1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: rtmain.c,v 2.59 2025/06/07 05:09:46 greg Exp $"; |
3 |
#endif |
4 |
5 |
* rtmain.c - main for rtrace per-ray calculation program |
6 |
7 |
8 |
#include "copyright.h" |
9 |
10 |
#include <signal.h> |
11 |
12 |
#include "platform.h" |
13 |
#include "rtprocess.h" /* getpid() */ |
14 |
#include "resolu.h" |
15 |
#include "ray.h" |
16 |
#include "func.h" |
17 |
#include "source.h" |
18 |
#include "ambient.h" |
19 |
#include "random.h" |
20 |
#include "pmapray.h" |
21 |
22 |
extern char *progname; /* global argv[0] */ |
23 |
24 |
/* persistent processes define */ |
25 |
#ifdef F_SETLKW |
26 |
#define PERSIST 1 /* normal persist */ |
27 |
#define PARALLEL 2 /* parallel persist */ |
28 |
#define PCHILD 3 /* child of normal persist */ |
29 |
#endif |
30 |
31 |
char *sigerr[NSIG]; /* signal error messages */ |
32 |
char *errfile = NULL; /* error output file */ |
33 |
34 |
int nproc = 1; /* number of processes */ |
35 |
36 |
extern int setrtoutput(void); /* set output values */ |
37 |
38 |
int inform = 'a'; /* input format */ |
39 |
int outform = 'a'; /* output format */ |
40 |
char *outvals = "v"; /* output specification */ |
41 |
42 |
int hresolu = 0; /* horizontal (scan) size */ |
43 |
int vresolu = 0; /* vertical resolution */ |
44 |
45 |
extern int castonly; /* only doing ray-casting? */ |
46 |
47 |
int imm_irrad = 0; /* compute immediate irradiance? */ |
48 |
int lim_dist = 0; /* limit distance? */ |
49 |
50 |
#ifndef MAXMODLIST |
51 |
#define MAXMODLIST 1024 /* maximum modifiers we'll track */ |
52 |
#endif |
53 |
54 |
extern void (*addobjnotify[])(); /* object notification calls */ |
55 |
extern void tranotify(OBJECT obj); |
56 |
57 |
char *tralist[MAXMODLIST]; /* list of modifers to trace (or no) */ |
58 |
int traincl = -1; /* include == 1, exclude == 0 */ |
59 |
60 |
double (*sens_curve)(const SCOLOR scol) = NULL; /* spectral conversion for 1-channel */ |
61 |
double out_scalefactor = 1; /* output calibration scale factor */ |
62 |
RGBPRIMP out_prims = stdprims; /* output color primitives (NULL if spectral) */ |
63 |
static RGBPRIMS our_prims; /* private output color primitives */ |
64 |
65 |
static int loadflags = ~IO_FILES; /* what to load from octree */ |
66 |
67 |
static void onsig(int signo); |
68 |
static void sigdie(int signo, char *msg); |
69 |
static void printdefaults(void); |
70 |
71 |
#ifdef PERSIST |
72 |
#define RTRACE_FEATURES "Persist\nParallelPersist\nMultiprocessing\n" \ |
73 |
"IrradianceCalc\nImmediateIrradiance\nDistanceLimiting\n" \ |
74 |
"ParticipatingMedia=Mist\n" \ |
75 |
"HessianAmbientCache\nAmbientAveraging\n" \ |
76 |
"AmbientValueSharing\nAdaptiveShadowTesting\n" \ |
77 |
"InputFormats=a,f,d\nOutputFormats=a,f,d,c\n" \ |
78 |
"Outputs=o,d,v,V,w,W,l,L,c,p,n,N,s,m,M,r,x,R,X,~\n" \ |
79 |
"OutputCS=RGB,XYZ,Y,S,M,prims,spec\n" |
80 |
#else |
81 |
#define RTRACE_FEATURES "IrradianceCalc\nIrradianceCalc\nDistanceLimiting\n" \ |
82 |
83 |
84 |
85 |
86 |
87 |
88 |
#endif |
89 |
90 |
91 |
int |
92 |
main(int argc, char *argv[]) |
93 |
94 |
#define check(ol,al) if (argv[i][ol] || \ |
95 |
badarg(argc-i-1,argv+i+1,al)) \ |
