1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: rtmain.c,v 2.60 2025/06/20 03:43:17 greg Exp $"; |
3 |
#endif |
4 |
5 |
* rtmain.c - main for rtrace per-ray calculation program |
6 |
7 |
8 |
#include "copyright.h" |
9 |
10 |
#include <signal.h> |
11 |
12 |
#include "platform.h" |
13 |
#include "rtprocess.h" /* getpid() */ |
14 |
#include "resolu.h" |
15 |
#include "ray.h" |
16 |
#include "func.h" |
17 |
#include "source.h" |
18 |
#include "ambient.h" |
19 |
#include "random.h" |
20 |
#include "pmapray.h" |
21 |
/* persistent processes define */ |
22 |
#ifdef F_SETLKW |
23 |
#define PERSIST 1 /* normal persist */ |
24 |
#define PARALLEL 2 /* parallel persist */ |
25 |
#define PCHILD 3 /* child of normal persist */ |
26 |
#endif |
27 |
28 |
char *sigerr[NSIG]; /* signal error messages */ |
29 |
char *errfile = NULL; /* error output file */ |
30 |
31 |
int nproc = 1; /* number of processes */ |
32 |
33 |
extern int setrtoutput(void); /* set output values */ |
34 |
35 |
int inform = 'a'; /* input format */ |
36 |
int outform = 'a'; /* output format */ |
37 |
char *outvals = "v"; /* output specification */ |
38 |
39 |
int hresolu = 0; /* horizontal (scan) size */ |
40 |
int vresolu = 0; /* vertical resolution */ |
41 |
42 |
extern int castonly; /* only doing ray-casting? */ |
43 |
44 |
int imm_irrad = 0; /* compute immediate irradiance? */ |
45 |
int lim_dist = 0; /* limit distance? */ |
46 |
47 |
#ifndef MAXMODLIST |
48 |
#define MAXMODLIST 1024 /* maximum modifiers we'll track */ |
49 |
#endif |
50 |
51 |
extern void (*addobjnotify[])(); /* object notification calls */ |
52 |
extern void tranotify(OBJECT obj); |
53 |
54 |
char *tralist[MAXMODLIST]; /* list of modifers to trace (or no) */ |
55 |
int traincl = -1; /* include == 1, exclude == 0 */ |
56 |
57 |
double (*sens_curve)(const SCOLOR scol) = NULL; /* spectral conversion for 1-channel */ |
58 |
double out_scalefactor = 1; /* output calibration scale factor */ |
59 |
RGBPRIMP out_prims = stdprims; /* output color primitives (NULL if spectral) */ |
60 |
static RGBPRIMS our_prims; /* private output color primitives */ |
61 |
62 |
static int loadflags = ~IO_FILES; /* what to load from octree */ |
63 |
64 |
static void onsig(int signo); |
65 |
static void sigdie(int signo, char *msg); |
66 |
static void printdefaults(void); |
67 |
68 |
#ifdef PERSIST |
69 |
#define RTRACE_FEATURES "Persist\nParallelPersist\nMultiprocessing\n" \ |
70 |
"IrradianceCalc\nImmediateIrradiance\nDistanceLimiting\n" \ |
71 |
"ParticipatingMedia=Mist\n" \ |
72 |
"HessianAmbientCache\nAmbientAveraging\n" \ |
73 |
"AmbientValueSharing\nAdaptiveShadowTesting\n" \ |
74 |
"InputFormats=a,f,d\nOutputFormats=a,f,d,c\n" \ |
75 |
"Outputs=o,d,v,V,w,W,l,L,c,p,n,N,s,m,M,r,x,R,X,~\n" \ |
76 |
"OutputCS=RGB,XYZ,Y,S,M,prims,spec\n" |
77 |
#else |
78 |
#define RTRACE_FEATURES "IrradianceCalc\nIrradianceCalc\nDistanceLimiting\n" \ |
79 |
80 |
81 |
82 |
83 |
84 |
85 |
#endif |
86 |
87 |
88 |
int |
89 |
main(int argc, char *argv[]) |
90 |
91 |
#define check(ol,al) if (argv[i][ol] || \ |
92 |
badarg(argc-i-1,argv+i+1,al)) \ |
93 |
goto badopt |
94 |
