#ifndef lint static const char RCSid[] = "$Id: rtmain.c,v 2.62 2025/12/05 17:51:34 greg Exp $"; #endif /* * rtmain.c - main for rtrace per-ray calculation program */ #include "copyright.h" #include #include "platform.h" #include "rtprocess.h" /* getpid() */ #include "resolu.h" #include "ray.h" #include "func.h" #include "source.h" #include "ambient.h" #include "random.h" #include "pmapray.h" /* persistent processes define */ #ifdef F_SETLKW #define PERSIST 1 /* normal persist */ #define PARALLEL 2 /* parallel persist */ #define PCHILD 3 /* child of normal persist */ #endif char *sigerr[NSIG]; /* signal error messages */ char *errfile = NULL; /* error output file */ int nproc = 1; /* number of processes */ extern int setrtoutput(void); /* set output values */ int inform = 'a'; /* input format */ int outform = 'a'; /* output format */ char *outvals = "v"; /* output specification */ int hresolu = 0; /* horizontal (scan) size */ int vresolu = 0; /* vertical resolution */ extern int castonly; /* only doing ray-casting? */ int imm_irrad = 0; /* compute immediate irradiance? */ int lim_dist = 0; /* limit distance? */ #ifndef MAXMODLIST #define MAXMODLIST 1024 /* maximum modifiers we'll track */ #endif extern void (*addobjnotify[])(); /* object notification calls */ extern void tranotify(OBJECT obj); char *tralist[MAXMODLIST]; /* list of modifers to trace (or no) */ int traincl = -1; /* include == 1, exclude == 0 */ double (*sens_curve)(const SCOLOR scol) = NULL; /* spectral conversion for 1-channel */ double out_scalefactor = 1; /* output calibration scale factor */ RGBPRIMP out_prims = stdprims; /* output color primitives (NULL if spectral) */ static RGBPRIMS our_prims; /* private output color primitives */ static int loadflags = ~IO_FILES; /* what to load from octree */ static void onsig(int signo); static void sigdie(int signo, char *msg); static void printdefaults(void); #ifdef PERSIST #define RTRACE_FEATURES "Persist\nParallelPersist\nMultiprocessing\n" \ "IrradianceCalc\nImmediateIrradiance\nDistanceLimiting\n" \ "ParticipatingMedia=Mist\n" \ "HessianAmbientCache\nAmbientAveraging\n" \ "AmbientValueSharing\nAdaptiveShadowTesting\n" \ "InputFormats=a,f,d\nOutputFormats=a,f,d,c\n" \ "Outputs=o,d,v,V,w,W,l,L,c,p,n,N,s,m,M,r,x,R,X,~\n" \ "OutputCS=RGB,XYZ,Y,S,M,prims,spec\n" #else #define RTRACE_FEATURES "IrradianceCalc\nIrradianceCalc\nDistanceLimiting\n" \ "ParticipatingMedia=Mist\n" \ "HessianAmbientCache\nAmbientAveraging\n" \ "AmbientValueSharing\nAdaptiveShadowTesting\n" \ "InputFormats=a,f,d\nOutputFormats=a,f,d,c\n" \ "Outputs=o,d,v,V,w,W,l,L,c,p,n,N,s,m,M,r,x,R,X,~\n" \ "OutputCS=RGB,XYZ,Y,S,M,prims,spec\n" #endif int main(int argc, char *argv[]) { #define check(ol,al) if (argv[i][ol] || \ badarg(argc-i-1,argv+i+1,al)) \ goto badopt #define check_bool(olen,var) switch (argv[i][olen]) { \ case '\0': var = !var; break; \ case 'y': case 'Y': case 't': case 'T': \ case '+': case '1': var = 1; break; \ case 'n': case 'N': case 'f': case 'F': \ case '-': case '0': var = 0; break; \ default: goto badopt; } extern char *octname; int persist = 0; char *octnm = NULL; char **tralp = NULL; int duped1 = -1; int rval; int i; /* global program name */ progname = argv[0] = fixargv0(argv[0]); /* feature check only? */ strcat(RFeatureList, RTRACE_FEATURES); if (argc > 1 && !strcmp(argv[1], "-features")) return feature_status(argc-2, argv+2); /* initialize calcomp routines */ initfunc(); /* add trace notify function */ for (i = 0; addobjnotify[i] != NULL; i++) ; addobjnotify[i] = tranotify; /* option city */ for (i = 1; i < argc; i++) { /* expand arguments */ while ((rval = expandarg(&argc, &argv, i)) > 0) ; if (rval < 0) { sprintf(errmsg, "cannot expand '%s'", argv[i]); error(SYSTEM, errmsg); } if (argv[i] == NULL || argv[i][0] != '-') break; /* break from options */ if (!strcmp(argv[i], "-version")) { puts(VersionID); quit(0); } if (!strcmp(argv[i], "-defaults") || !strcmp(argv[i], "-help")) { printdefaults(); quit(0); } rval = getrenderopt(argc-i, argv+i); if (rval >= 0) { i += rval; continue; } switch (argv[i][1]) { case 'n': /* number of cores */ check(2,"i"); nproc = atoi(argv[++i]); if (nproc <= 0) error(USER, "bad number of processes"); break; case 'x': /* x resolution */ check(2,"i"); hresolu = atoi(argv[++i]); break; case 'y': /* y resolution */ check(2,"i"); vresolu = atoi(argv[++i]); break; case 'w': /* warnings & spectral */ rval = erract[WARNING].pf != NULL; check_bool(2,rval); if (rval) erract[WARNING].pf = wputs; else erract[WARNING].pf = NULL; break; case 'e': /* error file */ check(2,"s"); errfile = argv[++i]; break; case 'l': /* limit distance */ if (argv[i][2] != 'd') goto badopt; check_bool(3,lim_dist); break; case 'I': /* immed. irradiance */ check_bool(2,imm_irrad); break; case 'f': /* format i/o */ switch (argv[i][2]) { case 'a': /* ascii */ case 'f': /* float */ case 'd': /* double */ inform = argv[i][2]; break; default: goto badopt; } switch (argv[i][3]) { case '\0': outform = inform; break; case 'a': /* ascii */ case 'f': /* float */ case 'd': /* double */ case 'c': /* color */ check(4,""); outform = argv[i][3]; break; default: goto badopt; } break; case 'o': /* output */ outvals = argv[i]+2; break; case 'h': /* header output */ rval = loadflags & IO_INFO; check_bool(2,rval); loadflags = rval ? loadflags | IO_INFO : loadflags & ~IO_INFO; break; case 't': /* trace */ switch (argv[i][2]) { case 'i': /* include */ case 'I': check(3,"s"); if (traincl != 1) { traincl = 1; tralp = tralist; } if (argv[i][2] == 'I') { /* file */ rval = wordfile(tralp, MAXMODLIST-(tralp-tralist), getpath(argv[++i],getrlibpath(),R_OK)); if (rval < 0) { sprintf(errmsg, "cannot open trace include file \"%s\"", argv[i]); error(SYSTEM, errmsg); } tralp += rval; } else { *tralp++ = argv[++i]; *tralp = NULL; } break; case 'e': /* exclude */ case 'E': check(3,"s"); if (traincl != 0) { traincl = 0; tralp = tralist; } if (argv[i][2] == 'E') { /* file */ rval = wordfile(tralp, MAXMODLIST-(tralp-tralist), getpath(argv[++i],getrlibpath(),R_OK)); if (rval < 0) { sprintf(errmsg, "cannot open trace exclude file \"%s\"", argv[i]); error(SYSTEM, errmsg); } tralp += rval; } else { *tralp++ = argv[++i]; *tralp = NULL; } break; default: goto badopt; } break; case 'p': /* value output */ switch (argv[i][2]) { case 'R': /* standard RGB output */ if (strcmp(argv[i]+2, "RGB")) goto badopt; out_prims = stdprims; out_scalefactor = 1; sens_curve = NULL; break; case 'X': /* XYZ output */ if (strcmp(argv[i]+2, "XYZ")) goto badopt; out_prims = xyzprims; out_scalefactor = WHTEFFICACY; sens_curve = NULL; break; case 'c': { int j; check(3,"ffffffff"); rval = 0; for (j = 0; j < 8; j++) { our_prims[0][j] = atof(argv[++i]); rval |= fabs(our_prims[0][j]-stdprims[0][j]) > .001; } if (rval) { if (!colorprimsOK(our_prims)) error(USER, "illegal primary chromaticities"); out_prims = our_prims; } else out_prims = stdprims; out_scalefactor = 1; sens_curve = NULL; } break; case 'Y': /* photopic response */ if (argv[i][3]) goto badopt; sens_curve = scolor_photopic; out_scalefactor = WHTEFFICACY; break; case 'S': /* scotopic response */ if (argv[i][3]) goto badopt; out_scalefactor = WHTSCOTOPIC; sens_curve = scolor_scotopic; break; case 'M': /* melanopic response */ if (argv[i][3]) goto badopt; out_scalefactor = WHTMELANOPIC; sens_curve = scolor_melanopic; break; case 'A': /* radiometric average */ if (argv[i][3]) goto badopt; out_scalefactor = 1; sens_curve = scolor_mean; break; default: goto badopt; } break; #if MAXCSAMP>3 case 