96 |
goto badopt |
97 |
#define check_bool(olen,var) switch (argv[i][olen]) { \ |
98 |
case '\0': var = !var; break; \ |
99 |
case 'y': case 'Y': case 't': case 'T': \ |
100 |
case '+': case '1': var = 1; break; \ |
101 |
case 'n': case 'N': case 'f': case 'F': \ |
102 |
case '-': case '0': var = 0; break; \ |
103 |
default: goto badopt; } |
104 |
extern char *octname; |
105 |
int persist = 0; |
106 |
char *octnm = NULL; |
107 |
char **tralp = NULL; |
108 |
int duped1 = -1; |
109 |
int rval; |
110 |
int i; |
111 |
/* global program name */ |
112 |
progname = argv[0] = fixargv0(argv[0]); |
113 |
/* feature check only? */ |
114 |
strcat(RFeatureList, RTRACE_FEATURES); |
115 |
if (argc > 1 && !strcmp(argv[1], "-features")) |
116 |
return feature_status(argc-2, argv+2); |
117 |
/* initialize calcomp routines */ |
118 |
initfunc(); |
119 |
/* add trace notify function */ |
120 |
for (i = 0; addobjnotify[i] != NULL; i++) |
121 |
122 |
addobjnotify[i] = tranotify; |
123 |
/* option city */ |
124 |
for (i = 1; i < argc; i++) { |
125 |
/* expand arguments */ |
126 |
while ((rval = expandarg(&argc, &argv, i)) > 0) |
127 |
128 |
if (rval < 0) { |
129 |
sprintf(errmsg, "cannot expand '%s'", argv[i]); |
130 |
error(SYSTEM, errmsg); |
131 |
132 |
if (argv[i] == NULL || argv[i][0] != '-') |
133 |
break; /* break from options */ |
134 |
if (!strcmp(argv[i], "-version")) { |
135 |
puts(VersionID); |
136 |
quit(0); |
137 |
138 |
if (!strcmp(argv[i], "-defaults") || |
139 |
!strcmp(argv[i], "-help")) { |
140 |
printdefaults(); |
141 |
quit(0); |
142 |
143 |
rval = getrenderopt(argc-i, argv+i); |
144 |
if (rval >= 0) { |
145 |
i += rval; |
146 |
continue; |
147 |
148 |
switch (argv[i][1]) { |
149 |
case 'n': /* number of cores */ |
150 |
check(2,"i"); |
151 |
nproc = atoi(argv[++i]); |
152 |
if (nproc <= 0) |
153 |
error(USER, "bad number of processes"); |
154 |
break; |
155 |
case 'x': /* x resolution */ |
156 |
check(2,"i"); |
157 |
hresolu = atoi(argv[++i]); |
158 |
break; |
159 |
case 'y': /* y resolution */ |
160 |
check(2,"i"); |
161 |
vresolu = atoi(argv[++i]); |
162 |
break; |
163 |
case 'w': /* warnings & spectral */ |
164 |
rval = erract[WARNING].pf != NULL; |
165 |
check_bool(2,rval); |
166 |
if (rval) erract[WARNING].pf = wputs; |
167 |
else erract[WARNING].pf = NULL; |
168 |
break; |
169 |
case 'e': /* error file */ |
170 |
check(2,"s"); |
171 |
errfile = argv[++i]; |
172 |
break; |
173 |
case 'l': /* limit distance */ |
174 |
if (argv[i][2] != 'd') |
175 |
goto badopt; |
176 |
check_bool(3,lim_dist); |
177 |
break; |
178 |
case 'I': /* immed. irradiance */ |
179 |
check_bool(2,imm_irrad); |
180 |
break; |
181 |
case 'f': /* format i/o */ |
182 |
switch (argv[i][2]) { |
183 |
case 'a': /* ascii */ |
184 |
case 'f': /* float */ |
185 |
case 'd': /* double */ |
186 |
inform = argv[i][2]; |
187 |
break; |
188 |
default: |
189 |
goto badopt; |
190 |
191 |
switch (argv[i][3]) { |
192 |
case '\0': |
193 |
outform = inform; |
194 |
break; |
195 |
196 |
197 |
198 |
case 'c': /* color */ |
199 |
check(4,""); |
200 |
outform = argv[i][3]; |
201 |
break; |
202 |
default: |
203 |