#define check_bool(olen,var) switch (argv[i][olen]) { \ |
95 |
case '\0': var = !var; break; \ |
96 |
case 'y': case 'Y': case 't': case 'T': \ |
97 |
case '+': case '1': var = 1; break; \ |
98 |
case 'n': case 'N': case 'f': case 'F': \ |
99 |
case '-': case '0': var = 0; break; \ |
100 |
default: goto badopt; } |
101 |
extern char *octname; |
102 |
int persist = 0; |
103 |
char *octnm = NULL; |
104 |
char **tralp = NULL; |
105 |
int duped1 = -1; |
106 |
int rval; |
107 |
int i; |
108 |
/* global program name */ |
109 |
progname = argv[0] = fixargv0(argv[0]); |
110 |
/* feature check only? */ |
111 |
strcat(RFeatureList, RTRACE_FEATURES); |
112 |
if (argc > 1 && !strcmp(argv[1], "-features")) |
113 |
return feature_status(argc-2, argv+2); |
114 |
/* initialize calcomp routines */ |
115 |
initfunc(); |
116 |
/* add trace notify function */ |
117 |
for (i = 0; addobjnotify[i] != NULL; i++) |
118 |
119 |
addobjnotify[i] = tranotify; |
120 |
/* option city */ |
121 |
for (i = 1; i < argc; i++) { |
122 |
/* expand arguments */ |
123 |
while ((rval = expandarg(&argc, &argv, i)) > 0) |
124 |
125 |
if (rval < 0) { |
126 |
sprintf(errmsg, "cannot expand '%s'", argv[i]); |
127 |
error(SYSTEM, errmsg); |
128 |
129 |
if (argv[i] == NULL || argv[i][0] != '-') |
130 |
break; /* break from options */ |
131 |
if (!strcmp(argv[i], "-version")) { |
132 |
puts(VersionID); |
133 |
quit(0); |
134 |
135 |
if (!strcmp(argv[i], "-defaults") || |
136 |
!strcmp(argv[i], "-help")) { |
137 |
printdefaults(); |
138 |
quit(0); |
139 |
140 |
rval = getrenderopt(argc-i, argv+i); |
141 |
if (rval >= 0) { |
142 |
i += rval; |
143 |
continue; |
144 |
145 |
switch (argv[i][1]) { |
146 |
case 'n': /* number of cores */ |
147 |
check(2,"i"); |
148 |
nproc = atoi(argv[++i]); |
149 |
if (nproc <= 0) |
150 |
error(USER, "bad number of processes"); |
151 |
break; |
152 |
case 'x': /* x resolution */ |
153 |
check(2,"i"); |
154 |
hresolu = atoi(argv[++i]); |
155 |
break; |
156 |
case 'y': /* y resolution */ |
157 |
check(2,"i"); |
158 |
vresolu = atoi(argv[++i]); |
159 |
break; |
160 |
case 'w': /* warnings & spectral */ |
161 |
rval = erract[WARNING].pf != NULL; |
162 |
check_bool(2,rval); |
163 |
if (rval) erract[WARNING].pf = wputs; |
164 |
else erract[WARNING].pf = NULL; |
165 |
break; |
166 |
case 'e': /* error file */ |
167 |
check(2,"s"); |
168 |
errfile = argv[++i]; |
169 |
break; |
170 |
case 'l': /* limit distance */ |
171 |
if (argv[i][2] != 'd') |
172 |
goto badopt; |
173 |
check_bool(3,lim_dist); |
174 |
break; |
175 |
case 'I': /* immed. irradiance */ |
176 |
check_bool(2,imm_irrad); |
177 |
break; |
178 |
case 'f': /* format i/o */ |
179 |
switch (argv[i][2]) { |
180 |
case 'a': /* ascii */ |
181 |
case 'f': /* float */ |
182 |
case 'd': /* double */ |
183 |
inform = argv[i][2]; |
184 |
break; |
185 |
default: |
186 |
goto badopt; |
187 |
188 |
switch (argv[i][3]) { |
189 |
case '\0': |
190 |
outform = inform; |
191 |
break; |
192 |
193 |
194 |
195 |
case 'c': /* color */ |
196 |
check(4,""); |
197 |
outform = argv[i][3]; |
198 |
break; |
199 |
default: |
200 |
goto badopt; |
201 |
202 |
break; |
203 |