'c': /* output spectral results */ if (argv[i][2] != 'o') goto badopt; rval = (out_prims == NULL) & (sens_curve == NULL); check_bool(3,rval); if (rval) { out_prims = NULL; sens_curve = NULL; } else if (out_prims == NULL) out_prims = stdprims; break; #endif #ifdef PERSIST case 'P': /* persist file */ if (argv[i][2] == 'P') { check(3,"s"); persist = PARALLEL; } else { check(2,"s"); persist = PERSIST; } persistfile(argv[++i]); break; #endif default: goto badopt; } } /* set/check spectral sampling */ rval = setspectrsamp(CNDX, WLPART); if (rval < 0) error(USER, "unsupported spectral sampling"); if (sens_curve != NULL) out_prims = NULL; else if (out_prims != NULL) { if (!rval) error(WARNING, "spectral range incompatible with color output"); } else if (NCSAMP == 3) out_prims = stdprims; /* 3 samples do not a spectrum make */ if (nproc > 1 && persist) error(USER, "multiprocessing incompatible with persist file"); /* initialize object types */ initotypes(); /* initialize urand */ reset_random(); /* set up signal handling */ sigdie(SIGINT, "Interrupt"); #ifdef SIGHUP sigdie(SIGHUP, "Hangup"); #endif sigdie(SIGTERM, "Terminate"); #ifdef SIGPIPE sigdie(SIGPIPE, "Broken pipe"); #endif #ifdef SIGALRM sigdie(SIGALRM, "Alarm clock"); #endif #ifdef SIGXCPU sigdie(SIGXCPU, "CPU limit exceeded"); sigdie(SIGXFSZ, "File size exceeded"); #endif /* open error file */ if (errfile != NULL) { if (freopen(errfile, "a", stderr) == NULL) quit(2); fprintf(stderr, "**************\n*** PID %5d: ", getpid()); printargs(argc, argv, stderr); putc('\n', stderr); fflush(stderr); } #ifdef NICE nice(NICE); /* lower priority */ #endif /* get octree */ if (i == argc) octnm = NULL; else if (i == argc-1) octnm = argv[i]; else goto badopt; if (octnm == NULL) error(USER, "missing octree argument"); /* set up output */ #ifdef PERSIST if (persist) { duped1 = dup(fileno(stdout)); /* don't lose our output */ openheader(); } #endif if (outform != 'a') SET_FILE_BINARY(stdout); rval = setrtoutput(); octname = savqstr(octnm); readoct(octname, loadflags, &thescene, NULL); nsceneobjs = nobjects; if (loadflags & IO_INFO) { /* print header */ printargs(i, argv, stdout); printf("SOFTWARE= %s\n", VersionID); fputnow(stdout); if (rval > 0) /* saved from setrtoutput() call */ fputncomp(rval, stdout); if (NCSAMP > 3) fputwlsplit(WLPART, stdout); if ((out_prims != stdprims) & (out_prims != NULL)) fputprims(out_prims, stdout); if ((outform == 'f') | (outform == 'd')) fputendian(stdout); fputformat(formstr(outform), stdout); fputc('\n', stdout); /* end of header */ } if (!castonly) { /* any actual ray traversal to do? */ ray_init_pmap(); /* PMAP: set up & load photon maps */ marksources(); /* find and mark sources */ setambient(); /* initialize ambient calculation */ } else distantsources(); /* else mark only distant sources */ fflush(stdout); /* in case we're duplicating header */ #ifdef PERSIST if (persist) { /* reconnect stdout */ dup2(duped1, fileno(stdout)); close(duped1); if (persist == PARALLEL) { /* multiprocessing */ cow_memshare(); /* preloads scene */ while ((rval=fork()) == 0) { /* keep on forkin' */ pflock(1); pfhold(); ambsync(); /* load new values */ } if (rval < 0) error(SYSTEM, "cannot fork child for persist function"); pfdetach(); /* parent will run then exit */ } } runagain: if (persist) dupheader(); /* send header to stdout */ #endif /* trace rays */ rtrace(NULL, nproc); /* flush ambient file */ ambsync(); #ifdef PERSIST if (persist == PERSIST) { /* first run-through */ if ((rval=fork()) == 0) { /* child loops until killed */ pflock(1); persist = PCHILD; } else { /* original process exits */ if (rval < 0) error(SYSTEM, "cannot fork child for persist function"); pfdetach(); /* parent exits */ } } if (persist == PCHILD) { /* wait for a