goto badopt; |
204 |
205 |
break; |
206 |
case 'o': /* output */ |
207 |
outvals = argv[i]+2; |
208 |
break; |
209 |
case 'h': /* header output */ |
210 |
rval = loadflags & IO_INFO; |
211 |
212 |
loadflags = rval ? loadflags | IO_INFO : |
213 |
loadflags & ~IO_INFO; |
214 |
break; |
215 |
case 't': /* trace */ |
216 |
217 |
case 'i': /* include */ |
218 |
case 'I': |
219 |
check(3,"s"); |
220 |
if (traincl != 1) { |
221 |
traincl = 1; |
222 |
tralp = tralist; |
223 |
224 |
if (argv[i][2] == 'I') { /* file */ |
225 |
rval = wordfile(tralp, MAXMODLIST-(tralp-tralist), |
226 |
getpath(argv[++i],getrlibpath(),R_OK)); |
227 |
if (rval < 0) { |
228 |
sprintf(errmsg, |
229 |
"cannot open trace include file \"%s\"", |
230 |
argv[i]); |
231 |
232 |
233 |
tralp += rval; |
234 |
} else { |
235 |
*tralp++ = argv[++i]; |
236 |
*tralp = NULL; |
237 |
238 |
break; |
239 |
case 'e': /* exclude */ |
240 |
case 'E': |
241 |
check(3,"s"); |
242 |
if (traincl != 0) { |
243 |
traincl = 0; |
244 |
tralp = tralist; |
245 |
246 |
if (argv[i][2] == 'E') { /* file */ |
247 |
248 |
249 |
if (rval < 0) { |
250 |
sprintf(errmsg, |
251 |
"cannot open trace exclude file \"%s\"", |
252 |
argv[i]); |
253 |
254 |
255 |
tralp += rval; |
256 |
} else { |
257 |
258 |
*tralp = NULL; |
259 |
260 |
break; |
261 |
default: |
262 |
goto badopt; |
263 |
264 |
break; |
265 |
case 'p': /* value output */ |
266 |
267 |
case 'R': /* standard RGB output */ |
268 |
if (strcmp(argv[i]+2, "RGB")) |
269 |
goto badopt; |
270 |
out_prims = stdprims; |
271 |
out_scalefactor = 1; |
272 |
sens_curve = NULL; |
273 |
break; |
274 |
case 'X': /* XYZ output */ |
275 |
if (strcmp(argv[i]+2, "XYZ")) |
276 |
goto badopt; |
277 |
out_prims = xyzprims; |
278 |
out_scalefactor = WHTEFFICACY; |
279 |
280 |
break; |
281 |
case 'c': { |
282 |
int j; |
283 |
check(3,"ffffffff"); |
284 |
rval = 0; |
285 |
for (j = 0; j < 8; j++) { |
286 |
our_prims[0][j] = atof(argv[++i]); |
287 |
rval |= fabs(our_prims[0][j]-stdprims[0][j]) > .001; |
288 |
289 |
if (rval) { |
290 |
if (!colorprimsOK(our_prims)) |
291 |
error(USER, "illegal primary chromaticities"); |
292 |
out_prims = our_prims; |
293 |
} else |
294 |
295 |
296 |
297 |
} break; |
298 |
case 'Y': /* photopic response */ |
299 |
if (argv[i][3]) |
300 |
goto badopt; |
301 |
sens_curve = scolor_photopic; |
302 |
303 |
break; |
304 |
case 'S': /* scotopic response */ |
305 |
if (argv[i][3]) |
306 |
goto badopt; |
307 |
sens_curve = scolor_scotopic; |
308 |
out_scalefactor = WHTSCOTOPIC; |
309 |
break; |
310 |
case 'M': /* melanopic response */ |
311 |
if (argv[i][3]) |
312 |
goto badopt; |
313 |
sens_curve = scolor_melanopic; |
314 |
out_scalefactor = WHTMELANOPIC; |
315 |
break; |
316 |
default: |
317 |
goto badopt; |
318 |
319 |
break; |
320 |
#if MAXCSAMP>3 |
321 |
case 'c': /* output spectral results */ |
322 |
if (argv[i][2] != 'o') |
323 |
goto badopt; |
324 |
rval = (out_prims == NULL) & (sens_curve == NULL); |
325 |
check_bool(3,rval); |
326 |
if (rval) { |
327 |
out_prims = NULL; |
328 |
329 |
} else if (out_prims == NULL) |
330 |
331 |
break; |
332 |
#endif |
333 |
#ifdef PERSIST |
334 |