case 'o': /* output */ |
204 |
outvals = argv[i]+2; |
205 |
break; |
206 |
case 'h': /* header output */ |
207 |
rval = loadflags & IO_INFO; |
208 |
209 |
loadflags = rval ? loadflags | IO_INFO : |
210 |
loadflags & ~IO_INFO; |
211 |
break; |
212 |
case 't': /* trace */ |
213 |
214 |
case 'i': /* include */ |
215 |
case 'I': |
216 |
check(3,"s"); |
217 |
if (traincl != 1) { |
218 |
traincl = 1; |
219 |
tralp = tralist; |
220 |
221 |
if (argv[i][2] == 'I') { /* file */ |
222 |
rval = wordfile(tralp, MAXMODLIST-(tralp-tralist), |
223 |
getpath(argv[++i],getrlibpath(),R_OK)); |
224 |
if (rval < 0) { |
225 |
sprintf(errmsg, |
226 |
"cannot open trace include file \"%s\"", |
227 |
argv[i]); |
228 |
229 |
230 |
tralp += rval; |
231 |
} else { |
232 |
*tralp++ = argv[++i]; |
233 |
*tralp = NULL; |
234 |
235 |
break; |
236 |
case 'e': /* exclude */ |
237 |
case 'E': |
238 |
check(3,"s"); |
239 |
if (traincl != 0) { |
240 |
traincl = 0; |
241 |
tralp = tralist; |
242 |
243 |
if (argv[i][2] == 'E') { /* file */ |
244 |
245 |
246 |
if (rval < 0) { |
247 |
sprintf(errmsg, |
248 |
"cannot open trace exclude file \"%s\"", |
249 |
argv[i]); |
250 |
251 |
252 |
tralp += rval; |
253 |
} else { |
254 |
255 |
*tralp = NULL; |
256 |
257 |
break; |
258 |
default: |
259 |
goto badopt; |
260 |
261 |
break; |
262 |
case 'p': /* value output */ |
263 |
264 |
case 'R': /* standard RGB output */ |
265 |
if (strcmp(argv[i]+2, "RGB")) |
266 |
goto badopt; |
267 |
out_prims = stdprims; |
268 |
out_scalefactor = 1; |
269 |
sens_curve = NULL; |
270 |
break; |
271 |
case 'X': /* XYZ output */ |
272 |
if (strcmp(argv[i]+2, "XYZ")) |
273 |
goto badopt; |
274 |
out_prims = xyzprims; |
275 |
out_scalefactor = WHTEFFICACY; |
276 |
277 |
break; |
278 |
case 'c': { |
279 |
int j; |
280 |
check(3,"ffffffff"); |
281 |
rval = 0; |
282 |
for (j = 0; j < 8; j++) { |
283 |
our_prims[0][j] = atof(argv[++i]); |
284 |
rval |= fabs(our_prims[0][j]-stdprims[0][j]) > .001; |
285 |
286 |
if (rval) { |
287 |
if (!colorprimsOK(our_prims)) |
288 |
error(USER, "illegal primary chromaticities"); |
289 |
out_prims = our_prims; |
290 |
} else |
291 |
292 |
293 |
294 |
} break; |
295 |
case 'Y': /* photopic response */ |
296 |
if (argv[i][3]) |
297 |
goto badopt; |
298 |
sens_curve = scolor_photopic; |
299 |
300 |
break; |
301 |
case 'S': /* scotopic response */ |
302 |
if (argv[i][3]) |
303 |
goto badopt; |
304 |
sens_curve = scolor_scotopic; |
305 |
out_scalefactor = WHTSCOTOPIC; |
306 |
break; |
307 |
case 'M': /* melanopic response */ |
308 |
if (argv[i][3]) |
309 |
goto badopt; |
310 |
sens_curve = scolor_melanopic; |
311 |
out_scalefactor = WHTMELANOPIC; |
312 |
break; |
313 |
default: |
314 |
goto badopt; |
315 |
316 |
break; |
317 |
#if MAXCSAMP>3 |
318 |
case 'c': /* output spectral results */ |
319 |
if (argv[i][2] != 'o') |
320 |
goto badopt; |
321 |
rval = (out_prims == NULL) & (sens_curve == NULL); |
322 |
check_bool(3,rval); |
323 |
if (rval) { |
324 |
out_prims = NULL; |
325 |
326 |
} else if (out_prims == NULL) |
327 |
328 |
break; |
329 |
#endif |
330 |
#ifdef PERSIST |
331 |
case 'P': /* persist file */ |
332 |