signal then go again */ pfhold(); raynum = nrays = 0; /* reinitialize */ goto runagain; } #endif ray_done_pmap(); /* PMAP: free photon maps */ quit(0); badopt: sprintf(errmsg, "command line error at '%s'", argv[i]); error(USER, errmsg); return 1; /* pro forma return */ #undef check #undef check_bool } void wputs( /* warning output function */ const char *s ) { int lasterrno = errno; if (erract[WARNING].pf == NULL) return; /* called by calcomp or someone */ eputs(s); errno = lasterrno; } void eputs( /* put string to stderr */ const char *s ) { static int midline = 0; if (!*s) return; if (!midline++) { fputs(progname, stderr); fputs(": ", stderr); } fputs(s, stderr); if (s[strlen(s)-1] == '\n') { fflush(stderr); midline = 0; } } static void onsig( /* fatal signal */ int signo ) { static int gotsig = 0; if (gotsig++) /* two signals and we're gone! */ _exit(signo); #ifdef SIGALRM alarm(15); /* allow 15 seconds to clean up */ signal(SIGALRM, SIG_DFL); /* make certain we do die */ #endif eputs("signal - "); eputs(sigerr[signo]); eputs("\n"); quit(3); } static void sigdie( /* set fatal signal */ int signo, char *msg ) { if (signal(signo, onsig) == SIG_IGN) signal(signo, SIG_IGN); sigerr[signo] = msg; } static void printdefaults(void) /* print default values to stdout */ { char *cp; printf(erract[WARNING].pf != NULL ? "-w+\t\t\t\t# warning messages on\n" : "-w-\t\t\t\t# warning messages off\n"); if (imm_irrad) printf("-I+\t\t\t\t# immediate irradiance on\n"); printf("-n %-2d\t\t\t\t# number of rendering processes\n", nproc); printf("-x %-9d\t\t\t# %s\n", hresolu, vresolu && hresolu ? "x resolution" : "flush interval"); printf("-y %-9d\t\t\t# y resolution\n", vresolu); printf(lim_dist ? "-ld+\t\t\t\t# limit distance on\n" : "-ld-\t\t\t\t# limit distance off\n"); printf(loadflags & IO_INFO ? "-h+\t\t\t\t# output header\n" : "-h-\t\t\t\t# no header\n"); printf("-f%c%c\t\t\t\t# format input/output = %s/%s\n", inform, outform, formstr(inform), formstr(outform)); printf("-o%-9s\t\t\t# output", outvals); for (cp = outvals; *cp; cp++) switch (*cp) { case 't': case 'T': printf(" trace"); break; case 'o': printf(" origin"); break; case 'd': printf(" direction"); break; case 'r': printf(" reflect_contrib"); break; case 'R': printf(" reflect_length"); break; case 'x': printf(" unreflect_contrib"); break; case 'X': printf(" unreflect_length"); break; case 'v': printf(" value"); break; case 'V': printf(" contribution"); break; case 'l': printf(" length"); break; case 'L': printf(" first_length"); break; case 'p': printf(" point"); break; case 'n': printf(" normal"); break; case 'N': printf(" unperturbed_normal"); break; case 's': printf(" surface"); break; case 'w': printf(" weight"); break; case 'W': printf(" coefficient"); break; case 'm': printf(" modifier"); break; case 'M': printf(" material"); break; case '~': printf(" tilde"); break; } fputc('\n', stdout); if (sens_curve == scolor_photopic) printf("-pY\t\t\t\t# photopic output\n"); else if (sens_curve == scolor_scotopic) printf("-pS\t\t\t\t# scotopic output\n"); else if (sens_curve == scolor_melanopic) printf("-pM\t\t\t\t# melanopic output\n"); else if (out_prims == stdprims) printf("-pRGB\t\t\t\t# standard RGB color output\n"); else if (out_prims == xyzprims) printf("-pXYZ\t\t\t\t# CIE XYZ color output\n"); else if (out_prims != NULL) printf("-pc %.4f %.4f %.4f %.4f %.4f %.4f %.4f %.4f\t# output color primaries and white point\n", out_prims[RED][0], out_prims[RED][1], out_prims[GRN][0], out_prims[GRN][1], out_prims[BLU][0], out_prims[BLU][1], out_prims[WHT][0], out_prims[WHT][1]); if ((sens_curve == NULL) & (NCSAMP > 3)) printf(out_prims != NULL ? "-co-\t\t\t\t# output tristimulus colors\n" : "-co+\t\t\t\t# output spectral values\n"); print_rdefaults(); }
