feat(rtrace,rxtrace): Added -pA output option for radiometric flux
fix: Avoid array bounds errors in dimlist[] in deep ray trees
fix(rvu): Issue with live reset of -u boolean and consistency improvements
feat(rtrace,rxtrace): Improved header output
fix(rpict,rtrace,rcontrib): Removed spurious warnings
refactor: moved memory sharing routines to preload.c with common call interface
fix(rtrace): compile error due to const
feat(rtrace): Improved diagnostic output
fix: Added missing eol escape for Windows
feat(rpict,rtrace,rcontrib): Added OutputCS to features list
fix(rtrace): bug for float spectral output
fix(rtrace): made spectral settings interaction more robust
fix(rcontrib): Removed participating media from rcontrib -features
fix(rtrace,rcontrib): Added i/o format options to features list
fix: Actually, need to allow -features to have arguments
fix: fixed crash when executed with no arguments
fix: Paired savqstr() and freeqstr() calls for octname
feat(rpict,rtrace,rcontrib): Added Output= list to -features
fix(rcontrib): removed AdaptiveShadowTesting from feature list (didn't belong)
fix(rtrace): corrected defaults reporting with tilde
style: indentation
fix(rpict): Bug in header output with -o option
Removed superfluous warnings
Fixes and improvements from last change, making ray-casting faster
Made start-up much faster when only doing ray-casting
Added NCOMP= to header and better checking of -o* options
Added BigEndian= line to binary header output
Made settings consistent with claims of matching rtrace and added missing rand_samp
newer C++ compilers have a standard type named "bool". rename macro to get rid of warnings.
Added missing external declaration
Fixed assignment of octname and removed redundant call to ray_init_pmap()
Reset default -u+ setting
Bug fix in -P option implementation
Modified rtcontrib -c option to accumulate a specified number of rays
Added ambient pre-synchronization in parallel persist mode
Made -u+ option truly random
Added -V option to rtcontrib and -oV option to rtrace to report contributions
Moved some more platform dependencies to common header files. Included a few necessary system headers.
Abstracted process and path handling for Windows. Renamed FLOAT to RREAL because of conflict on Windows. Added conditional compiles for some signal handlers.
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