if (argv[i][2] == 'P') { |
333 |
check(3,"s"); |
334 |
persist = PARALLEL; |
335 |
} else { |
336 |
check(2,"s"); |
337 |
persist = PERSIST; |
338 |
339 |
persistfile(argv[++i]); |
340 |
break; |
341 |
#endif |
342 |
default: |
343 |
goto badopt; |
344 |
345 |
346 |
/* set/check spectral sampling */ |
347 |
rval = setspectrsamp(CNDX, WLPART); |
348 |
if (rval < 0) |
349 |
error(USER, "unsupported spectral sampling"); |
350 |
if (sens_curve != NULL) |
351 |
out_prims = NULL; |
352 |
else if (out_prims != NULL) { |
353 |
if (!rval) |
354 |
error(WARNING, "spectral range incompatible with color output"); |
355 |
} else if (NCSAMP == 3) |
356 |
out_prims = stdprims; /* 3 samples do not a spectrum make */ |
357 |
if (nproc > 1 && persist) |
358 |
error(USER, "multiprocessing incompatible with persist file"); |
359 |
/* initialize object types */ |
360 |
initotypes(); |
361 |
/* initialize urand */ |
362 |
reset_random(); |
363 |
/* set up signal handling */ |
364 |
sigdie(SIGINT, "Interrupt"); |
365 |
#ifdef SIGHUP |
366 |
sigdie(SIGHUP, "Hangup"); |
367 |
#endif |
368 |
sigdie(SIGTERM, "Terminate"); |
369 |
#ifdef SIGPIPE |
370 |
sigdie(SIGPIPE, "Broken pipe"); |
371 |
#endif |
372 |
#ifdef SIGALRM |
373 |
sigdie(SIGALRM, "Alarm clock"); |
374 |
#endif |
375 |
#ifdef SIGXCPU |
376 |
sigdie(SIGXCPU, "CPU limit exceeded"); |
377 |
sigdie(SIGXFSZ, "File size exceeded"); |
378 |
#endif |
379 |
/* open error file */ |
380 |
if (errfile != NULL) { |
381 |
if (freopen(errfile, "a", stderr) == NULL) |
382 |
quit(2); |
383 |
fprintf(stderr, "**************\n*** PID %5d: ", |
384 |
getpid()); |
385 |
printargs(argc, argv, stderr); |
386 |
putc('\n', stderr); |
387 |
fflush(stderr); |
388 |
389 |
#ifdef NICE |
390 |
nice(NICE); /* lower priority */ |
391 |
#endif |
392 |
/* get octree */ |
393 |
if (i == argc) |
394 |
octnm = NULL; |
395 |
else if (i == argc-1) |
396 |
octnm = argv[i]; |
397 |
else |
398 |
goto badopt; |
399 |
if (octnm == NULL) |
400 |
error(USER, "missing octree argument"); |
401 |
/* set up output */ |
402 |
#ifdef PERSIST |
403 |
if (persist) { |
404 |
duped1 = dup(fileno(stdout)); /* don't lose our output */ |
405 |
openheader(); |
406 |
407 |
#endif |
408 |
if (outform != 'a') |
409 |
SET_FILE_BINARY(stdout); |
410 |
rval = setrtoutput(); |
411 |
octname = savqstr(octnm); |
412 |
readoct(octname, loadflags, &thescene, NULL); |
413 |
nsceneobjs = nobjects; |
414 |
415 |
if (loadflags & IO_INFO) { /* print header */ |
416 |
printargs(i, argv, stdout); |
417 |
printf("SOFTWARE= %s\n", VersionID); |
418 |
fputnow(stdout); |
419 |
if (rval > 0) /* saved from setrtoutput() call */ |
420 |
fputncomp(rval, stdout); |
421 |
if (NCSAMP > 3) |
422 |
fputwlsplit(WLPART, stdout); |
423 |
if ((out_prims != stdprims) & (out_prims != NULL)) |
424 |
fputprims(out_prims, stdout); |
425 |
if ((outform == 'f') | (outform == 'd')) |
426 |
fputendian(stdout); |
427 |
fputformat(formstr(outform), stdout); |
428 |
fputc('\n', stdout); /* end of header */ |
429 |
430 |
431 |
if (!castonly) { /* any actual ray traversal to do? */ |
432 |
433 |
ray_init_pmap(); /* PMAP: set up & load photon maps */ |
