root/radiance/ray/src/rt/rtmain.c
Revision: 2.19
Committed: Sun Dec 13 19:13:04 2009 UTC (15 years, 4 months ago) by greg
Changes since 2.18: +2 -6 lines
2 static const char RCSid[] = "$Id: rtmain.c,v 2.18 2009/12/12 19:01:00 greg Exp $";
5 * rtmain.c - main for rtrace per-ray calculation program
6 */
7
8 #include "copyright.h"
9
10 #include <signal.h>
11
12 #include "platform.h"
13 #include "rtprocess.h" /* getpid() */
14 #include "resolu.h"
15 #include "ray.h"
16 #include "source.h"
17 #include "ambient.h"
18 #include "random.h"
19 #include "paths.h"
20
21 extern char *progname; /* global argv[0] */
22
23 extern char *shm_boundary; /* boundary of shared memory */
24
25 /* persistent processes define */
26 #ifdef F_SETLKW
27 #define PERSIST 1 /* normal persist */
28 #define PARALLEL 2 /* parallel persist */
29 #define PCHILD 3 /* child of normal persist */
30 #endif
31
32 char *sigerr[NSIG]; /* signal error messages */
33 char *errfile = NULL; /* error output file */
34
35 int nproc = 1; /* number of processes */
36
37 extern char *formstr(); /* string from format */
38 int inform = 'a'; /* input format */
39 int outform = 'a'; /* output format */
40 char *outvals = "v"; /* output specification */
41
42 int hresolu = 0; /* horizontal (scan) size */
43 int vresolu = 0; /* vertical resolution */
44
45 int imm_irrad = 0; /* compute immediate irradiance? */
46 int lim_dist = 0; /* limit distance? */
47
48 #ifndef MAXMODLIST
49 #define MAXMODLIST 1024 /* maximum modifiers we'll track */
50 #endif
51
52 extern void (*addobjnotify[])(); /* object notification calls */
53 extern void tranotify(OBJECT obj);
54
55 char *tralist[MAXMODLIST]; /* list of modifers to trace (or no) */
56 int traincl = -1; /* include == 1, exclude == 0 */
57
58 static int loadflags = ~IO_FILES; /* what to load from octree */
59
60 static void onsig(int signo);
61 static void sigdie(int signo, char *msg);
62 static void printdefaults(void);
63
64
65 int
66 main(int argc, char *argv[])
67 {
68 #define check(ol,al) if (argv[i][ol] || \
69 badarg(argc-i-1,argv+i+1,al)) \
70 goto badopt
71 #define bool(olen,var) switch (argv[i][olen]) { \
72 case '\0': var = !var; break; \
73 case 'y': case 'Y': case 't': case 'T': \
74 case '+': case '1': var = 1; break; \
75 case 'n': case 'N': case 'f': case 'F': \
76 case '-': case '0': var = 0; break; \
77 default: goto badopt; }
78 int persist = 0;
79 char *octnm = NULL;
80 char **tralp;
81 int duped1;
82 int rval;
83 int i;
84 /* global program name */
85 progname = argv[0] = fixargv0(argv[0]);
86 /* add trace notify function */
87 for (i = 0; addobjnotify[i] != NULL; i++)
88 ;
89 addobjnotify[i] = tranotify;
90 /* set our defaults */
91 maxdepth = -10;
92 minweight = 2e-3;
93 /* option city */
94 for (i = 1; i < argc; i++) {
95 /* expand arguments */
96 while ((rval = expandarg(&argc, &argv, i)) > 0)
97 ;
98 if (rval < 0) {
99 sprintf(errmsg, "cannot expand '%s'", argv[i]);
100 error(SYSTEM, errmsg);
101 }
102 if (argv[i] == NULL || argv[i][0] != '-')
103 break; /* break from options */
104 if (!strcmp(argv[i], "-version")) {
105 puts(VersionID);
106 quit(0);