case 'P': /* persist file */ |
335 |
if (argv[i][2] == 'P') { |
336 |
check(3,"s"); |
337 |
persist = PARALLEL; |
338 |
} else { |
339 |
check(2,"s"); |
340 |
persist = PERSIST; |
341 |
342 |
persistfile(argv[++i]); |
343 |
break; |
344 |
#endif |
345 |
default: |
346 |
goto badopt; |
347 |
348 |
349 |
/* set/check spectral sampling */ |
350 |
rval = setspectrsamp(CNDX, WLPART); |
351 |
if (rval < 0) |
352 |
error(USER, "unsupported spectral sampling"); |
353 |
if (sens_curve != NULL) |
354 |
out_prims = NULL; |
355 |
else if (out_prims != NULL) { |
356 |
if (!rval) |
357 |
error(WARNING, "spectral range incompatible with color output"); |
358 |
} else if (NCSAMP == 3) |
359 |
out_prims = stdprims; /* 3 samples do not a spectrum make */ |
360 |
if (nproc > 1 && persist) |
361 |
error(USER, "multiprocessing incompatible with persist file"); |
362 |
/* initialize object types */ |
363 |
initotypes(); |
364 |
/* initialize urand */ |
365 |
reset_random(); |
366 |
/* set up signal handling */ |
367 |
sigdie(SIGINT, "Interrupt"); |
368 |
#ifdef SIGHUP |
369 |
sigdie(SIGHUP, "Hangup"); |
370 |
#endif |
371 |
sigdie(SIGTERM, "Terminate"); |
372 |
#ifdef SIGPIPE |
373 |
sigdie(SIGPIPE, "Broken pipe"); |
374 |
#endif |
375 |
#ifdef SIGALRM |
376 |
sigdie(SIGALRM, "Alarm clock"); |
377 |
#endif |
378 |
#ifdef SIGXCPU |
379 |
sigdie(SIGXCPU, "CPU limit exceeded"); |
380 |
sigdie(SIGXFSZ, "File size exceeded"); |
381 |
#endif |
382 |
/* open error file */ |
383 |
if (errfile != NULL) { |
384 |
if (freopen(errfile, "a", stderr) == NULL) |
385 |
quit(2); |
386 |
fprintf(stderr, "**************\n*** PID %5d: ", |
387 |
getpid()); |
388 |
printargs(argc, argv, stderr); |
389 |
putc('\n', stderr); |
390 |
fflush(stderr); |
391 |
392 |
#ifdef NICE |
393 |
nice(NICE); /* lower priority */ |
394 |
#endif |
395 |
/* get octree */ |
396 |
if (i == argc) |
397 |
octnm = NULL; |
398 |
else if (i == argc-1) |
399 |
octnm = argv[i]; |
400 |
else |
401 |
goto badopt; |
402 |
if (octnm == NULL) |
403 |
error(USER, "missing octree argument"); |
404 |
/* set up output */ |
405 |
#ifdef PERSIST |
406 |
if (persist) { |
407 |
duped1 = dup(fileno(stdout)); /* don't lose our output */ |
408 |
openheader(); |
409 |
410 |
#endif |
411 |
if (outform != 'a') |
412 |
SET_FILE_BINARY(stdout); |
413 |
rval = setrtoutput(); |
414 |
octname = savqstr(octnm); |
415 |
readoct(octname, loadflags, &thescene, NULL); |
416 |
nsceneobjs = nobjects; |
417 |
418 |
if (loadflags & IO_INFO) { /* print header */ |
419 |
printargs(i, argv, stdout); |
420 |
printf("SOFTWARE= %s\n", VersionID); |
421 |
fputnow(stdout); |
422 |
if (rval > 0) /* saved from setrtoutput() call */ |
423 |
fputncomp(rval, stdout); |
424 |
if (NCSAMP > 3) |
425 |
fputwlsplit(WLPART, stdout); |
426 |
if ((out_prims != stdprims) & (out_prims != NULL)) |
427 |
fputprims(out_prims, stdout); |
428 |
if ((outform == 'f') | (outform == 'd')) |
429 |
fputendian(stdout); |
430 |
fputformat(formstr(outform), stdout); |
431 |
fputc('\n', stdout); /* end of header */ |
432 |
433 |
434 |
if (!castonly) { /* any actual ray traversal to do? */ |
435 |
436 |
ray_init_pmap(); /* PMAP: set up & load photon maps */ |