434 |
435 |
marksources(); /* find and mark sources */ |
436 |
437 |
setambient(); /* initialize ambient calculation */ |
438 |
} else |
439 |
distantsources(); /* else mark only distant sources */ |
440 |
441 |
fflush(stdout); /* in case we're duplicating header */ |
442 |
443 |
#ifdef PERSIST |
444 |
if (persist) { |
445 |
/* reconnect stdout */ |
446 |
dup2(duped1, fileno(stdout)); |
447 |
close(duped1); |
448 |
if (persist == PARALLEL) { /* multiprocessing */ |
449 |
cow_memshare(); /* preloads scene */ |
450 |
while ((rval=fork()) == 0) { /* keep on forkin' */ |
451 |
pflock(1); |
452 |
pfhold(); |
453 |
ambsync(); /* load new values */ |
454 |
455 |
if (rval < 0) |
456 |
error(SYSTEM, "cannot fork child for persist function"); |
457 |
pfdetach(); /* parent will run then exit */ |
458 |
459 |
460 |
runagain: |
461 |
if (persist) |
462 |
dupheader(); /* send header to stdout */ |
463 |
#endif |
464 |
/* trace rays */ |
465 |
rtrace(NULL, nproc); |
466 |
/* flush ambient file */ |
467 |
ambsync(); |
468 |
#ifdef PERSIST |
469 |
if (persist == PERSIST) { /* first run-through */ |
470 |
if ((rval=fork()) == 0) { /* child loops until killed */ |
471 |
pflock(1); |
472 |
persist = PCHILD; |
473 |
} else { /* original process exits */ |
474 |
if (rval < 0) |
475 |
476 |
pfdetach(); /* parent exits */ |
477 |
478 |
479 |
if (persist == PCHILD) { /* wait for a signal then go again */ |
480 |
pfhold(); |
481 |
raynum = nrays = 0; /* reinitialize */ |
482 |
goto runagain; |
483 |
484 |
#endif |
485 |
486 |
ray_done_pmap(); /* PMAP: free photon maps */ |
487 |
488 |
quit(0); |
489 |
490 |
badopt: |
491 |
sprintf(errmsg, "command line error at '%s'", argv[i]); |
492 |
error(USER, errmsg); |
493 |
return 1; /* pro forma return */ |
494 |
495 |
#undef check |
496 |
#undef check_bool |
497 |
498 |
499 |
500 |
void |
501 |
wputs( /* warning output function */ |
502 |
const char *s |
503 |
504 |
505 |
int lasterrno = errno; |
506 |
if (erract[WARNING].pf == NULL) |
507 |
return; /* called by calcomp or someone */ |
508 |
eputs(s); |
509 |
errno = lasterrno; |
510 |
511 |
512 |
513 |
void |
514 |
eputs( /* put string to stderr */ |
515 |
const char *s |
516 |
517 |
518 |
static int midline = 0; |
519 |
520 |
if (!*s) |
521 |
return; |
522 |
if (!midline++) { |
523 |
fputs(progname, stderr); |
524 |
fputs(": ", stderr); |
525 |
526 |
fputs(s, stderr); |
527 |
if (s[strlen(s)-1] == '\n') { |
528 |
fflush(stderr); |
529 |
midline = 0; |
530 |
531 |
532 |
533 |
534 |
static void |
535 |
onsig( /* fatal signal */ |
536 |
int signo |
537 |
538 |
539 |
static int gotsig = 0; |
540 |
541 |
if (gotsig++) /* two signals and we're gone! */ |
542 |
_exit(signo); |
543 |
544 |
#ifdef SIGALRM |
545 |
alarm(15); /* allow 15 seconds to clean up */ |
546 |
signal(SIGALRM, SIG_DFL); /* make certain we do die */ |
547 |
#endif |
548 |
eputs("signal - "); |
549 |
eputs(sigerr[signo]); |
550 |
eputs("\n"); |
551 |
quit(3); |
552 |
553 |
554 |
555 |
static void |
556 |
sigdie( /* set fatal signal */ |
557 |
int signo, |
558 |
char *msg |
559 |
560 |
561 |
if (signal(signo, onsig) == SIG_IGN) |
562 |
