onsig(signo) /* fatal signal */
386 int signo;
387 {
388 static int gotsig = 0;
389
390 if (gotsig++) /* two signals and we're gone! */
391 _exit(signo);
392
393 alarm(15); /* allow 15 seconds to clean up */
394 signal(SIGALRM, SIG_DFL); /* make certain we do die */
395 eputs("signal - ");
396 eputs(sigerr[signo]);
397 eputs("\n");
398 quit(3);
399 }
400
401
402 void
403 sigdie(signo, msg) /* set fatal signal */
404 int signo;
405 char *msg;
406 {
407 if (signal(signo, onsig) == SIG_IGN)
408 signal(signo, SIG_IGN);
409 sigerr[signo] = msg;
410 }
411
412
413 void
414 printdefaults() /* print default values to stdout */
415 {
416 register char *cp;
417
418 if (imm_irrad)
419 printf("-I+\t\t\t\t# immediate irradiance on\n");
420 printf("-x %-9d\t\t\t# x resolution\n", hresolu);
421 printf("-y %-9d\t\t\t# y resolution\n", vresolu);
422 printf(lim_dist ? "-ld+\t\t\t\t# limit distance on\n" :
423 "-ld-\t\t\t\t# limit distance off\n");
424 printf("-f%c%c\t\t\t\t# format input/output = %s/%s\n",
425 inform, outform, formstr(inform), formstr(outform));
426 printf("-o%s\t\t\t\t# output", outvals);
427 for (cp = outvals; *cp; cp++)
428 switch (*cp) {
429 case 't': printf(" trace"); break;
430 case 'o': printf(" origin"); break;
431 case 'd': printf(" direction"); break;
432 case 'v': printf(" value"); break;
433 case 'l': printf(" length"); break;
434 case 'L': printf(" first_length"); break;
435 case 'p': printf(" point"); break;
436 case 'n': printf(" normal"); break;
437 case 'N': printf(" unperturbed_normal"); break;
438 case 's': printf(" surface"); break;
439 case 'w': printf(" weight"); break;
440 case 'm': printf(" modifier"); break;
441 }
442 putchar('\n');
443 printf(erract[WARNING].pf != NULL ?
444 "-w+\t\t\t\t# warning messages on\n" :
445 "-w-\t\t\t\t# warning messages off\n");
446 print_rdefaults();
447 }