437 |
438 |
marksources(); /* find and mark sources */ |
439 |
440 |
setambient(); /* initialize ambient calculation */ |
441 |
} else |
442 |
distantsources(); /* else mark only distant sources */ |
443 |
444 |
fflush(stdout); /* in case we're duplicating header */ |
445 |
446 |
#ifdef PERSIST |
447 |
if (persist) { |
448 |
/* reconnect stdout */ |
449 |
dup2(duped1, fileno(stdout)); |
450 |
close(duped1); |
451 |
if (persist == PARALLEL) { /* multiprocessing */ |
452 |
cow_memshare(); /* preloads scene */ |
453 |
while ((rval=fork()) == 0) { /* keep on forkin' */ |
454 |
pflock(1); |
455 |
pfhold(); |
456 |
ambsync(); /* load new values */ |
457 |
458 |
if (rval < 0) |
459 |
error(SYSTEM, "cannot fork child for persist function"); |
460 |
pfdetach(); /* parent will run then exit */ |
461 |
462 |
463 |
runagain: |
464 |
if (persist) |
465 |
dupheader(); /* send header to stdout */ |
466 |
#endif |
467 |
/* trace rays */ |
468 |
rtrace(NULL, nproc); |
469 |
/* flush ambient file */ |
470 |
ambsync(); |
471 |
#ifdef PERSIST |
472 |
if (persist == PERSIST) { /* first run-through */ |
473 |
if ((rval=fork()) == 0) { /* child loops until killed */ |
474 |
pflock(1); |
475 |
persist = PCHILD; |
476 |
} else { /* original process exits */ |
477 |
if (rval < 0) |
478 |
479 |
pfdetach(); /* parent exits */ |
480 |
481 |
482 |
if (persist == PCHILD) { /* wait for a signal then go again */ |
483 |
pfhold(); |
484 |
raynum = nrays = 0; /* reinitialize */ |
485 |
goto runagain; |
486 |
487 |
#endif |
488 |
489 |
ray_done_pmap(); /* PMAP: free photon maps */ |
490 |
491 |
quit(0); |
492 |
493 |
badopt: |
494 |
sprintf(errmsg, "command line error at '%s'", argv[i]); |
495 |
error(USER, errmsg); |
496 |
return 1; /* pro forma return */ |
497 |
498 |
#undef check |
499 |
#undef check_bool |
500 |
501 |
502 |
503 |
void |
504 |
wputs( /* warning output function */ |
505 |
const char *s |
506 |
507 |
508 |
int lasterrno = errno; |
509 |
if (erract[WARNING].pf == NULL) |
510 |
return; /* called by calcomp or someone */ |
511 |
eputs(s); |
512 |
errno = lasterrno; |
513 |
514 |
515 |
516 |
void |
517 |
eputs( /* put string to stderr */ |
518 |
const char *s |
519 |
520 |
521 |
static int midline = 0; |
522 |
523 |
if (!*s) |
524 |
return; |
525 |
if (!midline++) { |
526 |
fputs(progname, stderr); |
527 |
fputs(": ", stderr); |
528 |
529 |
fputs(s, stderr); |
530 |
if (s[strlen(s)-1] == '\n') { |
531 |
fflush(stderr); |
532 |
midline = 0; |
533 |
534 |
535 |
536 |
537 |
static void |
538 |
onsig( /* fatal signal */ |
539 |
int signo |
540 |
541 |
542 |
static int gotsig = 0; |
543 |
544 |
if (gotsig++) /* two signals and we're gone! */ |
545 |
_exit(signo); |
546 |
547 |
#ifdef SIGALRM |
548 |
alarm(15); /* allow 15 seconds to clean up */ |
549 |
signal(SIGALRM, SIG_DFL); /* make certain we do die */ |
550 |
#endif |
551 |
eputs("signal - "); |
552 |
eputs(sigerr[signo]); |
553 |
eputs("\n"); |
554 |
quit(3); |
555 |
556 |
557 |
558 |
static void |
559 |
sigdie( /* set fatal signal */ |
560 |
int signo, |
561 |
char *msg |
562 |
563 |
564 |
if (signal(signo, onsig) == SIG_IGN) |