signal(signo, SIG_IGN); |
563 |
sigerr[signo] = msg; |
564 |
565 |
566 |
567 |
static void |
568 |
printdefaults(void) /* print default values to stdout */ |
569 |
570 |
char *cp; |
571 |
572 |
printf(erract[WARNING].pf != NULL ? |
573 |
"-w+\t\t\t\t# warning messages on\n" : |
574 |
"-w-\t\t\t\t# warning messages off\n"); |
575 |
if (imm_irrad) |
576 |
printf("-I+\t\t\t\t# immediate irradiance on\n"); |
577 |
printf("-n %-2d\t\t\t\t# number of rendering processes\n", nproc); |
578 |
printf("-x %-9d\t\t\t# %s\n", hresolu, |
579 |
vresolu && hresolu ? "x resolution" : "flush interval"); |
580 |
printf("-y %-9d\t\t\t# y resolution\n", vresolu); |
581 |
printf(lim_dist ? "-ld+\t\t\t\t# limit distance on\n" : |
582 |
"-ld-\t\t\t\t# limit distance off\n"); |
583 |
printf(loadflags & IO_INFO ? "-h+\t\t\t\t# output header\n" : |
584 |
"-h-\t\t\t\t# no header\n"); |
585 |
printf("-f%c%c\t\t\t\t# format input/output = %s/%s\n", |
586 |
inform, outform, formstr(inform), formstr(outform)); |
587 |
printf("-o%-9s\t\t\t# output", outvals); |
588 |
for (cp = outvals; *cp; cp++) |
589 |
switch (*cp) { |
590 |
case 't': case 'T': printf(" trace"); break; |
591 |
case 'o': printf(" origin"); break; |
592 |
case 'd': printf(" direction"); break; |
593 |
case 'r': printf(" reflect_contrib"); break; |
594 |
case 'R': printf(" reflect_length"); break; |
595 |
case 'x': printf(" unreflect_contrib"); break; |
596 |
case 'X': printf(" unreflect_length"); break; |
597 |
case 'v': printf(" value"); break; |
598 |
case 'V': printf(" contribution"); break; |
599 |
case 'l': printf(" length"); break; |
600 |
case 'L': printf(" first_length"); break; |
601 |
case 'p': printf(" point"); break; |
602 |
case 'n': printf(" normal"); break; |
603 |
case 'N': printf(" unperturbed_normal"); break; |
604 |
case 's': printf(" surface"); break; |
605 |
case 'w': printf(" weight"); break; |
606 |
case 'W': printf(" coefficient"); break; |
607 |
case 'm': printf(" modifier"); break; |
608 |
case 'M': printf(" material"); break; |
609 |
case '~': printf(" tilde"); break; |
610 |
611 |
fputc('\n', stdout); |
612 |
if (sens_curve == scolor_photopic) |
613 |
printf("-pY\t\t\t\t# photopic output\n"); |
614 |
else if (sens_curve == scolor_scotopic) |
615 |
printf("-pS\t\t\t\t# scotopic output\n"); |
616 |
else if (sens_curve == scolor_melanopic) |
617 |
printf("-pM\t\t\t\t# melanopic output\n"); |
618 |
else if (out_prims == stdprims) |
619 |
printf("-pRGB\t\t\t\t# standard RGB color output\n"); |
620 |
else if (out_prims == xyzprims) |
621 |
printf("-pXYZ\t\t\t\t# CIE XYZ color output\n"); |
622 |
else if (out_prims != NULL) |
623 |
printf("-pc %.4f %.4f %.4f %.4f %.4f %.4f %.4f %.4f\t# output color primaries and white point\n", |
624 |
out_prims[RED][0], out_prims[RED][1], |
625 |
out_prims[GRN][0], out_prims[GRN][1], |
626 |
out_prims[BLU][0], out_prims[BLU][1], |
627 |
out_prims[WHT][0], out_prims[WHT][1]); |
628 |
if ((sens_curve == NULL) & (NCSAMP > 3)) |
629 |
printf(out_prims != NULL ? "-co-\t\t\t\t# output tristimulus colors\n" : |
630 |
"-co+\t\t\t\t# output spectral values\n"); |
631 |
print_rdefaults(); |
632 |