107 }
108 if (!strcmp(argv[i], "-defaults") ||
109 !strcmp(argv[i], "-help")) {
110 printdefaults();
111 quit(0);
112 }
113 rval = getrenderopt(argc-i, argv+i);
114 if (rval >= 0) {
115 i += rval;
116 continue;
117 }
118 switch (argv[i][1]) {
119 case 'n': /* number of cores */
120 check(2,"i");
121 nproc = atoi(argv[++i]);
122 if (nproc <= 0)
123 error(USER, "bad number of processes");
124 break;
125 case 'x': /* x resolution */
126 check(2,"i");
127 hresolu = atoi(argv[++i]);
128 break;
129 case 'y': /* y resolution */
130 check(2,"i");
131 vresolu = atoi(argv[++i]);
132 break;
133 case 'w': /* warnings */
134 rval = erract[WARNING].pf != NULL;
135 bool(2,rval);
136 if (rval) erract[WARNING].pf = wputs;
137 else erract[WARNING].pf = NULL;
138 break;
139 case 'e': /* error file */
140 check(2,"s");
141 errfile = argv[++i];
142 break;
143 case 'l': /* limit distance */
144 if (argv[i][2] != 'd')
145 goto badopt;
146 bool(3,lim_dist);
147 break;
148 case 'I': /* immed. irradiance */
149 bool(2,imm_irrad);
150 break;
151 case 'f': /* format i/o */
152 switch (argv[i][2]) {
153 case 'a': /* ascii */
154 case 'f': /* float */
155 case 'd': /* double */
156 inform = argv[i][2];
157 break;
158 default:
159 goto badopt;
160 }
161 switch (argv[i][3]) {
162 case '\0':
163 outform = inform;
164 break;
165 case 'a': /* ascii */
166 case 'f': /* float */
167 case 'd': /* double */
168 case 'c': /* color */
169 check(4,"");
170 outform = argv[i][3];
171 break;
172 default:
173 goto badopt;
174 }
175 break;
176 case 'o': /* output */
177 outvals = argv[i]+2;
178 break;
179 case 'h': /* header output */
180 rval = loadflags & IO_INFO;
181 bool(2,rval);
182 loadflags = rval ? loadflags | IO_INFO :
183 loadflags & ~IO_INFO;
184 break;
185 case 't': /* trace */
186 switch (argv[i][2]) {
187 case 'i': /* include */
188 case 'I':
189 check(3,"s");
190 if (traincl != 1) {
191 traincl = 1;
192 tralp = tralist;
193 }
194 if (argv[i][2] == 'I') { /* file */
195 rval = wordfile(tralp,
196 getpath(argv[++i],getrlibpath(),R_OK));
197 if (rval < 0) {
198 sprintf(errmsg,
199 "cannot open trace include file \"%s\"",
200 argv[i]);
201 error(SYSTEM, errmsg);
202 }
203 tralp += rval;
204 } else {
205 *tralp++ = argv[++i];
206 *tralp = NULL;
207 }
208 break;
209 case 'e': /* exclude */
210 case 'E':
211 check(3,"s");
212 if (traincl != 0) {
213 traincl = 0;
214 tralp = tralist;
215 }
216 if (argv[i][2] == 'E') { /* file */
217 rval = wordfile(tralp,
218 getpath(argv[++i],getrlibpath(),R_OK));
219 if (rval < 0) {
220 sprintf(errmsg,
221 "cannot open trace exclude file \"%s\"",
222 argv[i]);
223 error(SYSTEM, errmsg);
224 }
225 tralp += rval;
226 } else {
227 *tralp++ = argv[++i];
228 *tralp = NULL;
229 }
230 break;
231 default:
232 goto badopt;
233 }
234 break;
235 #ifdef PERSIST
236 case 'P': /* persist file */
237 if (argv[i][2] == 'P') {
238 check(3,"s");
239 persist = PARALLEL;
240 } else {
241 check(2,"s");
242 persist = PERSIST;
243 }
244 persistfile(argv[++i]);
245 break;
246 #endif
247 default:
248 goto badopt;
249 }
250 }
251 if (nproc > 1) {
252 if (persist)