565 |
signal(signo, SIG_IGN); |
566 |
sigerr[signo] = msg; |
567 |
568 |
569 |
570 |
static void |
571 |
printdefaults(void) /* print default values to stdout */ |
572 |
573 |
char *cp; |
574 |
575 |
printf(erract[WARNING].pf != NULL ? |
576 |
"-w+\t\t\t\t# warning messages on\n" : |
577 |
"-w-\t\t\t\t# warning messages off\n"); |
578 |
if (imm_irrad) |
579 |
printf("-I+\t\t\t\t# immediate irradiance on\n"); |
580 |
printf("-n %-2d\t\t\t\t# number of rendering processes\n", nproc); |
581 |
printf("-x %-9d\t\t\t# %s\n", hresolu, |
582 |
vresolu && hresolu ? "x resolution" : "flush interval"); |
583 |
printf("-y %-9d\t\t\t# y resolution\n", vresolu); |
584 |
printf(lim_dist ? "-ld+\t\t\t\t# limit distance on\n" : |
585 |
"-ld-\t\t\t\t# limit distance off\n"); |
586 |
printf(loadflags & IO_INFO ? "-h+\t\t\t\t# output header\n" : |
587 |
"-h-\t\t\t\t# no header\n"); |
588 |
printf("-f%c%c\t\t\t\t# format input/output = %s/%s\n", |
589 |
inform, outform, formstr(inform), formstr(outform)); |
590 |
printf("-o%-9s\t\t\t# output", outvals); |
591 |
for (cp = outvals; *cp; cp++) |
592 |
switch (*cp) { |
593 |
case 't': case 'T': printf(" trace"); break; |
594 |
case 'o': printf(" origin"); break; |
595 |
case 'd': printf(" direction"); break; |
596 |
case 'r': printf(" reflect_contrib"); break; |
597 |
case 'R': printf(" reflect_length"); break; |
598 |
case 'x': printf(" unreflect_contrib"); break; |
599 |
case 'X': printf(" unreflect_length"); break; |
600 |
case 'v': printf(" value"); break; |
601 |
case 'V': printf(" contribution"); break; |
602 |
case 'l': printf(" length"); break; |
603 |
case 'L': printf(" first_length"); break; |
604 |
case 'p': printf(" point"); break; |
605 |
case 'n': printf(" normal"); break; |
606 |
case 'N': printf(" unperturbed_normal"); break; |
607 |
case 's': printf(" surface"); break; |
608 |
case 'w': printf(" weight"); break; |
609 |
case 'W': printf(" coefficient"); break; |
610 |
case 'm': printf(" modifier"); break; |
611 |
case 'M': printf(" material"); break; |
612 |
case '~': printf(" tilde"); break; |
613 |
614 |
fputc('\n', stdout); |
615 |
if (sens_curve == scolor_photopic) |
616 |
printf("-pY\t\t\t\t# photopic output\n"); |
617 |
else if (sens_curve == scolor_scotopic) |
618 |
printf("-pS\t\t\t\t# scotopic output\n"); |
619 |
else if (sens_curve == scolor_melanopic) |
620 |
printf("-pM\t\t\t\t# melanopic output\n"); |
621 |
else if (out_prims == stdprims) |
622 |
printf("-pRGB\t\t\t\t# standard RGB color output\n"); |
623 |
else if (out_prims == xyzprims) |
624 |
printf("-pXYZ\t\t\t\t# CIE XYZ color output\n"); |
625 |
else if (out_prims != NULL) |
626 |
printf("-pc %.4f %.4f %.4f %.4f %.4f %.4f %.4f %.4f\t# output color primaries and white point\n", |
627 |
out_prims[RED][0], out_prims[RED][1], |
628 |
out_prims[GRN][0], out_prims[GRN][1], |
629 |
out_prims[BLU][0], out_prims[BLU][1], |
630 |
out_prims[WHT][0], out_prims[WHT][1]); |
631 |
if ((sens_curve == NULL) & (NCSAMP > 3)) |
632 |
printf(out_prims != NULL ? "-co-\t\t\t\t# output tristimulus colors\n" : |
633 |
"-co+\t\t\t\t# output spectral values\n"); |
634 |
print_rdefaults(); |
635 |