253 error(USER, "multiprocessing incompatible with persist file");
254 if (hresolu > 0 && hresolu < nproc)
255 error(WARNING, "number of cores should not exceed horizontal resolution");
256 if (trace != NULL)
257 error(WARNING, "multiprocessing does not work properly with trace mode");
258 }
259 /* initialize object types */
260 initotypes();
261 /* initialize urand */
262 if (rand_samp) {
263 srandom((long)time(0));
264 initurand(0);
265 } else {
266 srandom(0L);
267 initurand(2048);
268 }
269 /* set up signal handling */
270 sigdie(SIGINT, "Interrupt");
271 #ifdef SIGHUP
272 sigdie(SIGHUP, "Hangup");
273 #endif
274 sigdie(SIGTERM, "Terminate");
275 #ifdef SIGPIPE
276 sigdie(SIGPIPE, "Broken pipe");
277 #endif
278 #ifdef SIGALRM
279 sigdie(SIGALRM, "Alarm clock");
280 #endif
281 #ifdef SIGXCPU
282 sigdie(SIGXCPU, "CPU limit exceeded");
283 sigdie(SIGXFSZ, "File size exceeded");
284 #endif
285 /* open error file */
286 if (errfile != NULL) {
287 if (freopen(errfile, "a", stderr) == NULL)
288 quit(2);
289 fprintf(stderr, "**************\n*** PID %5d: ",
290 getpid());
291 printargs(argc, argv, stderr);
292 putc('\n', stderr);
293 fflush(stderr);
294 }
295 #ifdef NICE
296 nice(NICE); /* lower priority */
297 #endif
298 /* get octree */
299 if (i == argc)
300 octnm = NULL;
301 else if (i == argc-1)
302 octnm = argv[i];
303 else
304 goto badopt;
305 if (octnm == NULL)
306 error(USER, "missing octree argument");
307 /* set up output */
308 #ifdef PERSIST
309 if (persist) {
310 duped1 = dup(fileno(stdout)); /* don't lose our output */
311 openheader();
312 }
313 #endif
314 if (outform != 'a')
315 SET_FILE_BINARY(stdout);
316 readoct(octnm, loadflags, &thescene, NULL);
317 nsceneobjs = nobjects;
318
319 if (loadflags & IO_INFO) { /* print header */
320 printargs(i, argv, stdout);
321 printf("SOFTWARE= %s\n", VersionID);
322 fputnow(stdout);
323 fputformat(formstr(outform), stdout);
324 putchar('\n');
325 }
326
327 marksources(); /* find and mark sources */
328
329 setambient(); /* initialize ambient calculation */
330
331 #ifdef PERSIST
332 if (persist) {
333 fflush(stdout);
334 /* reconnect stdout */
335 dup2(duped1, fileno(stdout));
336 close(duped1);
337 if (persist == PARALLEL) { /* multiprocessing */
338 preload_objs(); /* preload scene */
339 shm_boundary = (char *)malloc(16);
340 strcpy(shm_boundary, "SHM_BOUNDARY");
341 while ((rval=fork()) == 0) { /* keep on forkin' */
342 pflock(1);
343 pfhold();
344 ambsync(); /* load new values */
345 }
346 if (rval < 0)
347 error(SYSTEM, "cannot fork child for persist function");
348 pfdetach(); /* parent will run then exit */
349 }
350 }
351 runagain:
352 if (persist)
353 dupheader(); /* send header to stdout */
354 #endif
355 /* trace rays */
356 rtrace(NULL, nproc);
357 /* flush ambient file */
358 ambsync();
359 #ifdef PERSIST
360 if (persist == PERSIST) { /* first run-through */
361 if ((rval=fork()) == 0) { /* child loops until killed */
362 pflock(1);
363 persist = PCHILD;
364 } else { /* original process exits */
365 if (rval < 0)
366 error(SYSTEM, "cannot fork child for persist function");
367 pfdetach(); /* parent exits */
368 }
369 }
370 if (persist == PCHILD) { /* wait for a signal then go again */
371 pfhold();
372 raynum = nrays = 0; /* reinitialize */
373 goto runagain;
374 }
375 #endif
376 quit(0);
377
378 badopt:
379 sprintf(errmsg, "command line error at '%s'", argv[i]);
380 error(USER, errmsg);
381 return 1; /* pro forma return */
382
383 #undef check
384 #undef bool
385 }
386
387
388 void
389 wputs( /* warning output function */
390 char *s
391 )
392 {
393 int lasterrno = errno;
394 eputs(s);
395 errno = lasterrno;
396 }
397
398
399 void
400 eputs( /* put string to stderr */
401 register char *s
402 )
403 {
404 static int midline = 0;
405
406 if (!*s)
407 return;
408 if (!midline++) {
409 fputs(progname, stderr);
410 fputs(": ", stderr);
411 }
412 fputs(s, stderr);
413 if (s[strlen(s)-1] == '\n') {
414 fflush(stderr);
415 midline = 0;
416 }
417 }
418
419
420 static void
421 onsig( /* fatal signal */
422 int signo
423 )
424 {
425 static int gotsig = 0;
426
427 if (gotsig++) /* two signals and we're gone! */
428 _exit(signo);
429
430 #ifdef SIGALRM
431 alarm(15); /* allow 15 seconds to clean up */
432 signal(SIGALRM, SIG_DFL); /* make certain we do die */
433 #endif
434 eputs("signal - ");
435 eputs(sigerr[signo]);
436 eputs("\n");
437 quit(3);
438 }
439
440
441 static void
442 sigdie( /* set fatal signal */
443 int signo,
444 char *msg
445 )
446 {
447 if (signal(signo, onsig) == SIG_IGN)
448 signal(signo, SIG_IGN);
449 sigerr[signo] = msg;
450 }
451
452
453 static void
454 printdefaults(void) /* print default values to stdout */
455 {
456 register char *cp;
457
458 if (imm_irrad)
459 printf("-I+\t\t\t\t# immediate irradiance on\n");
460 printf("-n %-2d\t\t\t\t# number of rendering processes\n", nproc);
461 printf("-x %-9d\t\t\t# x resolution (flush interval)\n", hresolu);
462 printf("-y %-9d\t\t\t# y resolution\n", vresolu);
463 printf(lim_dist ? "-ld+\t\t\t\t# limit distance on\n" :
464 "-ld-\t\t\t\t# limit distance off\n");
465 printf("-h%c\t\t\t\t# %s header\n", loadflags & IO_INFO ? '+' : '-',
466 loadflags & IO_INFO ? "output" : "no");
467 printf("-f%c%c\t\t\t\t# format input/output = %s/%s\n",
468 inform, outform, formstr(inform), formstr(outform));
469 printf("-o%-9s\t\t\t# output", outvals);
470 for (cp = outvals; *cp; cp++)
471 switch (*cp) {
472 case 't': case 'T': printf(" trace"); break;
473 case 'o': printf(" origin"); break;
474 case 'd': printf(" direction"); break;
475 case 'v': printf(" value"); break;
476 case 'V': printf(" contribution"); break;
477 case 'l': printf(" length"); break;
478 case 'L': printf(" first_length"); break;
479 case 'p': printf(" point"); break;
480 case 'n': printf(" normal"); break;
481 case 'N': printf(" unperturbed_normal"); break;
482 case 's': printf(" surface"); break;
483 case 'w': printf(" weight"); break;
484 case 'W': printf(" coefficient"); break;
485 case 'm': printf(" modifier"); break;
486 case 'M': printf(" material"); break;
487 case '-': printf(" stroke"); break;
488 }
489 putchar('\n');
490 printf(erract[WARNING].pf != NULL ?
491 "-w+\t\t\t\t# warning messages on\n" :
492 "-w-\t\t\t\t# warning messages off\n");
493 print_rdefaults();
494 }
